[GRASS-SVN] r43066 - grass-addons/vector/v.vect.stats
Thu Aug 12 10:36:08 EDT 2010
Author: mmetz
Date: 2010-08-12 14:36:08 +0000 (Thu, 12 Aug 2010)
New Revision: 43066
Added:
   grass-addons/vector/v.vect.stats/Makefile
   grass-addons/vector/v.vect.stats/description.html
   grass-addons/vector/v.vect.stats/main.c
import new module v.vect.stats
Added: grass-addons/vector/v.vect.stats/Makefile
--- grass-addons/vector/v.vect.stats/Makefile	                        (rev 0)
+++ grass-addons/vector/v.vect.stats/Makefile	2010-08-12 14:36:08 UTC (rev 43066)
@@ -0,0 +1,15 @@
+MODULE_TOPDIR = ../..
+PGM=v.vect.stats
+LIBES     = $(VECTLIB) $(VECTLIB_REAL) $(STATSLIB) $(GISLIB)
+DEPENDENCIES= $(VECTDEP) $(STATSDEP) $(GISDEP)
+EXTRA_INC = $(VECT_INC)
+EXTRA_CFLAGS = $(VECT_CFLAGS)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: grass-addons/vector/v.vect.stats/description.html
--- grass-addons/vector/v.vect.stats/description.html	                        (rev 0)
+++ grass-addons/vector/v.vect.stats/description.html	2010-08-12 14:36:08 UTC (rev 43066)
@@ -0,0 +1,95 @@
+<H2>DESCRIPTION</H2>
+<EM>v.vect.stats</EM> counts the number of points in vector map
+<em>points</em> falling into each area in vector map <em>areas</em>.
+Optionally statistics on point attributes in <em>points</em> are
+calculated for each area. The results are either uploaded to the
+attribute table of the vector map <em>areas</em> or printed to stdout.
+<h3>OPTIONS</h3>
+<em>Statistical Methods:</em>
+Using numeric attribute values of all points falling into a given area,
+a new value is detmined with the selected method.
+<em>v.vect.stats</em> can perform the following operations:
+<p>
+<dl>
+<dt><b>sum</b>
+<dd>The sum of values.
+<dt><b>average</b>
+<dd>The average value of all point attributes (sum / count).
+<dt><b>median</b>
+<dd>The value found half-way through a list of the
+attribute values, when these are ranged in numerical order.
+<dt><b>mode</b>
+<dd>The most frequently occurring value.
+<dt><b>minimum</b>
+<dd>The minimum observed value.
+<dt><b>min_cat</b>
+<dd>The point category corresponding to the minimum observed value.
+<dt><b>maximum</b>
+<dd>The maximum observed value.
+<dt><b>max_cat</b>
+<dd>The point category corresponding to the maximum observed value.
+<dt><b>range</b>
+<dd>The range of the observed values.
+<dt><b>stddev</b>
+<dd>The statistical standard deviation of the attribute values.
+<dt><b>variance</b>
+<dd>The statistical variance of the attribute values.
+<dt><b>diversity</b>
+<dd>The number of different attribute values.
+</dl>
+<H2>NOTES</H2>
+Points not falling into any area are ignored. Areas without category
+(no centroid attached or centroid without category) are ignored.
+If no points are falling into a given area, the point count is set to 0
+(zero) and the statistics result to "null".
+<p>
+The columns <em>count_column</em> and <em>stats_column</em> are created if not
+existing. If they do already exist, the <em>count_column</em> must be of
+type integer and the <em>stats_column</em> of type double.
+<H2>SEE ALSO</H2>
+<EM>
+<a href="v.distance.html">v.distance</a>,
+<a href="r.distance.html">r.distance</a>,
+<a href="v.what.vect.html">v.what.vect</a>
+</EM>
+<H2>AUTHOR</H2>
+Markus Metz
+<p><i>Last changed: $Date: 2008-08-13 21:52:37 +0200 (Wed, 13 Aug 2008) $</i>
Added: grass-addons/vector/v.vect.stats/main.c
--- grass-addons/vector/v.vect.stats/main.c	                        (rev 0)
+++ grass-addons/vector/v.vect.stats/main.c	2010-08-12 14:36:08 UTC (rev 43066)
@@ -0,0 +1,727 @@
+ * MODULE:       v.vect.stats
+ * AUTHOR(S):    Markus Metz
+ * PURPOSE:      Counts points per area and calculates aggregate statistics.
+ * COPYRIGHT:    (C) 2002-2010 by the GRASS Development Team
+ *               This program is free software under the
+ *               GNU General Public License (>=v2).
+ *               Read the file COPYING that comes with GRASS
+ *               for details.
+#include <stdlib.h>
+#include <stdio.h>
+#include <string.h>
+#include <unistd.h>
+#include <math.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+#include <grass/stats.h>
+#include <grass/dbmi.h>
+#include <grass/Vect.h>
+struct menu
+    stat_func *method;		/* routine to compute new value */
+    int half;			/* whether to add 0.5 to result */
+    char *name;			/* method name */
+    char *text;			/* menu display - full description */
+/* modify this table to add new methods */
+static struct menu menu[] = {
+    {c_sum, 0, "sum", "sum of values"},
+    {c_ave, 1, "average", "average value"},
+    {c_median, 0, "median", "median value"},
+    {c_mode, 0, "mode", "most frequently occuring value"},
+    {c_min, 0, "minimum", "lowest value"},
+    {c_minx, 0, "min_cat", "category number of lowest value"},
+    {c_max, 0, "maximum", "highest value"},
+    {c_maxx, 0, "max_cat", "category number of highest value"},
+    {c_range, 0, "range", "range of values"},
+    {c_stddev, 1, "stddev", "standard deviation"},
+    {c_var, 1, "variance", "statistical variance"},
+    {c_divr, 0, "diversity", "number of different values"},
+    {0, 0, 0, 0}
+/* Structure to store info for each area category */
+typedef struct
+    int area_cat;		/* area category */
+    int count;			/* number of points in areas with area_cat */
+    double *values;
+    int *cats;
+    int nvalues, nalloc;
+} AREA_CAT;
+static int cmp_area(const void *, const void *);
+int main(int argc, char *argv[])
+    char *p;
+    int i, j, k;
+    int method, half, use_catno;
+    char *mapset;
+    struct GModule *module;
+    struct Option *point_opt,	/* point vector */
+     *area_opt,			/* area vector */
+     *point_type_opt,		/* point type */
+     *point_field_opt,		/* point layer */
+     *area_field_opt,		/* area layer */
+     *method_opt,		/* stats method */
+     *point_column_opt,		/* point column for stats */
+     *count_column_opt,		/* area column for point count */
+     *stats_column_opt,		/* area column for stats result */
+     *fs_opt;			/* field separator for printed output */
+    struct Flag *print_flag;
+    char fs[2];
+    struct Map_info PIn, AIn;
+    int point_type, point_field, area_field;
+    struct line_pnts *Points;
+    struct line_cats *ACats, *PCats;
+    AREA_CAT *Area_cat;
+    int pline, ptype, count;
+    int area, nareas, nacats, nacatsalloc;
+    int ctype, nrec;
+    struct field_info *PFi, *AFi;
+    dbString stmt, dbstr;
+    dbDriver *Pdriver, *Adriver;
+    char buf[2000];
+    int update_ok, update_err;
+    struct ilist *List;
+    BOUND_BOX box;
+    dbCatValArray cvarr;
+    dbColumn *column;
+    struct pvalcat
+	double dval;
+	int catno;
+    } *pvalcats;
+    int npvalcats, npvalcatsalloc;
+    stat_func *statsvalue = NULL;
+    double result;
+    column = NULL;
+    G_gisinit(argv[0]);
+    module = G_define_module();
+    module->keywords = _("vector, database, attribute table");
+    module->description = _("Count points in areas, calculate statistics.");
+    point_opt = G_define_standard_option(G_OPT_V_INPUT);
+    point_opt->key = "points";
+    point_opt->description = _("Name of existing vector map with points");
+    /* point_opt->guisection = _("Required"); */
+    area_opt = G_define_standard_option(G_OPT_V_INPUT);
+    area_opt->key = "areas";
+    area_opt->description = _("Name of existing vector map with areas");
+    /* area_opt->guisection = _("Required"); */
+    point_type_opt = G_define_standard_option(G_OPT_V_TYPE);
+    point_type_opt->key = "point_type";
+    point_type_opt->options = "point,centroid";
+    point_type_opt->answer = "point";
+    point_type_opt->label = _("Feature type");
+    point_type_opt->required = NO;
+    point_field_opt = G_define_standard_option(G_OPT_V_FIELD);
+    point_field_opt->key = "point_layer";
+    point_field_opt->label = _("Layer number for points map");
+    area_field_opt = G_define_standard_option(G_OPT_V_FIELD);
+    area_field_opt->key = "area_layer";
+    area_field_opt->label = _("Layer number for area map");
+    method_opt = G_define_option();
+    method_opt->key = "method";
+    method_opt->type = TYPE_STRING;
+    method_opt->required = NO;
+    method_opt->multiple = NO;
+    p = G_malloc(1024);
+    for (i = 0; menu[i].name; i++) {
+	if (i)
+	    strcat(p, ",");
+	else
+	    *p = 0;
+	strcat(p, menu[i].name);
+    method_opt->options = p;
+    method_opt->description = _("Method for aggregate statistics");
+    point_column_opt = G_define_standard_option(G_OPT_COLUMN);
+    point_column_opt->required = NO;
+    point_column_opt->multiple = NO;
+    point_column_opt->label =
+	_("Column name of points map to use for statistics");
+    point_column_opt->description = _("Column of points map must be numeric");
+    count_column_opt = G_define_option();
+    count_column_opt->key = "count_column";
+    count_column_opt->type = TYPE_STRING;
+    count_column_opt->required = NO;
+    count_column_opt->multiple = NO;
+    count_column_opt->label = _("Column name for points count");
+    count_column_opt->description =
+	_("Column to hold points count, must be of type integer, will be created if not existing");
+    stats_column_opt = G_define_option();
+    stats_column_opt->key = "stats_column";
+    stats_column_opt->type = TYPE_STRING;
+    stats_column_opt->required = NO;
+    stats_column_opt->multiple = NO;
+    stats_column_opt->label = _("Column name for statistics");
+    stats_column_opt->description =
+	_("Column to hold statistics, must be of type double, will be created if not existing");
+    fs_opt = G_define_standard_option(G_OPT_F_SEP);
+    fs_opt->answer = "|";
+    fs_opt->key_desc = "character|space|tab";
+    fs_opt->description = _("Output field separator");
+    print_flag = G_define_flag();
+    print_flag->key = 'p';
+    print_flag->label =
+	_("Print output to stdout, do not update attribute table");
+    print_flag->description = _("First column is always area category");
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
+    point_type = Vect_option_to_types(point_type_opt);
+    point_field = atoi(point_field_opt->answer);
+    area_field = atoi(area_field_opt->answer);
+    strcpy(fs, " ");
+    if (print_flag->answer) {
+	/* get field separator */
+	if (fs_opt->answer) {
+	    if (strcmp(fs_opt->answer, "space") == 0)
+		*fs = ' ';
+	    else if (strcmp(fs_opt->answer, "tab") == 0)
+		*fs = '\t';
+	    else if (strcmp(fs_opt->answer, "\\t") == 0)
+		*fs = '\t';
+	    else
+		*fs = *fs_opt->answer;
+	else
+	    *fs = '|';
+    /* some checks for stats */
+    if (point_column_opt->answer) {
+	if (!method_opt->answer)
+	    G_fatal_error("No method for statistics selected");
+	if (!print_flag->answer && !stats_column_opt->answer)
+	    G_fatal_error("Name for stats column is missing");
+    else {
+	method_opt->answer = NULL;
+	stats_column_opt->answer = NULL;
+    /* Open points vector */
+    if ((mapset = G_find_vector2(point_opt->answer, "")) == NULL)
+	G_fatal_error(_("Vector map <%s> not found"), point_opt->answer);
+    Vect_set_open_level(2);
+    Vect_open_old(&PIn, point_opt->answer, mapset);
+    /* Open areas vector */
+    if ((mapset = G_find_vector2(area_opt->answer, "")) == NULL)
+	G_fatal_error(_("Vector map <%s> not found"), area_opt->answer);
+    if (!print_flag->answer && strcmp(mapset, G_mapset()) != 0)
+	G_fatal_error(_("Vector map <%s> is not in user mapset and cannot be updated"),
+		      area_opt->answer);
+    Vect_open_old(&AIn, area_opt->answer, mapset);
+    method = -1;
+    use_catno = 0;
+    half = 0;
+    if (method_opt->answer) {
+	/* get the method */
+	for (method = 0; (p = menu[method].name); method++)
+	    if ((strcmp(p, method_opt->answer) == 0))
+		break;
+	if (!p) {
+	    G_warning(_("<%s=%s> unknown %s"),
+		      method_opt->key, method_opt->answer,
+		      method_opt->answer);
+	    G_usage();
+	/* establish the statsvalue routine */
+	statsvalue = menu[method].method;
+	/* category number of lowest value */
+	if ((strcmp(menu[method].name, menu[5].name) == 0))
+	    use_catno = 1;
+	/* category number of highest value */
+	if ((strcmp(menu[method].name, menu[7].name) == 0))
+	    use_catno = 1;
+	G_debug(1, "method: %s, use cat no: %s", menu[method].name,
+		(use_catno == 1 ? "yes" : "no"));
+    /* Open database driver */
+    db_init_string(&stmt);
+    db_init_string(&dbstr);
+    Adriver = NULL;
+    if (!print_flag->answer) {
+	AFi = Vect_get_field(&AIn, area_field);
+	if (AFi == NULL)
+	    G_fatal_error(_("Database connection not defined for layer %d"),
+			  area_field);
+	Adriver = db_start_driver_open_database(AFi->driver, AFi->database);
+	if (Adriver == NULL)
+	    G_fatal_error(_("Unable to open database <%s> with driver <%s>"),
+			  AFi->database, AFi->driver);
+	if (!count_column_opt->answer)
+	    G_fatal_error(_("count_column is required to upload point counts"));
+	/* check if count column exists */
+	db_get_column(Adriver, AFi->table, count_column_opt->answer, &column);
+	if (column) {
+	    /* check count column type */
+	    if (db_column_Ctype(Adriver, AFi->table, count_column_opt->answer)
+		!= DB_C_TYPE_INT)
+		G_fatal_error(_("count_column must be of type integer"));
+	    db_free_column(column);
+	    column = NULL;
+	else {
+	    /* create column */
+	    db_set_string(&stmt, "alter table ");
+	    db_append_string(&stmt, AFi->table);
+	    db_append_string(&stmt, " add column ");
+	    db_append_string(&stmt, count_column_opt->answer);
+	    db_append_string(&stmt, " integer");
+	    if (db_execute_immediate(Adriver, &stmt) != DB_OK)
+		G_fatal_error(_("Unable to add column: '%s'"),
+			      db_get_string(&stmt));
+	    if (!stats_column_opt->answer)
+		G_fatal_error(_("stats_column is required to upload point stats"));
+	    /* check if stats column exists */
+	    db_get_column(Adriver, AFi->table, stats_column_opt->answer,
+			  &column);
+	    if (column) {
+		/* check stats column type */
+		    (Adriver, AFi->table,
+		     stats_column_opt->answer) != DB_C_TYPE_DOUBLE)
+		    G_fatal_error(_("stats_column must be of type double"));
+		column = NULL;
+	    else {
+		db_append_string(&stmt, stats_column_opt->answer);
+		db_append_string(&stmt, " double precision");
+    else
+	AFi = NULL;
+    Pdriver = NULL;
+	PFi = Vect_get_field(&PIn, point_field);
+	if (PFi == NULL)
+			  point_field);
+	Pdriver = db_start_driver_open_database(PFi->driver, PFi->database);
+	if (Pdriver == NULL)
+			  PFi->database, PFi->driver);
+	/* check if column exists */
+	db_get_column(Pdriver, PFi->table, point_column_opt->answer, &column);
+	if (column) {
+	    column = NULL;
+	else {
+	    G_fatal_error(_("Column <%s> not found in table <%s>"),
+			  point_column_opt->answer, PFi->table);
+	/* Check column type */
+	ctype =
+	    db_column_Ctype(Pdriver, PFi->table, point_column_opt->answer);
+	if (ctype == DB_C_TYPE_INT)
+	    half = menu[method].half;
+	else if (ctype == DB_C_TYPE_DOUBLE)
+	    half = 0;
+	else
+	    G_fatal_error(_("column for points vector must be numeric"));
+	db_CatValArray_init(&cvarr);
+	nrec = db_select_CatValArray(Pdriver, PFi->table, PFi->key,
+				     point_column_opt->answer, NULL, &cvarr);
+	G_debug(3, "selected values = %d", nrec);
+	db_close_database_shutdown_driver(Pdriver);
+    Points = Vect_new_line_struct();
+    ACats = Vect_new_cats_struct();
+    PCats = Vect_new_cats_struct();
+    List = Vect_new_list();
+    /* Allocate space ( may be more than needed (duplicate cats and elements without cats) ) */
+    if ((nareas = Vect_get_num_areas(&AIn)) <= 0)
+	G_fatal_error("No areas in area input vector");
+    nacatsalloc = nareas;
+    Area_cat = (AREA_CAT *) G_calloc(nacatsalloc, sizeof(AREA_CAT));
+    /* Read all cats from 'area' */
+    nacats = 0;
+    for (area = 1; area <= nareas; area++) {
+	Vect_get_area_cats(&AIn, area, ACats);
+	if (ACats->n_cats <= 0)
+	    continue;
+	for (i = 0; i < ACats->n_cats; i++) {
+	    if (ACats->field[i] == area_field) {
+		Area_cat[nacats].area_cat = ACats->cat[i];
+		Area_cat[nacats].count = 0;
+		Area_cat[nacats].nvalues = 0;
+		Area_cat[nacats].nalloc = 0;
+		nacats++;
+		if (nacats >= nacatsalloc) {
+		    nacatsalloc += 100;
+		    Area_cat =
+			(AREA_CAT *) G_realloc(Area_cat,
+					       nacatsalloc *
+					       sizeof(AREA_CAT));
+    G_debug(1, "%d cats loaded from vector (including duplicates)", nacats);
+    /* Sort by cats and remove duplicates */
+    qsort((void *)Area_cat, nacats, sizeof(AREA_CAT), cmp_area);
+    /* remove duplicates */
+    for (i = 1; i < nacats; i++) {
+	if (Area_cat[i].area_cat == Area_cat[i - 1].area_cat) {
+	    for (j = i; j < nacats - 1; j++) {
+		Area_cat[j].area_cat = Area_cat[j + 1].area_cat;
+	    nacats--;
+    G_debug(1, "%d cats loaded from vector (unique)", nacats);
+    /* Go through all areas in area vector and find points in points vector
+     * falling into the area */
+    npvalcatsalloc = 10;
+    npvalcats = 0;
+    pvalcats =
+	(struct pvalcat *)G_calloc(npvalcatsalloc, sizeof(struct pvalcat));
+    /* remove for GRASS 7 */
+    Vect_build_spatial_index(&PIn);
+    G_message(_("Selecting points for each area..."));
+    count = 0;
+	dbCatVal *catval;
+	G_debug(3, "area = %d", area);
+	G_percent(area, nareas, 2);
+	    continue;
+	/* select points by box */
+	Vect_get_area_box(&AIn, area, &box);
+	box.T = PORT_DOUBLE_MAX;
+	box.B = -PORT_DOUBLE_MAX;
+	Vect_select_lines_by_box(&PIn, &box, point_type, List);
+	G_debug(4, "%d points selected by box", List->n_values);
+	/* For each point in box check if it is in the area */
+	for (i = 0; i < List->n_values; i++) {
+	    pline = List->value[i];
+	    G_debug(4, "%d: point %d", i, pline);
+	    ptype = Vect_read_line(&PIn, Points, PCats, pline);
+	    if (!(ptype & point_type))
+		continue;
+	    /* point in area */
+	    if (Vect_point_in_area(&AIn, area, Points->x[0], Points->y[0])) {
+		AREA_CAT *area_info, search_ai;
+		int tmp_cat;
+		/* stats on point column */
+		    npvalcats = 0;
+		    tmp_cat = -1;
+		    for (j = 0; j < PCats->n_cats; j++) {
+			if (PCats->field[j] == point_field) {
+			    if (tmp_cat >= 0)
+				G_debug(3,
+					"More cats found in point layer (point=%d)",
+					pline);
+			    tmp_cat = PCats->cat[j];
+			    /* find cat in array */
+			    db_CatValArray_get_value(&cvarr, tmp_cat,
+						     &catval);
+			    if (catval) {
+				pvalcats[npvalcats].catno = tmp_cat;
+				switch (cvarr.ctype) {
+				case DB_C_TYPE_INT:
+				    pvalcats[npvalcats].dval = catval->val.i;
+				    npvalcats++;
+				    break;
+				case DB_C_TYPE_DOUBLE:
+				    pvalcats[npvalcats].dval = catval->val.d;
+				    pvalcats++;
+				    break;
+				if (npvalcats >= npvalcatsalloc) {
+				    npvalcatsalloc += 10;
+				    pvalcats =
+					(struct pvalcat *)G_realloc(pvalcats,
+								    npvalcatsalloc
+								    sizeof
+								    (struct
+								     pvalcat));
+		/* update count for all area cats of given field */
+		search_ai.area_cat = -1;
+		for (j = 0; j < ACats->n_cats; j++) {
+		    if (ACats->field[j] == area_field) {
+			if (search_ai.area_cat >= 0)
+			    G_debug(3,
+				    "More cats found in area layer (area=%d)",
+				    area);
+			search_ai.area_cat = ACats->cat[j];
+			area_info =
+			    (AREA_CAT *) bsearch((void *)&search_ai, Area_cat,
+						 nacats, sizeof(AREA_CAT),
+						 cmp_area);
+			if (area_info->area_cat != search_ai.area_cat)
+			    G_fatal_error(_("could not find area category %d"),
+					  search_ai.area_cat);
+			/* each point is counted once, also if it has
+			 * more than one category or no category
+			 * OK? */
+			area_info->count++;
+			    /* ensure enough space */
+			    if (area_info->nvalues + npvalcats >=
+				area_info->nalloc) {
+				if (area_info->nalloc == 0) {
+				    area_info->nalloc = npvalcats + 10;
+				    area_info->values =
+					(double *)G_calloc(area_info->nalloc,
+							   sizeof(double));
+				    area_info->cats =
+					(int *)G_calloc(area_info->nalloc,
+							sizeof(int));
+				else
+				    area_info->nalloc +=
+					area_info->nvalues + npvalcats + 10;
+				    (double *)G_realloc(area_info->values,
+							area_info->nalloc *
+							sizeof(double));
+				area_info->cats =
+				    (int *)G_realloc(area_info->cats,
+						     sizeof(int));
+			    for (k = 0; k < npvalcats; k++) {
+				area_info->cats[area_info->nvalues] =
+				    pvalcats[k].catno;
+				area_info->values[area_info->nvalues] =
+				    pvalcats[k].dval;
+				area_info->nvalues++;
+		count++;
+	}			/* next point in box */
+    }				/* next area */
+    G_debug(1, "count = %d", count);
+    /* release catval array */
+	db_CatValArray_free(&cvarr);
+    Vect_close(&PIn);
+    /* Update table or print to stdout */
+    if (print_flag->answer) {	/* print header */
+	fprintf(stdout, "area_cat%scount", fs);
+	    fprintf(stdout, "%s%s", fs, menu[method].name);
+	fprintf(stdout, "\n");
+    else {
+	G_message("Updating attributes for area vector...");
+	update_err = update_ok = 0;
+    if (Adriver)
+	db_begin_transaction(Adriver);
+    for (i = 0; i < nacats; i++) {
+	    G_percent(i, nacats, 2);
+	result = 0;
+	if (Area_cat[i].count > 0 && method_opt->answer) {
+	    /* get stats */
+	    statsvalue(&result, Area_cat[i].values, Area_cat[i].nvalues,
+		       NULL);
+	    if (half)
+		result += 0.5;
+	    else if (use_catno)
+		result = Area_cat[i].cats[(int)result];
+	    fprintf(stdout, "%d%s%d", Area_cat[i].area_cat, fs,
+		    Area_cat[i].count);
+		if (Area_cat[i].count > 0)
+		    fprintf(stdout, "%s%.15g", fs, result);
+		else
+		    fprintf(stdout, "%snull", fs);
+	else {
+	    sprintf(buf, "update %s set %s = %d", AFi->table,
+		    count_column_opt->answer, Area_cat[i].count);
+	    db_set_string(&stmt, buf);
+		    sprintf(buf, " , %s = %.15g", stats_column_opt->answer,
+			    result);
+		else
+		    sprintf(buf, " , %s = null", stats_column_opt->answer);
+		db_append_string(&stmt, buf);
+	    sprintf(buf, " where %s = %d", AFi->key, Area_cat[i].area_cat);
+	    G_debug(2, "SQL: %s", db_get_string(&stmt));
+	    if (db_execute_immediate(Adriver, &stmt) == DB_OK) {
+		update_ok++;
+	    else {
+		update_err++;
+    if (Adriver)
+	db_commit_transaction(Adriver);
+	G_percent(nacats, nacats, 2);
+	G_message(_("%d records updated"), update_ok);
+	if (update_err > 0)
+	    G_message(_("%d update errors"), update_err);
+	db_close_database_shutdown_driver(Adriver);
+	db_free_string(&stmt);
+	G_message(_("%d records inserted"), update_ok);
+	    G_message(_("%d insert errors"), update_err);
+	Vect_set_db_updated(&AIn);
+    Vect_close(&AIn);
+    G_done_msg(" ");
+    exit(EXIT_SUCCESS);
+static int cmp_area(const void *pa, const void *pb)
+    AREA_CAT *p1 = (AREA_CAT *) pa;
+    AREA_CAT *p2 = (AREA_CAT *) pb;
+    if (p1->area_cat < p2->area_cat)
+	return -1;
+    if (p1->area_cat > p2->area_cat)
+	return 1;
+    return 0;
