[GRASS-SVN] r42033 - in grass/branches/develbranch_6/gui/wxpython:
. gui_modules
svn_grass at osgeo.org
Mon Apr 26 13:07:11 EDT 2010
Author: martinl
Date: 2010-04-26 13:07:10 -0400 (Mon, 26 Apr 2010)
New Revision: 42033
grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
grass/branches/develbranch_6/gui/wxpython/wxgui.py
wxGUI: GdalSelect class implemented
(merge r42032 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py 2010-04-26 16:41:52 UTC (rev 42032)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py 2010-04-26 17:07:10 UTC (rev 42033)
@@ -12,7 +12,9 @@
- DecorationDialog
- TextLayerDialog
- LoadMapLayersDialog
- - MultiImportDialog
+ - ImportDialog
+ - GdalImportDialog
+ - DxfImportDialog
- LayersList (used by MultiImport)
- SetOpacityDialog
@@ -28,7 +30,6 @@
import os
import sys
import re
-import glob
import wx
import wx.lib.filebrowsebutton as filebrowse
@@ -925,155 +926,36 @@
"""!Get selected layer type"""
return self.layerType.GetStringSelection()
-class MultiImportDialog(wx.Dialog):
- """!Import dxf layers"""
+class ImportDialog(wx.Dialog):
+ """!Dialog for bulk import of various data (base class)"""
def __init__(self, parent, type,
- id=wx.ID_ANY, title=_("Multiple import"),
- link = False,
- style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
+ id = wx.ID_ANY, title = _("Multiple import"),
+ style = wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
self.parent = parent # GMFrame
self.importType = type
- self.link = link # Link or import data (only for GDAL/OGR)
self.commandId = -1 # id of running command
- wx.Dialog.__init__(self, parent, id, title, style=style)
- self.panel = wx.Panel(parent=self, id=wx.ID_ANY)
- self.inputTitle = _("Source name")
+ wx.Dialog.__init__(self, parent, id, title, style=style,
+ name = "MultiImportDialog")
- self.inputBox = wx.StaticBox(parent=self.panel, id=wx.ID_ANY,
- label=" %s " % self.inputTitle)
+ self.panel = wx.Panel(parent=self, id=wx.ID_ANY)
self.layerBox = wx.StaticBox(parent=self.panel, id=wx.ID_ANY,
label=_(" List of %s layers ") % self.importType.upper())
- # input
- if self.importType == 'dxf':
- inputFile = filebrowse.FileBrowseButton(parent=self.panel, id=wx.ID_ANY,
- size=globalvar.DIALOG_GSELECT_SIZE, labelText='',
- dialogTitle=_('Choose DXF file to import'),
- buttonText=_('Browse'),
- startDirectory=os.getcwd(), fileMode=0,
- changeCallback=self.OnSetInput,
- fileMask="DXF File (*.dxf)|*.dxf")
- self.input = { 'file' : [_("DXF file:"),
- inputFile,
- list()] }
- self.inputType = 'file'
- else:
- self.typeRadio = wx.RadioBox(parent = self.panel, id = wx.ID_ANY,
- label = _('Source type'),
- style = wx.RA_SPECIFY_COLS,
- choices = [_("File"),
- _("Directory"),
- _("Database"),
- _("Protocol")])
- self.typeRadio.SetSelection(0)
- self.Bind(wx.EVT_RADIOBOX, self.OnChangeType)
- # input widgets
- if self.importType == 'gdal':
- filemask = 'GeoTIFF (*.tif)|*.tif'
- else:
- filemask = 'ESRI Shapefile (*.shp)|*.shp'
- dialogTitle=_('Choose input file'),
- fileMask=filemask)
- inputDir = filebrowse.DirBrowseButton(parent=self.panel, id=wx.ID_ANY,
- dialogTitle=_('Choose input directory'),
- changeCallback=self.OnSetInput)
- inputDir.Hide()
- inputDbFile = filebrowse.FileBrowseButton(parent=self.panel, id=wx.ID_ANY,
- dialogTitle=_('Choose file'),
- inputDbFile.Hide()
- inputDbText = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY)
- inputDbText.Hide()
- inputDbText.Bind(wx.EVT_TEXT, self.OnSetInput)
- inputDbChoice = wx.Choice(parent = self.panel, id = wx.ID_ANY)
- inputDbChoice.Hide()
- inputDbChoice.Bind(wx.EVT_CHOICE, self.OnSetInput)
- inputPro = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY)
- inputPro.Hide()
- inputPro.Bind(wx.EVT_TEXT, self.OnSetInput)
- # format widget
- self.formatText = wx.StaticText(self.panel, id=wx.ID_ANY, label=_("Format:"))
- self.format = gselect.FormatSelect(parent = self.panel,
- ftype = self.importType)
- self.format.Bind(wx.EVT_CHOICE, self.OnSetFormat)
- self.input = { 'file' : [_("File:"),
- inputFile,
- globalvar.formats[self.importType]['file']],
- 'dir' : [_("Directory:"),
- inputDir,
- 'db' : [_("Database:"),
- inputDbFile,
- globalvar.formats[self.importType]['database']],
- 'pro' : [_("Protocol:"),
- inputPro,
- globalvar.formats[self.importType]['protocol']],
- 'db-win' : { 'file' : inputDbFile,
- 'text' : inputDbText,
- 'choice' : inputDbChoice },
- self.format.SetItems(self.input[self.inputType][2])
- self.format.SetStringSelection('GeoTIFF')
- elif self.importType == 'ogr':
- self.format.SetStringSelection('ESRI Shapefile')
- self.inputText = wx.StaticText(parent = self.panel, id = wx.ID_ANY,
- label = self.input[self.inputType][0],
- size = (75, -1))
# list of layers
self.list = LayersList(self.panel)
self.list.LoadData()
- self.add = wx.CheckBox(parent=self.panel, id=wx.ID_ANY)
- if link:
- self.add.SetLabel(_("Add linked layers into layer tree"))
- else:
- self.add.SetLabel(_("Add imported layers into layer tree"))
- if not link and self.importType in ('gdal', 'ogr'):
- self.overrideCheck = wx.CheckBox(parent=self.panel, id=wx.ID_ANY,
- label=_("Override projection (use location's projection)"))
- self.overrideCheck.SetValue(True)
- self.add.SetValue(UserSettings.Get(group='cmd', key='addNewLayer', subkey='enabled'))
self.overwrite = wx.CheckBox(parent=self.panel, id=wx.ID_ANY,
label=_("Allow output files to overwrite existing files"))
self.overwrite.SetValue(UserSettings.Get(group='cmd', key='overwrite', subkey='enabled'))
+ self.add = wx.CheckBox(parent=self.panel, id=wx.ID_ANY)
# buttons
@@ -1082,52 +964,19 @@
self.btn_cancel.SetToolTipString(_("Close dialog"))
self.btn_cancel.Bind(wx.EVT_BUTTON, self.OnCancel)
# run
- if link:
- self.btn_run = wx.Button(parent=self.panel, id=wx.ID_OK, label= _("&Link"))
- self.btn_run.SetToolTipString(_("Link selected layers"))
- else:
- self.btn_run = wx.Button(parent=self.panel, id=wx.ID_OK, label= _("&Import"))
- self.btn_run.SetToolTipString(_("Import selected layers"))
+ self.btn_run = wx.Button(parent=self.panel, id=wx.ID_OK)
self.btn_run.SetDefault()
self.btn_run.Enable(False)
self.btn_run.Bind(wx.EVT_BUTTON, self.OnRun)
- self.__doLayout()
- self.Layout()
- def __doLayout(self):
+ def doLayout(self):
+ """!Do layout"""
dialogSizer = wx.BoxSizer(wx.VERTICAL)
- # input
- inputSizer = wx.StaticBoxSizer(self.inputBox, wx.HORIZONTAL)
- gridSizer = wx.FlexGridSizer(cols=2, vgap=5, hgap=5)
- gridSizer.Add(item=self.inputText,
- flag=wx.ALIGN_CENTER_VERTICAL)
- gridSizer.AddGrowableCol(1)
- self.inputTypeSizer = wx.BoxSizer(wx.HORIZONTAL)
- self.inputTypeSizer.Add(item=self.input[self.inputType][1], proportion = 1,
- flag = wx.ALIGN_CENTER_VERTICAL)
+ # dsn input
+ dialogSizer.Add(item = self.dsnInput, proportion = 0,
+ flag = wx.EXPAND)
- gridSizer.Add(item=self.inputTypeSizer,
- flag=wx.EXPAND | wx.ALL)
- if self.importType != 'dxf':
- gridSizer.Add(item=self.formatText,
- gridSizer.Add(item=self.format)
- inputSizer.Add(item=gridSizer, proportion=1,
- dialogSizer.Add(item=self.typeRadio, proportion=0,
- flag=wx.ALL | wx.EXPAND, border=5)
- dialogSizer.Add(item=inputSizer, proportion=0,
# list of DXF layers
@@ -1138,17 +987,17 @@
dialogSizer.Add(item=layerSizer, proportion=1,
flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border=5)
if hasattr(self, "overrideCheck"):
dialogSizer.Add(item=self.overrideCheck, proportion=0,
dialogSizer.Add(item=self.overwrite, proportion=0,
dialogSizer.Add(item=self.add, proportion=0,
# buttons
@@ -1170,64 +1019,101 @@
self.panel.SetSizer(dialogSizer)
dialogSizer.Fit(self.panel)
- self.Layout()
# auto-layout seems not work here - FIXME
size = wx.Size(globalvar.DIALOG_GSELECT_SIZE[0] + 175, 400)
self.SetMinSize(size)
self.SetSize((size.width, size.height + 100))
width = self.GetSize()[0]
self.list.SetColumnWidth(col=1, width=width/2 - 50)
+ self.Layout()
- def OnChangeType(self, event):
- """!Datasource type changed"""
- sel = event.GetSelection()
- win = self.input[self.inputType][1]
- self.inputTypeSizer.Remove(win)
- win.Hide()
+ def OnCancel(self, event=None):
+ """!Close dialog"""
+ self.Close()
+ def OnRun(self, event):
+ """!Import/Link data (each layes as separate vector map)"""
+ pass
+ def AddLayers(self, returncode):
+ """!Add imported/linked layers into layer tree"""
+ self.commandId += 1
- if sel == 0: # file
- format = self.input[self.inputType][2][0]
- try:
- ext = self.format.GetExtension(format)
- if not ext:
- raise KeyError
- format += ' (*.%s)|*.%s' % (ext, ext)
- except KeyError:
- format += ' (*.*)|*.*'
- win = filebrowse.FileBrowseButton(parent=self.panel, id=wx.ID_ANY,
- fileMask = format)
- self.input[self.inputType][1] = win
- elif sel == 1: # directory
- self.inputType = 'dir'
- elif sel == 2: # database
- self.inputType = 'db'
- elif sel == 3: # protocol
- self.inputType = 'pro'
+ if not self.add.IsChecked():
+ return
- self.inputTypeSizer.Add(item = win, proportion = 1,
- win.SetValue('')
- self.list.DeleteAllItems()
- win.Show()
+ maptree = self.parent.curr_page.maptree
- self.inputText.SetLabel(self.input[self.inputType][0])
- self.format.SetSelection(0)
+ layer, output = self.list.GetLayers()[self.commandId]
- self.inputTypeSizer.Layout()
+ if '@' not in output:
+ name = output + '@' + grass.gisenv()['MAPSET']
+ else:
+ name = output
+ # add imported layers into layer tree
+ if self.importType == 'gdal':
+ cmd = ['d.rast',
+ 'map=%s' % name]
+ if UserSettings.Get(group='cmd', key='rasterOpaque', subkey='enabled'):
+ cmd.append('-n')
+ item = maptree.AddLayer(ltype='raster',
+ lname=name,
+ lcmd=cmd)
+ else:
+ item = maptree.AddLayer(ltype='vector',
+ lname=name,
+ lcmd=['d.vect',
+ 'map=%s' % name])
+ maptree.mapdisplay.MapWindow.ZoomToMap()
- def OnCancel(self, event=None):
- """!Close dialog"""
- self.Close()
+ def OnAbort(self, event):
+ """!Abort running import
+ @todo not yet implemented
+ pass
+class GdalImportDialog(ImportDialog):
+ """!Dialog for bulk import of various raster/vector data"""
+ def __init__(self, parent, ogr = False, link = False):
+ self.link = link
+ if ogr:
+ ImportDialog.__init__(self, parent, type = 'ogr')
+ if link:
+ self.SetTitle(_("Link vector data"))
+ else:
+ self.SetTitle(_("Import vector data"))
+ else:
+ ImportDialog.__init__(self, parent, type = 'gdal')
+ if link:
+ self.SetTitle(_("Link raster data"))
+ else:
+ self.SetTitle(_("Import raster data"))
+ self.dsnInput = gselect.GdalSelect(parent = self, panel = self.panel, ogr = ogr)
+ if not link:
+ self.overrideCheck = wx.CheckBox(parent=self.panel, id=wx.ID_ANY,
+ label=_("Override projection (use location's projection)"))
+ self.overrideCheck.SetValue(True)
+ if link:
+ self.add.SetLabel(_("Add linked layers into layer tree"))
+ else:
+ self.add.SetLabel(_("Add imported layers into layer tree"))
+ self.add.SetValue(UserSettings.Get(group='cmd', key='addNewLayer', subkey='enabled'))
+ if link:
+ self.btn_run.SetLabel(_("&Link"))
+ self.btn_run.SetToolTipString(_("Link selected layers"))
+ else:
+ self.btn_run.SetLabel(_("&Import"))
+ self.btn_run.SetToolTipString(_("Import selected layers"))
+ self.doLayout()
data = self.list.GetLayers()
@@ -1235,30 +1121,13 @@
# hide dialog
self.Hide()
- inputDxf = self.input[self.inputType][1].GetValue()
- else:
- if self.inputType == 'file':
- dsn = os.path.dirname(self.input[self.inputType][1].GetValue())
- else:
- if self.format.GetStringSelection() == 'PostgreSQL':
- dsn = 'PG:dbname=%s' % self.input[self.inputType][1].GetStringSelection()
- else:
- dsn = self.input[self.inputType][1].GetValue()
- try:
- ext = '.' + self.format.GetExtension(self.format.GetStringSelection())
- except KeyError:
- ext = ''
+ dsn = self.dsnInput.GetDsn()
+ ext = self.dsnInput.GetFormatExt()
for layer, output in data:
- cmd = ['v.in.dxf',
- 'input=%s' % inputDxf,
- 'layers=%s' % layer,
- 'output=%s' % output]
- if layer.rfind(ext) > -1:
- layer = layer.replace(ext, '')
+ if self.importType == 'ogr':
+ if ext and layer.rfind(ext) > -1:
+ layer = layer.replace('.' + ext, '')
if self.link:
cmd = ['v.external',
'dsn=%s' % dsn,
@@ -1270,19 +1139,22 @@
'layer=%s' % layer,
else: # gdal
+ if self.dsnInput.GetType() == 'dir':
+ dsn = os.path.join(dsn, layer)
if self.link:
cmd = ['r.external',
- 'input=%s' % (os.path.join(dsn, layer)),
+ 'input=%s' % dsn,
else:
cmd = ['r.in.gdal',
+ 'input=%s' % dsn,
if self.overwrite.IsChecked():
cmd.append('--overwrite')
- if hasattr(self, "overrideCheck") and self.overrideCheck.IsChecked():
+ if not self.link and self.overrideCheck.IsChecked():
cmd.append('-o')
if UserSettings.Get(group='cmd', key='overwrite', subkey='enabled'):
@@ -1290,174 +1162,79 @@
# run in Layer Manager
self.parent.goutput.RunCmd(cmd, switchPage=True,
- onDone = self._addLayers)
+ onDone = self.AddLayers)
self.OnCancel()
- def _addLayers(self, returncode):
- """!Add imported/linked layers into layer tree"""
- self.commandId += 1
+class DxfImportDialog(ImportDialog):
+ """!Dialog for bulk import of DXF layers"""
+ def __init__(self, parent):
+ ImportDialog.__init__(self, parent, type = 'dxf',
+ title = _("Import DXF layers"))
- if not self.add.IsChecked():
- return
+ self.dsnInput = filebrowse.FileBrowseButton(parent=self.panel, id=wx.ID_ANY,
+ size=globalvar.DIALOG_GSELECT_SIZE, labelText='',
+ dialogTitle=_('Choose DXF file to import'),
+ buttonText=_('Browse'),
+ startDirectory=os.getcwd(), fileMode=0,
+ changeCallback=self.OnSetDsn,
+ fileMask="DXF File (*.dxf)|*.dxf")
- maptree = self.parent.curr_page.maptree
- layer, output = self.list.GetLayers()[self.commandId]
- if '@' not in output:
- name = output + '@' + grass.gisenv()['MAPSET']
- else:
- name = output
- # add imported layers into layer tree
- cmd = ['d.rast',
- 'map=%s' % name]
- if UserSettings.Get(group='cmd', key='rasterOverlay', subkey='enabled'):
- cmd.append('-o')
- item = maptree.AddLayer(ltype='raster',
- lname=name,
- lcmd=cmd)
- else:
- item = maptree.AddLayer(ltype='vector',
- lname=name,
- lcmd=['d.vect',
- 'map=%s' % name])
- maptree.mapdisplay.MapWindow.ZoomToMap()
+ self.doLayout()
- def OnAbort(self, event):
- """!Abort running import
- @todo not yet implemented
- pass
+ data = self.list.GetLayers()
- def OnSetFormat(self, event):
- """!Format changed"""
- if self.inputType not in ['file', 'db']:
- return
+ # hide dialog
+ self.Hide()
+ inputDxf = self.dsnInput.GetValue()
- win.Destroy()
- else: # database
- win.Hide()
- format = event.GetString()
- try:
- if not ext:
- raise KeyError
- except KeyError:
+ for layer, output in data:
+ cmd = ['v.in.dxf',
+ 'input=%s' % inputDxf,
+ 'layers=%s' % layer,
+ 'output=%s' % output]
- else: # database
- if format == 'SQLite':
- win = self.input['db-win']['file']
- elif format == 'PostgreSQL':
- if grass.find_program('psql'):
- win = self.input['db-win']['choice']
- if not win.GetItems():
- p = grass.Popen(['psql', '-ltA'], stdout = grass.PIPE)
- ret = p.communicate()[0]
- if ret:
- db = list()
- for line in ret.splitlines():
- sline = line.split('|')
- if len(sline) < 2:
- continue
- dbname = sline[0]
- if dbname:
- db.append(dbname)
- win.SetItems(db)
- else:
- win = self.input['db-win']['text']
- else:
+ if self.overwrite.IsChecked() or \
+ UserSettings.Get(group='cmd', key='overwrite', subkey='enabled'):
+ cmd.append('--overwrite')
+ # run in Layer Manager
+ self.parent.goutput.RunCmd(cmd, switchPage=True,
- if not win.IsShown():
- win.Show()
- def OnSetInput(self, event):
- """!Input DXF file/OGR dsn defined, update list of layer widget"""
+ self.OnCancel()
+ def OnSetDsn(self, event):
+ """!Input DXF file defined, update list of layer widget"""
path = event.GetString()
if not path:
return
data = list()
- ret = gcmd.RunCommand('v.in.dxf',
- quiet = True,
- parent = self,
- read = True,
- flags = 'l',
- input = path)
- if not ret:
- self.list.LoadData()
- self.btn_run.Enable(False)
- return
+ ret = gcmd.RunCommand('v.in.dxf',
+ quiet = True,
+ parent = self,
+ read = True,
+ flags = 'l',
+ input = path)
+ if not ret:
+ self.list.LoadData()
+ self.btn_run.Enable(False)
+ return
- layerId = line.split(':')[0].split(' ')[1]
- layerName = line.split(':')[1].strip()
- grassName = utils.GetValidLayerName(layerName)
- data.append((layerId, layerName.strip(), grassName.strip()))
+ for line in ret.splitlines():
+ layerId = line.split(':')[0].split(' ')[1]
+ layerName = line.split(':')[1].strip()
+ grassName = utils.GetValidLayerName(layerName)
+ data.append((layerId, layerName.strip(), grassName.strip()))
- else: # gdal/ogr (for ogr maybe to use v.in.ogr -l)
- layerId = 1
- else:
- baseName = os.path.basename(dsn)
- grassName = utils.GetValidLayerName(baseName.split('.', -1)[0])
- data.append((layerId, baseName, grassName))
- elif self.inputType == 'dir':
- try:
- ext = self.format.GetExtension(self.format.GetStringSelection())
- except KeyError:
- ext = ''
- for file in glob.glob(os.path.join(dsn, "*.%s") % ext):
- baseName = os.path.basename(file)
- layerId += 1
- elif self.inputType == 'db':
- ret = gcmd.RunCommand('v.in.ogr',
- quiet = True,
- parent = self,
- read = True,
- flags = 'l',
- dsn = dsn)
- if not ret:
- return
- layerId = 1
- for line in ret.split(','):
- layerName = line.strip()
- layerId += 1
self.list.LoadData(data)
if len(data) > 0:
self.btn_run.Enable(True)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py 2010-04-26 16:41:52 UTC (rev 42032)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py 2010-04-26 17:07:10 UTC (rev 42033)
@@ -16,7 +16,8 @@
- MapsetSelect
- SubGroupSelect
- FormatSelect
+ - GdalSelect
(C) 2007-2010 by the GRASS Development Team This program is free
software under the GNU General Public License (>=v2). Read the file
COPYING that comes with GRASS for details.
@@ -27,9 +28,11 @@
import os
import sys
+import glob
import wx
import wx.combo
+import wx.lib.filebrowsebutton as filebrowse
import globalvar
@@ -765,18 +768,24 @@
self.SetValue('')
class FormatSelect(wx.Choice):
- def __init__(self, parent, ftype, sourceType = None, id = wx.ID_ANY, size = globalvar.DIALOG_COMBOBOX_SIZE,
+ sourceType = None, id = wx.ID_ANY, size = globalvar.DIALOG_COMBOBOX_SIZE,
**kwargs):
"""!Widget for selecting external (GDAL/OGR) format
@param parent parent window
@param sourceType source type ('file', 'directory', 'database', 'protocol') or None
- @param dataType data type ('gdal' or 'ogr')
+ @param ogr True for OGR otherwise GDAL
super(FormatSelect, self).__init__(parent, id, size = size,
style = wx.CB_READONLY, **kwargs)
self.SetName("FormatSelect")
+ if ogr:
+ ftype = 'ogr'
+ else:
+ ftype = 'gdal'
formats = list()
for f in globalvar.formats[ftype].values():
formats += f
@@ -853,3 +862,347 @@
except KeyError:
return ''
+class GdalSelect(wx.Panel):
+ def __init__(self, parent, panel, ogr = False,
+ defSource = 'file',
+ sources = [_("File"), _("Directory"),
+ _("Database"), _("Protocol")],
+ envHandler = None):
+ """!Widget for selecting GDAL/OGR datasource, format
+ @param parent parent window
+ @param ogr use OGR selector instead of GDAL
+ self.parent = parent
+ wx.Panel.__init__(self, parent = panel, id = wx.ID_ANY)
+ self.inputBox = wx.StaticBox(parent = self, id=wx.ID_ANY,
+ label=" %s " % _("Source name"))
+ # source type
+ self.source = wx.RadioBox(parent = self, id = wx.ID_ANY,
+ label = _('Source type'),
+ style = wx.RA_SPECIFY_COLS,
+ choices = sources)
+ self.source.SetSelection(0)
+ self.source.Bind(wx.EVT_RADIOBOX, self.OnSetType)
+ # dsn widgets
+ if not ogr:
+ filemask = 'GeoTIFF (*.tif)|*.tif'
+ else:
+ filemask = 'ESRI Shapefile (*.shp)|*.shp'
+ dsnFile = filebrowse.FileBrowseButton(parent=self, id=wx.ID_ANY,
+ dialogTitle=_('Choose input file'),
+ fileMask=filemask)
+ dsnFile.Hide()
+ dsnDir = filebrowse.DirBrowseButton(parent=self, id=wx.ID_ANY,
+ dialogTitle=_('Choose input directory'),
+ changeCallback=self.OnSetDsn)
+ dsnDir.Hide()
+ dsnDbFile = filebrowse.FileBrowseButton(parent=self, id=wx.ID_ANY,
+ dialogTitle=_('Choose file'),
+ dsnDbFile.Hide()
+ dsnDbText = wx.TextCtrl(parent = self, id = wx.ID_ANY)
+ dsnDbText.Hide()
+ dsnDbText.Bind(wx.EVT_TEXT, self.OnSetDsn)
+ dsnDbChoice = wx.Choice(parent = self, id = wx.ID_ANY)
+ dsnDbChoice.Hide()
+ dsnDbChoice.Bind(wx.EVT_CHOICE, self.OnSetDsn)
+ dsnPro = wx.TextCtrl(parent = self, id = wx.ID_ANY)
+ dsnPro.Hide()
+ dsnPro.Bind(wx.EVT_TEXT, self.OnSetDsn)
+ # format
+ self.format = FormatSelect(parent = self,
+ ogr = ogr)
+ self.format.Bind(wx.EVT_CHOICE, self.OnSetFormat)
+ if ogr:
+ fType = 'ogr'
+ else:
+ fType = 'gdal'
+ self.input = { 'file' : [_("File:"),
+ dsnFile,
+ globalvar.formats[fType]['file']],
+ 'dir' : [_("Directory:"),
+ dsnDir,
+ 'db' : [_("Database:"),
+ dsnDbFile,
+ globalvar.formats[fType]['database']],
+ 'pro' : [_("Protocol:"),
+ dsnPro,
+ globalvar.formats[fType]['protocol']],
+ 'db-win' : { 'file' : dsnDbFile,
+ 'text' : dsnDbText,
+ 'choice' : dsnDbChoice },
+ self.dsnType = defSource
+ self.input[self.dsnType][1].Show()
+ self.format.SetItems(self.input[self.dsnType][2])
+ if not ogr:
+ self.format.SetStringSelection('GeoTIFF')
+ else:
+ self.format.SetStringSelection('ESRI Shapefile')
+ self.dsnText = wx.StaticText(parent = self, id = wx.ID_ANY,
+ label = self.input[self.dsnType][0],
+ size = (75, -1))
+ self.formatText = wx.StaticText(parent = self, id = wx.ID_ANY,
+ label = _("Format:"))
+ self._layout()
+ def _layout(self):
+ """!Layout"""
+ mainSizer = wx.BoxSizer(wx.VERTICAL)
+ inputSizer = wx.StaticBoxSizer(self.inputBox, wx.HORIZONTAL)
+ self.dsnSizer = wx.GridBagSizer(vgap=3, hgap=3)
+ self.dsnSizer.AddGrowableCol(1)
+ self.dsnSizer.Add(item=self.dsnText,
+ flag=wx.ALIGN_CENTER_VERTICAL,
+ pos = (0, 0))
+ self.dsnSizer.Add(item=self.input[self.dsnType][1],
+ flag = wx.ALIGN_CENTER_VERTICAL | wx.EXPAND,
+ pos = (0, 1))
+ self.dsnSizer.Add(item=self.formatText,
+ pos = (1, 0))
+ self.dsnSizer.Add(item=self.format,
+ pos = (1, 1))
+ inputSizer.Add(item=self.dsnSizer, proportion=1,
+ flag=wx.EXPAND | wx.ALL)
+ mainSizer.Add(item=self.source, proportion=0,
+ flag=wx.ALL | wx.EXPAND, border=5)
+ mainSizer.Add(item=inputSizer, proportion=0,
+ self.SetSizer(mainSizer)
+ mainSizer.Fit(self)
+ def OnSetType(self, event):
+ """!Datasource type changed"""
+ sel = event.GetSelection()
+ win = self.input[self.dsnType][1]
+ self.dsnSizer.Remove(win)
+ win.Hide()
+ if sel == 0: # file
+ self.dsnType = 'file'
+ format = self.input[self.dsnType][2][0]
+ try:
+ ext = self.format.GetExtension(format)
+ if not ext:
+ raise KeyError
+ format += ' (*.%s)|*.%s' % (ext, ext)
+ except KeyError:
+ format += ' (*.*)|*.*'
+ win = filebrowse.FileBrowseButton(parent=self, id=wx.ID_ANY,
+ fileMask = format)
+ self.input[self.dsnType][1] = win
+ elif sel == 1: # directory
+ self.dsnType = 'dir'
+ elif sel == 2: # database
+ self.dsnType = 'db'
+ elif sel == 3: # protocol
+ self.dsnType = 'pro'
+ # if self.importType != 'dxf':
+ # self.dsnSizer.Add(item=self.formatText,
+ # flag=wx.ALIGN_CENTER_VERTICAL)
+ pos = (0, 1))
+ win.SetValue('')
+ if self.parent.GetName() == 'MultiImportDialog':
+ self.parent.list.DeleteAllItems()
+ win.Show()
+ self.dsnText.SetLabel(self.input[self.dsnType][0])
+ self.format.SetSelection(0)
+ self.dsnSizer.Layout()
+ """!Input DXF file/OGR dsn defined, update list of layer widget"""
+ path = event.GetString()
+ if not path:
+ return
+ data = list()
+ # if self.importType == 'dxf':
+ # ret = gcmd.RunCommand('v.in.dxf',
+ # quiet = True,
+ # parent = self,
+ # read = True,
+ # flags = 'l',
+ # input = path)
+ # if not ret:
+ # self.list.LoadData()
+ # self.btn_run.Enable(False)
+ # return
+ # for line in ret.splitlines():
+ # layerId = line.split(':')[0].split(' ')[1]
+ # layerName = line.split(':')[1].strip()
+ # grassName = utils.GetValidLayerName(layerName)
+ # data.append((layerId, layerName.strip(), grassName.strip()))
+ layerId = 1
+ if self.format.GetStringSelection() == 'PostgreSQL':
+ dsn = 'PG:dbname=%s' % self.input[self.dsnType][1].GetStringSelection()
+ else:
+ dsn = self.input[self.dsnType][1].GetValue()
+ if self.dsnType == 'file':
+ baseName = os.path.basename(dsn)
+ grassName = utils.GetValidLayerName(baseName.split('.', -1)[0])
+ data.append((layerId, baseName, grassName))
+ elif self.dsnType == 'dir':
+ try:
+ ext = self.format.GetExtension(self.format.GetStringSelection())
+ except KeyError:
+ ext = ''
+ for file in glob.glob(os.path.join(dsn, "*.%s") % ext):
+ baseName = os.path.basename(file)
+ layerId += 1
+ elif self.dsnType == 'db':
+ ret = gcmd.RunCommand('v.in.ogr',
+ quiet = True,
+ parent = self,
+ read = True,
+ flags = 'l',
+ dsn = dsn)
+ if not ret:
+ return
+ layerId = 1
+ layerName = line.strip()
+ layerId += 1
+ self.parent.list.LoadData(data)
+ if len(data) > 0:
+ self.parent.btn_run.Enable(True)
+ else:
+ self.parent.btn_run.Enable(False)
+ def OnSetFormat(self, event):
+ """!Format changed"""
+ if self.dsnType not in ['file', 'db']:
+ return
+ win.Destroy()
+ else: # database
+ win.Hide()
+ format = event.GetString()
+ try:
+ if not ext:
+ raise KeyError
+ except KeyError:
+ else: # database
+ if format == 'SQLite':
+ win = self.input['db-win']['file']
+ elif format == 'PostgreSQL':
+ if grass.find_program('psql'):
+ win = self.input['db-win']['choice']
+ if not win.GetItems():
+ p = grass.Popen(['psql', '-ltA'], stdout = grass.PIPE)
+ ret = p.communicate()[0]
+ if ret:
+ db = list()
+ sline = line.split('|')
+ if len(sline) < 2:
+ continue
+ dbname = sline[0]
+ if dbname:
+ db.append(dbname)
+ win.SetItems(db)
+ else:
+ win = self.input['db-win']['text']
+ else:
+ if not win.IsShown():
+ win.Show()
+ pos = (0, 1))
+ def GetType(self):
+ """!Get source type"""
+ return self.dsnType
+ def GetDsn(self):
+ """!Get DSN"""
+ return 'PG:dbname=%s' % self.input[self.dsnType][1].GetStringSelection()
+ return self.input[self.dsnType][1].GetValue()
+ def SetDsnHandler(self):
+ """!Get DSN"""
+ def GetFormatExt(self):
+ """!Get format extension"""
+ return self.format.GetExtension(self.format.GetStringSelection())
Modified: grass/branches/develbranch_6/gui/wxpython/wxgui.py
--- grass/branches/develbranch_6/gui/wxpython/wxgui.py 2010-04-26 16:41:52 UTC (rev 42032)
+++ grass/branches/develbranch_6/gui/wxpython/wxgui.py 2010-04-26 17:07:10 UTC (rev 42033)
@@ -1083,34 +1083,27 @@
def OnImportDxfFile(self, event):
"""!Convert multiple DXF layers to GRASS vector map layers"""
- dlg = gdialogs.MultiImportDialog(parent=self, type='dxf',
- title=_("Import DXF layers"))
+ dlg = gdialogs.DxfImportDialog(parent=self)
dlg.ShowModal()
def OnImportGdalLayers(self, event):
"""!Convert multiple GDAL layers to GRASS raster map layers"""
- dlg = gdialogs.MultiImportDialog(parent=self, type='gdal',
- title=_("Import raster data"))
+ dlg = gdialogs.GdalImportDialog(parent=self)
dlg.ShowModal()
def OnLinkGdalLayers(self, event):
"""!Link multiple GDAL layers to GRASS raster map layers"""
- title=_("Link raster data"),
- link = True)
+ dlg = gdialogs.GdalImportDialog(parent=self, link = True)
dlg.ShowModal()
def OnImportOgrLayers(self, event):
"""!Convert multiple OGR layers to GRASS vector map layers"""
- dlg = gdialogs.MultiImportDialog(parent=self, type='ogr',
- title=_("Import vector data"))
+ dlg = gdialogs.GdalImportDialog(parent=self, ogr = True)
dlg.ShowModal()
def OnLinkOgrLayers(self, event):
"""!Links multiple OGR layers to GRASS vector map layers"""
- title=_("Link vector data"),
- link = True)
+ dlg = gdialogs.GdalImportDialog(parent=self, ogr = True, link = True)
dlg.ShowModal()
def OnImportWMS(self, event):
