[GRASS-SVN] r42980 - grass/trunk/vector/v.db.connect
svn_grass at osgeo.org
Tue Aug 3 06:19:48 EDT 2010
Author: mmetz
Date: 2010-08-03 10:19:47 +0000 (Tue, 03 Aug 2010)
New Revision: 42980
grass/trunk/vector/v.db.connect/main.c
print shell script style output in shell script style
Modified: grass/trunk/vector/v.db.connect/main.c
--- grass/trunk/vector/v.db.connect/main.c 2010-08-03 09:48:12 UTC (rev 42979)
+++ grass/trunk/vector/v.db.connect/main.c 2010-08-03 10:19:47 UTC (rev 42980)
@@ -78,6 +78,7 @@
sep_opt = G_define_standard_option(G_OPT_F_SEP);
sep_opt->description = _("Field separator for shell script style output");
sep_opt->guisection = _("Print");
+ sep_opt->answer = "=";
print = G_define_flag();
print->key = 'p';
@@ -86,8 +87,7 @@
shell_print = G_define_flag();
shell_print->key = 'g';
- shell_print->label = _("Print all map connection parameters and exit "
- "in shell script style");
+ shell_print->label = _("Print all map connection parameters in shell script style and exit");
shell_print->description =
_("Format: layer[/layer name] table key database driver");
shell_print->guisection = _("Print");
@@ -171,32 +171,27 @@
if (shell_print->answer) {
const char *sep = sep_opt->answer;
- if (fi->name) {
- fprintf(stdout, "%d/%s%s%s%s%s%s%s%s%s\n",
- fi->number, fi->name, sep,
- fi->table, sep, fi->key, sep,
- fi->database, sep, fi->driver);
- else {
- fprintf(stdout, "%d%s%s%s%s%s%s%s%s\n",
- fi->number, sep,
+ if (!sep)
+ sep = "=";
+ fprintf(stdout, "layer%s%d\n", sep, fi->number);
+ if (fi->name)
+ fprintf(stdout, "name%s%s\n", sep, fi->name);
+ fprintf(stdout, "table%s%s\n", sep, fi->table);
+ fprintf(stdout, "key%s%s\n", sep, fi->key);
+ fprintf(stdout, "database%s%s\n", sep, fi->database);
+ fprintf(stdout, "driver%s%s\n", sep, fi->driver);
else {
if (fi->name) {
- fprintf(stdout,
- _("layer <%d/%s> table <%s> in database <%s> through driver "
- "<%s> with key <%s>\n"), fi->number, fi->name,
- fi->table, fi->database, fi->driver, fi->key);
+ G_message(_("layer <%d/%s>"), fi->number, fi->name);
else {
- fprintf(stdout,
- _("layer <%d> table <%s> in database <%s> through driver "
+ G_message(_("layer <%d>"), fi->number);
+ G_message(_("table <%s>"), fi->table);
+ G_message(_("in database <%s>"), fi->database);;
+ G_message(_("through driver <%s>"), fi->driver);
+ G_message(_("with key <%s>"), fi->key);
} /* end print */
