[GRASS-SVN] r42038 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Mon Apr 26 15:20:29 EDT 2010
Author: martinl
Date: 2010-04-26 15:20:29 -0400 (Mon, 26 Apr 2010)
New Revision: 42038
grass/trunk/gui/wxpython/gui_modules/gselect.py
grass/trunk/gui/wxpython/gui_modules/menuform.py
wxGUI: use GdalSelect in menuform
Modified: grass/trunk/gui/wxpython/gui_modules/gselect.py
--- grass/trunk/gui/wxpython/gui_modules/gselect.py 2010-04-26 18:43:15 UTC (rev 42037)
+++ grass/trunk/gui/wxpython/gui_modules/gselect.py 2010-04-26 19:20:29 UTC (rev 42038)
@@ -34,6 +34,7 @@
import wx
import wx.combo
import wx.lib.filebrowsebutton as filebrowse
+from wx.lib.newevent import NewEvent
import globalvar
@@ -45,6 +46,8 @@
import utils
from preferences import globalSettings as UserSettings
+wxGdalSelect, EVT_GDALSELECT = NewEvent()
class Select(wx.combo.ComboCtrl):
def __init__(self, parent, id, size = globalvar.DIALOG_GSELECT_SIZE,
type = None, multiple = False, mapsets = None, exclude = [],
@@ -1102,25 +1105,8 @@
path = event.GetString()
if not path:
return
data = list()
- # if self.importType == 'dxf':
- # ret = gcmd.RunCommand('v.in.dxf',
- # quiet = True,
- # parent = self,
- # read = True,
- # flags = 'l',
- # input = path)
- # if not ret:
- # self.list.LoadData()
- # self.btn_run.Enable(False)
- # return
- # for line in ret.splitlines():
- # layerId = line.split(':')[0].split(' ')[1]
- # layerName = line.split(':')[1].strip()
- # grassName = utils.GetValidLayerName(layerName)
- # data.append((layerId, layerName.strip(), grassName.strip()))
layerId = 1
if self.format.GetStringSelection() == 'PostgreSQL':
@@ -1159,6 +1145,10 @@
layerId += 1
+ evt = wxGdalSelect(dsn = dsn)
+ evt.SetId(self.input[self.dsnType][1].GetId())
+ wx.PostEvent(self.parent, evt)
if self.parent.GetName() == 'MultiImportDialog':
self.parent.list.LoadData(data)
if len(data) > 0:
@@ -1166,6 +1156,8 @@
else:
self.parent.btn_run.Enable(False)
+ event.Skip()
def OnSetFormat(self, event):
"""!Format changed"""
if self.dsnType not in ['file', 'db']:
@@ -1240,9 +1232,10 @@
return self.input[self.dsnType][1].GetValue()
- def SetDsnHandler(self):
- """!Get DSN"""
+ def GetDsnWin(self):
+ """!Get DSN windows"""
+ return self.input[self.dsnType][1]
def GetFormatExt(self):
"""!Get format extension"""
return self.format.GetExtension(self.format.GetStringSelection())
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py 2010-04-26 18:43:15 UTC (rev 42037)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py 2010-04-26 19:20:29 UTC (rev 42038)
@@ -706,7 +706,8 @@
pass
wx.Frame.__init__(self, parent=parent, id=ID, title=title,
- pos=wx.DefaultPosition, style=wx.DEFAULT_FRAME_STYLE | wx.TAB_TRAVERSAL)
+ pos=wx.DefaultPosition, style=wx.DEFAULT_FRAME_STYLE | wx.TAB_TRAVERSAL,
+ name = "MainFrame")
self.locale = wx.Locale(language = wx.LANGUAGE_DEFAULT)
@@ -1035,9 +1036,9 @@
return self.notebookpanel.createCmd(ignoreErrors=ignoreErrors)
class cmdPanel(wx.Panel):
+ """!A panel containing a notebook dividing in tabs the different
+ guisections of the GRASS cmd.
- A panel containing a notebook dividing in tabs the different guisections of the GRASS cmd.
def __init__( self, parent, task, standalone, mainFrame, *args, **kwargs ):
wx.Panel.__init__( self, parent, *args, **kwargs )
@@ -1421,6 +1422,9 @@
defSource = 'dir',
sources = [_("Directory"),
_("Database"), _("Protocol")])
+ self.Bind(gselect.EVT_GDALSELECT, self.OnUpdateSelection)
+ self.Bind(gselect.EVT_GDALSELECT, self.OnSetValue)
ogrSelection.SetName('OgrSelect')
ogrSelection.Hide()
@@ -1428,6 +1432,7 @@
p['wxId'].append(rbox.GetId())
p['wxId'].append(ogrSelection.GetId())
+ p['wxId'].append(ogrSelection.GetDsnWin().GetId())
else:
which_sizer.Add(item=selection, proportion=0,
flag=wx.ADJUST_MINSIZE | wx.BOTTOM | wx.LEFT | wx.RIGHT | wx.TOP | wx.ALIGN_CENTER_VERTICAL,
@@ -1872,7 +1877,6 @@
myId = event.GetId()
me = wx.FindWindowById(myId)
name = me.GetName()
for porf in self.task.params + self.task.flags:
if 'wxId' in porf:
found = False
