[GRASS-SVN] r43069 - grass-addons/vector/v.vect.stats
svn_grass at osgeo.org
Thu Aug 12 13:14:36 EDT 2010
Author: mmetz
Date: 2010-08-12 17:14:36 +0000 (Thu, 12 Aug 2010)
New Revision: 43069
grass-addons/vector/v.vect.stats/main.c
code cleanup
Modified: grass-addons/vector/v.vect.stats/main.c
--- grass-addons/vector/v.vect.stats/main.c 2010-08-12 16:44:08 UTC (rev 43068)
+++ grass-addons/vector/v.vect.stats/main.c 2010-08-12 17:14:36 UTC (rev 43069)
@@ -62,8 +62,18 @@
} AREA_CAT;
+/* compare function for qsort and bsearch */
+static int cmp_area(const void *pa, const void *pb)
+ AREA_CAT *p1 = (AREA_CAT *) pa;
+ AREA_CAT *p2 = (AREA_CAT *) pb;
-static int cmp_area(const void *, const void *);
+ if (p1->area_cat < p2->area_cat)
+ return -1;
+ if (p1->area_cat > p2->area_cat)
+ return 1;
+ return 0;
int main(int argc, char *argv[])
@@ -220,7 +230,7 @@
*fs = '|';
- /* some checks for stats */
+ /* check for stats */
if (point_column_opt->answer) {
if (!method_opt->answer)
G_fatal_error("No method for statistics selected");
@@ -268,14 +278,12 @@
/* establish the statsvalue routine */
statsvalue = menu[method].method;
- /* category number of lowest value */
- if ((strcmp(menu[method].name, menu[5].name) == 0))
+ /* category number of lowest/highest value */
+ if ((strcmp(menu[method].name, menu[5].name) == 0) ||
+ (strcmp(menu[method].name, menu[7].name) == 0))
use_catno = 1;
- /* category number of highest value */
- if ((strcmp(menu[method].name, menu[7].name) == 0))
- use_catno = 1;
- G_debug(1, "method: %s, use cat no: %s", menu[method].name,
+ G_debug(1, "method: %s, use cat value: %s", menu[method].name,
(use_catno == 1 ? "yes" : "no"));
@@ -360,6 +368,8 @@
Pdriver = NULL;
if (method_opt->answer) {
+ G_verbose_message(_("collecting attributes from points vector..."));
PFi = Vect_get_field(&PIn, point_field);
if (PFi == NULL)
G_fatal_error(_("Database connection not defined for layer %d"),
@@ -395,8 +405,7 @@
db_CatValArray_init(&cvarr);
nrec = db_select_CatValArray(Pdriver, PFi->table, PFi->key,
point_column_opt->answer, NULL, &cvarr);
- G_debug(3, "selected values = %d", nrec);
+ G_debug(1, "selected values = %d", nrec);
db_close_database_shutdown_driver(Pdriver);
@@ -439,11 +448,13 @@
G_debug(1, "%d cats loaded from vector (including duplicates)", nacats);
- /* Sort by cats and remove duplicates */
+ /* Sort by category */
qsort((void *)Area_cat, nacats, sizeof(AREA_CAT), cmp_area);
- /* remove duplicates */
+ /* remove duplicate categories */
for (i = 1; i < nacats; i++) {
if (Area_cat[i].area_cat == Area_cat[i - 1].area_cat) {
for (j = i; j < nacats - 1; j++) {
@@ -463,6 +474,7 @@
(struct pvalcat *)G_calloc(npvalcatsalloc, sizeof(struct pvalcat));
/* remove for GRASS 7 */
+ G_verbose_message(_("creating spatial index"));
Vect_build_spatial_index(&PIn);
G_message(_("Selecting points for each area..."));
@@ -688,20 +700,12 @@
if (!print_flag->answer) {
G_percent(nacats, nacats, 2);
+ db_close_database_shutdown_driver(Adriver);
+ db_free_string(&stmt);
G_message(_("%d records updated"), update_ok);
if (update_err > 0)
G_message(_("%d update errors"), update_err);
- if (!print_flag->answer) {
- db_close_database_shutdown_driver(Adriver);
- db_free_string(&stmt);
- G_message(_("%d records inserted"), update_ok);
- if (update_err > 0)
- G_message(_("%d insert errors"), update_err);
Vect_set_db_updated(&AIn);
@@ -711,17 +715,3 @@
exit(EXIT_SUCCESS);
-static int cmp_area(const void *pa, const void *pb)
- AREA_CAT *p1 = (AREA_CAT *) pa;
- AREA_CAT *p2 = (AREA_CAT *) pb;
- if (p1->area_cat < p2->area_cat)
- return -1;
- if (p1->area_cat > p2->area_cat)
- return 1;
- return 0;
