[GRASS-SVN] r43071 - grass/trunk/lib/vector/Vlib
Thu Aug 12 13:22:12 EDT 2010
Author: mmetz
Date: 2010-08-12 17:22:12 +0000 (Thu, 12 Aug 2010)
New Revision: 43071
   grass/trunk/lib/vector/Vlib/close.c
avoid struct stat
Modified: grass/trunk/lib/vector/Vlib/close.c
--- grass/trunk/lib/vector/Vlib/close.c	2010-08-12 17:21:55 UTC (rev 43070)
+++ grass/trunk/lib/vector/Vlib/close.c	2010-08-12 17:22:12 UTC (rev 43071)
@@ -75,21 +75,20 @@
 	Map->plus.built == GV_BUILD_ALL) {
 	char buf[GPATH_MAX];
 	char file_path[GPATH_MAX];
-	struct stat info;
 	/* Delete old support files if available */
 	sprintf(buf, "%s/%s", GV_DIRECTORY, Map->name);
 	G__file_name(file_path, buf, GV_TOPO_ELEMENT, G_mapset());
-	if (stat(file_path, &info) == 0)	/* file exists? */
+	if (access(file_path, F_OK) == 0)	/* file exists? */
 	    unlink(file_path);
 	G__file_name(file_path, buf, GV_SIDX_ELEMENT, G_mapset());
 	    unlink(file_path);
 	G__file_name(file_path, buf, GV_CIDX_ELEMENT, G_mapset());
 	    unlink(file_path);
 	Vect_coor_info(Map, &CInfo);
