[GRASS-SVN] r42991 - in grass-addons/raster/r.pi: . r.pi.export
Wed Aug 4 06:53:56 EDT 2010
Author: wegmann
Date: 2010-08-04 10:53:56 +0000 (Wed, 04 Aug 2010)
New Revision: 42991
Added:
   grass-addons/raster/r.pi/r.pi.export/
   grass-addons/raster/r.pi/r.pi.export/Makefile
   grass-addons/raster/r.pi/r.pi.export/description.html
   grass-addons/raster/r.pi/r.pi.export/frag.c
   grass-addons/raster/r.pi/r.pi.export/helpers.c
   grass-addons/raster/r.pi/r.pi.export/local_proto.h
   grass-addons/raster/r.pi/r.pi.export/main.c
   grass-addons/raster/r.pi/r.pi.export/stat_method.c
new module for exporting raster values based on patches
Added: grass-addons/raster/r.pi/r.pi.export/Makefile
--- grass-addons/raster/r.pi/r.pi.export/Makefile	                        (rev 0)
+++ grass-addons/raster/r.pi/r.pi.export/Makefile	2010-08-04 10:53:56 UTC (rev 42991)
@@ -0,0 +1,10 @@
+MODULE_TOPDIR = ../..
+PGM = r.pi.export
+LIBES = $(STATSLIB) $(GISLIB)
+DEPENDENCIES = $(STATSDEP) $(GISDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Property changes on: grass-addons/raster/r.pi/r.pi.export/Makefile
___________________________________________________________________
Added: svn:executable
Added: grass-addons/raster/r.pi/r.pi.export/description.html
--- grass-addons/raster/r.pi/r.pi.export/description.html	                        (rev 0)
+++ grass-addons/raster/r.pi/r.pi.export/description.html	2010-08-04 10:53:56 UTC (rev 42991)
@@ -0,0 +1,27 @@
+<H2>DESCRIPTION</H2>
+The <EM>r.pi.export</EM> module computes statistics of values within a patch and exports them to an ascii file. Additionally the raw patch values split up by patch ID are exported. The <EM>patch ID</EM>
+raster can be generated in order to visually link patch statistics and individual patches.
+<P>
+The program will be run non-interactively if the user specifies program arguments (see OPTIONS) on the command
+line.  Alternately, the user can simply type <B>r.pi.export</B> on the command line, without program
+arguments.  In this case, the user will be prompted for flag settings and parameter values.
+<H2>NOTES</H2>
+For export and import of patch values after e.g. R calculation <EM>r.pi.export</EM> and <EM>r.pi.import</EM> can be applied using the same raster (same extent, resolution is mandatory).
+<H2>SEE ALSO</H2>
+<EM><A HREF="r.pi.import/description.html">r.pi.import</A></EM><br>
+<H2>AUTHOR</H2>
+Programming: Elshad Shirinov<br>
+Scientific concept: Dr. Martin Wegmann <br>
+Department of Remote Sensing <br>Remote Sensing and Biodiversity Unit<br> University of Wuerzburg, Germany
Property changes on: grass-addons/raster/r.pi/r.pi.export/description.html
Added: grass-addons/raster/r.pi/r.pi.export/frag.c
--- grass-addons/raster/r.pi/r.pi.export/frag.c	                        (rev 0)
+++ grass-addons/raster/r.pi/r.pi.export/frag.c	2010-08-04 10:53:56 UTC (rev 42991)
@@ -0,0 +1,196 @@
+#include "local_proto.h"
+typedef struct
+    int x, y;
+} Position;
+Coords *writeFrag(DCELL * flagbuf, Coords * actpos, int row, int col,
+		  int nrows, int ncols, int nbr_cnt);
+int getNeighbors(Position * res, DCELL * flagbuf, int x, int y, int nx,
+		 int ny, int nbr_cnt);
+    int left, right, top, bottom;
+    int i, j;
+    int cnt = 0;
+    switch (nbr_cnt) {
+    case 4:			/* von Neumann neighborhood */
+	if (x > 0 && !G_is_d_null_value(&flagbuf[y * nx + x - 1])) {
+	    res[cnt].x = x - 1;
+	    res[cnt].y = y;
+	    cnt++;
+	if (y > 0 && !G_is_d_null_value(&flagbuf[(y - 1) * nx + x])) {
+	    res[cnt].x = x;
+	    res[cnt].y = y - 1;
+	    cnt++;
+	if (x < nx - 1 && !G_is_d_null_value(&flagbuf[y * nx + x + 1])) {
+	    res[cnt].x = x + 1;
+	    res[cnt].y = y;
+	    cnt++;
+	if (y < ny - 1 && !G_is_d_null_value(&flagbuf[(y + 1) * nx + x])) {
+	    res[cnt].x = x;
+	    res[cnt].y = y + 1;
+	    cnt++;
+	break;
+    case 8:			/* Moore neighborhood */
+	left = x > 0 ? x - 1 : 0;
+	top = y > 0 ? y - 1 : 0;
+	right = x < nx - 1 ? x + 1 : nx - 1;
+	bottom = y < ny - 1 ? y + 1 : ny - 1;
+	for (i = left; i <= right; i++) {
+	    for (j = top; j <= bottom; j++) {
+		if (!(i == x && j == y) &&
+		    !G_is_d_null_value(&flagbuf[j * nx + i])) {
+		    res[cnt].x = i;
+		    res[cnt].y = j;
+		    cnt++;
+	break;
+    return cnt;
+    int x, y, i;
+    Position *list = (Position *) G_malloc(nrows * ncols * sizeof(Position));
+    Position *first = list;
+    Position *last = list;
+    Position *nbr_list = (Position *) G_malloc(8 * sizeof(Position));
+    /* count neighbors */
+    int neighbors = 0;
+    if (col <= 0 || !G_is_d_null_value(&flagbuf[row * ncols + col - 1]))
+	neighbors++;
+    if (row <= 0 || !G_is_d_null_value(&flagbuf[(row - 1) * ncols + col]))
+	neighbors++;
+    if (col >= ncols - 1 ||
+	!G_is_d_null_value(&flagbuf[row * ncols + col + 1]))
+	neighbors++;
+    if (row >= nrows - 1 ||
+	!G_is_d_null_value(&flagbuf[(row + 1) * ncols + col]))
+	neighbors++;
+    /* write first cell */
+    actpos->x = col;
+    actpos->y = row;
+    actpos->neighbors = neighbors;
+    actpos->value = flagbuf[row * ncols + col];
+    actpos++;
+    /* write position to id map */
+    id_map[row * ncols + col] = fragcount - 1;
+    /* delete position from buffer */
+    G_set_d_null_value(&flagbuf[row * ncols + col], 1);
+    /* push position on fifo-list */
+    last->x = col;
+    last->y = row;
+    last++;
+    while (first < last) {
+	/* get position from fifo-list */
+	int r = first->y;
+	int c = first->x;
+	first++;
+	int left = c > 0 ? c - 1 : 0;
+	int top = r > 0 ? r - 1 : 0;
+	int right = c < ncols - 1 ? c + 1 : ncols - 1;
+	int bottom = r < nrows - 1 ? r + 1 : nrows - 1;
+	/* add neighbors to fifo-list */
+	int cnt =
+	    getNeighbors(nbr_list, flagbuf, c, r, ncols, nrows, nbr_cnt);
+	for (i = 0; i < cnt; i++) {
+	    x = nbr_list[i].x;
+	    y = nbr_list[i].y;
+	    /* add position to fifo-list */
+	    last->x = x;
+	    last->y = y;
+	    last++;
+	    neighbors = 0;
+	    if (x <= 0 || !G_is_d_null_value(&flagbuf[y * ncols + x - 1]))
+		neighbors++;
+	    if (y <= 0 || !G_is_d_null_value(&flagbuf[(y - 1) * ncols + x]))
+		neighbors++;
+	    if (x >= ncols - 1 ||
+		!G_is_d_null_value(&flagbuf[y * ncols + x + 1]))
+		neighbors++;
+	    if (y >= nrows - 1 ||
+		!G_is_d_null_value(&flagbuf[(y + 1) * ncols + x]))
+		neighbors++;
+	    /* set values */
+	    actpos->x = x;
+	    actpos->y = y;
+	    actpos->value = flagbuf[y * ncols + x];
+	    actpos++;
+	    id_map[y * ncols + x] = fragcount - 1;
+	    G_set_d_null_value(&flagbuf[y * ncols + x], 1);
+    G_free(list);
+    G_free(nbr_list);
+    return actpos;
+void writeFragments(DCELL * flagbuf, int nrows, int ncols, int nbr_cnt)
+    int row, col, i;
+    Coords *p;
+    fragcount = 0;
+    Coords *actpos = fragments[0];
+    /* find fragments */
+    for (row = 0; row < nrows; row++) {
+	for (col = 0; col < ncols; col++) {
+	    if (!G_is_d_null_value(&flagbuf[row * ncols + col])) {
+		fragcount++;
+		fragments[fragcount] =
+		    writeFrag(flagbuf, fragments[fragcount - 1], row, col,
+			      nrows, ncols, nbr_cnt);
+    return;
Added: grass-addons/raster/r.pi/r.pi.export/helpers.c
--- grass-addons/raster/r.pi/r.pi.export/helpers.c	                        (rev 0)
+++ grass-addons/raster/r.pi/r.pi.export/helpers.c	2010-08-04 10:53:56 UTC (rev 42991)
@@ -0,0 +1,95 @@
+int Round(double d)
+    return d < 0 ? d - 0.5 : d + 0.5;
+int Random(int max)
+    return max <=
+	RAND_MAX ? rand() % max : floor((double)rand() /
+					(double)(RAND_MAX + 1) * max);
+double Randomf()
+    return ((double)rand()) / ((double)RAND_MAX);
+void print_buffer(int *buffer, int sx, int sy)
+    int x, y;
+    fprintf(stderr, "buffer:\n");
+    for (y = 0; y < sy; y++) {
+	for (x = 0; x < sx; x++) {
+	    switch (buffer[x + y * sx]) {
+	    case NOTHING:
+		fprintf(stderr, ".");
+		break;
+	    default:
+		if (buffer[x + y * sx] < 0) {
+		    fprintf(stderr, "%d", buffer[x + y * sx]);
+		else {
+		break;
+	fprintf(stderr, "\n");
+void print_d_buffer(DCELL * buffer, int sx, int sy)
+    int x, y;
+	    fprintf(stderr, "%0.2f ", buffer[y * sx + x]);
+void print_array(DCELL * buffer, int size)
+    int i;
+    for (i = 0; i < size; i++) {
+	fprintf(stderr, "%0.2f ", buffer[i]);
+void print_fragments()
+    int f;
+    Coords *p;
+    for (f = 0; f < fragcount; f++) {
+	fprintf(stderr, "frag%d: ", f);
+	for (p = fragments[f]; p < fragments[f + 1]; p++) {
+	    fprintf(stderr, "(%d,%d), n=%d, val=%0.2f;", p->x, p->y,
+		    p->neighbors, p->value);
+void print_map(double *map, int size)
+    int x, y;
+    fprintf(stderr, "map:\n");
+    for (y = 0; y < size; y++) {
+	for (x = 0; x < size; x++) {
+	    fprintf(stderr, "%0.0f ", map[x + y * size]);
Added: grass-addons/raster/r.pi/r.pi.export/local_proto.h
--- grass-addons/raster/r.pi/r.pi.export/local_proto.h	                        (rev 0)
+++ grass-addons/raster/r.pi/r.pi.export/local_proto.h	2010-08-04 10:53:56 UTC (rev 42991)
@@ -0,0 +1,88 @@
+#ifndef LOCAL_PROTO_H
+#define LOCAL_PROTO_H
+#include <string.h>
+#include <stdlib.h>
+#include <unistd.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+#include <grass/stats.h>
+#include <math.h>
+#include <time.h>
+#define NOTHING 0
+#define RESOLUTION 10000
+#define MIN_DOUBLE -1000000
+#define MAX_DOUBLE 1000000
+typedef struct
+    int x, y;
+    int neighbors;
+    DCELL value;
+} Coords;
+typedef struct
+    int x, y;
+} Point;
+typedef struct
+    int x, y;
+    int patch;
+} PatchPoint;
+typedef DCELL(*f_statmethod) (DCELL *, int);
+/* helpers.c */
+int Round(double d);
+int Random(int max);
+double Randomf();
+void print_buffer(int *buffer, int sx, int sy);
+void print_d_buffer(DCELL * buffer, int sx, int sy);
+void print_map(double *map, int size);
+void print_array(DCELL * buffer, int size);
+void print_fragments();
+/* frag.c */
+void writeFragments(DCELL * flagbuf, int nrows, int ncols, int nbr_cnt);
+/* stat_method.c */
+DCELL average(DCELL * vals, int count);
+DCELL variance(DCELL * vals, int count);
+DCELL std_deviat(DCELL * vals, int count);
+DCELL median(DCELL * vals, int count);
+DCELL min(DCELL * vals, int count);
+DCELL max(DCELL * vals, int count);
+/* global variables */
+int verbose;
+Coords **fragments;
+Coords *cells;
+int fragcount;
+int sx, sy;
+int *id_map;
+int *adj_matrix;
+#endif /* LOCAL_PROTO_H */
Added: grass-addons/raster/r.pi/r.pi.export/main.c
--- grass-addons/raster/r.pi/r.pi.export/main.c	                        (rev 0)
+++ grass-addons/raster/r.pi/r.pi.export/main.c	2010-08-04 10:53:56 UTC (rev 42991)
@@ -0,0 +1,436 @@
+   Export of patch based values
+   by Elshad Shirinov.
+struct statmethod
+    f_statmethod *method;	/* routine to compute new value */
+    char *name;			/* method name */
+    char *text;			/* menu display - full description */
+    char *suffix;		/* output suffix */
+static struct statmethod statmethods[] = {
+    {average, "average", "average of patch values", "avg"},
+    {variance, "variance", "variance of patch values", "var"},
+    {std_deviat, "standard deviation", "standard deviation of patch values",
+     "dev"},
+    {median, "median", "median of patch values", "med"},
+    {min, "min", "minimum of patch values", "min"},
+    {max, "max", "maximum of patch values", "max"},
+    {0, 0, 0, 0}
+int main(int argc, char *argv[])
+    /* input */
+    char *oldname, *oldmapset;
+    /* id raster */
+    char *idname, *idmapset;
+    /* patch raster */
+    char *patchname, *patchmapset;
+    /* in and out file pointers */
+    int in_fd;
+    FILE *out_fp;		/* ASCII - output */
+    int out_fd;
+    /* parameters */
+    int keyval;
+    int stats[256];
+    int stat_count;
+    int ratio_flag;
+    int neighb_count;
+    /* maps */
+    DCELL *map;
+    /* other parameters */
+    char *title;
+    /* helper variables */
+    int row, col;
+    int *result;
+    DCELL *d_res;
+    int i, j, n;
+    int x, y;
+    Coords *p;
+    char output_name[256];
+    char *str;
+    int method;
+    f_statmethod perform_method;
+    DCELL val;
+    DCELL *values;
+    int count;
+    int area;
+    RASTER_MAP_TYPE map_type;
+    struct Cell_head ch, window;
+    struct GModule *module;
+    struct
+	struct Option *input, *output;
+	struct Option *values, *id_rast;
+	struct Option *patch_rast, *stats;
+	struct Option *title;
+    } parm;
+    struct
+	struct Flag *adjacent, *quiet;
+    } flag;
+    G_gisinit(argv[0]);
+    module = G_define_module();
+    module->keywords = _("raster");
+    module->description =
+	_("Performs statistical analysis and export of values within a patch");
+    parm.input = G_define_option();
+    parm.input->key = "input";
+    parm.input->type = TYPE_STRING;
+    parm.input->required = YES;
+    parm.input->gisprompt = "old,cell,raster";
+    parm.input->description = _("Name of existing raster file");
+    parm.output = G_define_option();
+    parm.output->key = "output";
+    parm.output->type = TYPE_STRING;
+    parm.output->required = YES;
+    parm.output->gisprompt = "new_file,file,output";
+    parm.output->description =
+	_("Name for the output ASCII-file with statistical values");
+    parm.values = G_define_option();
+    parm.values->key = "values";
+    parm.values->type = TYPE_STRING;
+    parm.values->required = NO;
+    parm.values->gisprompt = "new_file,file,output";
+    parm.values->description =
+	_("Name for the output ASCII-file with patch values");
+    parm.id_rast = G_define_option();
+    parm.id_rast->key = "id_raster";
+    parm.id_rast->type = TYPE_STRING;
+    parm.id_rast->required = NO;
+    parm.id_rast->gisprompt = "new,cell,raster";
+    parm.id_rast->description = _("Name for the id raster");
+    parm.patch_rast = G_define_option();
+    parm.patch_rast->key = "patch_raster";
+    parm.patch_rast->type = TYPE_STRING;
+    parm.patch_rast->required = NO;
+    parm.patch_rast->gisprompt = "new,cell,raster";
+    parm.patch_rast->description = _("Name for the binary patch raster");
+    parm.stats = G_define_option();
+    parm.stats->key = "stats";
+    parm.stats->type = TYPE_STRING;
+    parm.stats->required = YES;
+    parm.stats->multiple = YES;
+    str = parm.stats->options = G_malloc(1024);
+    for (n = 0; statmethods[n].name; n++) {
+	if (n)
+	    strcat(str, ",");
+	else
+	    *str = 0;
+	strcat(str, statmethods[n].name);
+    parm.stats->description =
+	_("Statistical method to perform on the values");
+    parm.title = G_define_option();
+    parm.title->key = "title";
+    parm.title->key_desc = "\"phrase\"";
+    parm.title->type = TYPE_STRING;
+    parm.title->required = NO;
+    parm.title->description = _("Title of the output raster file");
+    flag.adjacent = G_define_flag();
+    flag.adjacent->key = 'a';
+    flag.adjacent->description =
+	_("Set for 8 cell-neighbors. 4 cell-neighbors are default.");
+    flag.quiet = G_define_flag();
+    flag.quiet->key = 'q';
+    flag.quiet->description = _("Run quietly");
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
+    /* get name of input file */
+    oldname = parm.input->answer;
+    /* test input files existance */
+    if ((oldmapset = G_find_cell2(oldname, "")) == NULL) {
+	G_fatal_error(_("%s: <%s> raster file not found\n"), G_program_name(),
+		      oldname);
+	G_usage();
+    /* get verbose */
+    verbose = !flag.quiet->answer;
+    /* get number of cell-neighbors */
+    neighb_count = flag.adjacent->answer ? 8 : 4;
+    /* check if the id file name is correct */
+    idname = parm.id_rast->answer;
+    if (idname) {
+	if (G_legal_filename(idname) < 0) {
+	    G_fatal_error(_("%s: <%s> illegal file name\n"), G_program_name(),
+			  idname);
+	    G_usage();
+	idmapset = G_mapset();
+    /* check if the patch file name is correct */
+    patchname = parm.patch_rast->answer;
+    if (patchname) {
+	if (G_legal_filename(patchname) < 0) {
+			  patchname);
+	    G_usage();
+	patchmapset = G_mapset();
+    /* get size */
+    sx = G_window_cols();
+    sy = G_window_rows();
+    /* scan all statmethod answers */
+    stat_count = 0;
+    while (parm.stats->answers[stat_count] != NULL) {
+	/* get actual method */
+	for (method = 0; (str = statmethods[method].name); method++)
+	    if (strcmp(str, parm.stats->answers[stat_count]) == 0)
+		break;
+	if (!str) {
+	    G_warning(_("<%s=%s> unknown %s"),
+		      parm.stats->key, parm.stats->answers[stat_count],
+		      parm.stats->key);
+	    G_usage();
+	stats[stat_count] = method;
+	stat_count++;
+    /* allocate map buffers */
+    cells = (Coords *) G_malloc(sx * sy * sizeof(Coords));
+    fragments = (Coords **) G_malloc(sx * sy * sizeof(Coords *));
+    fragments[0] = cells;
+    map = (DCELL *) G_malloc(sx * sy * sizeof(DCELL));
+    id_map = (int *)G_malloc(sx * sy * sizeof(int));
+    d_res = G_allocate_d_raster_buf();
+    result = G_allocate_c_raster_buf();
+    G_set_c_null_value(id_map, sx * sy);
+    /* open map */
+    if ((in_fd = G_open_cell_old(oldname, oldmapset)) < 0) {
+	G_fatal_error(_("can't open cell file <%s> in mapset %s\n"), oldname,
+		      oldmapset);
+	G_usage();
+    /* read map */
+    if (verbose)
+	G_message("Reading map file:\n");
+    for (row = 0; row < sy; row++) {
+	G_get_d_raster_row(in_fd, map + row * sx, row);
+	if (verbose)
+	    G_percent(row, sy, 2);
+    if (verbose)
+	G_percent(1, 1, 2);
+    /* close map */
+    G_close_cell(in_fd);
+    writeFragments(map, sy, sx, neighb_count);
+    if (verbose)
+	G_message("Writing output ... ");
+    /* open ASCII-file or use stdout */
+    if (parm.values->answer) {
+	if (strcmp(parm.values->answer, "-") != 0) {
+	    if (!(out_fp = fopen(parm.values->answer, "w"))) {
+		G_fatal_error(_("Error creating file <%s>."),
+			      parm.values->answer);
+	else {
+	    out_fp = stdout;
+	/* write values */
+	for (i = 0; i < fragcount; i++) {
+	    double area = fragments[i + 1] - fragments[i];
+	    values = (DCELL *) G_malloc(area * sizeof(DCELL));
+	    for (p = fragments[i], j = 0; p < fragments[i + 1]; p++, j++) {
+		values[j] = p->value;
+	    /* write patch index */
+	    fprintf(out_fp, "%d %lf", i, area / (sx * sy));
+	    /* write patch value */
+	    for (method = 0; method < stat_count; method++) {
+		DCELL outval;
+		perform_method = statmethods[stats[method]].method;
+		outval = perform_method(values, area);
+		fprintf(out_fp, " %lf", outval);
+	    fprintf(out_fp, "\n");
+	    G_free(values);
+	/* close file */
+	if (out_fp != stdout) {
+	    fclose(out_fp);
+	else {
+    if (parm.output->answer && strcmp(parm.output->answer, "-") != 0) {
+	if (!(out_fp = fopen(parm.output->answer, "w"))) {
+			  parm.output->answer);
+    else {
+	out_fp = stdout;
+    /* write method names */
+	fprintf(out_fp, "%s ", statmethods[stats[method]].suffix);
+    fprintf(out_fp, "landcover number\n");
+    /* allocate an array for cell values */
+    count = fragments[fragcount] - fragments[0];
+    values = (DCELL *) G_malloc(count * sizeof(DCELL));
+    for (p = fragments[0], j = 0; p < fragments[fragcount]; p++, j++) {
+	val = perform_method(values, count);
+	fprintf(out_fp, "%f ", val);
+    /* write landcover and number of patches */
+    area = fragments[fragcount] - fragments[0];
+    fprintf(out_fp, "%lf %d\n", (DCELL) area / (DCELL) (sx * sy), fragcount);
+    G_free(values);
+    /* close file */
+	fclose(out_fp);
+    /* write id raster */
+    if (idname) {
+	/* open new cellfile  */
+	out_fd = G_open_raster_new(idname, CELL_TYPE);
+	if (out_fd < 0) {
+	    G_fatal_error(_("can't create new cell file <%s> in mapset %s\n"),
+			  idname, idmapset);
+	/* write the output file */
+	    G_put_c_raster_row(out_fd, id_map + row * sx);
+	    G_percent(row + 1, 2 * sy, 1);
+	/* close output */
+	G_close_cell(out_fd);
+    /* write patch raster */
+    if (patchname) {
+	out_fd = G_open_raster_new(patchname, CELL_TYPE);
+	if (out_fd < 0) {
+			  patchname, patchmapset);
+	    G_set_c_null_value(result, sx);
+	    for (col = 0; col < sx; col++) {
+		if (!G_is_c_null_value(id_map + row * sx + col)) {
+		    result[col] = 1;
+	    G_put_c_raster_row(out_fd, result);
+	    G_percent(sy + row + 1, 2 * sy, 1);
+    /* free allocated resources */
+    G_free(map);
+    exit(EXIT_SUCCESS);
Added: grass-addons/raster/r.pi/r.pi.export/stat_method.c
--- grass-addons/raster/r.pi/r.pi.export/stat_method.c	                        (rev 0)
+++ grass-addons/raster/r.pi/r.pi.export/stat_method.c	2010-08-04 10:53:56 UTC (rev 42991)
@@ -0,0 +1,125 @@
+    int i;
+    DCELL res = 0;
+    if (count <= 0)
+	return 0;
+    for (i = 0; i < count; i++)
+	res += vals[i];
+    return res / count;
+    int i;
+    DCELL mean;
+    DCELL s = 0;
+    DCELL ss = 0;
+    if (count <= 0)
+	return 0;
+    for (i = 0; i < count; i++) {
+	DCELL val = vals[i];
+	s += val;
+	ss += val * val;
+    mean = s / (DCELL) count;
+    return ss / count - mean * mean;
+    if (count <= 0)
+	return 0;
+    return sqrt(variance(vals, count));
+    int k = (count - 1) / 2;
+    int l = 0;
+    int h = count - 1;
+    DCELL pivot, tmp;
+    int i, j, z;
+    if (count <= 0)
+	return 0;
+    while (l < h) {
+	pivot = vals[k];
+	i = l;
+	j = h;
+	do {
+	    while (vals[i] < pivot)
+		i++;
+	    while (vals[j] > pivot)
+		j--;
+	    if (i <= j) {
+		tmp = vals[i];
+		vals[i] = vals[j];
+		vals[j] = tmp;
+		i++;
+		j--;
+	} while (i <= j);
+	if (j < k)
+	    l = i;
+	if (i > k)
+	    h = j;
+    return vals[k];
+    int i;
+    DCELL res = 0;
+    if (count <= 0)
+	return 0;
+    res = vals[0];
+	if (vals[i] < res)
+	    res = vals[i];
+    return res;
+    int i;
+    DCELL res = 0;
+    if (count <= 0)
+	return 0;
+    res = vals[0];
+	if (vals[i] > res)
+	    res = vals[i];
+    return res;
