[GRASS-SVN] r43040 - grass/trunk/vector/v.in.ogr
svn_grass at osgeo.org
Wed Aug 11 07:40:29 EDT 2010
Author: mmetz
Date: 2010-08-11 11:40:29 +0000 (Wed, 11 Aug 2010)
New Revision: 43040
grass/trunk/vector/v.in.ogr/geom.c
grass/trunk/vector/v.in.ogr/global.h
grass/trunk/vector/v.in.ogr/main.c
boundary splitting distance: account for multipolygons
Modified: grass/trunk/vector/v.in.ogr/geom.c
--- grass/trunk/vector/v.in.ogr/geom.c 2010-08-11 08:43:02 UTC (rev 43039)
+++ grass/trunk/vector/v.in.ogr/geom.c 2010-08-11 11:40:29 UTC (rev 43040)
@@ -158,6 +158,37 @@
return 0;
+/* count polygons and isles */
+int
+poly_count(OGRGeometryH hGeom)
+ int i, nr, ret;
+ OGRwkbGeometryType eType;
+ OGRGeometryH hRing;
+ eType = wkbFlatten(OGR_G_GetGeometryType(hGeom));
+ if (eType == wkbPolygon) {
+ G_debug(3, "Polygon");
+ nr = OGR_G_GetGeometryCount(hGeom);
+ n_polygon_boundaries += nr;
+ else if (eType == wkbGeometryCollection || eType == wkbMultiPolygon) {
+ G_debug(3, "GeometryCollection or MultiPolygon");
+ for (i = 0; i < nr; i++) {
+ hRing = OGR_G_GetGeometryRef(hGeom, i);
+ ret = poly_count(hRing);
+ if (ret == -1) {
+ G_warning(_("Cannot read part of geometry"));
+ return 0;
/* Write geometry to output map */
int
geom(OGRGeometryH hGeom, struct Map_info *Map, int field, int cat,
Modified: grass/trunk/vector/v.in.ogr/global.h
--- grass/trunk/vector/v.in.ogr/global.h 2010-08-11 08:43:02 UTC (rev 43039)
+++ grass/trunk/vector/v.in.ogr/global.h 2010-08-11 11:40:29 UTC (rev 43040)
@@ -25,6 +25,7 @@
extern int n_polygons;
+extern int n_polygon_boundaries;
extern double split_distance;
/* centroid structure */
Modified: grass/trunk/vector/v.in.ogr/main.c
--- grass/trunk/vector/v.in.ogr/main.c 2010-08-11 08:43:02 UTC (rev 43039)
+++ grass/trunk/vector/v.in.ogr/main.c 2010-08-11 11:40:29 UTC (rev 43040)
@@ -38,12 +38,14 @@
#endif
int n_polygons;
+int n_polygon_boundaries;
int geom(OGRGeometryH hGeom, struct Map_info *Map, int field, int cat,
double min_area, int type, int mk_centr);
int centroid(OGRGeometryH hGeom, CENTR * Centr, struct spatial_index * Sindex,
int field, int cat, double min_area, int type);
+int poly_count(OGRGeometryH hGeom);
int main(int argc, char *argv[])
@@ -820,16 +822,38 @@
OGR_L_ResetReading(Ogr_layer);
unsigned int n_features = 0, feature_count = 0;
+ n_polygon_boundaries = 0;
n_features = OGR_L_GetFeatureCount(Ogr_layer, 1);
- if (split_distance > -0.5 && n_features > 500) {
+ /* estimate distance for boundary splitting --> */
+ /* count polygons and isles */
+ G_message(_("Counting polygons for %d features..."), n_features);
+ while ((Ogr_feature = OGR_L_GetNextFeature(Ogr_layer)) != NULL) {
+ G_percent(feature_count++, n_features, 1); /* show something happens */
+ /* Geometry */
+ Ogr_geometry = OGR_F_GetGeometryRef(Ogr_feature);
+ if (Ogr_geometry != NULL) {
+ poly_count(Ogr_geometry);
+ OGR_F_Destroy(Ogr_feature);
+ /* rewind layer */
+ OGR_L_ResetReading(Ogr_layer);
+ feature_count = 0;
+ G_debug(0, "n polygon boundaries: %d", n_polygon_boundaries);
+ if (split_distance > -0.5 && n_polygon_boundaries > 50) {
split_distance =
- area_size / log(OGR_L_GetFeatureCount(Ogr_layer, 1));
+ area_size / log(n_features);
/* divisor is the handle: increase divisor to decrease split_distance */
split_distance = split_distance / 4.;
G_debug(1, "root of area size: %f", area_size);
G_verbose_message(_("Boundary splitting distance in map units: %G"),
split_distance);
+ /* <-- estimate distance for boundary splitting */
G_important_message(_("Importing map %d features..."), n_features);
