[GRASS-SVN] r42959 - grass/trunk/scripts/v.db.droptable
Sun Aug 1 05:00:40 EDT 2010
Author: mmetz
Date: 2010-08-01 09:00:40 +0000 (Sun, 01 Aug 2010)
New Revision: 42959
   grass/trunk/scripts/v.db.droptable/v.db.droptable.py
find grass.vector_layer_db, use the vector's database and driver
Modified: grass/trunk/scripts/v.db.droptable/v.db.droptable.py
--- grass/trunk/scripts/v.db.droptable/v.db.droptable.py	2010-08-01 03:16:39 UTC (rev 42958)
+++ grass/trunk/scripts/v.db.droptable/v.db.droptable.py	2010-08-01 09:00:40 UTC (rev 42959)
@@ -48,7 +48,7 @@
 import sys
 import os
-from grass.script import core as grass
+import grass.script as grass
 def main():
     force = flags['f']
@@ -85,7 +85,8 @@
     grass.message(_("Dropping table <%s>...") % table)
-    if grass.write_command('db.execute', stdin = "DROP TABLE %s" % table, input = '-') != 0:
+    if grass.write_command('db.execute', stdin = "DROP TABLE %s" % table, input = '-',
+                           database = database, driver = driver) != 0:
 	grass.fatal(_("An error occured while running db.execute"))
     grass.run_command('v.db.connect', flags = 'd', map = map, layer = layer)
