[GRASS-SVN] r42036 - grass-addons/gui/wxpython/data_catalog
svn_grass at osgeo.org
Mon Apr 26 14:37:46 EDT 2010
Author: rashadkm
Date: 2010-04-26 14:37:45 -0400 (Mon, 26 Apr 2010)
New Revision: 42036
grass-addons/gui/wxpython/data_catalog/LayerTree.py
grass-addons/gui/wxpython/data_catalog/catalog.py
grass-addons/gui/wxpython/data_catalog/mapdisplay.py
fixed cross location viewing of maps
Modified: grass-addons/gui/wxpython/data_catalog/LayerTree.py
--- grass-addons/gui/wxpython/data_catalog/LayerTree.py 2010-04-26 17:16:25 UTC (rev 42035)
+++ grass-addons/gui/wxpython/data_catalog/LayerTree.py 2010-04-26 18:37:45 UTC (rev 42036)
@@ -1,23 +1,3 @@
- at package LayerTree.py
-GRASS LayerTree.
- at breif A MapTree to display maps based on the selected location and mapset
-MapTree provides functionss such as view,copy,rename and delete mapset
-Classes:
- - LayerTree
-(C) 2007 by the GRASS Development Team
-This program is free software under the GNU General Public
-License (>=v2). Read the file COPYING that comes with GRASS
-for details.
- at author Mohammed Rashad K.M <rashadkm at gmail dot com>
import os
import sys
import wx
@@ -66,11 +46,8 @@
self.gisdbase = gisdbase
- self.layer_selected = None
self.Map = None
- self.root = None
#if self.Map is not None:
# print self.Map.width
@@ -94,14 +71,14 @@
self.layer = []
self.maplayer = None
d = self.GetParent()
notebook = d.GetParent()
child=notebook.GetChildren()
for panel in child:
if panel.GetName() == "pg_panel":
self.mapdisplay = panel
- break
self.MapWindow = self.mapdisplay.MapWindow2D
self.Bind(CT.EVT_TREE_ITEM_CHECKED, self.OnLayerChecked)
@@ -118,7 +95,8 @@
self.Bind(wx.EVT_MENU,self.OnOssim,id=self.ID_OSSIM)
self.Bind(wx.EVT_MENU,self.OnInfo,id=self.ID_INFO)
self.Bind(wx.EVT_MENU,self.OnReport,id=self.ID_REPORT)
def OnInfo(self,event):
item = self.GetSelection()
@@ -148,6 +126,8 @@
leftpanel=self.GetParent()
notebook = leftpanel.GetParent()
frame = notebook.GetParent()
+ notebook.SetSelection(notebook.GetPage(notebook.GetPageCount())
if not self.ItemHasChildren(item):
self.mapname = self.GetItemText(item) + "@" + frame.cmbMapset.GetValue()
@@ -159,23 +139,26 @@
command = ["v.report", 'map=' + self.mapname]
frame.goutput.RunCmd(command)
def OnLayerChecked(self, event):
"""!Enable/disable data layer"""
item = event.GetItem()
checked = item.IsChecked()
pText = self.GetItemText(self.GetItemParent(item))
#for f in frames:
@@ -183,52 +166,52 @@
#maptree = mapframe.maptree
if pText == "Raster Map" :
- if checked == True:
- self.cmd= ['d.rast', str("map=" + self.mapname)]
- maplayer = self.MapWindow.Map.AddLayer(type='raster', name=self.mapname, command=self.cmd)
- self.layer_selected = maplayer
- self.type = 'raster'
- else:
- layers = self.MapWindow.Map.GetListOfLayers( l_type='raster', l_name=self.mapname)
- for layer in layers:
- self.MapWindow.Map.DeleteLayer(layer)
- self.MapWindow.EraseMap()
+ self.cmd= ['d.rast', str("map=" + self.mapname)]
+ l_type='raster'
+ self.maplayer = self.MapWindow.Map.AddLayer(type='raster', name=self.mapname, command=self.cmd)
+ #layer = maptree.PrependItem(parent=maptree.root, text=self.mapname, ct_type=1)
+ #maptree.first = True
+ #maptree.layer_selected = layer
+ #maptree.CheckItem(layer)
+ #self.layer.append(self.maplayer)
+ #maptree.PlusLayer(self.maplayer)
if pText == "Vector Map" :
- self.cmd= ['d.vect', str("map=" + self.mapname)]
- maplayer = self.MapWindow.Map.AddLayer(type='vector', name=self.mapname, command=self.cmd)
- self.type = 'vector'
- else:
- layers = self.MapWindow.Map.GetListOfLayers( l_type='vector', l_name=self.mapname)
+ self.cmd= ['d.vect', str("map=" + self.mapname)]
+ l_type='vector'
+ self.maplayer = self.MapWindow.Map.AddLayer(type='vector', name=self.mapname, command=self.cmd)
self.MapWindow.Map.region = self.MapWindow.Map.GetRegion()
self.MapWindow.flag = True
self.MapWindow.UpdateMap(render=True)
self.MapWindow.flag = False
def AddTreeNodes(self,location,mapset):
Adds tree nodes. raster,vector and dbf files are identified using
their directory structure.
self.DeleteAllItems()
- self.root = self.AddRoot("Map Layers")
- self.SetPyData(self.root, (None,None))
- node_raster = self.AppendItem(self.root, "Raster Map")
- node_vector = self.AppendItem(self.root, "Vector Map")
- node_dbf = self.AppendItem(self.root, "DBF")
+ root = self.AddRoot("Map Layers")
+ self.SetPyData(root, (None,None))
+ node_raster = self.AppendItem(root, "Raster Map")
+ node_vector = self.AppendItem(root, "Vector Map")
+ node_dbf = self.AppendItem(root, "DBF")
treeNodes = [node_raster,node_vector,node_dbf]
glocs = glob.glob(os.path.join(self.gisdbase,location, mapset,"*"))
@@ -236,12 +219,10 @@
if not os.path.isfile(gloc) and os.path.isdir(gloc):
if(os.path.basename(gloc)=='cellhd'):
for rast in glob.glob(os.path.join(self.gisdbase,location, mapset,gloc, "*")):
- rlayer = self.PrependItem(node_raster, os.path.basename(rast),ct_type=1)
+ self.PrependItem(node_raster, os.path.basename(rast),ct_type=1)
elif(os.path.basename(gloc)=='vector'):
for vect in glob.glob(os.path.join(self.gisdbase,location, mapset,gloc, "*")):
- vlayer=self.PrependItem(node_vector, os.path.basename(vect),ct_type=1)
+ self.PrependItem(node_vector, os.path.basename(vect),ct_type=1)
elif(os.path.basename(gloc)=='dbf'):
for dfile in glob.glob(os.path.join(self.gisdbase,location, mapset,gloc, "*")):
self.PrependItem(node_dbf, os.path.basename(dfile),ct_type=1)
Modified: grass-addons/gui/wxpython/data_catalog/catalog.py
--- grass-addons/gui/wxpython/data_catalog/catalog.py 2010-04-26 17:16:25 UTC (rev 42035)
+++ grass-addons/gui/wxpython/data_catalog/catalog.py 2010-04-26 18:37:45 UTC (rev 42036)
@@ -600,6 +600,8 @@
index = self.notebook.GetSelection()
self.page = self.notebook.GetPage(index)
@@ -635,6 +637,7 @@
#self.page.Map.Region = self.page.Map.GetRegion()
self.update_grassrc(self.gisrc)
event.Skip()
@@ -1515,8 +1518,8 @@
self.page = MapFrame(parent=self.notebook, id=wx.ID_ANY, Map=render.Map(), size=globalvar.MAP_WINDOW_SIZE,frame=self)
self.notebook.InsertPage(self.disp_idx,self.page, text="Display "+ str(self.disp_idx), select = True)
- self.current = self.notebook.GetCurrentPage()
- self.notebook.SetSelection(0)
+ #self.current = self.notebook.GetCurrentPage()
+ #self.notebook.SetSelection(0)
Modified: grass-addons/gui/wxpython/data_catalog/mapdisplay.py
--- grass-addons/gui/wxpython/data_catalog/mapdisplay.py 2010-04-26 17:16:25 UTC (rev 42035)
+++ grass-addons/gui/wxpython/data_catalog/mapdisplay.py 2010-04-26 18:37:45 UTC (rev 42036)
@@ -5,13 +5,14 @@
management functions, and additional toolbars (vector digitizer, 3d
view).
+Can be used either from Layer Manager or as p.mon backend.
Classes:
-- Command
-- MapWindow
-- BufferedWindow
- MapFrame
+- MapApp
+Usage:
+python mapdisp.py monitor-identifier /path/to/command/file
(C) 2006-2009 by the GRASS Development Team
@@ -58,12 +59,6 @@
grassPath = os.path.join(globalvar.ETCDIR, "python")
sys.path.append(grassPath)
-import icons
-gmpath = icons.__path__[0]
-sys.path.append(gmpath)
-from icon import Icons
import render
import toolbars
import menuform
@@ -72,12 +67,11 @@
import gcmd
import dbm
import histogram
-import gui_modules.profile as profile
+import profile
import globalvar
import utils
import gdialogs
import goutput
-import gui_modules.goutput as goutput
from grass.script import core as grass
from debug import Debug
from preferences import globalSettings as UserSettings
@@ -270,13 +264,14 @@
mapframe= self.GetParent()
notebook=mapframe.GetParent()
self.gframe=notebook.GetParent()
# Flags
self.resize = False # indicates whether or not a resize event has taken place
self.dragimg = None # initialize variable for map panning
+ self.flag = False
# Variable for drawing on DC
@@ -320,7 +315,7 @@
self.zoomhistory = [] # list of past zoom extents
self.currzoom = 0 # current set of extents in zoom history being used
self.zoomtype = 1 # 1 zoom in, 0 no zoom, -1 zoom out
self.hitradius = 10 # distance for selecting map decorations
self.dialogOffset = 5 # offset for dialog (e.g. DisplayAttributesDialog)
@@ -330,8 +325,14 @@
# platforms at initialization, but little harm done.
### self.OnSize(None)
- self.DefinePseudoDC()
+ # create PseudoDC used for background map, map decorations like scales and legends
+ self.pdc = wx.PseudoDC()
+ # used for digitization tool
+ self.pdcVector = None
+ # decorations (region box, etc.)
+ self.pdcDec = wx.PseudoDC()
+ # pseudoDC for temporal objects (select box, measurement tool, etc.)
+ self.pdcTmp = wx.PseudoDC()
# redraw all pdc's, pdcTmp layer is redrawn always (speed issue)
self.redrawAll = True
@@ -339,61 +340,16 @@
self._buffer = ''
self.Bind(wx.EVT_ERASE_BACKGROUND, lambda x:None)
- self.Bind(wx.EVT_KEY_DOWN , self.OnKeyDown)
# vars for handling mouse clicks
self.dragid = -1
self.lastpos = (0, 0)
- def DefinePseudoDC(self, vdigit = False):
- """!Define PseudoDC class to use
- @vdigit True to use PseudoDC from vdigit
- # create PseudoDC used for background map, map decorations like scales and legends
- self.pdc = self.PseudoDC(vdigit)
- # used for digitization tool
- self.pdcVector = None
- # decorations (region box, etc.)
- self.pdcDec = self.PseudoDC(vdigit)
- # pseudoDC for temporal objects (select box, measurement tool, etc.)
- self.pdcTmp = self.PseudoDC(vdigit)
- def PseudoDC(self, vdigit = False):
- """!Create PseudoDC instance"""
- if vdigit:
- PseudoDC = VDigitPseudoDC
- else:
- PseudoDC = wx.PseudoDC
- return PseudoDC()
- def CheckPseudoDC(self):
- """!Try to draw background
- @return True on success
- @return False on failure
- try:
- self.pdc.BeginDrawing()
- self.pdc.SetBackground(wx.Brush(self.GetBackgroundColour()))
- except StandardError, e:
- traceback.print_exc(file = sys.stderr)
- return False
- return True
def Draw(self, pdc, img=None, drawid=None, pdctype='image', coords=[0, 0, 0, 0]):
Draws map and overlay decorations
if drawid == None:
if pdctype == 'image' and img:
drawid = self.imagedict[img]
@@ -414,7 +370,6 @@
bg = wx.Brush(self.GetBackgroundColour())
pdc.SetBackground(bg)
### pdc.Clear()
Debug.msg (5, "BufferedWindow.Draw(): id=%s, pdctype=%s, coord=%s" % \
@@ -439,7 +394,7 @@
bitmap = wx.BitmapFromImage(img)
w,h = bitmap.GetSize()
pdc.DrawBitmap(bitmap, coords[0], coords[1], True) # draw the composite map
- pdc.SetIdBounds(drawid, wx.Rect(coords[0],coords[1], w, h))
+ pdc.SetIdBounds(drawid, (coords[0],coords[1], w, h))
elif pdctype == 'box': # draw a box on top of the map
if self.pen:
@@ -451,30 +406,24 @@
y1 = min(coords[1],coords[3])
rwidth = x2-x1
rheight = y2-y1
- rect = wx.Rect(x1, y1, rwidth, rheight)
+ rect = wx.Rect(x1,y1,rwidth,rheight)
pdc.DrawRectangleRect(rect)
- pdc.SetIdBounds(drawid, rect)
+ pdc.SetIdBounds(drawid,rect)
+ # self.ovlcoords[drawid] = coords
elif pdctype == 'line': # draw a line on top of the map
if self.pen:
pdc.SetBrush(wx.Brush(wx.CYAN, wx.TRANSPARENT))
pdc.SetPen(self.pen)
- pdc.DrawLinePoint(wx.Point(coords[0], coords[1]),wx.Point(coords[2], coords[3]))
- pdc.SetIdBounds(drawid, wx.Rect(coords[0], coords[1], coords[2], coords[3]))
+ pdc.DrawLine(coords[0], coords[1], coords[2], coords[3])
+ pdc.SetIdBounds(drawid,(coords[0], coords[1], coords[2], coords[3]))
elif pdctype == 'polyline': # draw a polyline on top of the map
if self.polypen:
pdc.SetPen(self.polypen)
- ### pdc.DrawLines(coords)
- if (len(coords) < 2):
- return
- i = 1
- while i < len(coords):
- pdc.DrawLinePoint(wx.Point(coords[i-1][0], coords[i-1][1]),
- wx.Point(coords[i][0], coords[i][1]))
- i += 1
+ pdc.DrawLines(coords)
# get bounding rectangle for polyline
xlist = []
@@ -488,9 +437,9 @@
x2=max(xlist)
y1=min(ylist)
y2=max(ylist)
- pdc.SetIdBounds(drawid, wx.Rect(x1,y1,x2,y2))
+ pdc.SetIdBounds(drawid,(x1,y1,x2,y2))
# self.ovlcoords[drawid] = [x1,y1,x2,y2]
elif pdctype == 'point': # draw point
if self.pen:
@@ -499,7 +448,7 @@
coords[1] - 5,
coords[0] + 5,
coords[1] + 5)
- pdc.SetIdBounds(drawid, wx.Rect(coordsBound))
+ pdc.SetIdBounds(drawid, coordsBound)
elif pdctype == 'text': # draw text on top of map
@@ -517,7 +466,7 @@
pdc.DrawText(img['text'], coords[0], coords[1])
else:
pdc.DrawRotatedText(img['text'], coords[0], coords[1], rotation)
- pdc.SetIdBounds(drawid, wx.Rect(coords[0], coords[1], w, h))
+ pdc.SetIdBounds(drawid, (coords[0], coords[1], w, h))
pdc.EndDrawing()
@@ -526,7 +475,7 @@
return drawid
def TextBounds(self, textinfo):
Return text boundary data
@param textinfo text metadata (text, font, color, rotation)
@@ -560,28 +509,8 @@
return coords, boxw, boxh
- def OnKeyDown(self, event):
- """!Key pressed"""
- shift = event.ShiftDown()
- kc = event.GetKeyCode()
- vdigitToolbar = self.parent.toolbars['vdigit']
- ### vdigit
- if vdigitToolbar:
- event = None
- if not shift:
- if kc == ord('P'):
- event = wx.CommandEvent(winid = vdigitToolbar.addPoint)
- tool = vdigitToolbar.OnAddPoint
- elif kc == ord('L'):
- event = wx.CommandEvent(winid = vdigitToolbar.addLine)
- tool = vdigitToolbar.OnAddLine
- if event:
- vdigitToolbar.OnTool(event)
- tool(event)
def OnPaint(self, event):
Draw PseudoDC's to buffered paint DC
self.pdc for background and decorations
@@ -591,7 +520,7 @@
If self.redrawAll is False on self.pdcTmp content is re-drawn
Debug.msg(4, "BufferedWindow.OnPaint(): redrawAll=%s" % self.redrawAll)
dc = wx.BufferedPaintDC(self, self.buffer)
### dc.SetBackground(wx.Brush("White"))
@@ -643,8 +572,8 @@
# self.bufferLast = wx.BitmapFromImage(self.buffer.ConvertToImage())
self.bufferLast = dc.GetAsBitmap(wx.Rect(0, 0, self.Map.width, self.Map.height))
- pdcLast = self.PseudoDC(vdigit = False)
- pdcLast.DrawBitmap(self.bufferLast, 0, 0, False)
+ pdcLast = wx.PseudoDC()
+ pdcLast.DrawBitmap(bmp=self.bufferLast, x=0, y=0)
pdcLast.DrawToDC(dc)
# draw decorations (e.g. region box)
@@ -663,7 +592,7 @@
self.redrawAll = False
def OnSize(self, event):
Scale map image so that it is
the same size as the Window
@@ -682,7 +611,7 @@
# get the image to be rendered
self.img = self.GetImage()
# update map display
if self.img and self.Map.width + self.Map.height > 0: # scale image during resize
self.img = self.img.Scale(self.Map.width, self.Map.height)
@@ -699,7 +628,7 @@
self.parent.StatusbarUpdate()
def OnIdle(self, event):
Only re-render a composite map image from GRASS during
idle time instead of multiple times during resizing.
@@ -709,7 +638,7 @@
event.Skip()
def SaveToFile(self, FileName, FileType):
This draws the psuedo DC to a buffer that
can be saved to a file.
@@ -720,7 +649,7 @@
self.buffer.SaveFile(FileName, FileType)
def GetOverlay(self):
Converts rendered overlay files to wx.Image
Updates self.imagedict
@@ -738,7 +667,7 @@
return imgs
def GetImage(self):
Converts redered map files to wx.Image
Updates self.imagedict (id=99)
@@ -757,181 +686,185 @@
return img
def UpdateMap(self, render=True, renderVector=True):
Updates the canvas anytime there is a change to the
underlaying images or to the geometry of the canvas.
@param render re-render map composition
@param renderVector re-render vector map layer enabled for editing (used for digitizer)
- start = time.clock()
- self.resize = False
+ if self.flag == True:
+ self.flag = False
+ start = time.clock()
- # if len(self.Map.GetListOfLayers()) == 0:
- # return False
- if self.img is None:
- render = True
- # initialize process bar (only on 'render')
- if render is True or renderVector is True:
- self.parent.statusbarWin['progress'].Show()
- if self.parent.statusbarWin['progress'].GetRange() > 0:
- self.parent.statusbarWin['progress'].SetValue(1)
- # render background image if needed
- # update layer dictionary if there has been a change in layers
- if self.tree and self.tree.reorder == True:
- self.tree.ReorderLayers()
- # reset flag for auto-rendering
- if self.tree:
- self.tree.rerender = False
- if render:
- # update display size
- self.Map.ChangeMapSize(self.GetClientSize())
- if self.parent.statusbarWin['resolution'].IsChecked():
- # use computation region resolution for rendering
- windres = True
+ self.resize = False
+ if len(self.Map.GetListOfLayers()) == 0:
+ return False
+ if self.img is None:
+ render = True
+ # initialize process bar (only on 'render')
+ if render is True or renderVector is True:
+ self.parent.onRenderGauge.Show()
+ if self.parent.onRenderGauge.GetRange() > 0:
+ self.parent.onRenderGauge.SetValue(1)
+ # render background image if needed
+ # update layer dictionary if there has been a change in layers
+ if self.tree and self.tree.reorder == True:
+ self.tree.ReorderLayers()
+ # reset flag for auto-rendering
+ if self.tree:
+ self.tree.rerender = False
+ if render:
+ # update display size
+ self.Map.ChangeMapSize(self.GetClientSize())
+ if self.parent.compResolution.IsChecked():
+ # use computation region resolution for rendering
+ windres = True
+ else:
+ windres = False
+ self.mapfile = self.Map.Render(force=True, mapWindow=self.parent,
+ windres=windres)
else:
- windres = False
- self.mapfile = self.Map.Render(force=True, mapWindow=self.parent,
- windres=windres)
- else:
- self.mapfile = self.Map.Render(force=False, mapWindow=self.parent)
- self.img = self.GetImage() # id=99
+ self.mapfile = self.Map.Render(force=False, mapWindow=self.parent)
- # clear pseudoDcs
- for pdc in (self.pdc,
- self.pdcDec,
- self.pdcTmp):
- pdc.Clear()
- pdc.RemoveAll()
- # draw background map image to PseudoDC
- if not self.img:
- self.Draw(self.pdc, pdctype='clear')
- else:
- try:
- id = self.imagedict[self.img]['id']
- except:
- return False
+ self.img = self.GetImage() # id=99
+ # clear pseudoDcs
+ for pdc in (self.pdc,
+ self.pdcDec,
+ self.pdcTmp):
+ pdc.Clear()
+ pdc.RemoveAll()
+ # draw background map image to PseudoDC
+ if not self.img:
+ self.Draw(self.pdc, pdctype='clear')
+ else:
+ try:
+ id = self.imagedict[self.img]['id']
+ except:
+ return False
- self.Draw(self.pdc, self.img, drawid=id)
- # render vector map layer
- digitToolbar = self.parent.toolbars['vdigit']
- if renderVector and digitToolbar and \
- digitToolbar.GetLayer():
- # set region
- self.parent.digit.driver.UpdateRegion()
- # re-calculate threshold for digitization tool
- self.parent.digit.driver.GetThreshold()
- # draw map
- if self.pdcVector:
+ self.Draw(self.pdc, self.img, drawid=id)
+ # render vector map layer
+ digitToolbar = self.parent.toolbars['vdigit']
+ if renderVector and digitToolbar and \
+ digitToolbar.GetLayer():
+ # set region
+ self.parent.digit.driver.UpdateRegion()
+ # re-calculate threshold for digitization tool
+ self.parent.digit.driver.GetThreshold()
+ # draw map
self.pdcVector.Clear()
self.pdcVector.RemoveAll()
- try:
- item = self.tree.FindItemByData('maplayer', digitToolbar.GetLayer())
- except TypeError:
- item = None
+ try:
+ item = self.tree.FindItemByData('maplayer', digitToolbar.GetLayer())
+ except TypeError:
+ item = None
+ if item and self.tree.IsItemChecked(item):
+ self.parent.digit.driver.DrawMap()
+ # translate tmp objects (pointer position)
+ if digitToolbar.GetAction() == 'moveLine':
+ if hasattr(self, "vdigitMove") and \
+ self.vdigitMove.has_key('beginDiff'):
+ # move line
+ for id in self.vdigitMove['id']:
+ # print self.pdcTmp.GetIdBounds(id)
+ self.pdcTmp.TranslateId(id,
+ self.vdigitMove['beginDiff'][0],
+ self.vdigitMove['beginDiff'][1])
+ del self.vdigitMove['beginDiff']
- if item and self.tree.IsItemChecked(item):
- self.parent.digit.driver.DrawMap()
+ # render overlays
+ for img in self.GetOverlay():
+ # draw any active and defined overlays
+ if self.imagedict[img]['layer'].IsActive():
+ id = self.imagedict[img]['id']
+ self.Draw(self.pdc, img=img, drawid=id,
+ pdctype=self.overlays[id]['pdcType'], coords=self.overlays[id]['coords'])
- # translate tmp objects (pointer position)
- if digitToolbar.GetAction() == 'moveLine':
- if hasattr(self, "vdigitMove") and \
- self.vdigitMove.has_key('beginDiff'):
- # move line
- for id in self.vdigitMove['id']:
- self.pdcTmp.TranslateId(id,
- self.vdigitMove['beginDiff'][0],
- self.vdigitMove['beginDiff'][1])
- del self.vdigitMove['beginDiff']
- # render overlays
- for img in self.GetOverlay():
- # draw any active and defined overlays
- if self.imagedict[img]['layer'].IsActive():
- id = self.imagedict[img]['id']
- self.Draw(self.pdc, img=img, drawid=id,
- pdctype=self.overlays[id]['pdcType'], coords=self.overlays[id]['coords'])
+ for id in self.textdict.keys():
+ self.Draw(self.pdc, img=self.textdict[id], drawid=id,
+ pdctype='text', coords=[10, 10, 10, 10])
- for id in self.textdict.keys():
- self.Draw(self.pdc, img=self.textdict[id], drawid=id,
- pdctype='text', coords=[10, 10, 10, 10])
- # optionally draw computational extent box
- self.DrawCompRegionExtent()
- # redraw pdcTmp if needed
- if len(self.polycoords) > 0:
- self.DrawLines(self.pdcTmp)
- if not self.parent.IsStandalone() and \
- self.parent.GetLayerManager().georectifying:
- # -> georectifier (redraw GCPs)
- if self.parent.toolbars['georect']:
- coordtype = 'gcpcoord'
+ # optionally draw computational extent box
+ self.DrawCompRegionExtent()
+ # redraw pdcTmp if needed
+ if len(self.polycoords) > 0:
+ self.DrawLines(self.pdcTmp)
+ if self.gframe.georectifying:
+ # -> georectifier (redraw GCPs)
+ if self.parent.toolbars['georect']:
+ coordtype = 'gcpcoord'
+ else:
+ coordtype = 'mapcoord'
+ self.gframe.georectifying.DrawGCP(coordtype)
+ # clear measurement
+ if self.mouse["use"] == "measure":
+ self.ClearLines(pdc=self.pdcTmp)
+ self.polycoords = []
+ self.mouse['use'] = 'pointer'
+ self.mouse['box'] = 'point'
+ self.mouse['end'] = [0, 0]
+ self.SetCursor(self.parent.cursors["default"])
+ stop = time.clock()
+ # hide process bar
+ self.parent.onRenderGauge.Hide()
+ # update statusbar
+ ### self.Map.SetRegion()
+ self.parent.StatusbarUpdate()
+ if grass.find_file(name = 'MASK', element = 'cell')['name']:
+ # mask found
+ self.parent.maskInfo.SetLabel(_('MASK'))
else:
- coordtype = 'mapcoord'
- self.parent.GetLayerManager().georectifying.DrawGCP(coordtype)
+ self.parent.maskInfo.SetLabel('')
- # clear measurement
- if self.mouse["use"] == "measure":
- self.ClearLines(pdc=self.pdcTmp)
- self.polycoords = []
- self.mouse['use'] = 'pointer'
- self.mouse['box'] = 'point'
- self.mouse['end'] = [0, 0]
- self.SetCursor(self.parent.cursors["default"])
+ Debug.msg (2, "BufferedWindow.UpdateMap(): render=%s, renderVector=%s -> time=%g" % \
+ (render, renderVector, (stop-start)))
- stop = time.clock()
- # hide process bar
- self.parent.statusbarWin['progress'].Hide()
+ return True
- # update statusbar
- ### self.Map.SetRegion()
- self.parent.StatusbarUpdate()
- if grass.find_file(name = 'MASK', element = 'cell')['name']:
- # mask found
- self.parent.statusbarWin['mask'].SetLabel(_('MASK'))
- else:
- self.parent.statusbarWin['mask'].SetLabel('')
- Debug.msg (2, "BufferedWindow.UpdateMap(): render=%s, renderVector=%s -> time=%g" % \
- (render, renderVector, (stop-start)))
- return True
def DrawCompRegionExtent(self):
Draw computational region extent in the display
Display region is drawn as a blue box inside the computational region,
@@ -959,7 +892,7 @@
self.DrawLines(pdc=self.pdcDec, polycoords=self.regionCoords)
def IsInRegion(self, region, refRegion):
Test if 'region' is inside of 'refRegion'
@param region input region
@@ -977,7 +910,7 @@
return False
def EraseMap(self):
Erase the canvas
@@ -989,23 +922,24 @@
self.Draw(self.pdcTmp, pdctype='clear')
def DragMap(self, moveto):
Drag the entire map image for panning.
- @param moveto dx,dy
dc = wx.BufferedDC(wx.ClientDC(self))
dc.Clear()
self.dragimg = wx.DragImage(self.buffer)
self.dragimg.BeginDrag((0, 0), self)
self.dragimg.GetImageRect(moveto)
self.dragimg.Move(moveto)
self.dragimg.DoDrawImage(dc, moveto)
self.dragimg.EndDrag()
+ return True
def DragItem(self, id, event):
Drag an overlay decoration item
@@ -1038,13 +972,13 @@
self.lastpos = (event.GetX(), event.GetY())
def MouseDraw(self, pdc=None, begin=None, end=None):
Mouse box or line from 'begin' to 'end'
If not given from self.mouse['begin'] to self.mouse['end'].
-# self.redrawAll = False
+ self.redrawAll = False
if not pdc:
return
@@ -1063,13 +997,8 @@
mousecoords = [begin[0], begin[1],
end[0], end[1]]
r = pdc.GetIdBounds(boxid)
- if type(r) is list:
- r = wx.Rect(r[0], r[1], r[2], r[3])
- r.Inflate(4, 4)
- try:
- pdc.ClearId(boxid)
- except:
- pass
+ r.Inflate(4,4)
+ pdc.ClearId(boxid)
self.RefreshRect(r, False)
pdc.SetId(boxid)
self.Draw(pdc, drawid=boxid, pdctype='box', coords=mousecoords)
@@ -1089,10 +1018,11 @@
pass
pdc.SetId(self.lineid)
self.Draw(pdc, drawid=self.lineid, pdctype='line', coords=mousecoords)
def DrawLines(self, pdc=None, polycoords=None):
Draw polyline in PseudoDC
Set self.pline to wx.NEW_ID + 1
@@ -1125,7 +1055,7 @@
def DrawCross(self, pdc, coords, size, rotation=0,
text=None, textAlign='lr', textOffset=(5, 5)):
- """!Draw cross in PseudoDC
+ """Draw cross in PseudoDC
@todo implement rotation
@@ -1163,7 +1093,7 @@
return self.lineid
def MouseActions(self, event):
Mouse motion and button click notifier
if not self.processMouse:
@@ -1196,10 +1126,6 @@
elif event.MiddleDown():
self.OnMiddleDown(event)
- # middle mouse button relesed
- elif event.MiddleUp():
- self.OnMiddleUp(event)
# right mouse button pressed
elif event.RightDown():
self.OnRightDown(event)
@@ -1210,11 +1136,11 @@
elif event.Moving():
self.OnMouseMoving(event)
+# event.Skip()
- # event.Skip()
def OnMouseWheel(self, event):
Mouse wheel moved
self.processMouse = False
@@ -1226,7 +1152,7 @@
current[1] - self.Map.height / 4)
end = (current[0] + self.Map.width / 4,
current[1] + self.Map.height / 4)
if wheel > 0:
zoomtype = 1
else:
@@ -1248,7 +1174,7 @@
# event.Skip()
def OnDragging(self, event):
Mouse dragging with left button down
Debug.msg (5, "BufferedWindow.MouseAction(): Dragging")
@@ -1256,20 +1182,19 @@
previous = self.mouse['begin']
move = (current[0] - previous[0],
current[1] - previous[1])
# dragging or drawing box with left button
- if self.mouse['use'] == 'pan' or \
- event.MiddleIsDown():
+ if self.mouse['use'] == 'pan':
self.DragMap(move)
# dragging decoration overlay item
elif (self.mouse['use'] == 'pointer' and
not digitToolbar and
self.dragid != None):
self.DragItem(self.dragid, event)
# dragging anything else - rubber band box or line
else:
@@ -1282,327 +1207,9 @@
digitClass.driver.GetSelected() > 0)):
# draw box only when left mouse button is pressed
self.MouseDraw(pdc=self.pdcTmp)
- # event.Skip()
+# event.Skip()
- def OnLeftDownVDigitAddLine(self, event):
- Left mouse button down - vector digitizer add new line
- action
- digitClass = self.parent.digit
- try:
- mapLayer = digitToolbar.GetLayer().GetName()
- except:
- return
- if digitToolbar.GetAction('type') in ["point", "centroid"]:
- # add new point
- if digitToolbar.GetAction('type') == 'point':
- point = True
- else:
- point = False
- east, north = self.Pixel2Cell(self.mouse['begin'])
- fid = digitClass.AddPoint(mapLayer, point, east, north)
- if fid < 0:
- return
- self.UpdateMap(render=False) # redraw map
- # add new record into atribute table
- if UserSettings.Get(group='vdigit', key="addRecord", subkey='enabled') is True:
- # select attributes based on layer and category
- cats = { fid : {
- UserSettings.Get(group='vdigit', key="layer", subkey='value') :
- (UserSettings.Get(group='vdigit', key="category", subkey='value'), )
- posWindow = self.ClientToScreen((self.mouse['end'][0] + self.dialogOffset,
- self.mouse['end'][1] + self.dialogOffset))
- addRecordDlg = dbm_dialogs.DisplayAttributesDialog(parent=self, map=mapLayer,
- cats=cats,
- pos=posWindow,
- action="add")
- if not point:
- self.__geomAttrb(fid, addRecordDlg, 'area', digitClass,
- digitToolbar.GetLayer())
- self.__geomAttrb(fid, addRecordDlg, 'perimeter', digitClass,
- if addRecordDlg.mapDBInfo and \
- addRecordDlg.ShowModal() == wx.ID_OK:
- sqlfile = tempfile.NamedTemporaryFile(mode="w")
- for sql in addRecordDlg.GetSQLString():
- sqlfile.file.write(sql + ";\n")
- sqlfile.file.flush()
- gcmd.RunCommand('db.execute',
- parent = self,
- quiet = True,
- input = sqlfile.name)
- if addRecordDlg.mapDBInfo:
- self.__updateATM()
- elif digitToolbar.GetAction('type') in ["line", "boundary"]:
- # add new point to the line
- self.polycoords.append(self.Pixel2Cell(event.GetPositionTuple()[:]))
- self.DrawLines(pdc=self.pdcTmp)
- def __geomAttrb(self, fid, dialog, attrb, digit, mapLayer):
- """!Trac geometry attributes?"""
- item = self.tree.FindItemByData('maplayer', mapLayer)
- vdigit = self.tree.GetPyData(item)[0]['vdigit']
- if vdigit and \
- vdigit.has_key('geomAttr') and \
- vdigit['geomAttr'].has_key(attrb):
- val = -1
- if attrb == 'length':
- val = digit.GetLineLength(fid)
- type = attrb
- elif attrb == 'area':
- val = digit.GetAreaSize(fid)
- type = attrb
- elif attrb == 'perimeter':
- val = digit.GetAreaPerimeter(fid)
- type = 'length'
- if val > 0:
- layer = int(UserSettings.Get(group='vdigit', key="layer", subkey='value'))
- column = vdigit['geomAttr'][attrb]['column']
- val = UnitsConvertValue(val, type, vdigit['geomAttr'][attrb]['units'])
- dialog.SetColumnValue(layer, column, val)
- dialog.OnReset()
- def __geomAttrbUpdate(self, fids):
- """!Update geometry atrributes of currently selected features
- @param fid list feature id
- mapLayer = self.parent.toolbars['vdigit'].GetLayer()
- vectorName = mapLayer.GetName()
- digit = self.parent.digit
- if vdigit is None or not vdigit.has_key('geomAttr'):
- return
- dbInfo = gselect.VectorDBInfo(vectorName)
- for fid in fids:
- for layer, cats in digit.GetLineCats(fid).iteritems():
- table = dbInfo.GetTable(layer)
- for attrb, item in vdigit['geomAttr'].iteritems():
- val = -1
- type = attrb
- type = attrb
- type = 'length'
- if val < 0:
- continue
- val = UnitsConvertValue(val, type, item['units'])
- for cat in cats:
- sqlfile.write('UPDATE %s SET %s = %f WHERE %s = %d;\n' % \
- (table, item['column'], val,
- dbInfo.GetKeyColumn(layer), cat))
- parent = True,
- quiet = True,
- def __updateATM(self):
- """!Update open Attribute Table Manager
- @todo: use AddDataRow() instead
- # update ATM
- digitVector = digitToolbar.GetLayer().GetName()
- for atm in self.lmgr.dialogs['atm']:
- atmVector = atm.GetVectorName()
- if atmVector == digitVector:
- layer = UserSettings.Get(group='vdigit', key="layer", subkey='value')
- # TODO: use AddDataRow instead
- atm.LoadData(layer)
- def OnLeftDownVDigitEditLine(self, event):
- Left mouse button down - vector digitizer edit linear feature
- - add new vertex.
- self.polycoords.append(self.Pixel2Cell(self.mouse['begin']))
- self.vdigitMove['id'].append(wx.NewId())
- def OnLeftDownVDigitMoveLine(self, event):
- Left mouse button down - vector digitizer move feature/vertex,
- edit linear feature
- self.vdigitMove = {}
- # geographic coordinates of initial position (left-down)
- self.vdigitMove['begin'] = None
- # list of ids to modify
- self.vdigitMove['id'] = []
- # ids geographic coordinates
- self.vdigitMove['coord'] = {}
- if digitToolbar.GetAction() in ["moveVertex", "editLine"]:
- # set pen
- pcolor = UserSettings.Get(group='vdigit', key="symbol",
- subkey=["highlight", "color"])
- self.pen = self.polypen = wx.Pen(colour=pcolor,
- width=2, style=wx.SHORT_DASH)
- self.pdcTmp.SetPen(self.polypen)
- def OnLeftDownVDigitDisplayCA(self, event):
- Left mouse button down - vector digitizer display categories
- or attributes action
- try:
- except:
- return
- coords = self.Pixel2Cell(self.mouse['begin'])
- # unselect
- digitClass.driver.SetSelected([])
- # select feature by point
- cats = {}
- if digitClass.driver.SelectLineByPoint(coords,
- digitClass.GetSelectType()) is None:
- return
- if UserSettings.Get(group='vdigit', key='checkForDupl',
- subkey='enabled'):
- lines = digitClass.driver.GetSelected()
- else:
- lines = (digitClass.driver.GetSelected()[0],) # only first found
- for line in lines:
- cats[line] = digitClass.GetLineCats(line)
- if digitToolbar.GetAction() == "displayAttrs":
- # select attributes based on coordinates (all layers)
- if self.parent.dialogs['attributes'] is None:
- self.parent.dialogs['attributes'] = \
- dbm_dialogs.DisplayAttributesDialog(parent=self, map=mapLayer,
- cats=cats,
- action="update")
- else:
- # upgrade dialog
- self.parent.dialogs['attributes'].UpdateDialog(cats=cats)
- if self.parent.dialogs['attributes']:
- if len(cats.keys()) > 0:
- # highlight feature & re-draw map
- if not self.parent.dialogs['attributes'].IsShown():
- self.parent.dialogs['attributes'].Show()
- else:
- if self.parent.dialogs['attributes'] and \
- self.parent.dialogs['attributes'].IsShown():
- self.parent.dialogs['attributes'].Hide()
- else: # displayCats
- if self.parent.dialogs['category'] is None:
- # open new dialog
- dlg = VDigitCategoryDialog(parent=self,
- map=mapLayer,
- cats=cats,
- pos=posWindow,
- title=_("Update categories"))
- self.parent.dialogs['category'] = dlg
- else:
- # update currently open dialog
- self.parent.dialogs['category'].UpdateDialog(cats=cats)
- if self.parent.dialogs['category']:
- if not self.parent.dialogs['category'].IsShown():
- self.parent.dialogs['category'].Show()
- else:
- if self.parent.dialogs['category'].IsShown():
- self.parent.dialogs['category'].Hide()
- def OnLeftDownVDigitCopyCA(self, event):
- Left mouse button down - vector digitizer copy categories
- if not hasattr(self, "copyCatsList"):
- self.copyCatsList = []
- else:
- self.copyCatsIds = []
- self.mouse['box'] = 'box'
- def OnLeftDownVDigitCopyLine(self, event):
- Left mouse button down - vector digitizer copy lines action
- if not hasattr(self, "copyIds"):
- self.copyIds = []
- self.layerTmp = None
- def OnLeftDownVDigitBulkLine(self, event):
- Left mouse button down - vector digitizer label 3d vector
- lines
- if len(self.polycoords) > 1: # start new line
- if len(self.polycoords) == 1:
- begin = self.Pixel2Cell(self.polycoords[-1])
- end = self.Pixel2Cell(self.mouse['end'])
- else:
- end = self.Pixel2Cell(self.polycoords[-1])
- begin = self.Pixel2Cell(self.mouse['begin'])
- self.DrawLines(self.pdcTmp, polycoords = (begin, end))
def OnLeftDown(self, event):
Left mouse button pressed
@@ -1698,261 +1305,6 @@
event.Skip()
- def OnLeftUpVDigitVarious(self, event):
- Left mouse button up - vector digitizer various actions
- pos1 = self.Pixel2Cell(self.mouse['begin'])
- pos2 = self.Pixel2Cell(self.mouse['end'])
- nselected = 0
- # -> delete line || move line || move vertex
- if digitToolbar.GetAction() in ("moveVertex",
- "editLine"):
- if len(digitClass.driver.GetSelected()) == 0:
- nselected = digitClass.driver.SelectLineByPoint(pos1, type=VDigit_Lines_Type)
- if digitToolbar.GetAction() == "editLine":
- try:
- selVertex = digitClass.driver.GetSelectedVertex(pos1)[0]
- except IndexError:
- selVertex = None
- if selVertex:
- # self.UpdateMap(render=False)
- ids = digitClass.driver.GetSelected(grassId=False)
- # move this line to tmp layer
- for id in ids:
- if id % 2: # register only vertices
- e, n = self.Pixel2Cell(self.pdcVector.GetIdBounds(id)[0:2])
- self.polycoords.append((e, n))
- digitClass.driver.DrawSelected(False)
- if selVertex < ids[-1] / 2:
- # choose first or last node of line
- self.vdigitMove['id'].reverse()
- self.polycoords.reverse()
- else:
- # unselect
- elif digitToolbar.GetAction() in ("copyCats",
- "copyAttrs"):
- if not hasattr(self, "copyCatsIds"):
- # 'from' -> select by point
- nselected = digitClass.driver.SelectLineByPoint(pos1, digitClass.GetSelectType())
- if nselected:
- self.copyCatsList = digitClass.driver.GetSelected()
- else:
- # -> 'to' -> select by bbox
- # return number of selected features (by box/point)
- nselected = digitClass.driver.SelectLinesByBox(pos1, pos2,
- if nselected == 0:
- if digitClass.driver.SelectLineByPoint(pos1,
- digitClass.GetSelectType()) is not None:
- nselected = 1
- if nselected > 0:
- self.copyCatsIds = digitClass.driver.GetSelected()
- elif digitToolbar.GetAction() == "queryLine":
- selected = digitClass.SelectLinesByQuery(pos1, pos2)
- nselected = len(selected)
- if nselected > 0:
- digitClass.driver.SetSelected(selected)
- else:
- # -> moveLine || deleteLine, etc. (select by point/box)
- if digitToolbar.GetAction() == 'moveLine' and \
- len(digitClass.driver.GetSelected()) > 0:
- nselected = 0
- else:
- drawSeg = True
- else:
- drawSeg = False
- digitClass.GetSelectType(),
- drawSeg)
- nselected = 1
- if nselected > 0:
- if digitToolbar.GetAction() in ("moveLine",
- "moveVertex"):
- # get pseudoDC id of objects which should be redrawn
- if digitToolbar.GetAction() == "moveLine":
- # -> move line
- self.vdigitMove['id'] = digitClass.driver.GetSelected(grassId=False)
- self.vdigitMove['coord'] = digitClass.driver.GetSelectedCoord()
- else: # moveVertex
- self.vdigitMove['id'] = digitClass.driver.GetSelectedVertex(pos1)
- if len(self.vdigitMove['id']) == 0: # no vertex found
- # check for duplicates
- if UserSettings.Get(group='vdigit', key='checkForDupl', subkey='enabled') is True:
- dupl = digitClass.driver.GetDuplicates()
- if dupl:
- dlg = VDigitDuplicatesDialog(parent=self, data=dupl, pos=posWindow)
- if dlg.ShowModal() == wx.ID_OK:
- digitClass.driver.UnSelect(dlg.GetUnSelected())
- # update selected
- if digitToolbar.GetAction() != "editLine":
- # -> move line || move vertex
- else: # no vector object found
- if not (digitToolbar.GetAction() in ("moveLine",
- "moveVertex") and \
- len(self.vdigitMove['id']) > 0):
- # avoid left-click when features are already selected
- self.UpdateMap(render=False, renderVector=False)
- def OnLeftUpVDigitModifyLine(self, event):
- Left mouse button up - vector digitizer split line, add/remove
- vertex action
- pointOnLine = digitClass.driver.SelectLineByPoint(pos1,
- type=VDigit_Lines_Type)
- if not pointOnLine:
- return
- if digitToolbar.GetAction() in ["splitLine", "addVertex"]:
- self.UpdateMap(render=False) # highlight object
- self.DrawCross(pdc=self.pdcTmp, coords=self.Cell2Pixel(pointOnLine),
- size=5)
- else: # removeVertex
- # get only id of vertex
- try:
- id = digitClass.driver.GetSelectedVertex(pos1)[0]
- id = None
- if id:
- x, y = self.pdcVector.GetIdBounds(id)[0:2]
- self.pdcVector.RemoveId(id)
- self.DrawCross(pdc=self.pdcTmp, coords=(x, y),
- size=5)
- else:
- # unselect
- def OnLeftUpVDigitCopyLine(self, event):
- Left mouse button up - vector digitizer copy feature action
- if UserSettings.Get(group='vdigit', key='bgmap',
- subkey='value', internal=True) == '':
- # no background map -> copy from current vector map layer
- if nselected > 0:
- # highlight selected features
- else:
- else:
- # copy features from background map
- self.copyIds += digitClass.SelectLinesFromBackgroundMap(pos1, pos2)
- if len(self.copyIds) > 0:
- color = UserSettings.Get(group='vdigit', key='symbol',
- subkey=['highlight', 'color'])
- colorStr = str(color[0]) + ":" + \
- str(color[1]) + ":" + \
- str(color[2])
- dVectTmp = ['d.vect',
- 'map=%s' % UserSettings.Get(group='vdigit', key='bgmap',
- subkey='value', internal=True),
- 'cats=%s' % utils.ListOfCatsToRange(self.copyIds),
- '-i',
- 'color=%s' % colorStr,
- 'fcolor=%s' % colorStr,
- 'type=point,line,boundary,centroid',
- 'width=2']
- if not self.layerTmp:
- self.layerTmp = self.Map.AddLayer(type='vector',
- name=globalvar.QUERYLAYER,
- command=dVectTmp)
- else:
- self.layerTmp.SetCmd(dVectTmp)
- self.UpdateMap(render=True, renderVector=False)
- else:
- self.redrawAll = None
- def OnLeftUpVDigitBulkLine(self, event):
- Left mouse button up - vector digitizer z-bulk line action
- # select lines to be labeled
- pos1 = self.polycoords[0]
- pos2 = self.polycoords[1]
- if nselected > 0:
- self.DrawLines(pdc=self.pdcTmp) # redraw temp line
- else:
- def OnLeftUpVDigitConnectLine(self, event):
- Left mouse button up - vector digitizer connect line action
- if len(digitClass.driver.GetSelected()) > 0:
def OnLeftUp(self, event):
Left mouse button released
@@ -1980,6 +1332,7 @@
self.Zoom(begin, end, self.zoomtype)
# redraw map
+ self.flag=True
self.UpdateMap(render=True)
# update statusbar
@@ -1994,6 +1347,7 @@
self.parent.QueryVector(self.mouse['begin'][0], self.mouse['begin'][1])
# clear temp canvas
+ self.flag=True
elif self.mouse["use"] in ["measure", "profile"]:
@@ -2015,6 +1369,7 @@
self.parent.GetLayerManager().georectifying.SetGCPData(coordtype, coord, self)
+ self.flag=True
elif self.mouse["use"] == "pointer" and self.parent.toolbars['vdigit']:
@@ -2074,9 +1429,10 @@
pass
self.dragid = None
self.currtxtid = None
def OnButtonDClick(self, event):
Mouse button double click
Debug.msg (5, "BufferedWindow.OnButtonDClick(): use=%s" % \
@@ -2091,15 +1447,18 @@
self.Refresh()
elif self.mouse["use"] == "profile":
+ # profile
pass
- elif self.mouse['use'] == 'pointer' and \
- self.parent.toolbars['vdigit']:
- # vector digitizer
+ # self.pdc.ClearId(self.lineid)
+ # self.pdc.ClearId(self.plineid)
+ # print 'coordinates: ',self.polycoords
+ # self.polycoords = []
+ # self.mouse['begin'] = self.mouse['end'] = [0, 0]
+ # self.Refresh()
+ elif self.mouse['use'] == 'pointer' and self.parent.toolbars['vdigit']:
+ # digitization tool
pass
else:
# select overlay decoration options dialog
clickposition = event.GetPositionTuple()[:]
@@ -2116,9 +1475,11 @@
self.parent.OnAddBarscale(None)
elif self.dragid == 1:
self.parent.OnAddLegend(None)
+# event.Skip()
def OnRightDown(self, event):
Right mouse button pressed
Debug.msg (5, "BufferedWindow.OnRightDown(): use=%s" % \
@@ -2128,8 +1489,7 @@
if digitToolbar:
# digitization tool (confirm action)
+ if digitToolbar.GetAction() in ["moveLine", "moveVertex"] and \
hasattr(self, "vdigitMove"):
pFrom = self.vdigitMove['begin']
@@ -2144,18 +1504,15 @@
return
elif digitToolbar.GetAction() == "moveVertex":
# move vertex
- fid = digitClass.MoveSelectedVertex(pFrom, move)
- if fid < 0:
+ if digitClass.MoveSelectedVertex(pFrom, move) < 0:
return
- self.__geomAttrbUpdate([fid,])
del self.vdigitMove
event.Skip()
def OnRightUp(self, event):
Right mouse button released
Debug.msg (5, "BufferedWindow.OnRightUp(): use=%s" % \
@@ -2200,9 +1557,7 @@
self.Refresh()
- if UserSettings.Get(group='vdigit', key="addRecord", subkey='enabled') and \
- (line is True or \
- (not line and fid > 0)):
+ if UserSettings.Get(group='vdigit', key="addRecord", subkey='enabled') is True:
posWindow = self.ClientToScreen((position[0] + self.dialogOffset,
position[1] + self.dialogOffset))
@@ -2211,54 +1566,36 @@
- addRecordDlg = dbm_dialogs.DisplayAttributesDialog(parent=self, map=map,
- cats=cats,
- pos=posWindow,
- action="add")
- self.__geomAttrb(fid, addRecordDlg, 'length', digitClass,
- # auto-placing centroid
+ addRecordDlg = dbm.DisplayAttributesDialog(parent=self, map=map,
+ cats=cats,
+ pos=posWindow,
+ action="add")
- parent = True,
- quiet = True,
+ executeCommand = gcmd.Command(cmd=["db.execute",
+ "--q",
+ "input=%s" % sqlfile.name])
elif digitToolbar.GetAction() == "deleteLine":
# -> delete selected vector features
if digitClass.DeleteSelectedLines() < 0:
return
elif digitToolbar.GetAction() == "splitLine":
# split line
if digitClass.SplitLine(self.Pixel2Cell(self.mouse['begin'])) < 0:
return
elif digitToolbar.GetAction() == "addVertex":
# add vertex
- fid = digitClass.AddVertex(self.Pixel2Cell(self.mouse['begin']))
- if fid < 0:
+ if digitClass.AddVertex(self.Pixel2Cell(self.mouse['begin'])) < 0:
return
elif digitToolbar.GetAction() == "removeVertex":
# remove vertex
- fid = digitClass.RemoveVertex(self.Pixel2Cell(self.mouse['begin']))
- if fid < 0:
+ if digitClass.RemoveVertex(self.Pixel2Cell(self.mouse['begin'])) < 0:
return
elif digitToolbar.GetAction() in ("copyCats", "copyAttrs"):
try:
if digitToolbar.GetAction() == 'copyCats':
@@ -2274,9 +1611,6 @@
del self.copyCatsIds
except AttributeError:
pass
elif digitToolbar.GetAction() == "editLine" and \
line = digitClass.driver.GetSelected()
@@ -2319,7 +1653,7 @@
nselected=len(selected))
if digitClass.ZBulkLines(pos1, pos2, dlg.value.GetValue(),
- dlg.step.GetValue()) < 0:
+ dlg.step.GetValue()) < 0:
return
self.UpdateMap(render=False, renderVector=True)
elif digitToolbar.GetAction() == "typeConv":
@@ -2337,15 +1671,13 @@
self.Refresh()
event.Skip()
def OnMiddleDown(self, event):
Middle mouse button pressed
- self.mouse['begin'] = event.GetPositionTuple()[:]
# digitization tool
if self.mouse["use"] == "pointer" and digitToolbar:
@@ -2406,27 +1738,9 @@
- def OnMiddleUp(self, event):
- Middle mouse button released
- self.mouse['end'] = event.GetPositionTuple()[:]
- # set region in zoom or pan
- begin = self.mouse['begin']
- end = self.mouse['end']
- self.Zoom(begin, end, 0) # no zoom
- # redraw map
- self.UpdateMap(render=True)
def OnMouseMoving(self, event):
Motion event and no mouse buttons were pressed
@@ -2493,7 +1807,7 @@
event.Skip()
def ClearLines(self, pdc=None):
Clears temporary drawn lines from PseudoDC
if not pdc:
@@ -2518,7 +1832,7 @@
return True
def Pixel2Cell(self, (x, y)):
Convert image coordinates to real word coordinates
Input : int x, int y
@@ -2549,7 +1863,7 @@
return (east, north)
def Cell2Pixel(self, (east, north)):
Convert real word coordinates to image coordinates
@@ -2576,7 +1890,7 @@
return (x, y)
def Zoom(self, begin, end, zoomtype):
Calculates new region while (un)zoom/pan-ing
x1, y1 = begin
@@ -2652,120 +1966,95 @@
def ZoomBack(self):
- """!Zoom to previous extents in zoomhistory list
- zoom = list()
+ Zoom to previous extents in zoomhistory list
+ zoom = []
if len(self.zoomhistory) > 1:
self.zoomhistory.pop()
- zoom = self.zoomhistory[-1]
- # disable tool if stack is empty
- if len(self.zoomhistory) < 2: # disable tool
- if self.parent.GetName() == 'MapWindow':
- toolbar = self.parent.toolbars['map']
- elif self.parent.GetName() == 'GRMapWindow':
- toolbar = self.parent.toolbars['georect']
- toolbar.Enable('zoomback', enable = False)
- # zoom to selected region
- self.Map.GetRegion(n = zoom[0], s = zoom[1],
- e = zoom[2], w = zoom[3],
- update = True)
- # update map
- self.UpdateMap()
+ zoom = self.zoomhistory[len(self.zoomhistory)-1]
+ # (n, s, e, w)
+ if zoom:
+ # zoom to selected region
+ self.Map.region['center_easting'] = zoom[3] + \
+ (zoom[2] - zoom[3]) / 2
+ self.Map.region['center_northing'] = zoom[1] + \
+ (zoom[0] - zoom[1]) / 2
+ self.Map.region["ewres"] = (zoom[2] - zoom[3]) / self.Map.width
+ self.Map.region["nsres"] = (zoom[0] - zoom[1]) / self.Map.height
+ self.Map.AlignExtentFromDisplay()
+ # update map
+ self.UpdateMap()
def ZoomHistory(self, n, s, e, w):
Manages a list of last 10 zoom extents
- @param n,s,e,w north, south, east, west
- @return removed history item if exists (or None)
+ Return removed history item if exists
removed = None
self.zoomhistory.append((n,s,e,w))
if len(self.zoomhistory) > 10:
removed = self.zoomhistory.pop(0)
if removed:
Debug.msg(4, "BufferedWindow.ZoomHistory(): hist=%s, removed=%s" %
(self.zoomhistory, removed))
else:
Debug.msg(4, "BufferedWindow.ZoomHistory(): hist=%s" %
(self.zoomhistory))
- # update toolbar
- if len(self.zoomhistory) > 1:
- enable = True
- else:
- enable = False
- if self.parent.GetName() == 'pg_panel':
- toolbar.Enable('zoomback', enable)
return removed
- def ResetZoomHistory(self):
- """!Reset zoom history"""
- self.zoomhistory = list()
def OnZoomToMap(self, event):
Set display extents to match selected raster (including NULLs)
or vector map.
self.ZoomToMap()
def OnZoomToRaster(self, event):
Set display extents to match selected raster map (ignore NULLs)
- self.ZoomToMap(ignoreNulls = True)
+ self.ZoomToMap(zoom=True)
- def ZoomToMap(self, layers = None, ignoreNulls = False, render = True):
+ def ZoomToMap(self, layer = None, zoom = False):
- or vector map(s).
- @param layer list of layers to be zoom to
- @param ignoreNulls True to ignore null-values
- @param render True to re-render display
+ or vector map.
zoomreg = {}
- if not layers:
- layers = self.GetSelectedLayer(multi = True)
+ if not layer:
+ layer = self.GetSelectedLayer(multi = True)
- if not layers:
+ if not layer:
return
rast = []
vect = []
updated = False
- for l in layers:
+ for l in layer:
# only raster/vector layers are currently supported
if l.type == 'raster':
rast.append(l.name)
elif l.type == 'vector':
- if digitToolbar and digitToolbar.GetLayer() == l:
+ if self.parent.digit and l.name == self.parent.digit.map and \
+ self.parent.digit.type == 'vdigit':
w, s, b, e, n, t = self.parent.digit.driver.GetMapBoundingBox()
self.Map.GetRegion(n=n, s=s, w=w, e=e,
update=True)
updated = True
else:
vect.append(l.name)
if not updated:
self.Map.GetRegion(rast = rast,
vect = vect,
@@ -2773,14 +2062,16 @@
self.ZoomHistory(self.Map.region['n'], self.Map.region['s'],
self.Map.region['e'], self.Map.region['w'])
- if render:
- self.UpdateMap()
+ self.flag=True
+ self.UpdateMap()
def ZoomToWind(self, event):
Set display geometry to match computational
region settings (set with g.region)
@@ -2795,7 +2086,7 @@
def ZoomToDefault(self, event):
Set display geometry to match default region settings
self.Map.region = self.Map.GetRegion(default=True)
@@ -2809,7 +2100,7 @@
def DisplayToWind(self, event):
Set computational region (WIND file) to
match display extents
@@ -2820,16 +2111,17 @@
# We ONLY want to set extents here. Don't mess with resolution. Leave that
# for user to set explicitly with g.region
new = self.Map.AlignResolution()
- gcmd.RunCommand('g.region',
- parent = self,
- overwrite = True,
- n = new['n'],
- s = new['s'],
- e = new['e'],
- w = new['w'],
- rows = int(new['rows']),
- cols = int(new['cols']))
+ cmdRegion = ["g.region", "--o",
+ "n=%f" % new['n'],
+ "s=%f" % new['s'],
+ "e=%f" % new['e'],
+ "w=%f" % new['w'],
+ "rows=%d" % int(new['rows']),
+ "cols=%d" % int(new['cols'])]
+ p = gcmd.Command(cmdRegion)
if tmpreg:
os.environ["GRASS_REGION"] = tmpreg
@@ -2837,22 +2129,19 @@
"""!Set display geometry to match extents in
saved region file
- dlg = gdialogs.SavedRegion(parent = self,
+ dlg = gdialogs.SavedRegion(parent = self, id = wx.ID_ANY,
title = _("Zoom to saved region extents"),
+ pos=wx.DefaultPosition, size=wx.DefaultSize,
+ style=wx.DEFAULT_DIALOG_STYLE,
loadsave='load')
- if dlg.ShowModal() == wx.ID_CANCEL or not dlg.wind:
+ if dlg.ShowModal() == wx.ID_CANCEL:
dlg.Destroy()
return
- if not grass.find_file(name = dlg.wind, element = 'windows')['name']:
- wx.MessageBox(parent = self,
- message = _("Region <%s> not found. Operation canceled.") % dlg.wind,
- caption = _("Error"), style = wx.ICON_ERROR | wx.OK | wx.CENTRE)
- dlg.Destroy()
- return
+ wind = dlg.wind
- self.Map.GetRegion(regionName = dlg.wind,
+ self.Map.GetRegion(regionName = wind,
update = True)
dlg.Destroy()
@@ -2863,61 +2152,69 @@
self.UpdateMap()
def SaveDisplayRegion(self, event):
Save display extents to named region file.
title = _("Save display extents to region file"),
loadsave='save')
dlg.Destroy()
return
+ wind = dlg.wind
# test to see if it already exists and ask permission to overwrite
- if grass.find_file(name = dlg.wind, element = 'windows')['name']:
- overwrite = wx.MessageBox(parent = self,
- message = _("Region file <%s> already exists. "
- "Do you want to overwrite it?") % (dlg.wind),
- caption = _("Warning"), style = wx.YES_NO | wx.CENTRE)
+ windpath = os.path.join(self.Map.env["GISDBASE"], self.Map.env["LOCATION_NAME"],
+ self.Map.env["MAPSET"], "windows", wind)
+ if windpath and not os.path.exists(windpath):
+ self.SaveRegion(wind)
+ elif windpath and os.path.exists(windpath):
+ overwrite = wx.MessageBox(_("Region file <%s> already exists. "
+ "Do you want to overwrite it?") % (wind),
+ _("Warning"), wx.YES_NO | wx.CENTRE)
if (overwrite == wx.YES):
- self.SaveRegion(dlg.wind)
else:
+ pass
dlg.Destroy()
def SaveRegion(self, wind):
- """!Save region settings
- @param wind region name
+ Save region settings
+ ### new = self.Map.AlignResolution()
new = self.Map.GetCurrentRegion()
+ "-u",
+ "rows=%d" % new['rows'],
+ "cols=%d" % new['cols'],
+ "save=%s" % wind,
+ "--o"]
tmpreg = os.getenv("GRASS_REGION")
if tmpreg:
del os.environ["GRASS_REGION"]
- overwrite = True,
- parent = self,
- flags = 'u',
- n = new['n'],
- s = new['s'],
- e = new['e'],
- w = new['w'],
- cols = int(new['cols']),
- save = wind)
if tmpreg:
def Distance(self, beginpt, endpt, screen=True):
- """!Calculete distance
+ """Calculete distance
LL-locations not supported
@@ -2935,10 +2232,12 @@
else:
dEast = (x2 - x1)
dNorth = (y2 - y1)
return (math.sqrt(math.pow((dEast),2) + math.pow((dNorth),2)), (dEast, dNorth))
class MapFrame(wx.Panel):
Main frame for map display window. Drawing takes place in child double buffered
@@ -2972,7 +2271,6 @@
self.statusFlag = flag
self.statusbar = None
#FIX THIS
@@ -3046,13 +2344,13 @@
key='statusbarMode',
subkey='selection'))
-# self.statusbar.Bind(wx.EVT_CHOICE, self.OnToggleStatus, self.statusbarWin['toggle'])
+ self.statusbar.Bind(wx.EVT_CHOICE, self.OnToggleStatus, self.statusbarWin['toggle'])
# auto-rendering checkbox
self.statusbarWin['render'] = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
label=_("Render"))
- # self.statusbar.Bind(wx.EVT_CHECKBOX, self.OnToggleRender, self.statusbarWin['render'])
+ self.statusbar.Bind(wx.EVT_CHECKBOX, self.OnToggleRender, self.statusbarWin['render'])
self.statusbarWin['render'].SetValue(UserSettings.Get(group='display',
key='autoRendering',
@@ -3132,7 +2430,7 @@
self.MapWindow2D = BufferedWindow(self, id=wx.ID_ANY, Map=self.Map, tree=self.tree, gismgr=self._layerManager)
# default is 2D display mode
self.MapWindow = self.MapWindow2D
- self.MapWindow.Bind(wx.EVT_MOTION, self.OnMotion)
+ #self.MapWindow.Bind(wx.EVT_MOTION, self.OnMotion)
self.MapWindow.SetCursor(self.cursors["default"])
# used by Nviz (3D display mode)
self.MapWindow3D = None
@@ -3219,8 +2517,6 @@
size=wx.DefaultSize, style=wx.TR_HAS_BUTTONS
|wx.TR_LINES_AT_ROOT|wx.TR_HIDE_ROOT,
gisdbase=self.gisdbase)
- self.tree = self.maptree
#self.maptree.SetBackgroundColour("red")
self._mgr.AddPane(self.maptree, wx.aui.AuiPaneInfo().Left().
@@ -3228,9 +2524,6 @@
CloseButton(False).DestroyOnClose(True).
Layer(0).Caption("Map Tree"))
self._mgr.Update()
#r.rightSizer.Add(self.maptree)
