[GRASS-SVN] r43017 - in grass/trunk: gui/scripts include/Make
svn_grass at osgeo.org
Mon Aug 9 06:16:42 EDT 2010
Author: martinl
Date: 2010-08-09 10:16:42 +0000 (Mon, 09 Aug 2010)
New Revision: 43017
Added:
grass/trunk/gui/scripts/d.rast3d.py
Removed:
grass/trunk/gui/scripts/d.rast3.py
grass/trunk/gui/scripts/Makefile
grass/trunk/include/Make/Python.make
install wxGUI scripts correctly
d.rast3 renamed to d.rast3d
Modified: grass/trunk/gui/scripts/Makefile
--- grass/trunk/gui/scripts/Makefile 2010-08-09 09:37:04 UTC (rev 43016)
+++ grass/trunk/gui/scripts/Makefile 2010-08-09 10:16:42 UTC (rev 43017)
@@ -1,17 +1,24 @@
MODULE_TOPDIR = ../..
-include $(MODULE_TOPDIR)/include/Make/Dir.make
+include $(MODULE_TOPDIR)/include/Make/Rules.make
+include $(MODULE_TOPDIR)/include/Make/Vars.make
include $(MODULE_TOPDIR)/include/Make/Python.make
-ETCDIR = $(ETC)/gui/scripts
+SCRIPTDIR = $(ETC)/gui/scripts
-SRCFILES := $(wildcard *.py)
-DSTFILES := $(patsubst %,$(ETCDIR)/%,$(SRCFILES)) $(patsubst %.py,$(ETCDIR)/%.pyc,$(filter %.py,$(SRCFILES)))
+ifdef MINGW
+PYFILES := $(patsubst %.py, $(SCRIPTDIR)/%.py, $(filter %.py, $(PY_SOURCES)))
+else
+PYFILES := $(patsubst %.py, $(SCRIPTDIR)/%, $(filter %.py, $(PY_SOURCES)))
+endif
-default: $(DSTFILES)
+default: $(PYFILES)
-$(ETCDIR)/%: % | $(ETCDIR)
+$(SCRIPTDIR)/%: %.py | $(SCRIPTDIR)
$(INSTALL) $< $@
-$(ETCDIR):
- $(MKDIR) $@
+$(SCRIPTDIR)/%.py: %.py | $(SCRIPTDIR)
+ $(INSTALL) $< $@
+$(SCRIPTDIR):
+ -test -d $@ | $(MKDIR) $@
Deleted: grass/trunk/gui/scripts/d.rast3.py
--- grass/trunk/gui/scripts/d.rast3.py 2010-08-09 09:37:04 UTC (rev 43016)
+++ grass/trunk/gui/scripts/d.rast3.py 2010-08-09 10:16:42 UTC (rev 43017)
@@ -1,36 +0,0 @@
-#!/usr/bin/env python
-# MODULE: d.rast3d
-# AUTHOR(S): Martin Landa <landa.martin gmail.com>
-# PURPOSE: Wrapper for wxGUI -- add 3d raster map layer into layer tree
-# COPYRIGHT: (C) 2008 by the GRASS Development Team
-# This program is free software under the GNU General Public
-# License (>=v2). Read the file COPYING that comes with GRASS
-# for details.
-#%module
-#% description: Displays 3d raster data in the active frame on the graphics monitor.
-#% keywords: display, raster3d
-#%end
-#%option
-#% key: map
-#% type: string
-#% gisprompt: old,grid3,3d-raster
-#% description: 3D raster map to be displayed
-#% required : yes
-#%end
-from grass.script import core as grass
-if __name__ == "__main__":
- options, flags = grass.parser()
- main()
Copied: grass/trunk/gui/scripts/d.rast3d.py (from rev 43010, grass/trunk/gui/scripts/d.rast3.py)
--- grass/trunk/gui/scripts/d.rast3d.py (rev 0)
+++ grass/trunk/gui/scripts/d.rast3d.py 2010-08-09 10:16:42 UTC (rev 43017)
@@ -0,0 +1,36 @@
+#!/usr/bin/env python
+# MODULE: d.rast3d
+# AUTHOR(S): Martin Landa <landa.martin gmail.com>
+# PURPOSE: Wrapper for wxGUI to add 3D raster map into layer tree
+# COPYRIGHT: (C) 2008, 2010 by the GRASS Development Team
+# This program is free software under the GNU General
+# Public License (>=v2). Read the file COPYING that
+# comes with GRASS for details.
+#%module
+#% description: Displays 3D raster map layer.
+#% keywords: display, raster3d
+#%end
+#%option
+#% key: map
+#% type: string
+#% gisprompt: old,grid3,3d-raster
+#% description: 3D raster map to be displayed
+#% required : yes
+#%end
+from grass.script import core as grass
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ main()
Modified: grass/trunk/include/Make/Python.make
--- grass/trunk/include/Make/Python.make 2010-08-09 09:37:04 UTC (rev 43016)
+++ grass/trunk/include/Make/Python.make 2010-08-09 10:16:42 UTC (rev 43017)
@@ -8,6 +8,8 @@
endif
PYMOD_CFLAGS = $(SHLIB_CFLAGS) $(PYTHONINC) $(PYTHON_CFLAGS)
+PY_SOURCES := $(wildcard *.py)
%.pyc: %.py
$(PYTHON) -m py_compile $<
