[GRASS-SVN] r42997 -
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Aug 4 08:07:05 EDT 2010
Author: martinl
Date: 2010-08-04 12:07:04 +0000 (Wed, 04 Aug 2010)
New Revision: 42997
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gdialogs.py
wxGUI/dbm: set default DB settings if not defined
(merge r42994 from trunk)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gdialogs.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gdialogs.py 2010-08-04 11:39:00 UTC (rev 42996)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gdialogs.py 2010-08-04 12:07:04 UTC (rev 42997)
@@ -146,10 +146,10 @@
message=_("Unable to create vector map <%s>.") % outmap,
caption=_("Error"),
style=wx.ID_OK | wx.ICON_ERROR | wx.CENTRE)
- return False
+ return (None, None)
if outmap == '': # should not happen
- return False
cmd.append("%s=%s" % (cmdDef[1], outmap))
@@ -169,16 +169,17 @@
cmd.append('--overwrite')
else:
dlgOw.Destroy()
- return False
if UserSettings.Get(group='cmd', key='overwrite', subkey='enabled') is True:
try:
gcmd.Command(cmd)
- except gcmd.CmdError, e:
- print >> sys.stderr, e
- return None
+ except gcmd.GException, e:
+ gcmd.GError(parent = self,
+ message = e)
# create attribute table
@@ -187,17 +188,22 @@
key = UserSettings.Get(group='atm', key='keycolumn', subkey='value')
sql = 'CREATE TABLE %s (%s INTEGER)' % (outmap, key)
- gcmd.Command(['db.execute',
- '--q'],
- stdin=sql)
- gcmd.Command(['v.db.connect',
- '--q',
- 'map=%s' % outmap,
- 'table=%s' % outmap,
- 'key=%s' % key,
- 'layer=1'])
+ gcmd.RunCommand('db.connect',
+ flags = 'c')
+ gcmd.RunCommand('db.execute',
+ quiet = True,
+ parent = parent,
+ stdin = sql)
+ gcmd.RunCommand('v.db.connect',
+ quiet = True,
+ parent = parent,
+ map = outmap,
+ table = outmap,
+ key = key,
+ layer = '1')
# return fully qualified map name
if '@' not in outmap:
outmap += '@' + grassenv.GetGRASSVariable('MAPSET')
