[GRASS-SVN] r43048 -
grass-addons/LandDyn/devs_landcover_scripts/r.landcover.update.py
svn_grass at osgeo.org
Wed Aug 11 16:11:41 EDT 2010
Author: isaacullah
Date: 2010-08-11 20:11:41 +0000 (Wed, 11 Aug 2010)
New Revision: 43048
grass-addons/LandDyn/devs_landcover_scripts/r.landcover.update.py/r.landcover.update.py
Replace version of r.landcover.update with version that uses the internal grass python libs. Remove r.villages as r.landcover.update now contains the full functionality of r.villages in new version of APsim.
Modified: grass-addons/LandDyn/devs_landcover_scripts/r.landcover.update.py/r.landcover.update.py
--- grass-addons/LandDyn/devs_landcover_scripts/r.landcover.update.py/r.landcover.update.py 2010-08-11 20:11:08 UTC (rev 43047)
+++ grass-addons/LandDyn/devs_landcover_scripts/r.landcover.update.py/r.landcover.update.py 2010-08-11 20:11:41 UTC (rev 43048)
@@ -36,6 +36,14 @@
#%END
#%option
+#% key: villages
+#% type: string
+#% gisprompt: old,cell,raster
+#% description: input map of village locations (coded as the landcover value for village surfaces)
+#% required : yes
+#%END
+#%option
#% key: sfertil
#% type: string
@@ -56,7 +64,7 @@
#% type: string
#% gisprompt: string
#% description: maximum value for landcover maps (number for climax veg)
-#% answer: 50
+#% answer: 50.0
#% required : yes
#%END
@@ -74,7 +82,7 @@
#% type: string
#% description: Path to reclass rules file for making a "labels" map. If no rules specified, no labels map will be made.
-#% answer: /usr/local/grass-6.5.svn/scripts/rules/luse_reclass_rules.txt
+#% answer:
#% required : no
#%END
@@ -83,7 +91,7 @@
#% type: string
#% description: Path to color rules file for landcover map
-#% answer: /usr/local/grass-6.5.svn/scripts/rules/luse_colors.txt
+#% answer:
#% required : no
#%END
@@ -92,46 +100,25 @@
#% description: -s Output text file of land-use stats from the simulation (will be named "prefix"_luse_stats.txt, and will be overwritten if you run the simulation again with the same prefix)
#%END
+#%flag
+#% key: r
+#% description: -r Save the map of vegetation regrowth rates.
+#%END
import sys
import os
import subprocess
import tempfile
-# first define some useful custom methods
+grass_install_tree = os.getenv('GISBASE')
+sys.path.append(grass_install_tree + os.sep + 'etc' + os.sep + 'python')
+import grass.script as grass
-# m is a message (as a string) one wishes to have printed in the output window
-def grass_print(m):
- subprocess.Popen('g.message message="%s"' % m, shell='bash').wait()
- return
-# m is grass (or bash) command to execute (written as a string). script will wait for grass command to finish
-def grass_com(m):
- subprocess.Popen('%s' % m, shell='bash').wait()
- return
-# m is grass (or bash) command to execute (written as a string). script will not wait for grass command to finish
-def grass_com_nw(m):
- return
-# m is a grass/bash command that will generate some list of keyed info to stdout, n is the character that seperates the key from the data, o is a defined blank dictionary to write results to
-def out2dict(m, n, o):
- p1 = subprocess.Popen('%s' % m, stdout=subprocess.PIPE, shell='bash')
- p2 = p1.stdout.readlines()
- for y in p2:
- y0,y1 = y.split('%s' % n)
- o[y0] = y1.strip('\n')
-# m is a grass/bash command that will generate some charcater seperated list of info to stdout, n is the character that seperates individual pieces of information, and o is a defined blank list to write results to
-def out2list2(m, n, o):
- for y in p2:
- o.append(y0)
- o.append(y1.strip('\n'))
#main block of code starts here
def main():
#setting up variables for use later on
inmap = os.getenv('GIS_OPT_inmap')
impacts = os.getenv('GIS_OPT_impacts')
+ villages = os.getenv('GIS_OPT_villages')
sfertil = os.getenv('GIS_OPT_sfertil')
sdepth = os.getenv('GIS_OPT_sdepth')
outmap = os.getenv('GIS_OPT_outmap')
@@ -140,42 +127,49 @@
lc_color = os.getenv('GIS_OPT_lc_color')
txtout = outmap + '_landcover_stats.txt'
temp_rate = 'temp_rate'
+ temp_lcov = 'temp_lcov'
+ temp_reclass = 'temp_reclass'
reclass_out = outmap + '_labels'
#setting initial conditions of map area
- grass_com('g.region --quiet rast=' + inmap)
- grass_com('r.mask --quiet input=' + inmap + ' maskcats=*')
+ grass.run_command('r.mask', quiet = True, input = inmap, maskcats = '*')
# calculating rate of regrowth based on current soil fertility and depths. Recoding fertility (0 to 100) and depth (0 to >= 1) with a power regression curve from 0 to 1, then taking the mean of the two as the regrowth rate
- grass_com('r.mapcalc "' + temp_rate + '=if(' + sdepth + ' <= 1, ( ( ( (-0.000118528 * (exp(' + sfertil + ',2))) + (0.0215056 * ' + sfertil + ') + 0.0237987 ) + ( ( -0.000118528 * (exp((100*' + sdepth + '),2))) + (0.0215056 * (100*' + sdepth + ')) + 0.0237987 ) ) / 2 ), ( ( ( (-0.000118528 * (exp(' + sfertil + ',2))) + (0.0215056 * ' + sfertil + ') + 0.0237987 ) + 1) / 2 ) )"')
+ grass.mapcalc('${out}=if(${map1} <= 1.0, ( ( ( (-0.000118528 * (exp(${map2},2.0))) + (0.0215056 * ${map2}) + 0.0237987 ) + ( ( -0.000118528 * (exp((100*${map1}),2.0))) + (0.0215056 * (100*${map1})) + 0.0237987 ) ) / 2.0 ), ( ( ( (-0.000118528 * (exp(${map2},2.0))) + (0.0215056 * ${map2}) + 0.0237987 ) + 1.0) / 2.0 ) )', out = temp_rate, map1 = sdepth, map2 = sfertil)
#updating raw landscape category numbers based on agent impacts and newly calculated regrowth rate
- grass_com('r.mapcalc "' + outmap + '=if(' + inmap + '== ' + max + ' && isnull(' + impacts + '), ' + max + ', if(' + inmap + '< ' + max + ' && isnull(' + impacts + '), (' + inmap + ' + ' + temp_rate + '), if(' + inmap + ' > ' + max + ', (' + max + ' - ' + impacts + '), if(' + inmap + ' <= 0, 0, (' + inmap + ' - ' + impacts + ') ) ) ) )"')
- grass_com('r.colors --quiet map=' + outmap + ' rules=' + lc_color)
+ grass.mapcalc('${out}=if(${inm} == ${m} && isnull(${imp}), double(${m}), if(${inm} < ${m} && isnull(${imp}), (double(${inm}) + double(${tr})), if(${inm} > ${m}, (double(${m}) - double(${imp})), if(${inm} <= 0.0, 0.0, (double(${inm}) - double(${imp})) ) ) ) )', out = temp_lcov, m = max, inm = inmap, imp = impacts, tr = temp_rate)
try:
lc_rules
except NameError:
lc_rules = None
if lc_rules is None:
- grass_print( "No Labels reclass rules specified, so no Labels map will be made")
+ grass.message( "No Labels reclass rules specified, so no Labels map will be made")
else:
- grass_print( 'Creating reclassed Lables map (' + reclass_out +') of text descriptions to raw landscape categories')
- grass_com('r.reclass --quiet input=' + outmap + ' output=' + reclass_out + ' rules=' + lc_rules)
- grass_com('r.colors --quiet map=' + reclass_out + ' rules=' + lc_color)
+ grass.message( 'Creating reclassed Lables map (' + reclass_out +') of text descriptions to raw landscape categories')
+ grass.run_command('r.reclass', quiet = True, input = temp_lcov, output = temp_reclass, rules = lc_rules)
+ grass.mapcalc('${out}=${input}', out = reclass_out, input = temp_reclass)
+ grass.run_command('r.colors', quiet = True, map = reclass_out, rules = lc_color)
#checking total area of updated cells
- statlist = []
- out2list2('r.stats -a -n input=' + impacts + ' fs=, nv=* nsteps=1', ',', statlist)
- grass_print('Total area of impacted zones = ' + statlist[1] + ' square meters\n')
+ statdict = grass.parse_command('r.stats', quiet = True, flags = 'Aan', input = impacts, fs = ':', nv ='*', parse = (grass.parse_key_val, { 'sep' : ':' }))
+ sumofimpacts = 0.0
+ for key in statdict:
+ sumofimpacts = sumofimpacts + float(statdict[key])
+ grass.message('Total area of impacted zones = %s square meters\n' % sumofimpacts)
#creating optional output text file of stats
if os.getenv('GIS_FLAG_s') == '1':
f = file(txtout, 'wt')
- f.write('Stats for ' + prfx + '_landcover\n\nTotal area of impacted zones = ' + statlist[1] + ' square meters\n\n\nLandcover class #, Landcover description, Area (sq. m)\n')
- p1 = grass_com_nw('r.stats --quiet -a -l -n input=' + prfx +'_landuse1 fs=, nv=* nsteps=' + max )
- for y in p2:
- f.write(y)
+ f.write('Stats for ' + prfx + '_landcover\n\nTotal area of impacted zones = %s square meters\n\n\nLandcover class #, Landcover description, Area (sq. m)\n' % sumofimpacts)
+ p1 = grass.parse_command('r.stats', quiet = True, flags = 'aln', input = prfx + '_landuse1', fs = ':', nv ='*', nsteps = max, parse = (grass.parse_key_val, { 'sep' : ':' }))
+ for key in p1:
+ f.write(str(key) + ',' + str(p1[key]))
f.close()
- grass_print('\nCleaning up\n')
- grass_com('g.remove --quiet rast=MASK,' + temp_rate)
- grass_print("\nDONE!\n")
+ grass.run_command('r.patch', quiet = True, input = villages + ',' + temp_lcov, output= outmap)
+ grass.run_command('r.colors', quiet = True, map = outmap, rules = lc_color)
+ grass.message('\nCleaning up\n')
+ if os.getenv('GIS_FLAG_r') == '1':
+ grass.run_command('g.remove', quiet =True, rast = 'MASK,temp_reclass,temp_lcov')
+ grass.run_command('g.rename', quiet = True, rast='temp_rate,' + outmap +'_rate')
+ else:
+ grass.run_command('g.remove', quiet =True, rast = 'MASK,temp_rate,temp_reclass,temp_lcov')
+ grass.message("\nDONE!\n")
return
# here is where the code in "main" actually gets executed. This way of programming is neccessary for the way g.parser needs to run.
