[GRASS-SVN] r42029 - grass-addons/gui/wxpython/data_catalog
svn_grass at osgeo.org
Sun Apr 25 06:45:30 EDT 2010
Author: rashadkm
Date: 2010-04-25 06:45:29 -0400 (Sun, 25 Apr 2010)
New Revision: 42029
grass-addons/gui/wxpython/data_catalog/LayerTree.py
grass-addons/gui/wxpython/data_catalog/catalog.py
grass-addons/gui/wxpython/data_catalog/mapdisplay.py
grass-addons/gui/wxpython/data_catalog/toolbars.py
fixed for zoom and pan
Modified: grass-addons/gui/wxpython/data_catalog/LayerTree.py
--- grass-addons/gui/wxpython/data_catalog/LayerTree.py 2010-04-25 07:47:36 UTC (rev 42028)
+++ grass-addons/gui/wxpython/data_catalog/LayerTree.py 2010-04-25 10:45:29 UTC (rev 42029)
@@ -66,8 +66,11 @@
self.gisdbase = gisdbase
+ self.layer_selected = None
self.Map = None
+ self.root = None
#if self.Map is not None:
# print self.Map.width
@@ -97,6 +100,7 @@
for panel in child:
if panel.GetName() == "pg_panel":
self.mapdisplay = panel
+ break
self.MapWindow = self.mapdisplay.MapWindow2D
self.Bind(CT.EVT_TREE_ITEM_CHECKED, self.OnLayerChecked)
@@ -128,6 +132,8 @@
frame = notebook.GetParent()
if not self.ItemHasChildren(item):
self.mapname = self.GetItemText(item) + "@" + frame.cmbMapset.GetValue()
#for f in frames:
@@ -137,7 +143,9 @@
if pText == "Raster Map" :
if checked == True:
self.cmd= ['d.rast', str("map=" + self.mapname)]
- self.MapWindow.Map.AddLayer(type='raster', name=self.mapname, command=self.cmd)
+ maplayer = self.MapWindow.Map.AddLayer(type='raster', name=self.mapname, command=self.cmd)
+ self.layer_selected = maplayer
+ self.type = 'raster'
else:
layers = self.MapWindow.Map.GetListOfLayers( l_type='raster', l_name=self.mapname)
for layer in layers:
@@ -150,7 +158,9 @@
if pText == "Vector Map" :
if checked == True:
self.cmd= ['d.vect', str("map=" + self.mapname)]
- self.MapWindow.Map.AddLayer(type='vector', name=self.mapname, command=self.cmd)
+ maplayer = self.MapWindow.Map.AddLayer(type='vector', name=self.mapname, command=self.cmd)
+ self.type = 'vector'
else:
layers = self.MapWindow.Map.GetListOfLayers( l_type='vector', l_name=self.mapname)
@@ -165,17 +175,18 @@
def AddTreeNodes(self,location,mapset):
Adds tree nodes. raster,vector and dbf files are identified using
their directory structure.
self.DeleteAllItems()
- root = self.AddRoot("Map Layers")
- self.SetPyData(root, (None,None))
- node_raster = self.AppendItem(root, "Raster Map")
- node_vector = self.AppendItem(root, "Vector Map")
- node_dbf = self.AppendItem(root, "DBF")
+ self.root = self.AddRoot("Map Layers")
+ self.SetPyData(self.root, (None,None))
+ node_raster = self.AppendItem(self.root, "Raster Map")
+ node_vector = self.AppendItem(self.root, "Vector Map")
+ node_dbf = self.AppendItem(self.root, "DBF")
treeNodes = [node_raster,node_vector,node_dbf]
glocs = glob.glob(os.path.join(self.gisdbase,location, mapset,"*"))
Modified: grass-addons/gui/wxpython/data_catalog/catalog.py
--- grass-addons/gui/wxpython/data_catalog/catalog.py 2010-04-25 07:47:36 UTC (rev 42028)
+++ grass-addons/gui/wxpython/data_catalog/catalog.py 2010-04-25 10:45:29 UTC (rev 42029)
@@ -505,12 +505,17 @@
self.notebook.SetTabAreaColour(globalvar.FNPageColor)
# self._lmgr=wx.aui.AuiManager(self)
- self.pg_panel = MapFrame(parent=self.notebook, id=wx.ID_ANY, Map=render.Map(), size=globalvar.MAP_WINDOW_SIZE,frame=self,flag=True,gismgr=self)
+ self.pg_panel = MapFrame(parent=self.notebook, id=wx.ID_ANY, Map=render.Map(), size=globalvar.MAP_WINDOW_SIZE,flag=True,frame=self,gismgr=self)
self.disp_idx = self.disp_idx + 1
self.notebook.AddPage(self.pg_panel, text="Display "+ str(self.disp_idx), select = True)
+ self.goutput = goutput.GMConsole(self, pageid=1)
+ self.outpage = self.notebook.AddPage(self.goutput, text=_("Command console"))
+ self.notebook.SetSelection(0)
# self.notebook.Bind(FN.EVT_FLATNOTEBOOK_PAGE_CHANGED, self.OnPageChanged)
# self.notebook.Bind(FN.EVT_FLATNOTEBOOK_PAGE_CLOSING, self.OnPageClosed)
@@ -1441,7 +1446,7 @@
# available only for vector map layers
try:
- maptype = self.current.maptree.GetPyData(layer)[0]['maplayer'].type
+ maptype = self.current.maptree.type
except:
maptype = None
@@ -1453,15 +1458,15 @@
style=wx.OK | wx.ICON_INFORMATION | wx.CENTRE)
return
- if not self.current.maptree.GetPyData(layer)[0]:
- return
- dcmd = self.current.maptree.GetPyData(layer)[0]['cmd']
+ dcmd = self.current.maptree.cmd
if not dcmd:
return
busy = wx.BusyInfo(message=_("Please wait, loading attribute data..."),
parent=self)
wx.Yield()
dbmanager = dbm.AttributeManager(parent=self, id=wx.ID_ANY,
size=wx.Size(500, 300),
@@ -1508,9 +1513,10 @@
self.page = MapFrame(parent=self.notebook, id=wx.ID_ANY, Map=render.Map(), size=globalvar.MAP_WINDOW_SIZE,frame=self)
- self.notebook.AddPage(self.page, text="Display "+ str(self.disp_idx), select = True)
+ self.notebook.InsertPage(self.disp_idx,self.page, text="Display "+ str(self.disp_idx), select = True)
self.current = self.notebook.GetCurrentPage()
@@ -1701,9 +1707,15 @@
def AddRaster(self, event):
if not self.current:
self.NewDisplay()
+ #cmd = ['d.rast']
+ #menuform.GUI().ParseCommand(cmd,parentframe=self)
- self.current.maptree.AddLayer('raster')
+ #self.current.maptree.AddLayer('raster')
+ dlg = AddLayer(parent=self, title = "Add Raster")
+ dlg.ShowModal()
def AddRaster3d(self, event):
self.NewDisplay()
@@ -1911,7 +1923,7 @@
index = 0
while index < count:
self.current = self.notebook.GetPage(index)
- self.current.Map.Clean()
+ #self.current.Map.Clean()
index = index+1
self.notebook.DeleteAllPages()
@@ -1969,7 +1981,7 @@
def OnRunScript():
- print "for grass"
+ print "for grass7"
def OnQuit():
print "for grass7"
@@ -2018,42 +2030,20 @@
self.Bind(wx.EVT_COMBOBOX,self.OnMapsetChange,self.cmbMapset)
self.Bind(wx.EVT_COMBOBOX,self.OnLocationChange,self.cmbLocation)
- #Event bindings for tree -(display,popup,label edit.)
- #self.Bind(wx.EVT_TREE_ITEM_ACTIVATED, self.ltree.OnDisplay,self.ltree)
- #self.Bind(wx.EVT_TREE_ITEM_RIGHT_CLICK,self.ltree.OnTreePopUp,self.ltree)
- #self.Bind(wx.EVT_TREE_END_LABEL_EDIT, self.ltree.OnEndRename,self.ltree)
- # self.Bind(wx.EVT_TREE_BEGIN_LABEL_EDIT, self.ltree.OnBeginRename,self.ltree)
- #Event bindings for tree menu
- #self.Bind(wx.EVT_MENU,self.ltree.OnCopy,id=self.ltree.ID_COPY)
- #self.Bind(wx.EVT_MENU,self.ltree.OnRename,id=self.ltree.ID_REN)
- #self.Bind(wx.EVT_MENU,self.ltree.OnDelete,id=self.ltree.ID_DEL)
- #self.Bind(wx.EVT_MENU,self.ltree.OnOssim,id=self.ltree.ID_OSSIM)
self.Bind(wx.EVT_CLOSE, self.OnCloseWindow)
#Event bindings for v/r.info checkbox
#self.Bind(wx.EVT_CHECKBOX, self.OnToggleInfo,self.chkInfo)
- #self.Bind(wx.EVT_CHECKBOX, self.OnToggleExpand,self.treeExpand)
- def OnToggleExpand(self,event):
- if self.treeExpand.IsChecked():
- if not self.gmconsole:
- self.gmconsole = GLog(parent=self)
- # self.gmconsole.show()
-# sys.exit(0)
- else:
- self.gmconsole.Raise()
- else:
- self.gmconsole.Destroy()
def doLayout(self):
#combo panel sizers
self.cmbSizer.Add(self.cmbLocation)
self.cmbSizer.Add(self.cmbMapset)
- self.cmbSizer.Add(self.treeExpand)
+ #self.cmbSizer.Add(self.treeExpand)
#splitter window sizers
self.mSizer.Add(self.cmbPanel,flag=wx.EXPAND)
#self.mSizer.Add(self.win, 1, wx.EXPAND)
@@ -2124,7 +2114,7 @@
#End of DataCatalog class
class CatalogApp(wx.App):
def OnInit(self):
Modified: grass-addons/gui/wxpython/data_catalog/mapdisplay.py
--- grass-addons/gui/wxpython/data_catalog/mapdisplay.py 2010-04-25 07:47:36 UTC (rev 42028)
+++ grass-addons/gui/wxpython/data_catalog/mapdisplay.py 2010-04-25 10:45:29 UTC (rev 42029)
@@ -58,6 +58,12 @@
grassPath = os.path.join(globalvar.ETCDIR, "python")
sys.path.append(grassPath)
+import icons
+gmpath = icons.__path__[0]
+sys.path.append(gmpath)
+from icon import Icons
import render
import toolbars
import menuform
@@ -66,11 +72,12 @@
import gcmd
import dbm
import histogram
-import profile
+import gui_modules.profile as profile
import globalvar
import utils
import gdialogs
import goutput
+import gui_modules.goutput as goutput
from grass.script import core as grass
from debug import Debug
from preferences import globalSettings as UserSettings
@@ -263,14 +270,13 @@
mapframe= self.GetParent()
notebook=mapframe.GetParent()
self.gframe=notebook.GetParent()
# Flags
self.resize = False # indicates whether or not a resize event has taken place
self.dragimg = None # initialize variable for map panning
- self.flag = False
# Variable for drawing on DC
@@ -314,7 +320,7 @@
self.zoomhistory = [] # list of past zoom extents
self.currzoom = 0 # current set of extents in zoom history being used
self.zoomtype = 1 # 1 zoom in, 0 no zoom, -1 zoom out
self.hitradius = 10 # distance for selecting map decorations
self.dialogOffset = 5 # offset for dialog (e.g. DisplayAttributesDialog)
@@ -324,14 +330,8 @@
# platforms at initialization, but little harm done.
### self.OnSize(None)
- # create PseudoDC used for background map, map decorations like scales and legends
- self.pdc = wx.PseudoDC()
- # used for digitization tool
- self.pdcVector = None
- # decorations (region box, etc.)
- self.pdcDec = wx.PseudoDC()
- # pseudoDC for temporal objects (select box, measurement tool, etc.)
- self.pdcTmp = wx.PseudoDC()
+ self.DefinePseudoDC()
# redraw all pdc's, pdcTmp layer is redrawn always (speed issue)
self.redrawAll = True
@@ -339,16 +339,61 @@
self._buffer = ''
self.Bind(wx.EVT_ERASE_BACKGROUND, lambda x:None)
+ self.Bind(wx.EVT_KEY_DOWN , self.OnKeyDown)
# vars for handling mouse clicks
self.dragid = -1
self.lastpos = (0, 0)
+ def DefinePseudoDC(self, vdigit = False):
+ """!Define PseudoDC class to use
+ @vdigit True to use PseudoDC from vdigit
+ # create PseudoDC used for background map, map decorations like scales and legends
+ self.pdc = self.PseudoDC(vdigit)
+ # used for digitization tool
+ self.pdcVector = None
+ # decorations (region box, etc.)
+ self.pdcDec = self.PseudoDC(vdigit)
+ # pseudoDC for temporal objects (select box, measurement tool, etc.)
+ self.pdcTmp = self.PseudoDC(vdigit)
+ def PseudoDC(self, vdigit = False):
+ """!Create PseudoDC instance"""
+ if vdigit:
+ PseudoDC = VDigitPseudoDC
+ else:
+ PseudoDC = wx.PseudoDC
+ return PseudoDC()
+ def CheckPseudoDC(self):
+ """!Try to draw background
+ @return True on success
+ @return False on failure
+ try:
+ self.pdc.BeginDrawing()
+ self.pdc.SetBackground(wx.Brush(self.GetBackgroundColour()))
+ except StandardError, e:
+ traceback.print_exc(file = sys.stderr)
+ return False
+ return True
def Draw(self, pdc, img=None, drawid=None, pdctype='image', coords=[0, 0, 0, 0]):
Draws map and overlay decorations
if drawid == None:
if pdctype == 'image' and img:
drawid = self.imagedict[img]
@@ -369,6 +414,7 @@
bg = wx.Brush(self.GetBackgroundColour())
pdc.SetBackground(bg)
### pdc.Clear()
Debug.msg (5, "BufferedWindow.Draw(): id=%s, pdctype=%s, coord=%s" % \
@@ -393,7 +439,7 @@
bitmap = wx.BitmapFromImage(img)
w,h = bitmap.GetSize()
pdc.DrawBitmap(bitmap, coords[0], coords[1], True) # draw the composite map
- pdc.SetIdBounds(drawid, (coords[0],coords[1], w, h))
+ pdc.SetIdBounds(drawid, wx.Rect(coords[0],coords[1], w, h))
elif pdctype == 'box': # draw a box on top of the map
if self.pen:
@@ -405,24 +451,30 @@
y1 = min(coords[1],coords[3])
rwidth = x2-x1
rheight = y2-y1
- rect = wx.Rect(x1,y1,rwidth,rheight)
+ rect = wx.Rect(x1, y1, rwidth, rheight)
pdc.DrawRectangleRect(rect)
- pdc.SetIdBounds(drawid,rect)
- # self.ovlcoords[drawid] = coords
+ pdc.SetIdBounds(drawid, rect)
elif pdctype == 'line': # draw a line on top of the map
if self.pen:
pdc.SetBrush(wx.Brush(wx.CYAN, wx.TRANSPARENT))
pdc.SetPen(self.pen)
- pdc.DrawLine(coords[0], coords[1], coords[2], coords[3])
- pdc.SetIdBounds(drawid,(coords[0], coords[1], coords[2], coords[3]))
+ pdc.DrawLinePoint(wx.Point(coords[0], coords[1]),wx.Point(coords[2], coords[3]))
+ pdc.SetIdBounds(drawid, wx.Rect(coords[0], coords[1], coords[2], coords[3]))
elif pdctype == 'polyline': # draw a polyline on top of the map
if self.polypen:
pdc.SetPen(self.polypen)
- pdc.DrawLines(coords)
+ ### pdc.DrawLines(coords)
+ if (len(coords) < 2):
+ return
+ i = 1
+ while i < len(coords):
+ pdc.DrawLinePoint(wx.Point(coords[i-1][0], coords[i-1][1]),
+ wx.Point(coords[i][0], coords[i][1]))
+ i += 1
# get bounding rectangle for polyline
xlist = []
@@ -436,9 +488,9 @@
x2=max(xlist)
y1=min(ylist)
y2=max(ylist)
- pdc.SetIdBounds(drawid,(x1,y1,x2,y2))
+ pdc.SetIdBounds(drawid, wx.Rect(x1,y1,x2,y2))
# self.ovlcoords[drawid] = [x1,y1,x2,y2]
elif pdctype == 'point': # draw point
if self.pen:
@@ -447,7 +499,7 @@
coords[1] - 5,
coords[0] + 5,
coords[1] + 5)
- pdc.SetIdBounds(drawid, coordsBound)
+ pdc.SetIdBounds(drawid, wx.Rect(coordsBound))
elif pdctype == 'text': # draw text on top of map
@@ -465,7 +517,7 @@
pdc.DrawText(img['text'], coords[0], coords[1])
else:
pdc.DrawRotatedText(img['text'], coords[0], coords[1], rotation)
- pdc.SetIdBounds(drawid, (coords[0], coords[1], w, h))
+ pdc.SetIdBounds(drawid, wx.Rect(coords[0], coords[1], w, h))
pdc.EndDrawing()
@@ -474,7 +526,7 @@
return drawid
def TextBounds(self, textinfo):
Return text boundary data
@param textinfo text metadata (text, font, color, rotation)
@@ -508,8 +560,28 @@
return coords, boxw, boxh
+ def OnKeyDown(self, event):
+ """!Key pressed"""
+ shift = event.ShiftDown()
+ kc = event.GetKeyCode()
+ vdigitToolbar = self.parent.toolbars['vdigit']
+ ### vdigit
+ if vdigitToolbar:
+ event = None
+ if not shift:
+ if kc == ord('P'):
+ event = wx.CommandEvent(winid = vdigitToolbar.addPoint)
+ tool = vdigitToolbar.OnAddPoint
+ elif kc == ord('L'):
+ event = wx.CommandEvent(winid = vdigitToolbar.addLine)
+ tool = vdigitToolbar.OnAddLine
+ if event:
+ vdigitToolbar.OnTool(event)
+ tool(event)
def OnPaint(self, event):
Draw PseudoDC's to buffered paint DC
self.pdc for background and decorations
@@ -519,7 +591,7 @@
If self.redrawAll is False on self.pdcTmp content is re-drawn
Debug.msg(4, "BufferedWindow.OnPaint(): redrawAll=%s" % self.redrawAll)
dc = wx.BufferedPaintDC(self, self.buffer)
### dc.SetBackground(wx.Brush("White"))
@@ -571,8 +643,8 @@
# self.bufferLast = wx.BitmapFromImage(self.buffer.ConvertToImage())
self.bufferLast = dc.GetAsBitmap(wx.Rect(0, 0, self.Map.width, self.Map.height))
- pdcLast = wx.PseudoDC()
- pdcLast.DrawBitmap(bmp=self.bufferLast, x=0, y=0)
+ pdcLast = self.PseudoDC(vdigit = False)
+ pdcLast.DrawBitmap(self.bufferLast, 0, 0, False)
pdcLast.DrawToDC(dc)
# draw decorations (e.g. region box)
@@ -591,7 +663,7 @@
self.redrawAll = False
def OnSize(self, event):
Scale map image so that it is
the same size as the Window
@@ -610,7 +682,7 @@
# get the image to be rendered
self.img = self.GetImage()
# update map display
if self.img and self.Map.width + self.Map.height > 0: # scale image during resize
self.img = self.img.Scale(self.Map.width, self.Map.height)
@@ -627,7 +699,7 @@
self.parent.StatusbarUpdate()
def OnIdle(self, event):
Only re-render a composite map image from GRASS during
idle time instead of multiple times during resizing.
@@ -637,7 +709,7 @@
event.Skip()
def SaveToFile(self, FileName, FileType):
This draws the psuedo DC to a buffer that
can be saved to a file.
@@ -648,7 +720,7 @@
self.buffer.SaveFile(FileName, FileType)
def GetOverlay(self):
Converts rendered overlay files to wx.Image
Updates self.imagedict
@@ -666,7 +738,7 @@
return imgs
def GetImage(self):
Converts redered map files to wx.Image
Updates self.imagedict (id=99)
@@ -685,185 +757,181 @@
return img
def UpdateMap(self, render=True, renderVector=True):
Updates the canvas anytime there is a change to the
underlaying images or to the geometry of the canvas.
@param render re-render map composition
@param renderVector re-render vector map layer enabled for editing (used for digitizer)
- if self.flag == True:
- self.flag = False
- start = time.clock()
+ start = time.clock()
+ self.resize = False
+ # if len(self.Map.GetListOfLayers()) == 0:
+ # return False
+ if self.img is None:
+ render = True
- self.resize = False
- if len(self.Map.GetListOfLayers()) == 0:
- return False
- if self.img is None:
- render = True
- # initialize process bar (only on 'render')
- if render is True or renderVector is True:
- self.parent.onRenderGauge.Show()
- if self.parent.onRenderGauge.GetRange() > 0:
- self.parent.onRenderGauge.SetValue(1)
- # render background image if needed
- # update layer dictionary if there has been a change in layers
- if self.tree and self.tree.reorder == True:
- self.tree.ReorderLayers()
- # reset flag for auto-rendering
- if self.tree:
- self.tree.rerender = False
- if render:
- # update display size
- self.Map.ChangeMapSize(self.GetClientSize())
- if self.parent.compResolution.IsChecked():
- # use computation region resolution for rendering
- windres = True
- else:
- windres = False
- self.mapfile = self.Map.Render(force=True, mapWindow=self.parent,
- windres=windres)
+ # initialize process bar (only on 'render')
+ if render is True or renderVector is True:
+ self.parent.statusbarWin['progress'].Show()
+ if self.parent.statusbarWin['progress'].GetRange() > 0:
+ self.parent.statusbarWin['progress'].SetValue(1)
+ # render background image if needed
+ # update layer dictionary if there has been a change in layers
+ if self.tree and self.tree.reorder == True:
+ self.tree.ReorderLayers()
+ # reset flag for auto-rendering
+ if self.tree:
+ self.tree.rerender = False
+ if render:
+ # update display size
+ self.Map.ChangeMapSize(self.GetClientSize())
+ if self.parent.statusbarWin['resolution'].IsChecked():
+ # use computation region resolution for rendering
+ windres = True
else:
- self.mapfile = self.Map.Render(force=False, mapWindow=self.parent)
+ windres = False
+ self.mapfile = self.Map.Render(force=True, mapWindow=self.parent,
+ windres=windres)
+ else:
+ self.mapfile = self.Map.Render(force=False, mapWindow=self.parent)
+ self.img = self.GetImage() # id=99
- self.img = self.GetImage() # id=99
- # clear pseudoDcs
- for pdc in (self.pdc,
- self.pdcDec,
- self.pdcTmp):
- pdc.Clear()
- pdc.RemoveAll()
- # draw background map image to PseudoDC
- if not self.img:
- self.Draw(self.pdc, pdctype='clear')
- else:
- try:
- id = self.imagedict[self.img]['id']
- except:
- return False
+ # clear pseudoDcs
+ for pdc in (self.pdc,
+ self.pdcDec,
+ self.pdcTmp):
+ pdc.Clear()
+ pdc.RemoveAll()
+ # draw background map image to PseudoDC
+ if not self.img:
+ self.Draw(self.pdc, pdctype='clear')
+ else:
+ try:
+ id = self.imagedict[self.img]['id']
+ except:
+ return False
- self.Draw(self.pdc, self.img, drawid=id)
- # render vector map layer
- digitToolbar = self.parent.toolbars['vdigit']
- if renderVector and digitToolbar and \
- digitToolbar.GetLayer():
- # set region
- self.parent.digit.driver.UpdateRegion()
- # re-calculate threshold for digitization tool
- self.parent.digit.driver.GetThreshold()
- # draw map
+ self.Draw(self.pdc, self.img, drawid=id)
+ # render vector map layer
+ digitToolbar = self.parent.toolbars['vdigit']
+ if renderVector and digitToolbar and \
+ digitToolbar.GetLayer():
+ # set region
+ self.parent.digit.driver.UpdateRegion()
+ # re-calculate threshold for digitization tool
+ self.parent.digit.driver.GetThreshold()
+ # draw map
+ if self.pdcVector:
self.pdcVector.Clear()
self.pdcVector.RemoveAll()
- try:
- item = self.tree.FindItemByData('maplayer', digitToolbar.GetLayer())
- except TypeError:
- item = None
- if item and self.tree.IsItemChecked(item):
- self.parent.digit.driver.DrawMap()
- # translate tmp objects (pointer position)
- if digitToolbar.GetAction() == 'moveLine':
- if hasattr(self, "vdigitMove") and \
- self.vdigitMove.has_key('beginDiff'):
- # move line
- for id in self.vdigitMove['id']:
- # print self.pdcTmp.GetIdBounds(id)
- self.pdcTmp.TranslateId(id,
- self.vdigitMove['beginDiff'][0],
- self.vdigitMove['beginDiff'][1])
- del self.vdigitMove['beginDiff']
+ try:
+ item = self.tree.FindItemByData('maplayer', digitToolbar.GetLayer())
+ except TypeError:
+ item = None
- # render overlays
- for img in self.GetOverlay():
- # draw any active and defined overlays
- if self.imagedict[img]['layer'].IsActive():
- id = self.imagedict[img]['id']
- self.Draw(self.pdc, img=img, drawid=id,
- pdctype=self.overlays[id]['pdcType'], coords=self.overlays[id]['coords'])
+ if item and self.tree.IsItemChecked(item):
+ self.parent.digit.driver.DrawMap()
- for id in self.textdict.keys():
- self.Draw(self.pdc, img=self.textdict[id], drawid=id,
- pdctype='text', coords=[10, 10, 10, 10])
+ # translate tmp objects (pointer position)
+ if digitToolbar.GetAction() == 'moveLine':
+ if hasattr(self, "vdigitMove") and \
+ self.vdigitMove.has_key('beginDiff'):
+ # move line
+ for id in self.vdigitMove['id']:
+ self.pdcTmp.TranslateId(id,
+ self.vdigitMove['beginDiff'][0],
+ self.vdigitMove['beginDiff'][1])
+ del self.vdigitMove['beginDiff']
+ # render overlays
+ for img in self.GetOverlay():
+ # draw any active and defined overlays
+ if self.imagedict[img]['layer'].IsActive():
+ id = self.imagedict[img]['id']
+ self.Draw(self.pdc, img=img, drawid=id,
+ pdctype=self.overlays[id]['pdcType'], coords=self.overlays[id]['coords'])
- # optionally draw computational extent box
- self.DrawCompRegionExtent()
- # redraw pdcTmp if needed
- if len(self.polycoords) > 0:
- self.DrawLines(self.pdcTmp)
- if self.gframe.georectifying:
- # -> georectifier (redraw GCPs)
- if self.parent.toolbars['georect']:
- coordtype = 'gcpcoord'
- else:
- coordtype = 'mapcoord'
- self.gframe.georectifying.DrawGCP(coordtype)
- # clear measurement
- if self.mouse["use"] == "measure":
- self.ClearLines(pdc=self.pdcTmp)
- self.polycoords = []
- self.mouse['use'] = 'pointer'
- self.mouse['box'] = 'point'
- self.mouse['end'] = [0, 0]
- self.SetCursor(self.parent.cursors["default"])
- stop = time.clock()
- # hide process bar
- self.parent.onRenderGauge.Hide()
- # update statusbar
- ### self.Map.SetRegion()
- self.parent.StatusbarUpdate()
- if grass.find_file(name = 'MASK', element = 'cell')['name']:
- # mask found
- self.parent.maskInfo.SetLabel(_('MASK'))
+ for id in self.textdict.keys():
+ self.Draw(self.pdc, img=self.textdict[id], drawid=id,
+ pdctype='text', coords=[10, 10, 10, 10])
+ # optionally draw computational extent box
+ self.DrawCompRegionExtent()
+ # redraw pdcTmp if needed
+ if len(self.polycoords) > 0:
+ self.DrawLines(self.pdcTmp)
+ if not self.parent.IsStandalone() and \
+ self.parent.GetLayerManager().georectifying:
+ # -> georectifier (redraw GCPs)
+ if self.parent.toolbars['georect']:
+ coordtype = 'gcpcoord'
else:
- self.parent.maskInfo.SetLabel('')
+ coordtype = 'mapcoord'
+ self.parent.GetLayerManager().georectifying.DrawGCP(coordtype)
- Debug.msg (2, "BufferedWindow.UpdateMap(): render=%s, renderVector=%s -> time=%g" % \
- (render, renderVector, (stop-start)))
+ # clear measurement
+ if self.mouse["use"] == "measure":
+ self.ClearLines(pdc=self.pdcTmp)
+ self.polycoords = []
+ self.mouse['use'] = 'pointer'
+ self.mouse['box'] = 'point'
+ self.mouse['end'] = [0, 0]
+ self.SetCursor(self.parent.cursors["default"])
- return True
+ stop = time.clock()
+ # hide process bar
+ self.parent.statusbarWin['progress'].Hide()
+ # update statusbar
+ ### self.Map.SetRegion()
+ self.parent.StatusbarUpdate()
+ if grass.find_file(name = 'MASK', element = 'cell')['name']:
+ # mask found
+ self.parent.statusbarWin['mask'].SetLabel(_('MASK'))
+ else:
+ self.parent.statusbarWin['mask'].SetLabel('')
+ Debug.msg (2, "BufferedWindow.UpdateMap(): render=%s, renderVector=%s -> time=%g" % \
+ (render, renderVector, (stop-start)))
+ return True
def DrawCompRegionExtent(self):
Draw computational region extent in the display
Display region is drawn as a blue box inside the computational region,
@@ -891,7 +959,7 @@
self.DrawLines(pdc=self.pdcDec, polycoords=self.regionCoords)
def IsInRegion(self, region, refRegion):
Test if 'region' is inside of 'refRegion'
@param region input region
@@ -909,7 +977,7 @@
return False
def EraseMap(self):
Erase the canvas
@@ -921,25 +989,25 @@
self.Draw(self.pdcTmp, pdctype='clear')
def DragMap(self, moveto):
Drag the entire map image for panning.
+ @param moveto dx,dy
dc = wx.BufferedDC(wx.ClientDC(self))
dc.Clear()
self.dragimg = wx.DragImage(self.buffer)
self.dragimg.BeginDrag((0, 0), self)
self.dragimg.GetImageRect(moveto)
self.dragimg.Move(moveto)
self.dragimg.DoDrawImage(dc, moveto)
self.dragimg.EndDrag()
- return True
def DragItem(self, id, event):
Drag an overlay decoration item
if id == 99 or id == '' or id == None: return
@@ -949,6 +1017,9 @@
dy = event.GetY() - y
r = self.pdc.GetIdBounds(id)
+ ### FIXME in vdigit/pseudodc.i
+ if type(r) is list:
+ r = wx.Rect(r[0], r[1], r[2], r[3])
if id > 100: # text dragging
rtop = (r[0],r[1]-r[3],r[2],r[3])
r = r.Union(rtop)
@@ -957,6 +1028,8 @@
self.pdc.TranslateId(id, dx, dy)
r2 = self.pdc.GetIdBounds(id)
+ if type(r2) is list:
+ r2 = wx.Rect(r[0], r[1], r[2], r[3])
if id > 100: # text
self.textdict[id]['coords'] = r2
r = r.Union(r2)
@@ -965,13 +1038,13 @@
self.lastpos = (event.GetX(), event.GetY())
def MouseDraw(self, pdc=None, begin=None, end=None):
Mouse box or line from 'begin' to 'end'
If not given from self.mouse['begin'] to self.mouse['end'].
- self.redrawAll = False
+# self.redrawAll = False
if not pdc:
return
@@ -990,8 +1063,13 @@
mousecoords = [begin[0], begin[1],
end[0], end[1]]
r = pdc.GetIdBounds(boxid)
- r.Inflate(4,4)
- pdc.ClearId(boxid)
+ r.Inflate(4, 4)
+ try:
+ pdc.ClearId(boxid)
+ except:
+ pass
self.RefreshRect(r, False)
pdc.SetId(boxid)
self.Draw(pdc, drawid=boxid, pdctype='box', coords=mousecoords)
@@ -1011,11 +1089,10 @@
pass
pdc.SetId(self.lineid)
self.Draw(pdc, drawid=self.lineid, pdctype='line', coords=mousecoords)
def DrawLines(self, pdc=None, polycoords=None):
Draw polyline in PseudoDC
Set self.pline to wx.NEW_ID + 1
@@ -1048,7 +1125,7 @@
def DrawCross(self, pdc, coords, size, rotation=0,
text=None, textAlign='lr', textOffset=(5, 5)):
- """Draw cross in PseudoDC
+ """!Draw cross in PseudoDC
@todo implement rotation
@@ -1086,7 +1163,7 @@
return self.lineid
def MouseActions(self, event):
Mouse motion and button click notifier
if not self.processMouse:
@@ -1119,6 +1196,10 @@
elif event.MiddleDown():
self.OnMiddleDown(event)
+ # middle mouse button relesed
+ elif event.MiddleUp():
+ self.OnMiddleUp(event)
# right mouse button pressed
elif event.RightDown():
self.OnRightDown(event)
@@ -1129,11 +1210,11 @@
elif event.Moving():
self.OnMouseMoving(event)
-# event.Skip()
+ # event.Skip()
def OnMouseWheel(self, event):
Mouse wheel moved
self.processMouse = False
@@ -1145,7 +1226,7 @@
current[1] - self.Map.height / 4)
end = (current[0] + self.Map.width / 4,
current[1] + self.Map.height / 4)
if wheel > 0:
zoomtype = 1
else:
@@ -1167,7 +1248,7 @@
# event.Skip()
def OnDragging(self, event):
Mouse dragging with left button down
Debug.msg (5, "BufferedWindow.MouseAction(): Dragging")
@@ -1175,19 +1256,20 @@
previous = self.mouse['begin']
move = (current[0] - previous[0],
current[1] - previous[1])
# dragging or drawing box with left button
- if self.mouse['use'] == 'pan':
+ if self.mouse['use'] == 'pan' or \
+ event.MiddleIsDown():
self.DragMap(move)
# dragging decoration overlay item
elif (self.mouse['use'] == 'pointer' and
not digitToolbar and
self.dragid != None):
self.DragItem(self.dragid, event)
# dragging anything else - rubber band box or line
else:
@@ -1200,18 +1282,336 @@
digitClass.driver.GetSelected() > 0)):
# draw box only when left mouse button is pressed
self.MouseDraw(pdc=self.pdcTmp)
-# event.Skip()
+ # event.Skip()
+ def OnLeftDownVDigitAddLine(self, event):
+ Left mouse button down - vector digitizer add new line
+ action
+ digitClass = self.parent.digit
+ try:
+ mapLayer = digitToolbar.GetLayer().GetName()
+ except:
+ return
+ if digitToolbar.GetAction('type') in ["point", "centroid"]:
+ # add new point
+ if digitToolbar.GetAction('type') == 'point':
+ point = True
+ else:
+ point = False
+ east, north = self.Pixel2Cell(self.mouse['begin'])
+ fid = digitClass.AddPoint(mapLayer, point, east, north)
+ if fid < 0:
+ return
+ self.UpdateMap(render=False) # redraw map
+ # add new record into atribute table
+ if UserSettings.Get(group='vdigit', key="addRecord", subkey='enabled') is True:
+ # select attributes based on layer and category
+ cats = { fid : {
+ UserSettings.Get(group='vdigit', key="layer", subkey='value') :
+ (UserSettings.Get(group='vdigit', key="category", subkey='value'), )
+ posWindow = self.ClientToScreen((self.mouse['end'][0] + self.dialogOffset,
+ self.mouse['end'][1] + self.dialogOffset))
+ addRecordDlg = dbm_dialogs.DisplayAttributesDialog(parent=self, map=mapLayer,
+ cats=cats,
+ pos=posWindow,
+ action="add")
+ if not point:
+ self.__geomAttrb(fid, addRecordDlg, 'area', digitClass,
+ digitToolbar.GetLayer())
+ self.__geomAttrb(fid, addRecordDlg, 'perimeter', digitClass,
+ if addRecordDlg.mapDBInfo and \
+ addRecordDlg.ShowModal() == wx.ID_OK:
+ sqlfile = tempfile.NamedTemporaryFile(mode="w")
+ for sql in addRecordDlg.GetSQLString():
+ sqlfile.file.write(sql + ";\n")
+ sqlfile.file.flush()
+ gcmd.RunCommand('db.execute',
+ parent = self,
+ quiet = True,
+ input = sqlfile.name)
+ if addRecordDlg.mapDBInfo:
+ self.__updateATM()
+ elif digitToolbar.GetAction('type') in ["line", "boundary"]:
+ # add new point to the line
+ self.polycoords.append(self.Pixel2Cell(event.GetPositionTuple()[:]))
+ self.DrawLines(pdc=self.pdcTmp)
+ def __geomAttrb(self, fid, dialog, attrb, digit, mapLayer):
+ """!Trac geometry attributes?"""
+ item = self.tree.FindItemByData('maplayer', mapLayer)
+ vdigit = self.tree.GetPyData(item)[0]['vdigit']
+ if vdigit and \
+ vdigit.has_key('geomAttr') and \
+ vdigit['geomAttr'].has_key(attrb):
+ val = -1
+ if attrb == 'length':
+ val = digit.GetLineLength(fid)
+ type = attrb
+ elif attrb == 'area':
+ val = digit.GetAreaSize(fid)
+ type = attrb
+ elif attrb == 'perimeter':
+ val = digit.GetAreaPerimeter(fid)
+ type = 'length'
+ if val > 0:
+ layer = int(UserSettings.Get(group='vdigit', key="layer", subkey='value'))
+ column = vdigit['geomAttr'][attrb]['column']
+ val = UnitsConvertValue(val, type, vdigit['geomAttr'][attrb]['units'])
+ dialog.SetColumnValue(layer, column, val)
+ dialog.OnReset()
+ def __geomAttrbUpdate(self, fids):
+ """!Update geometry atrributes of currently selected features
+ @param fid list feature id
+ mapLayer = self.parent.toolbars['vdigit'].GetLayer()
+ vectorName = mapLayer.GetName()
+ digit = self.parent.digit
+ if vdigit is None or not vdigit.has_key('geomAttr'):
+ return
+ dbInfo = gselect.VectorDBInfo(vectorName)
+ for fid in fids:
+ for layer, cats in digit.GetLineCats(fid).iteritems():
+ table = dbInfo.GetTable(layer)
+ for attrb, item in vdigit['geomAttr'].iteritems():
+ val = -1
+ type = attrb
+ type = attrb
+ type = 'length'
+ if val < 0:
+ continue
+ val = UnitsConvertValue(val, type, item['units'])
+ for cat in cats:
+ sqlfile.write('UPDATE %s SET %s = %f WHERE %s = %d;\n' % \
+ (table, item['column'], val,
+ dbInfo.GetKeyColumn(layer), cat))
+ parent = True,
+ quiet = True,
+ def __updateATM(self):
+ """!Update open Attribute Table Manager
+ @todo: use AddDataRow() instead
+ # update ATM
+ digitVector = digitToolbar.GetLayer().GetName()
+ for atm in self.lmgr.dialogs['atm']:
+ atmVector = atm.GetVectorName()
+ if atmVector == digitVector:
+ layer = UserSettings.Get(group='vdigit', key="layer", subkey='value')
+ # TODO: use AddDataRow instead
+ atm.LoadData(layer)
+ def OnLeftDownVDigitEditLine(self, event):
+ Left mouse button down - vector digitizer edit linear feature
+ - add new vertex.
+ self.polycoords.append(self.Pixel2Cell(self.mouse['begin']))
+ self.vdigitMove['id'].append(wx.NewId())
+ def OnLeftDownVDigitMoveLine(self, event):
+ Left mouse button down - vector digitizer move feature/vertex,
+ edit linear feature
+ self.vdigitMove = {}
+ # geographic coordinates of initial position (left-down)
+ self.vdigitMove['begin'] = None
+ # list of ids to modify
+ self.vdigitMove['id'] = []
+ # ids geographic coordinates
+ self.vdigitMove['coord'] = {}
+ if digitToolbar.GetAction() in ["moveVertex", "editLine"]:
+ # set pen
+ pcolor = UserSettings.Get(group='vdigit', key="symbol",
+ subkey=["highlight", "color"])
+ self.pen = self.polypen = wx.Pen(colour=pcolor,
+ width=2, style=wx.SHORT_DASH)
+ self.pdcTmp.SetPen(self.polypen)
+ def OnLeftDownVDigitDisplayCA(self, event):
+ Left mouse button down - vector digitizer display categories
+ or attributes action
+ try:
+ except:
+ return
+ coords = self.Pixel2Cell(self.mouse['begin'])
+ # unselect
+ digitClass.driver.SetSelected([])
+ # select feature by point
+ cats = {}
+ if digitClass.driver.SelectLineByPoint(coords,
+ digitClass.GetSelectType()) is None:
+ return
+ if UserSettings.Get(group='vdigit', key='checkForDupl',
+ subkey='enabled'):
+ lines = digitClass.driver.GetSelected()
+ else:
+ lines = (digitClass.driver.GetSelected()[0],) # only first found
+ for line in lines:
+ cats[line] = digitClass.GetLineCats(line)
+ if digitToolbar.GetAction() == "displayAttrs":
+ # select attributes based on coordinates (all layers)
+ if self.parent.dialogs['attributes'] is None:
+ self.parent.dialogs['attributes'] = \
+ dbm_dialogs.DisplayAttributesDialog(parent=self, map=mapLayer,
+ cats=cats,
+ action="update")
+ else:
+ # upgrade dialog
+ self.parent.dialogs['attributes'].UpdateDialog(cats=cats)
+ if self.parent.dialogs['attributes']:
+ if len(cats.keys()) > 0:
+ # highlight feature & re-draw map
+ if not self.parent.dialogs['attributes'].IsShown():
+ self.parent.dialogs['attributes'].Show()
+ else:
+ if self.parent.dialogs['attributes'] and \
+ self.parent.dialogs['attributes'].IsShown():
+ self.parent.dialogs['attributes'].Hide()
+ else: # displayCats
+ if self.parent.dialogs['category'] is None:
+ # open new dialog
+ dlg = VDigitCategoryDialog(parent=self,
+ map=mapLayer,
+ cats=cats,
+ pos=posWindow,
+ title=_("Update categories"))
+ self.parent.dialogs['category'] = dlg
+ else:
+ # update currently open dialog
+ self.parent.dialogs['category'].UpdateDialog(cats=cats)
+ if self.parent.dialogs['category']:
+ if not self.parent.dialogs['category'].IsShown():
+ self.parent.dialogs['category'].Show()
+ else:
+ if self.parent.dialogs['category'].IsShown():
+ self.parent.dialogs['category'].Hide()
+ def OnLeftDownVDigitCopyCA(self, event):
+ Left mouse button down - vector digitizer copy categories
+ if not hasattr(self, "copyCatsList"):
+ self.copyCatsList = []
+ else:
+ self.copyCatsIds = []
+ self.mouse['box'] = 'box'
+ def OnLeftDownVDigitCopyLine(self, event):
+ Left mouse button down - vector digitizer copy lines action
+ if not hasattr(self, "copyIds"):
+ self.copyIds = []
+ self.layerTmp = None
+ def OnLeftDownVDigitBulkLine(self, event):
+ Left mouse button down - vector digitizer label 3d vector
+ lines
+ if len(self.polycoords) > 1: # start new line
+ if len(self.polycoords) == 1:
+ begin = self.Pixel2Cell(self.polycoords[-1])
+ end = self.Pixel2Cell(self.mouse['end'])
+ else:
+ end = self.Pixel2Cell(self.polycoords[-1])
+ begin = self.Pixel2Cell(self.mouse['begin'])
+ self.DrawLines(self.pdcTmp, polycoords = (begin, end))
def OnLeftDown(self, event):
Left mouse button pressed
Debug.msg (5, "BufferedWindow.OnLeftDown(): use=%s" % \
self.mouse["use"])
self.mouse['begin'] = event.GetPositionTuple()[:]
if self.mouse["use"] in ["measure", "profile"]:
# measure or profile
if len(self.polycoords) == 0:
@@ -1222,247 +1622,351 @@
self.mouse['begin'] = self.mouse['end']
elif self.mouse['use'] == 'zoom':
pass
- elif self.mouse["use"] == "pointer" and self.parent.toolbars['vdigit']:
- # digitization
+ # vector digizer
+ elif self.mouse["use"] == "pointer" and \
+ self.parent.toolbars['vdigit']:
- east, north = self.Pixel2Cell(self.mouse['begin'])
try:
- map = digitToolbar.GetLayer().GetName()
except:
- map = None
wx.MessageBox(parent=self,
message=_("No vector map selected for editing."),
- caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
+ caption=_("Vector digitizer"),
+ style=wx.OK | wx.ICON_INFORMATION | wx.CENTRE)
event.Skip()
return
- # calculate position of 'update record' dialog
- position = self.mouse['begin']
- posWindow = self.ClientToScreen((position[0] + self.dialogOffset,
- position[1] + self.dialogOffset))
- if digitToolbar.GetAction() not in ("moveVertex", "addVertex",
- "removeVertex", "editLine"):
+ if digitToolbar.GetAction() not in ("moveVertex",
+ "addVertex",
+ "removeVertex",
+ "editLine"):
# set pen
self.pen = wx.Pen(colour='Red', width=2, style=wx.SHORT_DASH)
self.polypen = wx.Pen(colour='dark green', width=2, style=wx.SOLID)
- if digitToolbar.GetAction() in ("addVertex", "removeVertex"):
+ if digitToolbar.GetAction() in ("addVertex",
+ "removeVertex",
+ "splitLines"):
# unselect
if digitToolbar.GetAction() == "addLine":
- if digitToolbar.GetAction('type') in ["point", "centroid"]:
- # add new point
- if digitToolbar.GetAction('type') == 'point':
- point = True
- else:
- point = False
+ self.OnLeftDownVDigitAddLine(event)
+ elif digitToolbar.GetAction() == "editLine" and \
+ hasattr(self, "vdigitMove"):
+ self.OnLeftDownVDigitEditLine(event)
- fid = digitClass.AddPoint(map, point, east, north)
- if fid < 0:
- return
+ elif digitToolbar.GetAction() in ("moveLine",
+ "moveVertex",
+ "editLine") and \
+ not hasattr(self, "vdigitMove"):
+ self.OnLeftDownVDigitMoveLine(event)
- self.UpdateMap(render=False) # redraw map
- # add new record into atribute table
- if UserSettings.Get(group='vdigit', key="addRecord", subkey='enabled') is True:
- # select attributes based on layer and category
- cats = { fid : {
- UserSettings.Get(group='vdigit', key="layer", subkey='value') :
- (UserSettings.Get(group='vdigit', key="category", subkey='value'), )
- addRecordDlg = dbm.DisplayAttributesDialog(parent=self, map=map,
- cats=cats,
- pos=posWindow,
- action="add")
- if addRecordDlg.mapDBInfo and \
- addRecordDlg.ShowModal() == wx.ID_OK:
- sqlfile = tempfile.NamedTemporaryFile(mode="w")
- for sql in addRecordDlg.GetSQLString():
- sqlfile.file.write(sql + ";\n")
- sqlfile.file.flush()
- executeCommand = gcmd.Command(cmd=["db.execute",
- "--q",
- "input=%s" % sqlfile.name])
- elif digitToolbar.GetAction('type') in ["line", "boundary"]:
- # add new point to the line
- self.polycoords.append(self.Pixel2Cell(event.GetPositionTuple()[:]))
- self.DrawLines(pdc=self.pdcTmp)
+ elif digitToolbar.GetAction() in ("displayAttrs"
+ "displayCats"):
+ self.OnLeftDownVDigitDisplayCA(event)
- elif digitToolbar.GetAction() == "editLine" and hasattr(self, "vdigitMove"):
- self.polycoords.append(self.Pixel2Cell(self.mouse['begin']))
- self.vdigitMove['id'].append(wx.NewId())
+ elif digitToolbar.GetAction() in ("copyCats",
+ "copyAttrs"):
+ self.OnLeftDownVDigitCopyCA(event)
+ elif digitToolbar.GetAction() == "copyLine":
+ self.OnLeftDownVDigitCopyLine(event)
+ elif digitToolbar.GetAction() == "zbulkLine":
+ self.OnLeftDownVDigitBulkLine(event)
+ elif self.mouse['use'] == 'pointer':
+ # get decoration or text id
+ self.idlist = []
+ self.dragid = ''
+ self.lastpos = self.mouse['begin']
+ idlist = self.pdc.FindObjects(self.lastpos[0], self.lastpos[1],
+ self.hitradius)
+ if 99 in idlist:
+ idlist.remove(99)
+ if idlist != []:
+ self.dragid = idlist[0] #drag whatever is on top
+ else:
+ pass
- elif digitToolbar.GetAction() == "deleteLine":
- pass
+ event.Skip()
- elif digitToolbar.GetAction() in ["moveLine", "moveVertex", "editLine"] and \
- not hasattr(self, "vdigitMove"):
- self.vdigitMove = {}
- # geographic coordinates of initial position (left-down)
- self.vdigitMove['begin'] = None
- # list of ids to modify
- self.vdigitMove['id'] = []
- # ids geographic coordinates
- self.vdigitMove['coord'] = {}
+ def OnLeftUpVDigitVarious(self, event):
+ Left mouse button up - vector digitizer various actions
+ pos1 = self.Pixel2Cell(self.mouse['begin'])
+ pos2 = self.Pixel2Cell(self.mouse['end'])
+ nselected = 0
+ # -> delete line || move line || move vertex
+ if digitToolbar.GetAction() in ("moveVertex",
+ "editLine"):
+ if len(digitClass.driver.GetSelected()) == 0:
+ nselected = digitClass.driver.SelectLineByPoint(pos1, type=VDigit_Lines_Type)
- if digitToolbar.GetAction() in ["moveVertex", "editLine"]:
- # set pen
- pcolor = UserSettings.Get(group='vdigit', key="symbol",
- subkey=["highlight", "color"])
- self.pen = self.polypen = wx.Pen(colour=pcolor,
- width=2, style=wx.SHORT_DASH)
- self.pdcTmp.SetPen(self.polypen)
- elif digitToolbar.GetAction() == "splitLine":
- # unselect
+ if digitToolbar.GetAction() == "editLine":
+ try:
+ selVertex = digitClass.driver.GetSelectedVertex(pos1)[0]
+ except IndexError:
+ selVertex = None
+ if selVertex:
+ # self.UpdateMap(render=False)
+ ids = digitClass.driver.GetSelected(grassId=False)
+ # move this line to tmp layer
+ for id in ids:
+ if id % 2: # register only vertices
+ e, n = self.Pixel2Cell(self.pdcVector.GetIdBounds(id)[0:2])
+ self.polycoords.append((e, n))
+ digitClass.driver.DrawSelected(False)
+ if selVertex < ids[-1] / 2:
+ # choose first or last node of line
+ self.vdigitMove['id'].reverse()
+ self.polycoords.reverse()
+ else:
+ # unselect
+ "copyAttrs"):
+ if not hasattr(self, "copyCatsIds"):
+ # 'from' -> select by point
+ nselected = digitClass.driver.SelectLineByPoint(pos1, digitClass.GetSelectType())
+ if nselected:
+ self.copyCatsList = digitClass.driver.GetSelected()
+ else:
+ # -> 'to' -> select by bbox
+ # return number of selected features (by box/point)
+ nselected = digitClass.driver.SelectLinesByBox(pos1, pos2,
+ if nselected == 0:
+ if digitClass.driver.SelectLineByPoint(pos1,
+ digitClass.GetSelectType()) is not None:
+ nselected = 1
+ if nselected > 0:
+ self.copyCatsIds = digitClass.driver.GetSelected()
- elif digitToolbar.GetAction() in ["displayAttrs", "displayCats"]:
- qdist = digitClass.driver.GetThreshold(type='selectThresh')
- coords = (east, north)
- if digitClass.type == 'vdigit':
- # unselect
- digitClass.driver.SetSelected([])
+ elif digitToolbar.GetAction() == "queryLine":
+ selected = digitClass.SelectLinesByQuery(pos1, pos2)
+ nselected = len(selected)
+ if nselected > 0:
+ digitClass.driver.SetSelected(selected)
- # select feature by point
- cats = {}
- if digitClass.driver.SelectLineByPoint(coords,
- digitClass.GetSelectType()) is not None:
- if UserSettings.Get(group='vdigit', key='checkForDupl',
- subkey='enabled'):
- lines = digitClass.driver.GetSelected()
- else:
- lines = (digitClass.driver.GetSelected()[0],) # only first found
- for line in lines:
- cats[line] = digitClass.GetLineCats(line)
+ else:
+ # -> moveLine || deleteLine, etc. (select by point/box)
+ if digitToolbar.GetAction() == 'moveLine' and \
+ len(digitClass.driver.GetSelected()) > 0:
+ nselected = 0
+ else:
+ drawSeg = True
+ else:
+ drawSeg = False
+ digitClass.GetSelectType(),
+ drawSeg)
- if digitToolbar.GetAction() == "displayAttrs":
- # select attributes based on coordinates (all layers)
- if self.parent.dialogs['attributes'] is None:
- if digitClass.type == 'vedit':
- self.parent.dialogs['attributes'] = dbm.DisplayAttributesDialog(parent=self, map=map,
- query=(coords, qdist),
- pos=posWindow,
- action="update")
- else:
- cats=cats,
- action="update")
- else:
- # update currently open dialog
- self.parent.dialogs['attributes'].UpdateDialog(query=(coords, qdist))
- else:
- # upgrade dialog
- self.parent.dialogs['attributes'].UpdateDialog(cats=cats)
+ nselected = 1
+ if nselected > 0:
+ if digitToolbar.GetAction() in ("moveLine",
+ "moveVertex"):
+ # get pseudoDC id of objects which should be redrawn
+ if digitToolbar.GetAction() == "moveLine":
+ # -> move line
+ self.vdigitMove['id'] = digitClass.driver.GetSelected(grassId=False)
+ self.vdigitMove['coord'] = digitClass.driver.GetSelectedCoord()
+ else: # moveVertex
+ self.vdigitMove['id'] = digitClass.driver.GetSelectedVertex(pos1)
+ if len(self.vdigitMove['id']) == 0: # no vertex found
+ # check for duplicates
+ if UserSettings.Get(group='vdigit', key='checkForDupl', subkey='enabled') is True:
+ dupl = digitClass.driver.GetDuplicates()
+ if dupl:
+ dlg = VDigitDuplicatesDialog(parent=self, data=dupl, pos=posWindow)
+ if dlg.ShowModal() == wx.ID_OK:
+ digitClass.driver.UnSelect(dlg.GetUnSelected())
+ # update selected
+ if digitToolbar.GetAction() != "editLine":
+ # -> move line || move vertex
+ else: # no vector object found
+ if not (digitToolbar.GetAction() in ("moveLine",
+ "moveVertex") and \
+ len(self.vdigitMove['id']) > 0):
+ # avoid left-click when features are already selected
+ self.UpdateMap(render=False, renderVector=False)
+ def OnLeftUpVDigitModifyLine(self, event):
+ Left mouse button up - vector digitizer split line, add/remove
+ vertex action
+ pointOnLine = digitClass.driver.SelectLineByPoint(pos1,
+ type=VDigit_Lines_Type)
- if self.parent.dialogs['attributes']:
- if len(cats.keys()) > 0:
- # highlight feature & re-draw map
- if not self.parent.dialogs['attributes'].IsShown():
- self.parent.dialogs['attributes'].Show()
- else:
- if self.parent.dialogs['attributes'] and \
- self.parent.dialogs['attributes'].IsShown():
- self.parent.dialogs['attributes'].Hide()
+ if not pointOnLine:
+ return
- else: # displayCats
- if self.parent.dialogs['category'] is None:
- # open new dialog
- dlg = VDigitCategoryDialog(parent=self,
- map=map,
- pos=posWindow,
- title=_("Update categories"))
- self.parent.dialogs['category'] = dlg
- else:
- map=map,
- cats=cats,
- pos=posWindow,
- else:
- self.parent.dialogs['category'].UpdateDialog(query=(coords, qdist))
- else:
- # upgrade dialog
- self.parent.dialogs['category'].UpdateDialog(cats=cats)
- if self.parent.dialogs['category']:
- ### digitClass.driver.SetSelected(line)
- if not self.parent.dialogs['category'].IsShown():
- self.parent.dialogs['category'].Show()
- else:
- if self.parent.dialogs['category'].IsShown():
- self.parent.dialogs['category'].Hide()
+ if digitToolbar.GetAction() in ["splitLine", "addVertex"]:
+ self.UpdateMap(render=False) # highlight object
+ self.DrawCross(pdc=self.pdcTmp, coords=self.Cell2Pixel(pointOnLine),
+ size=5)
+ else: # removeVertex
+ # get only id of vertex
+ try:
+ id = digitClass.driver.GetSelectedVertex(pos1)[0]
+ id = None
+ if id:
+ x, y = self.pdcVector.GetIdBounds(id)[0:2]
+ self.pdcVector.RemoveId(id)
+ self.DrawCross(pdc=self.pdcTmp, coords=(x, y),
+ size=5)
+ else:
+ # unselect
- elif digitToolbar.GetAction() in ("copyCats", "copyAttrs"):
- if not hasattr(self, "copyCatsList"):
- self.copyCatsList = []
- else:
- self.copyCatsIds = []
- self.mouse['box'] = 'box'
+ def OnLeftUpVDigitCopyLine(self, event):
+ Left mouse button up - vector digitizer copy feature action
+ if UserSettings.Get(group='vdigit', key='bgmap',
+ subkey='value', internal=True) == '':
+ # no background map -> copy from current vector map layer
- elif digitToolbar.GetAction() == "copyLine":
- self.copyIds = []
- self.layerTmp = None
- elif digitToolbar.GetAction() == "zbulkLine":
- if len(self.polycoords) > 1: # start new line
- if len(self.polycoords) == 1:
- begin = self.Pixel2Cell(self.polycoords[-1])
- end = self.Pixel2Cell(self.mouse['end'])
+ if nselected > 0:
+ # highlight selected features
+ else:
+ else:
+ # copy features from background map
+ self.copyIds += digitClass.SelectLinesFromBackgroundMap(pos1, pos2)
+ if len(self.copyIds) > 0:
+ color = UserSettings.Get(group='vdigit', key='symbol',
+ subkey=['highlight', 'color'])
+ colorStr = str(color[0]) + ":" + \
+ str(color[1]) + ":" + \
+ str(color[2])
+ dVectTmp = ['d.vect',
+ 'map=%s' % UserSettings.Get(group='vdigit', key='bgmap',
+ subkey='value', internal=True),
+ 'cats=%s' % utils.ListOfCatsToRange(self.copyIds),
+ '-i',
+ 'color=%s' % colorStr,
+ 'fcolor=%s' % colorStr,
+ 'type=point,line,boundary,centroid',
+ 'width=2']
+ if not self.layerTmp:
+ self.layerTmp = self.Map.AddLayer(type='vector',
+ name=globalvar.QUERYLAYER,
+ command=dVectTmp)
else:
- end = self.Pixel2Cell(self.polycoords[-1])
- begin = self.Pixel2Cell(self.mouse['begin'])
+ self.layerTmp.SetCmd(dVectTmp)
+ self.UpdateMap(render=True, renderVector=False)
+ else:
+ self.redrawAll = None
+ def OnLeftUpVDigitBulkLine(self, event):
+ Left mouse button up - vector digitizer z-bulk line action
+ # select lines to be labeled
+ pos1 = self.polycoords[0]
+ pos2 = self.polycoords[1]
- self.DrawLines(self.pdcTmp, polycoords = [begin, end])
- elif self.mouse['use'] == 'pointer':
- # get decoration or text id
- self.idlist = []
- self.dragid = ''
- self.lastpos = self.mouse['begin']
- idlist = self.pdc.FindObjects(x=self.lastpos[0], y=self.lastpos[1],
- radius=self.hitradius)
- if 99 in idlist: idlist.remove(99)
- if idlist != [] :
- self.dragid = idlist[0] #drag whatever is on top
+ if nselected > 0:
+ self.DrawLines(pdc=self.pdcTmp) # redraw temp line
else:
- pass
- event.Skip()
+ def OnLeftUpVDigitConnectLine(self, event):
+ Left mouse button up - vector digitizer connect line action
+ if len(digitClass.driver.GetSelected()) > 0:
def OnLeftUp(self, event):
Left mouse button released
Debug.msg (5, "BufferedWindow.OnLeftUp(): use=%s" % \
- self.mouse["use"])
+ self.mouse["use"])
self.mouse['end'] = event.GetPositionTuple()[:]
if self.mouse['use'] in ["zoom", "pan"]:
# set region in zoom or pan
begin = self.mouse['begin']
end = self.mouse['end']
# set region for click (zero-width box)
if begin[0] - end[0] == 0 or \
@@ -1472,7 +1976,7 @@
end[1] - self.Map.height / 4)
end = (end[0] + self.Map.width / 4,
end[1] + self.Map.height / 4)
self.Zoom(begin, end, self.zoomtype)
# redraw map
@@ -1501,7 +2005,8 @@
- elif self.mouse["use"] == "pointer" and self.parent.gismanager.georectifying:
# -> georectifying
coord = self.Pixel2Cell(self.mouse['end'])
@@ -1509,242 +2014,54 @@
else:
- self.parent.gismanager.georectifying.SetGCPData(coordtype, coord, self)
+ self.parent.GetLayerManager().georectifying.SetGCPData(coordtype, coord, self)
# digitization tool active
- pos1 = self.Pixel2Cell(self.mouse['begin'])
- pos2 = self.Pixel2Cell(self.mouse['end'])
if hasattr(self, "vdigitMove"):
- self.vdigitMove['begin'] = pos1 # left down
- ### else:
- ### dx = pos2[0] - pos1[0] ### ???
- ### dy = pos2[1] - pos1[1]
- ### self.vdigitMove = (self.vdigitMove['begin'][0] + dx,
- ### self.vdigitMove['begin'][1] + dy)
+ self.vdigitMove['begin'] = self.Pixel2Cell(self.mouse['begin']) # left down
# eliminate initial mouse moving efect
- if digitToolbar.GetAction() in ["deleteLine", "moveLine", "moveVertex",
- "copyCats", "copyAttrs", "editLine", "flipLine",
- "mergeLine", "snapLine",
- "queryLine", "breakLine", "typeConv", "connectLine"]:
- nselected = 0
- # -> delete line || move line || move vertex
- if len(digitClass.driver.GetSelected()) == 0:
- nselected = digitClass.driver.SelectLineByPoint(pos1, type=VDigit_Lines_Type)
- if digitToolbar.GetAction() == "editLine":
- try:
- selVertex = digitClass.driver.GetSelectedVertex(pos1)[0]
- except IndexError:
- selVertex = None
+ if digitToolbar.GetAction() in ("deleteLine",
+ "moveLine",
+ "moveVertex",
+ "copyCats",
+ "copyAttrs",
+ "editLine",
+ "flipLine",
+ "mergeLine",
+ "snapLine",
+ "queryLine",
+ "breakLine",
+ "typeConv",
+ "connectLine"):
+ self.OnLeftUpVDigitVarious(event)
- if selVertex:
- # self.UpdateMap(render=False)
- ids = digitClass.driver.GetSelected(grassId=False)
- # move this line to tmp layer
- for id in ids:
- if id % 2: # register only vertices
- e, n = self.Pixel2Cell(self.pdcVector.GetIdBounds(id)[0:2])
- self.polycoords.append((e, n))
- # self.pdcVector.RemoveId(id)
- digitClass.driver.DrawSelected(False)
- if selVertex < ids[-1] / 2:
- # choose first or last node of line
- self.vdigitMove['id'].reverse()
- self.polycoords.reverse()
- else:
- # unselect
+ elif digitToolbar.GetAction() in ("splitLine",
+ "addVertex",
+ "removeVertex"):
+ self.OnLeftUpVDigitModifyLine(event)
- if not hasattr(self, "copyCatsIds"):
- # 'from' -> select by point
- nselected = digitClass.driver.SelectLineByPoint(pos1, digitClass.GetSelectType())
- if nselected:
- self.copyCatsList = digitClass.driver.GetSelected()
- else:
- # -> 'to' -> select by bbox
- # return number of selected features (by box/point)
- nselected = digitClass.driver.SelectLinesByBox(pos1, pos2,
- if nselected == 0:
- if digitClass.driver.SelectLineByPoint(pos1,
- nselected = 1
- if nselected > 0:
- self.copyCatsIds = digitClass.driver.GetSelected()
- elif digitToolbar.GetAction() == "queryLine":
- selected = digitClass.SelectLinesByQuery(pos1, pos2)
- nselected = len(selected)
- if nselected > 0:
- digitClass.driver.SetSelected(selected)
- else:
- # -> moveLine || deleteLine, etc. (select by point/box)
- if digitToolbar.GetAction() == 'moveLine' and \
- len(digitClass.driver.GetSelected()) > 0:
- nselected = 0
- else:
- drawSeg = True
- else:
- drawSeg = False
- digitClass.GetSelectType(),
- drawSeg)
- nselected = 1
- if nselected > 0:
- if digitToolbar.GetAction() in ["moveLine", "moveVertex"]:
- # get pseudoDC id of objects which should be redrawn
- if digitToolbar.GetAction() == "moveLine":
- # -> move line
- self.vdigitMove['id'] = digitClass.driver.GetSelected(grassId=False)
- self.vdigitMove['coord'] = digitClass.driver.GetSelectedCoord()
- elif digitToolbar.GetAction() == "moveVertex":
- # -> move vertex
- self.vdigitMove['id'] = digitClass.driver.GetSelectedVertex(pos1)
- if len(self.vdigitMove['id']) == 0: # no vertex found
- # check for duplicates
- if UserSettings.Get(group='vdigit', key='checkForDupl', subkey='enabled') is True:
- dupl = digitClass.driver.GetDuplicates()
- if dupl:
- posWindow = self.ClientToScreen((self.mouse['end'][0] + self.dialogOffset,
- self.mouse['end'][1] + self.dialogOffset))
- dlg = VDigitDuplicatesDialog(parent=self, data=dupl, pos=posWindow)
- if dlg.ShowModal() == wx.ID_OK:
- digitClass.driver.UnSelect(dlg.GetUnSelected())
- # update selected
- if digitToolbar.GetAction() != "editLine":
- # -> move line || move vertex
- else: # no vector object found
- if not (digitToolbar.GetAction() in ["moveLine", "moveVertex"] and \
- len(self.vdigitMove['id']) > 0):
- # avoid left-click when features are already selected
- self.UpdateMap(render=False, renderVector=False)
- elif digitToolbar.GetAction() in ["splitLine", "addVertex", "removeVertex"]:
- pointOnLine = digitClass.driver.SelectLineByPoint(pos1,
- type=VDigit_Lines_Type)
- if pointOnLine:
- if digitToolbar.GetAction() in ["splitLine", "addVertex"]:
- self.UpdateMap(render=False) # highlight object
- self.DrawCross(pdc=self.pdcTmp, coords=self.Cell2Pixel(pointOnLine),
- size=5)
- elif digitToolbar.GetAction() == "removeVertex":
- # get only id of vertex
- try:
- id = digitClass.driver.GetSelectedVertex(pos1)[0]
- id = None
- if id:
- x, y = self.pdcVector.GetIdBounds(id)[0:2]
- self.pdcVector.RemoveId(id)
- self.DrawCross(pdc=self.pdcTmp, coords=(x, y),
- size=5)
- else:
- # unselect
- if UserSettings.Get(group='vdigit', key='bgmap',
- subkey='value', internal=True) == '':
- # no background map -> copy from current vector map layer
- if nselected > 0:
- # highlight selected features
- else:
- else:
- # copy features from background map
- self.copyIds = digitClass.SelectLinesFromBackgroundMap(pos1, pos2)
- if len(self.copyIds) > 0:
- color = UserSettings.Get(group='vdigit', key='symbol',
- subkey=['highlight', 'color'])
- colorStr = str(color[0]) + ":" + \
- str(color[1]) + ":" + \
- str(color[2])
- dVectTmp = ['d.vect',
- 'map=%s' % UserSettings.Get(group='vdigit', key='bgmap',
- subkey='value', internal=True),
- 'cats=%s' % utils.ListOfCatsToRange(self.copyIds),
- '-i',
- 'color=%s' % colorStr,
- 'fcolor=%s' % colorStr,
- 'type=point,line,boundary,centroid',
- 'width=2']
- self.layerTmp = self.Map.AddLayer(type='vector',
- name=globalvar.QUERYLAYER,
- command=dVectTmp)
- self.UpdateMap(render=True, renderVector=False)
- else:
- self.redrawAll = None
- elif digitToolbar.GetAction() == "zbulkLine" and len(self.polycoords) == 2:
- # select lines to be labeled
- pos1 = self.polycoords[0]
- pos2 = self.polycoords[1]
- if nselected > 0:
- self.DrawLines(pdc=self.pdcTmp) # redraw temp line
- else:
+ self.OnLeftUpVDigitCopyLine(event)
+ elif digitToolbar.GetAction() == "zbulkLine" and \
+ len(self.polycoords) == 2:
+ self.OnLeftUpVDigitBulkLine(event)
elif digitToolbar.GetAction() == "connectLine":
- if len(digitClass.driver.GetSelected()) > 0:
+ self.OnLeftUpConnectLine(event)
- ### self.OnPaint(None)
self.dragid >= 0):
# end drag of overlay decoration
@@ -1757,15 +2074,9 @@
pass
self.dragid = None
self.currtxtid = None
-# self.UpdateMap(render=True)
- else:
- pass
-# event.Skip()
def OnButtonDClick(self, event):
Mouse button double click
Debug.msg (5, "BufferedWindow.OnButtonDClick(): use=%s" % \
@@ -1780,18 +2091,15 @@
self.Refresh()
elif self.mouse["use"] == "profile":
- # profile
pass
- # self.pdc.ClearId(self.lineid)
- # self.pdc.ClearId(self.plineid)
- # print 'coordinates: ',self.polycoords
- # self.polycoords = []
- # self.mouse['begin'] = self.mouse['end'] = [0, 0]
- # self.Refresh()
- elif self.mouse['use'] == 'pointer' and self.parent.toolbars['vdigit']:
- # digitization tool
+ elif self.mouse['use'] == 'pointer' and \
+ # vector digitizer
pass
else:
# select overlay decoration options dialog
clickposition = event.GetPositionTuple()[:]
@@ -1808,11 +2116,9 @@
self.parent.OnAddBarscale(None)
elif self.dragid == 1:
self.parent.OnAddLegend(None)
-# event.Skip()
def OnRightDown(self, event):
Right mouse button pressed
Debug.msg (5, "BufferedWindow.OnRightDown(): use=%s" % \
@@ -1822,7 +2128,8 @@
if digitToolbar:
# digitization tool (confirm action)
- if digitToolbar.GetAction() in ["moveLine", "moveVertex"] and \
pFrom = self.vdigitMove['begin']
@@ -1837,15 +2144,18 @@
return
# move vertex
- if digitClass.MoveSelectedVertex(pFrom, move) < 0:
+ fid = digitClass.MoveSelectedVertex(pFrom, move)
+ if fid < 0:
return
+ self.__geomAttrbUpdate([fid,])
del self.vdigitMove
event.Skip()
def OnRightUp(self, event):
Right mouse button released
Debug.msg (5, "BufferedWindow.OnRightUp(): use=%s" % \
@@ -1890,7 +2200,9 @@
self.Refresh()
+ if UserSettings.Get(group='vdigit', key="addRecord", subkey='enabled') and \
+ (line is True or \
+ (not line and fid > 0)):
@@ -1899,36 +2211,54 @@
+ addRecordDlg = dbm_dialogs.DisplayAttributesDialog(parent=self, map=map,
+ cats=cats,
+ pos=posWindow,
+ action="add")
- cats=cats,
- pos=posWindow,
- action="add")
+ self.__geomAttrb(fid, addRecordDlg, 'length', digitClass,
+ # auto-placing centroid
- "--q",
+ parent = True,
+ quiet = True,
# -> delete selected vector features
if digitClass.DeleteSelectedLines() < 0:
return
# split line
if digitClass.SplitLine(self.Pixel2Cell(self.mouse['begin'])) < 0:
return
elif digitToolbar.GetAction() == "addVertex":
# add vertex
- if digitClass.AddVertex(self.Pixel2Cell(self.mouse['begin'])) < 0:
+ fid = digitClass.AddVertex(self.Pixel2Cell(self.mouse['begin']))
+ if fid < 0:
return
# remove vertex
- if digitClass.RemoveVertex(self.Pixel2Cell(self.mouse['begin'])) < 0:
+ fid = digitClass.RemoveVertex(self.Pixel2Cell(self.mouse['begin']))
+ if fid < 0:
return
try:
if digitToolbar.GetAction() == 'copyCats':
@@ -1944,6 +2274,9 @@
del self.copyCatsIds
except AttributeError:
pass
line = digitClass.driver.GetSelected()
@@ -1986,7 +2319,7 @@
nselected=len(selected))
if digitClass.ZBulkLines(pos1, pos2, dlg.value.GetValue(),
- dlg.step.GetValue()) < 0:
+ dlg.step.GetValue()) < 0:
return
self.UpdateMap(render=False, renderVector=True)
elif digitToolbar.GetAction() == "typeConv":
@@ -2004,13 +2337,15 @@
self.Refresh()
event.Skip()
def OnMiddleDown(self, event):
Middle mouse button pressed
+ self.mouse['begin'] = event.GetPositionTuple()[:]
# digitization tool
if self.mouse["use"] == "pointer" and digitToolbar:
@@ -2071,9 +2406,27 @@
+ def OnMiddleUp(self, event):
+ Middle mouse button released
+ self.mouse['end'] = event.GetPositionTuple()[:]
+ # set region in zoom or pan
+ begin = self.mouse['begin']
+ end = self.mouse['end']
+ self.Zoom(begin, end, 0) # no zoom
+ # redraw map
+ self.UpdateMap(render=True)
def OnMouseMoving(self, event):
Motion event and no mouse buttons were pressed
@@ -2140,7 +2493,7 @@
event.Skip()
def ClearLines(self, pdc=None):
Clears temporary drawn lines from PseudoDC
if not pdc:
@@ -2165,7 +2518,7 @@
return True
def Pixel2Cell(self, (x, y)):
Convert image coordinates to real word coordinates
Input : int x, int y
@@ -2196,7 +2549,7 @@
return (east, north)
def Cell2Pixel(self, (east, north)):
Convert real word coordinates to image coordinates
@@ -2223,7 +2576,7 @@
return (x, y)
def Zoom(self, begin, end, zoomtype):
Calculates new region while (un)zoom/pan-ing
x1, y1 = begin
@@ -2299,95 +2652,120 @@
def ZoomBack(self):
+ """!Zoom to previous extents in zoomhistory list
- Zoom to previous extents in zoomhistory list
- zoom = []
+ zoom = list()
if len(self.zoomhistory) > 1:
self.zoomhistory.pop()
- zoom = self.zoomhistory[len(self.zoomhistory)-1]
- # (n, s, e, w)
- if zoom:
- # zoom to selected region
- self.Map.region['center_easting'] = zoom[3] + \
- (zoom[2] - zoom[3]) / 2
- self.Map.region['center_northing'] = zoom[1] + \
- (zoom[0] - zoom[1]) / 2
- self.Map.region["ewres"] = (zoom[2] - zoom[3]) / self.Map.width
- self.Map.region["nsres"] = (zoom[0] - zoom[1]) / self.Map.height
- self.Map.AlignExtentFromDisplay()
+ zoom = self.zoomhistory[-1]
+ # disable tool if stack is empty
+ if len(self.zoomhistory) < 2: # disable tool
+ if self.parent.GetName() == 'MapWindow':
+ toolbar = self.parent.toolbars['map']
+ elif self.parent.GetName() == 'GRMapWindow':
+ toolbar = self.parent.toolbars['georect']
+ toolbar.Enable('zoomback', enable = False)
+ # zoom to selected region
+ self.Map.GetRegion(n = zoom[0], s = zoom[1],
+ e = zoom[2], w = zoom[3],
+ update = True)
+ # update map
+ self.UpdateMap()
- # update map
- self.UpdateMap()
def ZoomHistory(self, n, s, e, w):
Manages a list of last 10 zoom extents
- Return removed history item if exists
+ @param n,s,e,w north, south, east, west
+ @return removed history item if exists (or None)
removed = None
self.zoomhistory.append((n,s,e,w))
if len(self.zoomhistory) > 10:
removed = self.zoomhistory.pop(0)
if removed:
Debug.msg(4, "BufferedWindow.ZoomHistory(): hist=%s, removed=%s" %
(self.zoomhistory, removed))
else:
Debug.msg(4, "BufferedWindow.ZoomHistory(): hist=%s" %
(self.zoomhistory))
+ # update toolbar
+ if len(self.zoomhistory) > 1:
+ enable = True
+ else:
+ enable = False
+ if self.parent.GetName() == 'pg_panel':
+ toolbar.Enable('zoomback', enable)
return removed
+ def ResetZoomHistory(self):
+ """!Reset zoom history"""
+ self.zoomhistory = list()
def OnZoomToMap(self, event):
Set display extents to match selected raster (including NULLs)
or vector map.
self.ZoomToMap()
def OnZoomToRaster(self, event):
Set display extents to match selected raster map (ignore NULLs)
- self.ZoomToMap(zoom=True)
+ self.ZoomToMap(ignoreNulls = True)
- def ZoomToMap(self, layer = None, zoom = False):
+ def ZoomToMap(self, layers = None, ignoreNulls = False, render = True):
- or vector map.
+ or vector map(s).
+ @param layer list of layers to be zoom to
+ @param ignoreNulls True to ignore null-values
+ @param render True to re-render display
zoomreg = {}
- if not layer:
- layer = self.GetSelectedLayer(multi = True)
+ if not layers:
+ layers = self.GetSelectedLayer(multi = True)
- if not layer:
+ if not layers:
return
rast = []
vect = []
updated = False
- for l in layer:
+ for l in layers:
# only raster/vector layers are currently supported
if l.type == 'raster':
rast.append(l.name)
elif l.type == 'vector':
- if self.parent.digit and l.name == self.parent.digit.map and \
- self.parent.digit.type == 'vdigit':
+ if digitToolbar and digitToolbar.GetLayer() == l:
w, s, b, e, n, t = self.parent.digit.driver.GetMapBoundingBox()
self.Map.GetRegion(n=n, s=s, w=w, e=e,
update=True)
updated = True
else:
vect.append(l.name)
if not updated:
self.Map.GetRegion(rast = rast,
vect = vect,
@@ -2395,13 +2773,14 @@
self.ZoomHistory(self.Map.region['n'], self.Map.region['s'],
self.Map.region['e'], self.Map.region['w'])
+ if render:
+ self.UpdateMap()
- self.UpdateMap()
def ZoomToWind(self, event):
Set display geometry to match computational
region settings (set with g.region)
@@ -2416,7 +2795,7 @@
def ZoomToDefault(self, event):
Set display geometry to match default region settings
self.Map.region = self.Map.GetRegion(default=True)
@@ -2430,7 +2809,7 @@
def DisplayToWind(self, event):
Set computational region (WIND file) to
match display extents
@@ -2441,17 +2820,16 @@
# We ONLY want to set extents here. Don't mess with resolution. Leave that
# for user to set explicitly with g.region
new = self.Map.AlignResolution()
+ gcmd.RunCommand('g.region',
+ parent = self,
+ overwrite = True,
+ n = new['n'],
+ s = new['s'],
+ e = new['e'],
+ w = new['w'],
+ rows = int(new['rows']),
+ cols = int(new['cols']))
- cmdRegion = ["g.region", "--o",
- "n=%f" % new['n'],
- "s=%f" % new['s'],
- "e=%f" % new['e'],
- "w=%f" % new['w'],
- "rows=%d" % int(new['rows']),
- "cols=%d" % int(new['cols'])]
- p = gcmd.Command(cmdRegion)
if tmpreg:
os.environ["GRASS_REGION"] = tmpreg
@@ -2459,19 +2837,22 @@
"""!Set display geometry to match extents in
saved region file
- dlg = gdialogs.SavedRegion(parent = self, id = wx.ID_ANY,
+ dlg = gdialogs.SavedRegion(parent = self,
title = _("Zoom to saved region extents"),
- pos=wx.DefaultPosition, size=wx.DefaultSize,
- style=wx.DEFAULT_DIALOG_STYLE,
loadsave='load')
- if dlg.ShowModal() == wx.ID_CANCEL:
+ if dlg.ShowModal() == wx.ID_CANCEL or not dlg.wind:
dlg.Destroy()
return
- wind = dlg.wind
+ if not grass.find_file(name = dlg.wind, element = 'windows')['name']:
+ wx.MessageBox(parent = self,
+ message = _("Region <%s> not found. Operation canceled.") % dlg.wind,
+ caption = _("Error"), style = wx.ICON_ERROR | wx.OK | wx.CENTRE)
+ dlg.Destroy()
+ return
- self.Map.GetRegion(regionName = wind,
+ self.Map.GetRegion(regionName = dlg.wind,
update = True)
dlg.Destroy()
@@ -2482,69 +2863,61 @@
self.UpdateMap()
def SaveDisplayRegion(self, event):
Save display extents to named region file.
title = _("Save display extents to region file"),
loadsave='save')
dlg.Destroy()
return
- wind = dlg.wind
# test to see if it already exists and ask permission to overwrite
- windpath = os.path.join(self.Map.env["GISDBASE"], self.Map.env["LOCATION_NAME"],
- self.Map.env["MAPSET"], "windows", wind)
- if windpath and not os.path.exists(windpath):
- self.SaveRegion(wind)
- elif windpath and os.path.exists(windpath):
- overwrite = wx.MessageBox(_("Region file <%s> already exists. "
- "Do you want to overwrite it?") % (wind),
- _("Warning"), wx.YES_NO | wx.CENTRE)
+ if grass.find_file(name = dlg.wind, element = 'windows')['name']:
+ overwrite = wx.MessageBox(parent = self,
+ message = _("Region file <%s> already exists. "
+ "Do you want to overwrite it?") % (dlg.wind),
+ caption = _("Warning"), style = wx.YES_NO | wx.CENTRE)
if (overwrite == wx.YES):
+ self.SaveRegion(dlg.wind)
else:
- pass
dlg.Destroy()
def SaveRegion(self, wind):
+ """!Save region settings
+ @param wind region name
- Save region settings
- ### new = self.Map.AlignResolution()
new = self.Map.GetCurrentRegion()
- "-u",
- "rows=%d" % new['rows'],
- "cols=%d" % new['cols'],
- "save=%s" % wind,
- "--o"]
tmpreg = os.getenv("GRASS_REGION")
if tmpreg:
del os.environ["GRASS_REGION"]
+ overwrite = True,
+ parent = self,
+ flags = 'u',
+ n = new['n'],
+ s = new['s'],
+ e = new['e'],
+ w = new['w'],
+ cols = int(new['cols']),
+ save = wind)
if tmpreg:
def Distance(self, beginpt, endpt, screen=True):
- """Calculete distance
+ """!Calculete distance
LL-locations not supported
@@ -2562,12 +2935,10 @@
else:
dEast = (x2 - x1)
dNorth = (y2 - y1)
return (math.sqrt(math.pow((dEast),2) + math.pow((dNorth),2)), (dEast, dNorth))
class MapFrame(wx.Panel):
Main frame for map display window. Drawing takes place in child double buffered
@@ -2601,6 +2972,7 @@
self.statusFlag = flag
self.statusbar = None
#FIX THIS
@@ -2674,13 +3046,13 @@
key='statusbarMode',
subkey='selection'))
- self.statusbar.Bind(wx.EVT_CHOICE, self.OnToggleStatus, self.statusbarWin['toggle'])
+# self.statusbar.Bind(wx.EVT_CHOICE, self.OnToggleStatus, self.statusbarWin['toggle'])
# auto-rendering checkbox
self.statusbarWin['render'] = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
label=_("Render"))
- self.statusbar.Bind(wx.EVT_CHECKBOX, self.OnToggleRender, self.statusbarWin['render'])
+ # self.statusbar.Bind(wx.EVT_CHECKBOX, self.OnToggleRender, self.statusbarWin['render'])
self.statusbarWin['render'].SetValue(UserSettings.Get(group='display',
key='autoRendering',
@@ -2760,7 +3132,7 @@
self.MapWindow2D = BufferedWindow(self, id=wx.ID_ANY, Map=self.Map, tree=self.tree, gismgr=self._layerManager)
# default is 2D display mode
self.MapWindow = self.MapWindow2D
- #self.MapWindow.Bind(wx.EVT_MOTION, self.OnMotion)
+ self.MapWindow.Bind(wx.EVT_MOTION, self.OnMotion)
self.MapWindow.SetCursor(self.cursors["default"])
# used by Nviz (3D display mode)
self.MapWindow3D = None
@@ -2847,6 +3219,8 @@
size=wx.DefaultSize, style=wx.TR_HAS_BUTTONS
|wx.TR_LINES_AT_ROOT|wx.TR_HIDE_ROOT,
gisdbase=self.gisdbase)
+ self.tree = self.maptree
#self.maptree.SetBackgroundColour("red")
self._mgr.AddPane(self.maptree, wx.aui.AuiPaneInfo().Left().
@@ -2854,6 +3228,9 @@
CloseButton(False).DestroyOnClose(True).
Layer(0).Caption("Map Tree"))
self._mgr.Update()
#r.rightSizer.Add(self.maptree)
@@ -2892,14 +3269,14 @@
if name == "map":
self.toolbars['map'] = toolbars.MapToolbar(self, self.Map)
- self._mgr.AddPane(self.toolbars['map'].toolbar,
+ self._mgr.AddPane(self.toolbars['map'],
Name("maptoolbar").Caption(_("Map Toolbar")).
ToolbarPane().Top().
LeftDockable(False).RightDockable(False).
BottomDockable(False).TopDockable(True).
CloseButton(False).Layer(2).
- BestSize((self.toolbars['map'].GetToolbar().GetSize())))
+ BestSize((self.toolbars['map'].GetSize())))
# vector digitizer
elif name == "vdigit":
@@ -2921,20 +3298,19 @@
log = self._layerManager.goutput
else:
log = None
- self.toolbars['vdigit'] = toolbars.VDigitToolbar(parent=self, map=self.Map,
+ self.toolbars['vdigit'] = toolbars.VDigitToolbar(parent=self, mapcontent=self.Map,
layerTree=self.tree,
log=log)
- for toolRow in range(0, self.toolbars['vdigit'].numOfRows):
- self._mgr.AddPane(self.toolbars['vdigit'].toolbar[toolRow],
- wx.aui.AuiPaneInfo().
- Name("vdigittoolbar" + str(toolRow)).Caption(_("Vector digitizer toolbar")).
- ToolbarPane().Top().Row(toolRow + 1).
- LeftDockable(False).RightDockable(False).
- BottomDockable(False).TopDockable(True).
- CloseButton(False).Layer(2).
- BestSize((self.toolbars['vdigit'].GetToolbar().GetSize())))
+ self._mgr.AddPane(self.toolbars['vdigit'],
+ wx.aui.AuiPaneInfo().
+ Name("vdigittoolbar").Caption(_("Vector digitizer toolbar")).
+ ToolbarPane().Top().Row(1).
+ LeftDockable(False).RightDockable(False).
+ BottomDockable(False).TopDockable(True).
+ CloseButton(False).Layer(2).
+ BestSize((self.toolbars['vdigit'].GetSize())))
# change mouse to draw digitized line
self.MapWindow.mouse['box'] = "point"
self.MapWindow.zoomtype = 0
@@ -2944,7 +3320,7 @@
elif name == "georect":
self.toolbars['georect'] = toolbars.GRToolbar(self, self.Map)
- self._mgr.AddPane(self.toolbars['georect'].toolbar,
+ self._mgr.AddPane(self.toolbars['georect'],
Name("georecttoolbar").Caption(_("Georectification toolbar")).
@@ -3003,7 +3379,8 @@
# create GL window & NVIZ toolbar
if not self.MapWindow3D:
- self.MapWindow3D = nviz.GLWindow(self, id=wx.ID_ANY, Map=self.Map, tree=self.maptree, gismgr=self._layerManager)
+ self.MapWindow3D = nviz.GLWindow(self, id=wx.ID_ANY,
+ Map=self.Map, tree=self.tree, lmgr=self._layerManager)
# -> show after paint
self.nvizToolWin = nviz.NvizToolWindow(self, id=wx.ID_ANY,
mapWindow=self.MapWindow3D)
@@ -3023,7 +3400,7 @@
Dockable(False).BestSize((-1,-1)).
Layer(0))
- self._mgr.AddPane(self.toolbars['nviz'].toolbar,
+ self._mgr.AddPane(self.toolbars['nviz'],
Name("nviztoolbar").Caption(_("Nviz toolbar")).
@@ -3032,7 +3409,7 @@
CloseButton(False).Layer(2))
self.MapWindow = self.MapWindow3D
- self.frame.SetStatusText("", 0)
+ self.SetStatusText("", 0)
self._mgr.Update()
@@ -3048,12 +3425,11 @@
return
# TODO: not destroy only hide
- self._mgr.DetachPane (self.toolbars['vdigit'].toolbar[toolRow])
- self.toolbars['vdigit'].toolbar[toolRow].Destroy()
+ self._mgr.DetachPane(self.toolbars['vdigit'])
+ self.toolbars['vdigit'].Destroy()
else:
- self._mgr.DetachPane (self.toolbars[name].toolbar)
- self.toolbars[name].toolbar.Destroy()
+ self._mgr.DetachPane (self.toolbars[name])
+ self.toolbars[name].Destroy()
self.toolbars[name] = None
@@ -3310,10 +3686,8 @@
Erase the canvas
self.MapWindow.EraseMap()
def OnZoomRegion(self, event):
Zoom to region
@@ -3751,63 +4125,29 @@
win.SetSize((w, h))
def SaveToFile(self, event):
+ """!Save map to image
- Save image to file
- lext = []
- for h in self.MapWindow.img.GetHandlers():
- lext.append(h.GetExtension())
+ filetype, ltype = gdialogs.GetImageHandlers(self.MapWindow.img)
- filetype = "BMP file (*.bmp)|*.bmp|"
- if 'gif' in lext:
- filetype += "GIF file (*.gif)|*.gif|"
- if 'jpg' in lext:
- filetype += "JPG file (*.jpg)|*.jpg|"
- if 'pcx' in lext:
- filetype += "PCX file (*.pcx)|*.pcx|"
- if 'png' in lext:
- filetype += "PNG file (*.png)|*.png|"
- if 'pnm' in lext:
- filetype += "PNM file (*.pnm)|*.pnm|"
- if 'tif' in lext:
- filetype += "TIF file (*.tif)|*.tif|"
- if 'xpm' in lext:
- filetype += "XPM file (*.xpm)|*.xpm"
- dlg = wx.FileDialog(self, _("Choose a file name to save the image (no need to add extension)"),
+ dlg = wx.FileDialog(parent = self,
+ message = _("Choose a file name to save the image (no need to add extension)"),
defaultDir = "",
defaultFile = "",
wildcard = filetype,
- style=wx.SAVE|wx.FD_OVERWRITE_PROMPT)
+ style=wx.SAVE | wx.FD_OVERWRITE_PROMPT)
path = dlg.GetPath()
- if path == None: return
- base = os.path.splitext(dlg.GetPath())[0]
- ext = os.path.splitext(dlg.GetPath())[1]
- if dlg.GetFilterIndex() == 0:
- type = wx.BITMAP_TYPE_BMP
- if ext != '.bmp': path = base+'.bmp'
- if dlg.GetFilterIndex() == 1:
- type = wx.BITMAP_TYPE_GIF
- if ext != '.gif': path = base+'.gif'
- elif dlg.GetFilterIndex() == 2:
- type = wx.BITMAP_TYPE_JPEG
- if ext != '.jpg': path = base+'.jpg'
- elif dlg.GetFilterIndex() == 3:
- if ext != '.pcx': path = base+'.pcx'
- elif dlg.GetFilterIndex() == 4:
- type = wx.BITMAP_TYPE_PNG
- if ext != '.png': path = base+'.png'
- elif dlg.GetFilterIndex() == 5:
- type = wx.BITMAP_TYPE_PNM
- if ext != '.pnm': path = base+'.pnm'
- elif dlg.GetFilterIndex() == 6:
- type = wx.BITMAP_TYPE_TIF
- if ext != '.tif': path = base+'.tif'
- elif dlg.GetFilterIndex() == 7:
- type = wx.BITMAP_TYPE_XPM
- if ext != '.xpm': path = base+'.xpm'
+ if not path:
+ dlg.Destroy()
+ return
+ base, ext = os.path.splitext(path)
+ fileType = ltype[dlg.GetFilterIndex()]['type']
+ extType = ltype[dlg.GetFilterIndex()]['ext']
+ if ext != extType:
+ path = base + '.' + extType
self.MapWindow.SaveToFile(path, type)
dlg.Destroy()
@@ -3837,8 +4177,7 @@
printmenu.Destroy()
def OnCloseWindow(self, event):
- Window closed.
+ """!Window closed.
Also close associated layer tree page
pgnum = None
@@ -3853,7 +4192,7 @@
if self.toolbars['nviz']:
self.toolbars['nviz'].OnExit()
if not self._layerManager:
self.Destroy()
elif self.page:
@@ -3862,11 +4201,14 @@
self.layerbook.DeletePage(pgnum)
def GetRender(self):
+ """!Returns current instance of render.Map()
- Returns the current instance of render.Map()
return self.Map
+ def GetWindow(self):
+ """!Get map window"""
+ return self.MapWindow
def OnQueryDisplay(self, event):
Query currrent raster/vector map layers (display mode)
@@ -4148,11 +4490,25 @@
str(color[2])
+ # icon used in vector display and its size
+ icon = ''
+ size = 0
+ vparam = self.tree.GetPyData(self.tree.layer_selected)[0]['cmd']
+ for p in vparam:
+ if '=' in p:
+ parg,pval = p.split('=')
+ if parg == 'icon': icon = pval
+ elif parg == 'size': size = int(pval)
pattern = ["d.vect",
"map=%s" % name,
"color=%s" % colorStr,
"fcolor=%s" % colorStr,
"width=%d" % UserSettings.Get(group='atm', key='highlight', subkey='width')]
+ if icon != '':
+ pattern.append('icon=%s' % icon)
+ if size > 0:
+ pattern.append('size=%i' % size)
if useId:
cmd = pattern
@@ -4278,7 +4634,7 @@
mstring = 'segment = %s %s\ttotal distance = %s %s' \
% (strdist,dunits,strtotdist,tdunits)
- self.gismanager.goutput.WriteLog(mstring)
+ self._layerManager.goutput.WriteLog(mstring)
return dist
@@ -4558,7 +4914,7 @@
def IsStandalone(self):
"""!Check if Map display is standalone"""
- if self.gismanager:
+ if self._layerManager:
return False
return True
@@ -4569,8 +4925,7 @@
@return window reference
@return None (if standalone)
- return self.gismanager
+ return self._layerManager
# end of class MapFrame
Modified: grass-addons/gui/wxpython/data_catalog/toolbars.py
--- grass-addons/gui/wxpython/data_catalog/toolbars.py 2010-04-25 07:47:36 UTC (rev 42028)
+++ grass-addons/gui/wxpython/data_catalog/toolbars.py 2010-04-25 10:45:29 UTC (rev 42029)
@@ -1,7 +1,7 @@
@package toolbar
- at brief Toolbars for Map Display window
+ at brief wxGUI toolbar widgets
Classes:
- AbstractToolbar
@@ -11,87 +11,85 @@
- VDigitToolbar
- ProfileToolbar
- NvizToolbar
+ - ModelToolbar
-(C) 2007-2008 by the GRASS Development Team This program is free
-software under the GNU General Public License (>=v2). Read the file
-COPYING that comes with GRASS for details.
+(C) 2007-2010 by the GRASS Development Team
+This program is free software under the GNU General Public License
+(>=v2). Read the file COPYING that comes with GRASS for details.
@author Michael Barton
@author Jachym Cepicky
@author Martin Landa <landa.martin gmail.com>
-import wx
-import os, sys
+import os
+import sys
import platform
+from grass.script import core as grass
+import wx
import globalvar
import gcmd
-version = os.getenv("GRASS_VERSION")
-if version == "6.4.0svn":
- import grassenv
import gdialogs
import vdigit
from vdigit import VDigitSettingsDialog as VDigitSettingsDialog
from debug import Debug as Debug
-from icon import Icons as Icons
from preferences import globalSettings as UserSettings
gmpath = os.path.join(globalvar.ETCWXDIR, "icons")
sys.path.append(gmpath)
+from icon import Icons as Icons
-class AbstractToolbar(object):
- """Abstract toolbar class"""
- def __init__(self):
- pass
+class AbstractToolbar(wx.ToolBar):
+ """!Abstract toolbar class"""
+ def __init__(self, parent):
+ self.parent = parent
+ wx.ToolBar.__init__(self, parent = self.parent, id = wx.ID_ANY)
- def InitToolbar(self, parent, toolbar, toolData):
- """Initialize toolbar, i.e. add tools to the toolbar
- @return list of ids (of added tools)
+ self.action = dict()
+ self.Bind(wx.EVT_TOOL, self.OnTool)
+ self.SetToolBitmapSize(globalvar.toolbarSize)
+ def InitToolbar(self, toolData):
+ """!Initialize toolbar, add tools to the toolbar
for tool in toolData:
- self.CreateTool(parent, toolbar, *tool)
- self._toolbar = toolbar
+ self.CreateTool(*tool)
self._data = toolData
- self.parent = parent
def ToolbarData(self):
- """Toolbar data"""
+ """!Toolbar data (virtual)"""
return None
- def CreateTool(self, parent, toolbar, tool, label, bitmap, kind,
+ def CreateTool(self, tool, label, bitmap, kind,
shortHelp, longHelp, handler):
- """Add tool to the toolbar
+ """!Add tool to the toolbar
@return id of tool
bmpDisabled=wx.NullBitmap
if label:
Debug.msg(3, "CreateTool(): tool=%d, label=%s bitmap=%s" % \
(tool, label, bitmap))
- toolWin = toolbar.AddLabelTool(tool, label, bitmap,
- bmpDisabled, kind,
- shortHelp, longHelp)
- parent.Bind(wx.EVT_TOOL, handler, toolWin)
- else: # add separator
- toolbar.AddSeparator()
+ toolWin = self.AddLabelTool(tool, label, bitmap,
+ bmpDisabled, kind,
+ shortHelp, longHelp)
+ self.Bind(wx.EVT_TOOL, handler, toolWin)
+ else: # separator
+ self.AddSeparator()
return tool
- def GetToolbar(self):
- """Get toolbar widget reference"""
- return self._toolbar
def EnableLongHelp(self, enable=True):
- """Enable/disable long help
+ """!Enable/disable long help
@param enable True for enable otherwise disable
for tool in self._data:
@@ -99,94 +97,109 @@
continue
if enable:
- self._toolbar.SetToolLongHelp(tool[0], tool[5])
+ self.SetToolLongHelp(tool[0], tool[5])
else:
- self._toolbar.SetToolLongHelp(tool[0], "")
+ self.SetToolLongHelp(tool[0], "")
def OnTool(self, event):
- """Tool selected"""
+ """!Tool selected"""
+ if self.parent.GetName() == "GCPFrame":
+ return
if self.parent.toolbars['vdigit']:
# update vdigit toolbar (unselect currently selected tool)
id = self.parent.toolbars['vdigit'].GetAction(type='id')
- self.parent.toolbars['vdigit'].GetToolbar().ToggleTool(id, False)
+ self.parent.toolbars['vdigit'].ToggleTool(id, False)
if event:
# deselect previously selected tool
id = self.action.get('id', -1)
if id != event.GetId():
- self._toolbar.ToggleTool(self.action['id'], False)
+ self.ToggleTool(self.action['id'], False)
else:
- self._toolbar.ToggleTool(self.action['id'], True)
+ self.ToggleTool(self.action['id'], True)
self.action['id'] = event.GetId()
event.Skip()
else:
# initialize toolbar
def GetAction(self, type='desc'):
- """Get current action info"""
+ """!Get current action info"""
return self.action.get(type, '')
def SelectDefault(self, event):
- """Select default tool"""
- self._toolbar.ToggleTool(self.defaultAction['id'], True)
+ """!Select default tool"""
+ self.ToggleTool(self.defaultAction['id'], True)
self.defaultAction['bind'](event)
self.action = { 'id' : self.defaultAction['id'],
'desc' : self.defaultAction.get('desc', '') }
def FixSize(self, width):
- """Fix toolbar width on Windows
+ """!Fix toolbar width on Windows
@todo Determine why combobox causes problems here
if platform.system() == 'Windows':
- size = self._toolbar.GetBestSize()
- self._toolbar.SetSize((size[0] + width, size[1]))
+ size = self.GetBestSize()
+ self.SetSize((size[0] + width, size[1]))
+ def Enable(self, tool, enable = True):
+ """!Enable defined tool
+ @param tool name
+ @param enable True to enable otherwise disable tool
+ try:
+ id = getattr(self, tool)
+ except AttributeError:
+ return
+ self.EnableTool(id, enable)
class MapToolbar(AbstractToolbar):
+ """!Map Display toolbar
- Main Map Display toolbar
+ def __init__(self, parent, mapcontent):
+ """!Map Display constructor
- def __init__(self, mapdisplay, map):
- AbstractToolbar.__init__(self)
- self.mapcontent = map
- self.mapdisplay = mapdisplay
- self.toolbar = wx.ToolBar(parent=self.mapdisplay, id=wx.ID_ANY)
- self.toolbar.SetToolBitmapSize(globalvar.toolbarSize)
- self.InitToolbar(self.mapdisplay, self.toolbar, self.ToolbarData())
+ @param parent reference to MapFrame
+ @param mapcontent reference to render.Map (registred by MapFrame)
+ self.mapcontent = mapcontent # render.Map
+ AbstractToolbar.__init__(self, parent = parent) # MapFrame
+ self.InitToolbar(self.ToolbarData())
# optional tools
- self.combo = wx.ComboBox(parent=self.toolbar, id=wx.ID_ANY, value=_('2D view'),
+ self.combo = wx.ComboBox(parent=self, id=wx.ID_ANY, value=_('2D view'),
choices=[_('2D view'), _('3D view'), _('Digitize')],
style=wx.CB_READONLY, size=(90, -1))
- self.comboid = self.toolbar.AddControl(self.combo)
- self.mapdisplay.Bind(wx.EVT_COMBOBOX, self.OnSelectTool, self.comboid)
+ self.comboid = self.AddControl(self.combo)
+ self.parent.Bind(wx.EVT_COMBOBOX, self.OnSelectTool, self.comboid)
# realize the toolbar
- self.toolbar.Realize()
+ self.Realize()
# workaround for Mac bug. May be fixed by 2.8.8, but not before then.
self.combo.Hide()
self.combo.Show()
- # default action
self.action = { 'id' : self.pointer }
self.defaultAction = { 'id' : self.pointer,
- 'bind' : self.mapdisplay.OnPointer }
+ 'bind' : self.parent.OnPointer }
self.OnTool(None)
+ self.EnableTool(self.zoomback, False)
self.FixSize(width = 90)
+ """!Toolbar data"""
self.displaymap = wx.NewId()
self.rendermap = wx.NewId()
self.erase = wx.NewId()
@@ -201,60 +214,60 @@
self.dec = wx.NewId()
self.savefile = wx.NewId()
self.printmap = wx.NewId()
# tool, label, bitmap, kind, shortHelp, longHelp, handler
return (
(self.displaymap, "displaymap", Icons["displaymap"].GetBitmap(),
wx.ITEM_NORMAL, Icons["displaymap"].GetLabel(), Icons["displaymap"].GetDesc(),
- self.mapdisplay.OnDraw),
+ self.parent.OnDraw),
(self.rendermap, "rendermap", Icons["rendermap"].GetBitmap(),
wx.ITEM_NORMAL, Icons["rendermap"].GetLabel(), Icons["rendermap"].GetDesc(),
- self.mapdisplay.OnRender),
+ self.parent.OnRender),
(self.erase, "erase", Icons["erase"].GetBitmap(),
wx.ITEM_NORMAL, Icons["erase"].GetLabel(), Icons["erase"].GetDesc(),
- self.mapdisplay.OnErase),
+ self.parent.OnErase),
(self.pointer, "pointer", Icons["pointer"].GetBitmap(),
wx.ITEM_CHECK, Icons["pointer"].GetLabel(), Icons["pointer"].GetDesc(),
- self.mapdisplay.OnPointer),
+ self.parent.OnPointer),
(self.query, "query", Icons["query"].GetBitmap(),
wx.ITEM_CHECK, Icons["query"].GetLabel(), Icons["query"].GetDesc(),
- self.mapdisplay.OnQuery),
+ self.parent.OnQuery),
(self.pan, "pan", Icons["pan"].GetBitmap(),
wx.ITEM_CHECK, Icons["pan"].GetLabel(), Icons["pan"].GetDesc(),
- self.mapdisplay.OnPan),
+ self.parent.OnPan),
(self.zoomin, "zoom_in", Icons["zoom_in"].GetBitmap(),
wx.ITEM_CHECK, Icons["zoom_in"].GetLabel(), Icons["zoom_in"].GetDesc(),
- self.mapdisplay.OnZoomIn),
+ self.parent.OnZoomIn),
(self.zoomout, "zoom_out", Icons["zoom_out"].GetBitmap(),
wx.ITEM_CHECK, Icons["zoom_out"].GetLabel(), Icons["zoom_out"].GetDesc(),
- self.mapdisplay.OnZoomOut),
+ self.parent.OnZoomOut),
(self.zoomback, "zoom_back", Icons["zoom_back"].GetBitmap(),
wx.ITEM_NORMAL, Icons["zoom_back"].GetLabel(), Icons["zoom_back"].GetDesc(),
- self.mapdisplay.OnZoomBack),
+ self.parent.OnZoomBack),
(self.zoommenu, "zoommenu", Icons["zoommenu"].GetBitmap(),
wx.ITEM_NORMAL, Icons["zoommenu"].GetLabel(), Icons["zoommenu"].GetDesc(),
- self.mapdisplay.OnZoomMenu),
+ self.parent.OnZoomMenu),
(self.analyze, "analyze", Icons["analyze"].GetBitmap(),
wx.ITEM_NORMAL, Icons["analyze"].GetLabel(), Icons["analyze"].GetDesc(),
- self.mapdisplay.OnAnalyze),
+ self.parent.OnAnalyze),
(self.dec, "overlay", Icons["overlay"].GetBitmap(),
wx.ITEM_NORMAL, Icons["overlay"].GetLabel(), Icons["overlay"].GetDesc(),
- self.mapdisplay.OnDecoration),
+ self.parent.OnDecoration),
(self.savefile, "savefile", Icons["savefile"].GetBitmap(),
wx.ITEM_NORMAL, Icons["savefile"].GetLabel(), Icons["savefile"].GetDesc(),
- self.mapdisplay.SaveToFile),
+ self.parent.SaveToFile),
(self.printmap, "printmap", Icons["printmap"].GetBitmap(),
wx.ITEM_NORMAL, Icons["printmap"].GetLabel(), Icons["printmap"].GetDesc(),
- self.mapdisplay.PrintMenu),
+ self.parent.PrintMenu),
def OnSelectTool(self, event):
Select / enable tool available in tools list
tool = event.GetSelection()
@@ -262,23 +275,24 @@
if tool == 0:
self.ExitToolbars()
self.Enable2D(True)
- elif tool == 1 and not self.mapdisplay.toolbars['nviz']:
+ elif tool == 1 and not self.parent.toolbars['nviz']:
self.ExitToolbars()
- self.mapdisplay.AddToolbar("nviz")
+ self.parent.AddToolbar("nviz")
- elif tool == 2 and not self.mapdisplay.toolbars['vdigit']:
+ elif tool == 2 and not self.parent.toolbars['vdigit']:
self.ExitToolbars()
- self.mapdisplay.AddToolbar("vdigit")
+ self.parent.AddToolbar("vdigit")
+ self.parent.MapWindow.SetFocus()
def ExitToolbars(self):
- if self.mapdisplay.toolbars['vdigit']:
- self.mapdisplay.toolbars['vdigit'].OnExit()
- if self.mapdisplay.toolbars['nviz']:
- self.mapdisplay.toolbars['nviz'].OnExit()
+ if self.parent.toolbars['vdigit']:
+ self.parent.toolbars['vdigit'].OnExit()
+ if self.parent.toolbars['nviz']:
+ self.parent.toolbars['nviz'].OnExit()
def Enable2D(self, enabled):
- """Enable/Disable 2D display mode specific tools"""
+ """!Enable/Disable 2D display mode specific tools"""
for tool in (self.pointer,
self.query,
self.pan,
@@ -290,30 +304,37 @@
self.dec,
self.savefile,
self.printmap):
- self.toolbar.EnableTool(tool, enabled)
+ self.EnableTool(tool, enabled)
class GRToolbar(AbstractToolbar):
- Georectification Display toolbar
+ Georectification toolbar
+ Georectification toolbar constructor
- # self.SetToolBar(self.toolbar)
+ AbstractToolbar.__init__(self, parent)
+ self.Realize()
+ self.action = { 'id' : self.gcpset }
+ self.defaultAction = { 'id' : self.gcpset,
+ self.OnTool(None)
@@ -323,68 +344,60 @@
self.zoomout = wx.NewId()
self.zoomback = wx.NewId()
self.zoomtomap = wx.NewId()
return (
(self.gcpset, "grGcpSet", Icons["grGcpSet"].GetBitmap(),
wx.ITEM_RADIO, Icons["grGcpSet"].GetLabel(), Icons["grGcpSet"].GetDesc(),
wx.ITEM_RADIO, Icons["pan"].GetLabel(), Icons["pan"].GetDesc(),
wx.ITEM_RADIO, Icons["zoom_in"].GetLabel(), Icons["zoom_in"].GetDesc(),
wx.ITEM_RADIO, Icons["zoom_out"].GetLabel(), Icons["zoom_out"].GetDesc(),
(self.zoomtomap, "zoomtomap", Icons["zoommenu"].GetBitmap(),
wx.ITEM_NORMAL, _("Zoom to map"), _("Zoom to displayed map"),
self.OnZoomMap),
def OnZoomMap(self, event):
- """Zoom to selected map"""
- layer = self.mapcontent.GetListOfLayers()[0]
- self.mapdisplay.MapWindow.ZoomToMap(layer=layer)
- event.Skip()
+ """!Zoom to selected map"""
+ self.parent.MapWindow.ZoomToMap(layers = self.mapcontent.GetListOfLayers())
+ if event:
+ event.Skip()
class GCPToolbar(AbstractToolbar):
Toolbar for managing ground control points during georectification
+ @param parent reference to GCP widget
- def __init__(self, parent, tbframe):
- self.parent = parent # GCP
- self.tbframe = tbframe
- self.toolbar = wx.ToolBar(parent=self.tbframe, id=wx.ID_ANY)
- self.InitToolbar(self.tbframe, self.toolbar, self.ToolbarData())
+ self.Realize()
self.gcpSave = wx.NewId()
self.gcpAdd = wx.NewId()
self.gcpDelete = wx.NewId()
@@ -432,38 +445,26 @@
Toolbar for digitization
- def __init__(self, parent, map, layerTree=None, log=None):
- self.mapcontent = map # Map class instance
- self.parent = parent # MapFrame
- self.layerTree = layerTree # reference to layer tree associated to map display
- self.log = log # log area
+ def __init__(self, parent, mapcontent, layerTree=None, log=None):
+ self.mapcontent = mapcontent # Map class instance
+ self.layerTree = layerTree # reference to layer tree associated to map display
+ self.log = log # log area
# currently selected map layer for editing (reference to MapLayer instance)
self.mapLayer = None
# list of vector layers from Layer Manager (only in the current mapset)
self.layers = []
self.comboid = None
# only one dialog can be open
self.settingsDialog = None
# create toolbars (two rows optionally)
- self.toolbar = []
- self.numOfRows = 1 # number of rows for toolbar
- for row in range(0, self.numOfRows):
- self.toolbar.append(wx.ToolBar(parent=self.parent, id=wx.ID_ANY))
- self.toolbar[row].SetToolBitmapSize(globalvar.toolbarSize)
- self.toolbar[row].Bind(wx.EVT_TOOL, self.OnTool)
- # create toolbar
- if self.numOfRows == 1:
- rowdata=None
- else:
- rowdata = row
- self.InitToolbar(self.parent, self.toolbar[row], self.ToolbarData(rowdata))
# default action (digitize new point, line, etc.)
self.action = { 'desc' : 'addLine',
'type' : 'point',
@@ -471,141 +472,135 @@
# list of available vector maps
self.UpdateListOfLayers(updateTool=True)
# realize toolbar
- self.toolbar[row].Realize()
- # workaround for Mac bug. May be fixed by 2.8.8, but not before then.
- self.combo.Hide()
- self.combo.Show()
+ self.Realize()
+ # workaround for Mac bug. May be fixed by 2.8.8, but not before then.
+ self.combo.Hide()
+ self.combo.Show()
# disable undo/redo
- self.toolbar[0].EnableTool(self.undo, False)
+ self.EnableTool(self.undo, False)
# toogle to pointer by default
self.OnTool(None)
self.FixSize(width = 105)
- def ToolbarData(self, row=None):
+ def ToolbarData(self):
Toolbar data
data = []
- if row is None or row == 0:
- self.addPoint = wx.NewId()
- self.addLine = wx.NewId()
- self.addBoundary = wx.NewId()
- self.addCentroid = wx.NewId()
- self.moveVertex = wx.NewId()
- self.addVertex = wx.NewId()
- self.removeVertex = wx.NewId()
- self.splitLine = wx.NewId()
- self.editLine = wx.NewId()
- self.moveLine = wx.NewId()
- self.deleteLine = wx.NewId()
- self.additionalTools = wx.NewId()
- self.displayCats = wx.NewId()
- self.displayAttr = wx.NewId()
- self.copyCats = wx.NewId()
- data = [("", "", "", "", "", "", ""),
- (self.addPoint, "digAddPoint", Icons["digAddPoint"].GetBitmap(),
- wx.ITEM_CHECK, Icons["digAddPoint"].GetLabel(), Icons["digAddPoint"].GetDesc(),
- self.OnAddPoint),
- (self.addLine, "digAddLine", Icons["digAddLine"].GetBitmap(),
- wx.ITEM_CHECK, Icons["digAddLine"].GetLabel(), Icons["digAddLine"].GetDesc(),
- self.OnAddLine),
- (self.addBoundary, "digAddBoundary", Icons["digAddBoundary"].GetBitmap(),
- wx.ITEM_CHECK, Icons["digAddBoundary"].GetLabel(), Icons["digAddBoundary"].GetDesc(),
- self.OnAddBoundary),
- (self.addCentroid, "digAddCentroid", Icons["digAddCentroid"].GetBitmap(),
- wx.ITEM_CHECK, Icons["digAddCentroid"].GetLabel(), Icons["digAddCentroid"].GetDesc(),
- self.OnAddCentroid),
- (self.moveVertex, "digMoveVertex", Icons["digMoveVertex"].GetBitmap(),
- wx.ITEM_CHECK, Icons["digMoveVertex"].GetLabel(), Icons["digMoveVertex"].GetDesc(),
- self.OnMoveVertex),
- (self.addVertex, "digAddVertex", Icons["digAddVertex"].GetBitmap(),
- wx.ITEM_CHECK, Icons["digAddVertex"].GetLabel(), Icons["digAddVertex"].GetDesc(),
- self.OnAddVertex),
- (self.removeVertex, "digRemoveVertex", Icons["digRemoveVertex"].GetBitmap(),
- wx.ITEM_CHECK, Icons["digRemoveVertex"].GetLabel(), Icons["digRemoveVertex"].GetDesc(),
- self.OnRemoveVertex),
- (self.splitLine, "digSplitLine", Icons["digSplitLine"].GetBitmap(),
- wx.ITEM_CHECK, Icons["digSplitLine"].GetLabel(), Icons["digSplitLine"].GetDesc(),
- self.OnSplitLine),
- (self.editLine, "digEditLine", Icons["digEditLine"].GetBitmap(),
- wx.ITEM_CHECK, Icons["digEditLine"].GetLabel(), Icons["digEditLine"].GetDesc(),
- self.OnEditLine),
- (self.moveLine, "digMoveLine", Icons["digMoveLine"].GetBitmap(),
- wx.ITEM_CHECK, Icons["digMoveLine"].GetLabel(), Icons["digMoveLine"].GetDesc(),
- self.OnMoveLine),
- (self.deleteLine, "digDeleteLine", Icons["digDeleteLine"].GetBitmap(),
- wx.ITEM_CHECK, Icons["digDeleteLine"].GetLabel(), Icons["digDeleteLine"].GetDesc(),
- self.OnDeleteLine),
- (self.displayCats, "digDispCats", Icons["digDispCats"].GetBitmap(),
- wx.ITEM_CHECK, Icons["digDispCats"].GetLabel(), Icons["digDispCats"].GetDesc(),
- self.OnDisplayCats),
- (self.copyCats, "digCopyCats", Icons["digCopyCats"].GetBitmap(),
- wx.ITEM_CHECK, Icons["digCopyCats"].GetLabel(), Icons["digCopyCats"].GetDesc(),
- self.OnCopyCA),
- (self.displayAttr, "digDispAttr", Icons["digDispAttr"].GetBitmap(),
- wx.ITEM_CHECK, Icons["digDispAttr"].GetLabel(), Icons["digDispAttr"].GetDesc(),
- self.OnDisplayAttr),
- (self.additionalTools, "digAdditionalTools", Icons["digAdditionalTools"].GetBitmap(),
- wx.ITEM_CHECK, Icons["digAdditionalTools"].GetLabel(),
- Icons["digAdditionalTools"].GetDesc(),
- self.OnAdditionalToolMenu)]
- if row is None or row == 1:
- self.undo = wx.NewId()
- self.settings = wx.NewId()
- self.exit = wx.NewId()
- data.append(("", "", "", "", "", "", ""))
- data.append((self.undo, "digUndo", Icons["digUndo"].GetBitmap(),
- wx.ITEM_NORMAL, Icons["digUndo"].GetLabel(), Icons["digUndo"].GetDesc(),
- self.OnUndo))
- # data.append((self.undo, "digRedo", Icons["digRedo"].GetBitmap(),
- # wx.ITEM_NORMAL, Icons["digRedo"].GetLabel(), Icons["digRedo"].GetDesc(),
- # self.OnRedo))
- data.append((self.settings, "digSettings", Icons["digSettings"].GetBitmap(),
- wx.ITEM_NORMAL, Icons["digSettings"].GetLabel(), Icons["digSettings"].GetDesc(),
- self.OnSettings))
- data.append((self.exit, "digExit", Icons["quit"].GetBitmap(),
- wx.ITEM_NORMAL, Icons["digExit"].GetLabel(), Icons["digExit"].GetDesc(),
- self.OnExit))
+ self.addPoint = wx.NewId()
+ self.addLine = wx.NewId()
+ self.addBoundary = wx.NewId()
+ self.addCentroid = wx.NewId()
+ self.moveVertex = wx.NewId()
+ self.addVertex = wx.NewId()
+ self.removeVertex = wx.NewId()
+ self.splitLine = wx.NewId()
+ self.editLine = wx.NewId()
+ self.moveLine = wx.NewId()
+ self.deleteLine = wx.NewId()
+ self.additionalTools = wx.NewId()
+ self.displayCats = wx.NewId()
+ self.displayAttr = wx.NewId()
+ self.copyCats = wx.NewId()
+ self.undo = wx.NewId()
+ self.settings = wx.NewId()
+ self.exit = wx.NewId()
+ data = [("", "", "", "", "", "", ""),
+ (self.addPoint, "digAddPoint", Icons["digAddPoint"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["digAddPoint"].GetLabel(), Icons["digAddPoint"].GetDesc(),
+ self.OnAddPoint),
+ (self.addLine, "digAddLine", Icons["digAddLine"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["digAddLine"].GetLabel(), Icons["digAddLine"].GetDesc(),
+ self.OnAddLine),
+ (self.addBoundary, "digAddBoundary", Icons["digAddBoundary"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["digAddBoundary"].GetLabel(), Icons["digAddBoundary"].GetDesc(),
+ self.OnAddBoundary),
+ (self.addCentroid, "digAddCentroid", Icons["digAddCentroid"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["digAddCentroid"].GetLabel(), Icons["digAddCentroid"].GetDesc(),
+ self.OnAddCentroid),
+ (self.moveVertex, "digMoveVertex", Icons["digMoveVertex"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["digMoveVertex"].GetLabel(), Icons["digMoveVertex"].GetDesc(),
+ self.OnMoveVertex),
+ (self.addVertex, "digAddVertex", Icons["digAddVertex"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["digAddVertex"].GetLabel(), Icons["digAddVertex"].GetDesc(),
+ self.OnAddVertex),
+ (self.removeVertex, "digRemoveVertex", Icons["digRemoveVertex"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["digRemoveVertex"].GetLabel(), Icons["digRemoveVertex"].GetDesc(),
+ self.OnRemoveVertex),
+ (self.splitLine, "digSplitLine", Icons["digSplitLine"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["digSplitLine"].GetLabel(), Icons["digSplitLine"].GetDesc(),
+ self.OnSplitLine),
+ (self.editLine, "digEditLine", Icons["digEditLine"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["digEditLine"].GetLabel(), Icons["digEditLine"].GetDesc(),
+ self.OnEditLine),
+ (self.moveLine, "digMoveLine", Icons["digMoveLine"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["digMoveLine"].GetLabel(), Icons["digMoveLine"].GetDesc(),
+ self.OnMoveLine),
+ (self.deleteLine, "digDeleteLine", Icons["digDeleteLine"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["digDeleteLine"].GetLabel(), Icons["digDeleteLine"].GetDesc(),
+ self.OnDeleteLine),
+ (self.displayCats, "digDispCats", Icons["digDispCats"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["digDispCats"].GetLabel(), Icons["digDispCats"].GetDesc(),
+ self.OnDisplayCats),
+ (self.copyCats, "digCopyCats", Icons["digCopyCats"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["digCopyCats"].GetLabel(), Icons["digCopyCats"].GetDesc(),
+ self.OnCopyCA),
+ (self.displayAttr, "digDispAttr", Icons["digDispAttr"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["digDispAttr"].GetLabel(), Icons["digDispAttr"].GetDesc(),
+ self.OnDisplayAttr),
+ (self.additionalTools, "digAdditionalTools", Icons["digAdditionalTools"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["digAdditionalTools"].GetLabel(),
+ Icons["digAdditionalTools"].GetDesc(),
+ self.OnAdditionalToolMenu),
+ (self.undo, "digUndo", Icons["digUndo"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["digUndo"].GetLabel(), Icons["digUndo"].GetDesc(),
+ self.OnUndo),
+ # data.append((self.undo, "digRedo", Icons["digRedo"].GetBitmap(),
+ # wx.ITEM_NORMAL, Icons["digRedo"].GetLabel(), Icons["digRedo"].GetDesc(),
+ # self.OnRedo))
+ (self.settings, "digSettings", Icons["digSettings"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["digSettings"].GetLabel(), Icons["digSettings"].GetDesc(),
+ self.OnSettings),
+ (self.exit, "digExit", Icons["quit"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["digExit"].GetLabel(), Icons["digExit"].GetDesc(),
+ self.OnExit)]
return data
- """Tool selected -> disable selected tool in map toolbar"""
- # update map toolbar (unselect currently selected tool)
+ """!Tool selected -> disable selected tool in map toolbar"""
id = self.parent.toolbars['map'].GetAction(type='id')
- self.parent.toolbars['map'].toolbar.ToggleTool(id, False)
+ self.parent.toolbars['map'].ToggleTool(id, False)
# set cursor
cursor = self.parent.cursors["cross"]
self.parent.MapWindow.SetCursor(cursor)
# pointer
self.parent.OnPointer(None)
if event:
- self.toolbar[0].ToggleTool(self.action['id'], False)
else:
- self.toolbar[0].ToggleTool(self.action['id'], True)
event.Skip()
- else:
- # initialize toolbar
# clear tmp canvas
if self.action['id'] != id:
self.parent.MapWindow.ClearLines(pdc=self.parent.MapWindow.pdcTmp)
@@ -614,25 +609,28 @@
# cancel action
self.parent.MapWindow.OnMiddleDown(None)
+ # set focus
def OnAddPoint(self, event):
- """Add point to the vector map Laier"""
+ """!Add point to the vector map Laier"""
Debug.msg (2, "VDigitToolbar.OnAddPoint()")
self.action = { 'desc' : "addLine",
'type' : "point",
'id' : self.addPoint }
self.parent.MapWindow.mouse['box'] = 'point'
def OnAddLine(self, event):
- """Add line to the vector map layer"""
+ """!Add line to the vector map layer"""
Debug.msg (2, "VDigitToolbar.OnAddLine()")
'type' : "line",
'id' : self.addLine }
self.parent.MapWindow.mouse['box'] = 'line'
### self.parent.MapWindow.polycoords = [] # reset temp line
def OnAddBoundary(self, event):
- """Add boundary to the vector map layer"""
+ """!Add boundary to the vector map layer"""
Debug.msg (2, "VDigitToolbar.OnAddBoundary()")
if self.action['desc'] != 'addLine' or \
self.action['type'] != 'boundary':
@@ -641,9 +639,9 @@
'type' : "boundary",
'id' : self.addBoundary }
def OnAddCentroid(self, event):
- """Add centroid to the vector map layer"""
+ """!Add centroid to the vector map layer"""
Debug.msg (2, "VDigitToolbar.OnAddCentroid()")
'type' : "centroid",
@@ -651,90 +649,88 @@
def OnExit (self, event=None):
- """Quit digitization tool"""
+ """!Quit digitization tool"""
# stop editing of the currently selected map layer
if self.mapLayer:
self.StopEditing()
# close dialogs if still open
if self.settingsDialog:
self.settingsDialog.OnCancel(None)
- # disable the toolbar
- self.parent.RemoveToolbar ("vdigit")
# set default mouse settings
self.parent.MapWindow.mouse['use'] = "pointer"
self.parent.MapWindow.mouse['box'] = "point"
+ # disable the toolbar
+ self.parent.RemoveToolbar("vdigit")
def OnMoveVertex(self, event):
- """Move line vertex"""
+ """!Move line vertex"""
Debug.msg(2, "Digittoolbar.OnMoveVertex():")
self.action = { 'desc' : "moveVertex",
'id' : self.moveVertex }
def OnAddVertex(self, event):
- """Add line vertex"""
+ """!Add line vertex"""
Debug.msg(2, "Digittoolbar.OnAddVertex():")
self.action = { 'desc' : "addVertex",
'id' : self.addVertex }
def OnRemoveVertex(self, event):
- """Remove line vertex"""
+ """!Remove line vertex"""
Debug.msg(2, "Digittoolbar.OnRemoveVertex():")
self.action = { 'desc' : "removeVertex",
'id' : self.removeVertex }
def OnSplitLine(self, event):
- """Split line"""
+ """!Split line"""
Debug.msg(2, "Digittoolbar.OnSplitLine():")
self.action = { 'desc' : "splitLine",
'id' : self.splitLine }
def OnEditLine(self, event):
- """Edit line"""
+ """!Edit line"""
Debug.msg(2, "Digittoolbar.OnEditLine():")
self.action = { 'desc' : "editLine",
'id' : self.editLine }
def OnMoveLine(self, event):
- """Move line"""
+ """!Move line"""
Debug.msg(2, "Digittoolbar.OnMoveLine():")
self.action = { 'desc' : "moveLine",
'id' : self.moveLine }
self.parent.MapWindow.mouse['box'] = 'box'
def OnDeleteLine(self, event):
- """Delete line"""
+ """!Delete line"""
Debug.msg(2, "Digittoolbar.OnDeleteLine():")
self.action = { 'desc' : "deleteLine",
'id' : self.deleteLine }
def OnDisplayCats(self, event):
- """Display/update categories"""
+ """!Display/update categories"""
Debug.msg(2, "Digittoolbar.OnDisplayCats():")
self.action = { 'desc' : "displayCats",
'id' : self.displayCats }
def OnDisplayAttr(self, event):
- """Display/update attributes"""
+ """!Display/update attributes"""
Debug.msg(2, "Digittoolbar.OnDisplayAttr():")
self.action = { 'desc' : "displayAttrs",
'id' : self.displayAttr }
def OnCopyCA(self, event):
- """Copy categories/attributes menu"""
+ """!Copy categories/attributes menu"""
point = wx.GetMousePosition()
toolMenu = wx.Menu()
# Add items to the menu
@@ -745,7 +741,7 @@
self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnCopyCats, cats)
if self.action['desc'] == "copyCats":
cats.Check(True)
attrb = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
text=_('Duplicate attributes'),
kind=wx.ITEM_CHECK)
@@ -753,20 +749,20 @@
self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnCopyAttrb, attrb)
if self.action['desc'] == "copyAttrs":
attrb.Check(True)
# Popup the menu. If an item is selected then its handler
# will be called before PopupMenu returns.
self.parent.MapWindow.PopupMenu(toolMenu)
toolMenu.Destroy()
if self.action['desc'] == "addPoint":
- self.toolbar[0].ToggleTool(self.copyCats, False)
+ self.ToggleTool(self.copyCats, False)
def OnCopyCats(self, event):
- """Copy categories"""
+ """!Copy categories"""
if self.action['desc'] == 'copyCats': # select previous action
- self.toolbar[0].ToggleTool(self.addPoint, True)
+ self.ToggleTool(self.addPoint, True)
self.OnAddPoint(event)
return
@@ -777,8 +773,8 @@
def OnCopyAttrb(self, event):
if self.action['desc'] == 'copyAttrs': # select previous action
return
@@ -788,38 +784,40 @@
def OnUndo(self, event):
- """Undo previous changes"""
+ """!Undo previous changes"""
self.parent.digit.Undo()
event.Skip()
def EnableUndo(self, enable=True):
- """Enable 'Undo' in toolbar
+ """!Enable 'Undo' in toolbar
@param enable False for disable
if enable:
- if self.toolbar[0].GetToolEnabled(self.undo) is False:
- self.toolbar[0].EnableTool(self.undo, True)
+ if self.GetToolEnabled(self.undo) is False:
+ self.EnableTool(self.undo, True)
else:
- if self.toolbar[0].GetToolEnabled(self.undo) is True:
+ if self.GetToolEnabled(self.undo) is True:
def OnSettings(self, event):
- """Show settings dialog"""
+ """!Show settings dialog"""
if self.parent.digit is None:
reload(vdigit)
- from vdigit import Digit as Digit
- self.parent.digit = Digit(mapwindow=self.parent.MapWindow)
+ from vdigit import VDigit as VDigit
+ try:
+ self.parent.digit = VDigit(mapwindow=self.parent.MapWindow)
+ except SystemExit:
+ self.parent.digit = None
if not self.settingsDialog:
self.settingsDialog = VDigitSettingsDialog(parent=self.parent, title=_("Digitization settings"),
style=wx.DEFAULT_DIALOG_STYLE)
self.settingsDialog.Show()
def OnAdditionalToolMenu(self, event):
- """Menu for additional tools"""
+ """!Menu for additional tools"""
@@ -830,7 +828,7 @@
self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnCopy, copy)
if self.action['desc'] == "copyLine":
copy.Check(True)
flip = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
text=_('Flip selected lines/boundaries'),
kind=wx.ITEM_CHECK)
@@ -838,7 +836,7 @@
self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnFlip, flip)
if self.action['desc'] == "flipLine":
flip.Check(True)
merge = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
text=_('Merge selected lines/boundaries'),
kind=wx.ITEM_CHECK)
@@ -846,7 +844,7 @@
self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnMerge, merge)
if self.action['desc'] == "mergeLine":
merge.Check(True)
breakL = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
text=_('Break selected lines/boundaries at intersection'),
kind=wx.ITEM_CHECK)
@@ -854,7 +852,7 @@
self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnBreak, breakL)
if self.action['desc'] == "breakLine":
breakL.Check(True)
snap = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
text=_('Snap selected lines/boundaries (only to nodes)'),
kind=wx.ITEM_CHECK)
@@ -862,7 +860,7 @@
self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnSnap, snap)
if self.action['desc'] == "snapLine":
snap.Check(True)
connect = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
text=_('Connect selected lines/boundaries'),
kind=wx.ITEM_CHECK)
@@ -870,7 +868,7 @@
self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnConnect, connect)
if self.action['desc'] == "connectLine":
connect.Check(True)
query = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
text=_('Query features'),
kind=wx.ITEM_CHECK)
@@ -878,7 +876,7 @@
self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnQuery, query)
if self.action['desc'] == "queryLine":
query.Check(True)
zbulk = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
text=_('Z bulk-labeling of 3D lines'),
kind=wx.ITEM_CHECK)
@@ -886,7 +884,7 @@
self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnZBulk, zbulk)
if self.action['desc'] == "zbulkLine":
zbulk.Check(True)
typeconv = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
text=_('Feature type conversion'),
kind=wx.ITEM_CHECK)
@@ -894,20 +892,20 @@
self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnTypeConversion, typeconv)
if self.action['desc'] == "typeConv":
typeconv.Check(True)
toolMenu.Destroy()
if self.action['desc'] == 'addPoint':
- self.toolbar[0].ToggleTool(self.additionalTools, False)
+ self.ToggleTool(self.additionalTools, False)
def OnCopy(self, event):
- """Copy selected features from (background) vector map"""
+ """!Copy selected features from (background) vector map"""
if self.action['desc'] == 'copyLine': # select previous action
return
@@ -917,10 +915,10 @@
def OnFlip(self, event):
- """Flip selected lines/boundaries"""
+ """!Flip selected lines/boundaries"""
if self.action['desc'] == 'flipLine': # select previous action
return
@@ -930,10 +928,10 @@
def OnMerge(self, event):
- """Merge selected lines/boundaries"""
+ """!Merge selected lines/boundaries"""
if self.action['desc'] == 'mergeLine': # select previous action
return
@@ -943,10 +941,10 @@
def OnBreak(self, event):
- """Break selected lines/boundaries"""
+ """!Break selected lines/boundaries"""
if self.action['desc'] == 'breakLine': # select previous action
return
@@ -956,10 +954,10 @@
def OnSnap(self, event):
- """Snap selected features"""
+ """!Snap selected features"""
if self.action['desc'] == 'snapLine': # select previous action
return
@@ -969,10 +967,10 @@
def OnConnect(self, event):
- """Connect selected lines/boundaries"""
+ """!Connect selected lines/boundaries"""
if self.action['desc'] == 'connectLine': # select previous action
return
@@ -982,10 +980,10 @@
def OnQuery(self, event):
- """Query selected lines/boundaries"""
+ """!Query selected lines/boundaries"""
if self.action['desc'] == 'queryLine': # select previous action
return
@@ -996,7 +994,7 @@
def OnZBulk(self, event):
- """Z bulk-labeling selected lines/boundaries"""
+ """!Z bulk-labeling selected lines/boundaries"""
if not self.parent.digit.driver.Is3D():
wx.MessageBox(parent=self.parent,
message=_("Vector map is not 3D. Operation canceled."),
@@ -1004,8 +1002,8 @@
return
if self.action['desc'] == 'zbulkLine': # select previous action
return
@@ -1015,15 +1013,15 @@
def OnTypeConversion(self, event):
- """Feature type conversion
+ """!Feature type conversion
Supported conversions:
- point <-> centroid
- line <-> boundary
if self.action['desc'] == 'typeConv': # select previous action
return
@@ -1046,8 +1044,10 @@
else:
openVectorMap = None
mapName = gdialogs.CreateNewVector(self.parent,
- exceptMap=openVectorMap, log=self.log,
- cmdDef=(['v.edit', 'tool=create'], "map"),
+ exceptMap = openVectorMap, log = self.log,
+ cmd = (('v.edit',
+ { 'tool' : 'create' },
+ 'map')),
disableAdd=True)[0]
if mapName:
# add layer to map layer tree
@@ -1067,18 +1067,18 @@
return
else:
selection = event.GetSelection() - 1 # first option is 'New vector map'
# skip currently selected map
if self.layers[selection] == self.mapLayer:
return False
if self.mapLayer:
# deactive map layer for editing
self.StopEditing()
# select the given map layer for editing
self.StartEditing(self.layers[selection])
event.Skip()
return True
@@ -1091,33 +1091,41 @@
# deactive layer
self.mapcontent.ChangeLayerActive(mapLayer, False)
# clean map canvas
### self.parent.MapWindow.EraseMap()
# unset background map if needed
- subkey='value', internal=True) == mapLayer.GetName():
- UserSettings.Set(group='vdigit', key='bgmap',
- subkey='value', value='', internal=True)
+ if mapLayer:
+ if UserSettings.Get(group='vdigit', key='bgmap',
+ subkey='value', internal=True) == mapLayer.GetName():
+ UserSettings.Set(group='vdigit', key='bgmap',
+ subkey='value', value='', internal=True)
+ self.parent.statusbar.SetStatusText(_("Please wait, "
+ "opening vector map <%s> for editing...") % \
+ mapLayer.GetName(),
+ 0)
- self.parent.statusbar.SetStatusText(_("Please wait, "
- "opening vector map <%s> for editing...") % \
- mapLayer.GetName(),
- 0)
# reload vdigit module
reload(vdigit)
+ # use vdigit's PseudoDC
+ self.parent.MapWindow.DefinePseudoDC(vdigit = True)
self.mapLayer = mapLayer
# open vector map
try:
+ if not self.parent.MapWindow.CheckPseudoDC():
+ raise gcmd.DigitError(parent=self.parent,
+ message=_("Unable to initialize display driver of vector "
+ "digitizer. See 'Command output' for details."))
self.parent.digit.SetMapName(mapLayer.GetName())
except gcmd.DigitError, e:
+ self.StopEditing()
print >> sys.stderr, e # wxMessageBox
return False
@@ -1137,7 +1145,7 @@
if not self.parent.MapWindow.resize:
self.parent.MapWindow.UpdateMap(render=True)
opacity = mapLayer.GetOpacity(float=True)
if opacity < 1.0:
alpha = int(opacity * 255)
@@ -1145,50 +1153,51 @@
return True
- def StopEditing (self):
- """Stop editing of selected vector map layer.
+ def StopEditing(self):
+ """!Stop editing of selected vector map layer.
@return True on success
@return False on failure
- if not self.mapLayer:
- return False
+ # use wx's PseudoDC
+ self.parent.MapWindow.DefinePseudoDC(vdigit = False)
- Debug.msg (4, "VDigitToolbar.StopEditing(): layer=%s" % self.mapLayer.GetName())
self.combo.SetValue (_('Select vector map'))
# save changes
- if UserSettings.Get(group='vdigit', key='saveOnExit', subkey='enabled') is False:
- if self.parent.digit.GetUndoLevel() > 0:
- dlg = wx.MessageDialog(parent=self.parent,
- message=_("Do you want to save changes "
- "in vector map <%s>?") % self.mapLayer.GetName(),
- caption=_("Save changes?"),
- style=wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
- if dlg.ShowModal() == wx.ID_NO:
- # revert changes
- self.parent.digit.Undo(0)
- dlg.Destroy()
+ if self.mapLayer:
+ Debug.msg (4, "VDigitToolbar.StopEditing(): layer=%s" % self.mapLayer.GetName())
+ if UserSettings.Get(group='vdigit', key='saveOnExit', subkey='enabled') is False:
+ if self.parent.digit.GetUndoLevel() > -1:
+ dlg = wx.MessageDialog(parent=self.parent,
+ message=_("Do you want to save changes "
+ "in vector map <%s>?") % self.mapLayer.GetName(),
+ caption=_("Save changes?"),
+ style=wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
+ if dlg.ShowModal() == wx.ID_NO:
+ # revert changes
+ self.parent.digit.Undo(0)
+ dlg.Destroy()
+ "closing and rebuilding topology of "
+ "vector map <%s>...") % self.mapLayer.GetName(),
+ 0)
- "closing and rebuilding topology of "
- "vector map <%s>...") % self.mapLayer.GetName(),
- 0)
+ self.parent.digit.SetMapName(None) # -> close map
- self.parent.digit.SetMapName(None) # -> close map
+ # re-active layer
+ item = self.parent.tree.FindItemByData('maplayer', self.mapLayer)
+ if item and self.parent.tree.IsItemChecked(item):
+ self.mapcontent.ChangeLayerActive(self.mapLayer, True)
- # re-active layer
- item = self.parent.tree.FindItemByData('maplayer', self.mapLayer)
- if item and self.parent.tree.IsItemChecked(item):
- self.mapcontent.ChangeLayerActive(self.mapLayer, True)
# change cursor
self.parent.MapWindow.SetCursor(self.parent.cursors["default"])
# disable pseudodc for vector map layer
self.parent.MapWindow.pdcVector = None
self.parent.digit.driver.SetDevice(None)
# close dialogs
for dialog in ('attributes', 'category'):
if self.parent.dialogs[dialog]:
@@ -1205,29 +1214,28 @@
return True
def UpdateListOfLayers (self, updateTool=False):
Update list of available vector map layers.
This list consists only editable layers (in the current mapset)
Optionally also update toolbar
Debug.msg (4, "VDigitToolbar.UpdateListOfLayers(): updateTool=%d" % \
updateTool)
layerNameSelected = None
# name of currently selected layer
if self.mapLayer:
layerNameSelected = self.mapLayer.GetName()
# select vector map layer in the current mapset
layerNameList = []
self.layers = self.mapcontent.GetListOfLayers(l_type="vector",
- l_mapset=grassenv.GetGRASSVariable('MAPSET'))
+ l_mapset=grass.gisenv()['MAPSET'])
for layer in self.layers:
if not layer.name in layerNameList: # do not duplicate layer
layerNameList.append (layer.GetName())
if updateTool: # update toolbar
value = _('Select vector map')
@@ -1235,43 +1243,36 @@
value = layerNameSelected
if not self.comboid:
- self.combo = wx.ComboBox(self.toolbar[self.numOfRows-1], id=wx.ID_ANY, value=value,
- choices=[_('New vector map'), ] + layerNameList, size=(85, -1),
+ self.combo = wx.ComboBox(self, id=wx.ID_ANY, value=value,
+ choices=[_('New vector map'), ] + layerNameList, size=(115, -1),
style=wx.CB_READONLY)
- self.comboid = self.toolbar[self.numOfRows-1].InsertControl(0, self.combo)
+ self.comboid = self.InsertControl(0, self.combo)
self.parent.Bind(wx.EVT_COMBOBOX, self.OnSelectMap, self.comboid)
else:
self.combo.SetItems([_('New vector map'), ] + layerNameList)
- self.toolbar[self.numOfRows-1].Realize()
+ self.Realize()
return layerNameList
def GetLayer(self):
- """Get selected layer for editing -- MapLayer instance"""
+ """!Get selected layer for editing -- MapLayer instance"""
return self.mapLayer
class ProfileToolbar(AbstractToolbar):
Toolbar for profiling raster map
+ self.Realize()
self.transect = wx.NewId()
self.addraster = wx.NewId()
self.draw = wx.NewId()
@@ -1323,29 +1324,23 @@
class NvizToolbar(AbstractToolbar):
Nviz toolbar
- def __init__(self, parent, map):
- self.toolbar = wx.ToolBar(parent=self.parent, id=wx.ID_ANY)
- self.InitToolbar(self.parent, self.toolbar, self.ToolbarData())
+ self.Realize()
self.quit = wx.NewId()
return (
(self.settings, "settings", Icons["nvizSettings"].GetBitmap(),
@@ -1355,7 +1350,7 @@
wx.ITEM_NORMAL, Icons["quit"].GetLabel(), Icons["quit"].GetDesc(),
self.OnExit),
win = self.parent.nvizToolWin
if not win.IsShown():
@@ -1364,17 +1359,82 @@
self.parent.nvizToolWin.Hide()
- """Quit nviz tool (swith to 2D mode)"""
+ """!Quit nviz tool (swith to 2D mode)"""
# hide dialogs if still open
if self.parent.nvizToolWin:
- self.parent.RemoveToolbar ("nviz")
+ self.parent.RemoveToolbar("nviz")
+class ModelToolbar(AbstractToolbar):
+ """!Graphical modeler toolbar (see gmodeler.py)
+ # realize the toolbar
+ self.Realize()
+ self.new = wx.NewId()
+ self.open = wx.NewId()
+ self.save = wx.NewId()
+ self.image = wx.NewId()
+ self.python = wx.NewId()
+ self.action = wx.NewId()
+ self.data = wx.NewId()
+ self.relation = wx.NewId()
+ self.run = wx.NewId()
+ self.validate = wx.NewId()
+ self.quit = wx.NewId()
+ # tool, label, bitmap, kind, shortHelp, longHelp, handler
+ return (
+ (self.new, 'new', Icons['modelNew'].GetBitmap(),
+ wx.ITEM_NORMAL, Icons['modelNew'].GetLabel(), Icons['modelNew'].GetDesc(),
+ self.parent.OnModelNew),
+ (self.open, 'open', Icons['modelOpen'].GetBitmap(),
+ wx.ITEM_NORMAL, Icons['modelOpen'].GetLabel(), Icons['modelOpen'].GetDesc(),
+ self.parent.OnModelOpen),
+ (self.save, 'save', Icons['modelSave'].GetBitmap(),
+ wx.ITEM_NORMAL, Icons['modelSave'].GetLabel(), Icons['modelSave'].GetDesc(),
+ self.parent.OnModelSave),
+ (self.image, 'image', Icons['modelToImage'].GetBitmap(),
+ wx.ITEM_NORMAL, Icons['modelToImage'].GetLabel(), Icons['modelToImage'].GetDesc(),
+ self.parent.OnExportImage),
+ (self.python, 'python', Icons['modelToPython'].GetBitmap(),
+ wx.ITEM_NORMAL, Icons['modelToPython'].GetLabel(), Icons['modelToPython'].GetDesc(),
+ self.parent.OnExportPython),
+ (self.data, 'data', Icons['modelDataAdd'].GetBitmap(),
+ wx.ITEM_NORMAL, Icons['modelDataAdd'].GetLabel(), Icons['modelDataAdd'].GetDesc(),
+ self.parent.OnAddData),
+ (self.action, 'action', Icons['modelActionAdd'].GetBitmap(),
+ wx.ITEM_NORMAL, Icons['modelActionAdd'].GetLabel(), Icons['modelActionAdd'].GetDesc(),
+ self.parent.OnAddAction),
+ (self.relation, 'relation', Icons['modelRelation'].GetBitmap(),
+ wx.ITEM_NORMAL, Icons['modelRelation'].GetLabel(), Icons['modelRelation'].GetDesc(),
+ self.parent.OnDefineRelation),
+ (self.run, 'run', Icons['modelRun'].GetBitmap(),
+ wx.ITEM_NORMAL, Icons['modelRun'].GetLabel(), Icons['modelRun'].GetDesc(),
+ self.parent.OnRunModel),
+ (self.validate, 'validate', Icons['modelValidate'].GetBitmap(),
+ wx.ITEM_NORMAL, Icons['modelValidate'].GetLabel(), Icons['modelValidate'].GetDesc(),
+ self.parent.OnValidateModel),
+ (self.quit, 'quit', Icons['quit'].GetBitmap(),
+ wx.ITEM_NORMAL, Icons['quit'].GetLabel(), Icons['quit'].GetDesc(),
+ self.parent.OnCloseWindow),
