[GRASS-SVN] r42056 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Apr 28 17:14:47 EDT 2010
Author: martinl
Date: 2010-04-28 17:14:46 -0400 (Wed, 28 Apr 2010)
New Revision: 42056
grass/trunk/gui/wxpython/gui_modules/gcmd.py
grass/trunk/gui/wxpython/gui_modules/gselect.py
grass/trunk/gui/wxpython/gui_modules/layertree.py
grass/trunk/gui/wxpython/gui_modules/menuform.py
grass/trunk/gui/wxpython/gui_modules/utils.py
wxGUI: direct OGR read access fixes
Modified: grass/trunk/gui/wxpython/gui_modules/gcmd.py
--- grass/trunk/gui/wxpython/gui_modules/gcmd.py 2010-04-28 19:27:09 UTC (rev 42055)
+++ grass/trunk/gui/wxpython/gui_modules/gcmd.py 2010-04-28 21:14:46 UTC (rev 42056)
@@ -79,19 +79,27 @@
caption = caption,
style = style)
else:
- exception = traceback.format_exc()
- reason = exception.split('\n')[-2].split(':', 1)[-1].strip()
- if Debug.get_level() > 0:
+ exc_type, exc_value, exc_traceback = sys.exc_info()
+ if exc_traceback:
+ exception = traceback.format_exc()
+ reason = exception.splitlines()[-2].split(':', 1)[-1].strip()
+ if Debug.get_level() > 0 and exc_traceback:
sys.stderr.write(exception)
- wx.MessageBox(parent = parent,
- message = message + '\n\n%s: %s\n\n%s' % \
- (_('Reason'),
- reason, exception),
- caption = caption,
- style = style)
+ if exc_traceback:
+ wx.MessageBox(parent = parent,
+ message = message + '\n\n%s: %s\n\n%s' % \
+ (_('Reason'),
+ reason, exception),
+ caption = caption,
+ style = style)
+ else:
+ message = message,
+ style = style)
class GError(Exception):
def __init__(self, value):
self.value = value
Modified: grass/trunk/gui/wxpython/gui_modules/gselect.py
--- grass/trunk/gui/wxpython/gui_modules/gselect.py 2010-04-28 19:27:09 UTC (rev 42055)
+++ grass/trunk/gui/wxpython/gui_modules/gselect.py 2010-04-28 21:14:46 UTC (rev 42056)
@@ -983,18 +983,22 @@
startDirectory=os.getcwd(),
changeCallback=self.OnSetDsn)
dsnDbFile.Hide()
+ dsnDbFile.SetName('GdalSelect')
dsnDbText = wx.TextCtrl(parent = self, id = wx.ID_ANY)
dsnDbText.Hide()
dsnDbText.Bind(wx.EVT_TEXT, self.OnSetDsn)
+ dsnDbText.SetName('GdalSelect')
dsnDbChoice = wx.Choice(parent = self, id = wx.ID_ANY)
dsnDbChoice.Hide()
dsnDbChoice.Bind(wx.EVT_CHOICE, self.OnSetDsn)
+ dsnDbChoice.SetName('GdalSelect')
dsnPro = wx.TextCtrl(parent = self, id = wx.ID_ANY)
dsnPro.Hide()
dsnPro.Bind(wx.EVT_TEXT, self.OnSetDsn)
+ dsnPro.SetName('GdalSelect')
# format
self.format = FormatSelect(parent = self,
@@ -1163,7 +1167,7 @@
data.append((layerId, layerName.strip(), grassName.strip()))
layerId += 1
- evt = wxGdalSelect(dsn = dsn)
+ evt = wxGdalSelect(dsn = dsn + '@OGR')
evt.SetId(self.input[self.dsnType][1].GetId())
wx.PostEvent(self.parent, evt)
@@ -1251,8 +1255,14 @@
return self.input[self.dsnType][1].GetValue()
def GetDsnWin(self):
- """!Get DSN windows"""
- return self.input[self.dsnType][1]
+ """!Get list of DSN windows"""
+ win = list()
+ for stype in ('file', 'dir', 'pro'):
+ win.append(self.input[stype][1])
+ for stype in ('file', 'text', 'choice'):
+ win.append(self.input['db-win'][stype])
+ return win
def GetFormatExt(self):
"""!Get format extension"""
Modified: grass/trunk/gui/wxpython/gui_modules/layertree.py
--- grass/trunk/gui/wxpython/gui_modules/layertree.py 2010-04-28 19:27:09 UTC (rev 42055)
+++ grass/trunk/gui/wxpython/gui_modules/layertree.py 2010-04-28 21:14:46 UTC (rev 42056)
@@ -46,6 +46,7 @@
from icon import Icons as Icons
from preferences import globalSettings as UserSettings
from vdigit import haveVDigit
+from gcmd import GMessage
try:
import subprocess
except:
@@ -1293,11 +1294,8 @@
mapname = utils.GetLayerNameFromCmd(dcmd, layerType=mapLayer.type,
fullyQualified=True)
if not mapname:
- wx.MessageBox(parent=self,
- message=_("Map <%s> not found.") % utils.GetLayerNameFromCmd(dcmd),
- caption=_("Error"),
- style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
+ GMessage(parent=self,
+ message=_("Map <%s> not found.") % utils.GetLayerNameFromCmd(dcmd))
return
self.SetItemText(layer, mapname + ' (opacity: ' + str(opacity) + '%)')
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py 2010-04-28 19:27:09 UTC (rev 42055)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py 2010-04-28 21:14:46 UTC (rev 42056)
@@ -1431,7 +1431,8 @@
p['wxId'].append(rbox.GetId())
p['wxId'].append(ogrSelection.GetId())
- p['wxId'].append(ogrSelection.GetDsnWin().GetId())
+ for win in ogrSelection.GetDsnWin():
+ p['wxId'].append(win.GetId())
else:
which_sizer.Add(item=selection, proportion=0,
flag=wx.ADJUST_MINSIZE | wx.BOTTOM | wx.LEFT | wx.RIGHT | wx.TOP | wx.ALIGN_CENTER_VERTICAL,
@@ -1889,11 +1890,11 @@
if found:
if name in ('LayerSelect', 'DriverSelect', 'TableSelect'):
porf['value'] = me.GetStringSelection()
+ elif name == 'GdalSelect':
+ porf['value'] = event.dsn
else:
porf['value'] = me.GetValue()
- if name == 'GdalSelect':
- porf['value'] += '@OGR'
self.OnUpdateValues()
Modified: grass/trunk/gui/wxpython/gui_modules/utils.py
--- grass/trunk/gui/wxpython/gui_modules/utils.py 2010-04-28 19:27:09 UTC (rev 42055)
+++ grass/trunk/gui/wxpython/gui_modules/utils.py 2010-04-28 21:14:46 UTC (rev 42056)
@@ -98,7 +98,7 @@
params = list()
for idx in range(len(dcmd)):
try:
- p, v = dcmd[idx].split('=')
+ p, v = dcmd[idx].split('=', 1)
except ValueError:
continue
@@ -111,7 +111,7 @@
'h_map', 's_map', 'i_map',
'reliefmap'):
params.append((idx, p, v))
if len(params) < 1:
return mapname
@@ -147,7 +147,7 @@
ogr = True
if p == 'layer' and not ogr:
continue
- maps.append(dcmd[i].split('=')[1])
+ maps.append(dcmd[i].split('=', 1)[1])
mapname = '\n'.join(maps)
return mapname
