[GRASS-SVN] r42023 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sat Apr 24 18:35:15 EDT 2010
Author: martinl
Date: 2010-04-24 18:35:15 -0400 (Sat, 24 Apr 2010)
New Revision: 42023
grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/globalvar.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
wxGUI: gselect.FormatSelect class added
(merge from r42022 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py 2010-04-24 22:27:37 UTC (rev 42022)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py 2010-04-24 22:35:15 UTC (rev 42023)
@@ -1018,119 +1018,28 @@
# format widget
self.formatText = wx.StaticText(self.panel, id=wx.ID_ANY, label=_("Format:"))
- self.format = wx.Choice(parent = self.panel, id = wx.ID_ANY, size=(300, -1))
+ self.format = gselect.FormatSelect(parent = self.panel,
+ ftype = self.importType)
self.format.Bind(wx.EVT_CHOICE, self.OnSetFormat)
- if self.importType == 'gdal':
- ret = gcmd.RunCommand('r.in.gdal',
- quiet = True, read = True,
- flags = 'f')
- else: # ogr
- ret = gcmd.RunCommand('v.in.ogr',
- flags = 'f')
self.input = { 'file' : [_("File:"),
inputFile,
- list()],
+ globalvar.formats[self.importType]['file']],
'dir' : [_("Directory:"),
inputDir,
- list()],
'db' : [_("Database:"),
inputDbFile,
- list()],
+ globalvar.formats[self.importType]['database']],
'pro' : [_("Protocol:"),
inputPro,
- list()],
+ globalvar.formats[self.importType]['protocol']],
'db-win' : { 'file' : inputDbFile,
'text' : inputDbText,
'choice' : inputDbChoice },
- self.formatToExt = {
- # raster
- 'GeoTIFF' : 'tif',
- 'Erdas Imagine Images (.img)' : '.img',
- 'Ground-based SAR Applications Testbed File Format (.gff)' : '.gff',
- 'Arc/Info Binary Grid' : 'adf',
- 'Portable Network Graphics' : 'png',
- 'JPEG JFIF' : 'jpg',
- 'Japanese DEM (.mem)' : 'mem',
- 'Graphics Interchange Format (.gif)' : 'gif',
- 'X11 PixMap Format' : 'xpm',
- 'MS Windows Device Independent Bitmap' : 'bmp',
- 'SPOT DIMAP' : '.dim',
- 'RadarSat 2 XML Product' : 'xml',
- 'EarthWatch .TIL' : '.til',
- 'ERMapper .ers Labelled' : '.ers',
- 'ERMapper Compressed Wavelets' : 'ecw',
- 'GRIdded Binary (.grb)' : 'grb',
- 'EUMETSAT Archive native (.nat)' : '.nat',
- 'Idrisi Raster A.1' : 'rst',
- 'Golden Software ASCII Grid (.grd)' : '.grd',
- 'Golden Software Binary Grid (.grd)' : 'grd',
- 'Golden Software 7 Binary Grid (.grd)' : 'grd',
- 'R Object Data Store' : 'r',
- 'USGS DOQ (Old Style)' : 'doq',
- 'USGS DOQ (New Style)' : 'doq',
- 'ENVI .hdr Labelled' : 'hdr',
- 'ESRI .hdr Labelled' : 'hdr',
- 'Generic Binary (.hdr Labelled)' : 'hdr',
- 'PCI .aux Labelled' : 'aux',
- 'EOSAT FAST Format' : 'fst',
- 'VTP .bt (Binary Terrain) 1.3 Format' : 'bt',
- 'FARSITE v.4 Landscape File (.lcp)' : 'lcp',
- 'Swedish Grid RIK (.rik)' : 'rik',
- 'USGS Optional ASCII DEM (and CDED)' : '.dem',
- 'Northwood Numeric Grid Format .grd/.tab' : '',
- 'Northwood Classified Grid Format .grc/.tab' : '',
- 'ARC Digitized Raster Graphics' : 'arc',
- 'Magellan topo (.blx)' : 'blx',
- 'SAGA GIS Binary Grid (.sdat)' : 'sdat',
- # vector
- 'ESRI Shapefile' : 'shp',
- 'UK .NTF' : 'ntf',
- 'SDTS' : 'ddf',
- 'DGN' : 'dgn',
- 'VRT' : 'vrt',
- 'REC' : 'rec',
- 'BNA' : 'bna',
- 'CSV' : 'csv',
- 'GML' : 'gml',
- 'GPX' : 'gpx',
- 'KML' : 'kml',
- 'GMT' : 'gmt',
- 'PGeo' : 'mdb',
- 'XPlane' : 'dat',
- 'AVCBin' : 'adf',
- 'AVCE00' : 'e00',
- 'DXF' : 'dxf',
- 'Geoconcept' : 'gxt',
- 'GeoRSS' : 'xml',
- 'GPSTrackMaker' : 'gtm',
- 'VFK' : 'vfk' }
- if ret:
- for line in ret.splitlines():
- format = line.strip().rsplit(':', -1)[1].strip()
- if format in ('Memory', 'Virtual Raster', 'In Memory Raster'):
- continue
- if format in ('PostgreSQL', 'SQLite',
- 'ODBC', 'ESRI Personal GeoDatabase',
- 'Rasterlite',
- 'PostGIS WKT Raster driver'):
- self.input['db'][2].append(format)
- elif format in ('GeoJSON',
- 'OGC Web Coverage Service',
- 'OGC Web Map Service',
- 'HTTP Fetching Wrapper'):
- self.input['pro'][2].append(format)
- else:
- self.input['file'][2].append(format)
- self.input['dir'][2].append(format)
self.inputType = 'file'
self.format.SetItems(self.input[self.inputType][2])
@@ -1280,7 +1189,7 @@
format = self.input[self.inputType][2][0]
try:
- ext = self.formatToExt[format]
+ ext = self.format.GetExtension(format)
if not ext:
raise KeyError
format += ' (*.%s)|*.%s' % (ext, ext)
@@ -1337,7 +1246,7 @@
else:
dsn = self.input[self.inputType][1].GetValue()
try:
- ext = '.' + self.formatToExt[self.format.GetStringSelection()]
+ ext = '.' + self.format.GetExtension(self.format.GetStringSelection())
except KeyError:
ext = ''
@@ -1441,7 +1350,7 @@
if self.inputType == 'file':
try:
if not ext:
raise KeyError
@@ -1523,7 +1432,7 @@
data.append((layerId, baseName, grassName))
elif self.inputType == 'dir':
try:
- ext = self.formatToExt[self.format.GetStringSelection()]
+ ext = self.format.GetExtension(self.format.GetStringSelection())
except KeyError:
ext = ''
for file in glob.glob(os.path.join(dsn, "*.%s") % ext):
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/globalvar.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/globalvar.py 2010-04-24 22:27:37 UTC (rev 42022)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/globalvar.py 2010-04-24 22:35:15 UTC (rev 42023)
@@ -6,11 +6,10 @@
This module provide the space for global variables
used in the code.
-(C) 2007-2009 by the GRASS Development Team
+(C) 2007-2010 by the GRASS Development Team
-This program is free software under the GNU General Public
-License (>=v2). Read the file COPYING that comes with GRASS
-for details.
+This program is free software under the GNU General Public License
+(>=v2). Read the file COPYING that comes with GRASS for details.
@author Martin Landa <landa.martin gmail.com>
@@ -23,6 +22,8 @@
import gettext
gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode=True)
+import grass.script as grass
# wxversion.select() called once at the beginning
check = True
@@ -156,3 +157,53 @@
have_mlist = True
else:
have_mlist = False
+def _getGDALFormats():
+ """!Get dictionary of avaialble GDAL drivers"""
+ ret = grass.read_command('r.in.gdal',
+ quiet = True,
+ flags = 'f')
+ return _parseFormats(ret)
+def _getOGRFormats():
+ """!Get dictionary of avaialble OGR drivers"""
+ ret = grass.read_command('v.in.ogr',
+ quiet = True,
+ flags = 'f')
+def _parseFormats(output):
+ """!Parse r.in.gdal/v.in.ogr -f output"""
+ formats = { 'file' : list(),
+ 'database' : list(),
+ 'protocol' : list()
+ if not output:
+ return formats
+ for line in output.splitlines():
+ format = line.strip().rsplit(':', -1)[1].strip()
+ if format in ('Memory', 'Virtual Raster', 'In Memory Raster'):
+ continue
+ if format in ('PostgreSQL', 'SQLite',
+ 'ODBC', 'ESRI Personal GeoDatabase',
+ 'Rasterlite',
+ 'PostGIS WKT Raster driver'):
+ formats['database'].append(format)
+ elif format in ('GeoJSON',
+ 'OGC Web Coverage Service',
+ 'OGC Web Map Service',
+ 'HTTP Fetching Wrapper'):
+ formats['protocol'].append(format)
+ else:
+ formats['file'].append(format)
+ return formats
+formats = {
+ 'gdal' : _getGDALFormats(),
+ 'ogr' : _getOGRFormats()
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py 2010-04-24 22:27:37 UTC (rev 42022)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py 2010-04-24 22:35:15 UTC (rev 42023)
@@ -15,6 +15,7 @@
- LocationSelect
- MapsetSelect
- SubGroupSelect
+ - FormatSelect
(C) 2007-2010 by the GRASS Development Team This program is free
software under the GNU General Public License (>=v2). Read the file
@@ -762,3 +763,93 @@
except OSError:
self.SetItems([])
self.SetValue('')
+class FormatSelect(wx.Choice):
+ def __init__(self, parent, ftype, sourceType = None, id = wx.ID_ANY, size = globalvar.DIALOG_COMBOBOX_SIZE,
+ **kwargs):
+ """!Widget for selecting external (GDAL/OGR) format
+ @param parent parent window
+ @param sourceType source type ('file', 'directory', 'database', 'protocol') or None
+ @param dataType data type ('gdal' or 'ogr')
+ super(FormatSelect, self).__init__(parent, id, size = size,
+ style = wx.CB_READONLY, **kwargs)
+ self.SetName("FormatSelect")
+ formats = list()
+ for f in globalvar.formats[ftype].values():
+ formats += f
+ self.SetItems(formats)
+ def GetExtension(self, name):
+ """!Get file extension by format name"""
+ formatToExt = {
+ # raster
+ 'GeoTIFF' : 'tif',
+ 'Erdas Imagine Images (.img)' : '.img',
+ 'Ground-based SAR Applications Testbed File Format (.gff)' : '.gff',
+ 'Arc/Info Binary Grid' : 'adf',
+ 'Portable Network Graphics' : 'png',
+ 'JPEG JFIF' : 'jpg',
+ 'Japanese DEM (.mem)' : 'mem',
+ 'Graphics Interchange Format (.gif)' : 'gif',
+ 'X11 PixMap Format' : 'xpm',
+ 'MS Windows Device Independent Bitmap' : 'bmp',
+ 'SPOT DIMAP' : '.dim',
+ 'RadarSat 2 XML Product' : 'xml',
+ 'EarthWatch .TIL' : '.til',
+ 'ERMapper .ers Labelled' : '.ers',
+ 'ERMapper Compressed Wavelets' : 'ecw',
+ 'GRIdded Binary (.grb)' : 'grb',
+ 'EUMETSAT Archive native (.nat)' : '.nat',
+ 'Idrisi Raster A.1' : 'rst',
+ 'Golden Software ASCII Grid (.grd)' : '.grd',
+ 'Golden Software Binary Grid (.grd)' : 'grd',
+ 'Golden Software 7 Binary Grid (.grd)' : 'grd',
+ 'R Object Data Store' : 'r',
+ 'USGS DOQ (Old Style)' : 'doq',
+ 'USGS DOQ (New Style)' : 'doq',
+ 'ENVI .hdr Labelled' : 'hdr',
+ 'ESRI .hdr Labelled' : 'hdr',
+ 'Generic Binary (.hdr Labelled)' : 'hdr',
+ 'PCI .aux Labelled' : 'aux',
+ 'EOSAT FAST Format' : 'fst',
+ 'VTP .bt (Binary Terrain) 1.3 Format' : 'bt',
+ 'FARSITE v.4 Landscape File (.lcp)' : 'lcp',
+ 'Swedish Grid RIK (.rik)' : 'rik',
+ 'USGS Optional ASCII DEM (and CDED)' : '.dem',
+ 'Northwood Numeric Grid Format .grd/.tab' : '',
+ 'Northwood Classified Grid Format .grc/.tab' : '',
+ 'ARC Digitized Raster Graphics' : 'arc',
+ 'Magellan topo (.blx)' : 'blx',
+ 'SAGA GIS Binary Grid (.sdat)' : 'sdat',
+ # vector
+ 'ESRI Shapefile' : 'shp',
+ 'UK .NTF' : 'ntf',
+ 'SDTS' : 'ddf',
+ 'DGN' : 'dgn',
+ 'VRT' : 'vrt',
+ 'REC' : 'rec',
+ 'BNA' : 'bna',
+ 'CSV' : 'csv',
+ 'GML' : 'gml',
+ 'GPX' : 'gpx',
+ 'KML' : 'kml',
+ 'GMT' : 'gmt',
+ 'PGeo' : 'mdb',
+ 'XPlane' : 'dat',
+ 'AVCBin' : 'adf',
+ 'AVCE00' : 'e00',
+ 'DXF' : 'dxf',
+ 'Geoconcept' : 'gxt',
+ 'GeoRSS' : 'xml',
+ 'GPSTrackMaker' : 'gtm',
+ 'VFK' : 'vfk'
+ try:
+ return formatToExt[name]
+ except KeyError:
+ return ''
