[GRASS-SVN] r43037 - grass/trunk/scripts/v.db.addcolumn
svn_grass at osgeo.org
Tue Aug 10 11:22:39 EDT 2010
Author: martinl
Date: 2010-08-10 15:22:39 +0000 (Tue, 10 Aug 2010)
New Revision: 43037
grass/trunk/scripts/v.db.addcolumn/v.db.addcolumn.py
v.db.addcolumn: inform user when column already exists
Modified: grass/trunk/scripts/v.db.addcolumn/v.db.addcolumn.py
--- grass/trunk/scripts/v.db.addcolumn/v.db.addcolumn.py 2010-08-10 12:08:04 UTC (rev 43036)
+++ grass/trunk/scripts/v.db.addcolumn/v.db.addcolumn.py 2010-08-10 15:22:39 UTC (rev 43037)
@@ -55,38 +55,43 @@
import grass.script as grass
def main():
- map = options['map']
- layer = options['layer']
+ map = options['map']
+ layer = options['layer']
columns = options['columns']
columns = [col.strip() for col in columns.split(',')]
# does map exist in CURRENT mapset?
mapset = grass.gisenv()['MAPSET']
exists = bool(grass.find_file(map, element = 'vector', mapset = mapset)['file'])
if not exists:
grass.fatal(_("Vector map <%s> not found in current mapset") % map)
try:
f = grass.vector_db(map)[int(layer)]
except KeyError:
grass.fatal(_("There is no table connected to this map. Run v.db.connect or v.db.addtable first."))
- table = f['table']
+ table = f['table']
database = f['database']
- driver = f['driver']
- colnum = len(columns)
+ driver = f['driver']
+ column_existing = grass.vector_columns(map, int(layer)).keys()
for col in columns:
if not col:
grass.fatal(_("There is an empty column. Did you leave a trailing comma?"))
+ col_name = col.split(' ')[0].strip()
+ if col_name in column_existing:
+ grass.error(_("Column <%s> is already in the table. Skipping.") % col_name)
+ continue
+ grass.verbose(_("Adding column <%s> to the table") % col_name)
p = grass.feed_command('db.execute', input = '-', database = database, driver = driver)
p.stdin.write("ALTER TABLE %s ADD COLUMN %s" % (table, col))
+ grass.debug("ALTER TABLE %s ADD COLUMN %s" % (table, col))
p.stdin.close()
if p.wait() != 0:
grass.fatal(_("Unable to add column <%s>.") % col)
# write cmd history:
grass.vector_history(map)
