[GRASS-SVN] r43089 - grass-addons/imagery/i.landsat.acca
svn_grass at osgeo.org
Fri Aug 13 06:34:28 EDT 2010
Author: martinl
Date: 2010-08-13 10:34:28 +0000 (Fri, 13 Aug 2010)
New Revision: 43089
Added:
grass-addons/imagery/i.landsat.acca/grass7.patch
i.landsat.acca: patch for GRASS7
Added: grass-addons/imagery/i.landsat.acca/grass7.patch
--- grass-addons/imagery/i.landsat.acca/grass7.patch (rev 0)
+++ grass-addons/imagery/i.landsat.acca/grass7.patch 2010-08-13 10:34:28 UTC (rev 43089)
@@ -0,0 +1,362 @@
+Index: tools.c
+--- tools.c (revision 43088)
++++ tools.c (working copy)
+@@ -4,6 +4,7 @@
+ #include <math.h>
+ #include <unistd.h>
+ #include <grass/gis.h>
++#include <grass/raster.h>
+ #include <grass/glocale.h>
+ #include "local_proto.h"
+@@ -122,7 +123,7 @@
+ int pval(void * rast, int i)
+ void * ptr = (void *)((CELL *)rast + i);
+- if( G_is_c_null_value(ptr) )
++ if( Rast_is_c_null_value(ptr) )
+ return 0;
+ else
+ return (int)((CELL *) rast)[i];
+@@ -138,26 +139,26 @@
+ Gfile tmp;
+- nrows = G_window_rows();
+- ncols = G_window_cols();
++ nrows = Rast_window_rows();
++ ncols = Rast_window_cols();
+ if( nrows < 3 || ncols < 3 )
+ return;
+ /* Open to read */
+- mapset = G_find_cell2(out->name, "");
++ mapset = G_find_raster2(out->name, "");
+ if (mapset == NULL)
+ G_fatal_error("cell file [%s] not found", out->name);
+- arast = G_allocate_raster_buf(CELL_TYPE);
+- brast = G_allocate_raster_buf(CELL_TYPE);
+- crast = G_allocate_raster_buf(CELL_TYPE);
+- if ((out->fd = G_open_cell_old(out->name, mapset)) < 0)
++ arast = Rast_allocate_buf(CELL_TYPE);
++ brast = Rast_allocate_buf(CELL_TYPE);
++ crast = Rast_allocate_buf(CELL_TYPE);
++ if ((out->fd = Rast_open_old(out->name, mapset)) < 0)
+ G_fatal_error("Cannot open cell file [%s]", out->name);
+ /* Open to write */
+ sprintf(tmp.name, "_%d.BBB", getpid()) ;
+- tmp.rast = G_allocate_raster_buf(CELL_TYPE);
+- if ((tmp.fd = G_open_raster_new(tmp.name, CELL_TYPE)) < 0)
++ tmp.rast = Rast_allocate_buf(CELL_TYPE);
++ if ((tmp.fd = Rast_open_new(tmp.name, CELL_TYPE)) < 0)
+ G_fatal_error(_("Could not open <%s>"), tmp.name);
+ fprintf(stdout, "Filling cloud holes ... \n");
+@@ -172,17 +173,12 @@
+ /* Read row values */
+ if (row != 0)
+- if (G_get_c_raster_row(out->fd, arast, row - 1) < 0)
+- G_fatal_error(_("Could not read from <%s>"), out->name);
++ Rast_get_c_row(out->fd, arast, row - 1);
+- if (G_get_c_raster_row(out->fd, brast, row) < 0)
++ Rast_get_c_row(out->fd, brast, row);
+ if (row != (nrows - 1))
+- if (G_get_c_raster_row(out->fd, crast, row + 1) < 0)
++ Rast_get_c_row(out->fd, crast, row + 1);
+ /* Analysis of all pixels */
+ for (col = 0; col < ncols; col++)
+@@ -322,22 +318,19 @@
+ else
+- G_set_c_null_value((CELL *) tmp.rast + col, 1);
++ Rast_set_c_null_value((CELL *) tmp.rast + col, 1);
+- if (G_put_raster_row(tmp.fd, tmp.rast, CELL_TYPE) < 0)
+- G_fatal_error(_("Cannot write to <%s>"), tmp.name);
++ Rast_put_row(tmp.fd, tmp.rast, CELL_TYPE);
+ G_free(arast);
+ G_free(brast);
+ G_free(crast);
+- G_close_cell(out->fd);
++ Rast_close(out->fd);
+ G_free(tmp.rast);
+- G_close_cell(tmp.fd);
++ Rast_close(tmp.fd);
+ G_remove("cats", out->name);
+ G_remove("cell", out->name);
+Index: main.c
+--- main.c (revision 43088)
++++ main.c (working copy)
+@@ -19,6 +19,7 @@
+ #include <stdlib.h>
+ #include <string.h>
+@@ -53,7 +54,7 @@
+ int raster_fd;
+ char *mapset;
+- mapset = G_find_cell2(raster_name, "");
++ mapset = G_find_raster2(raster_name, "");
+ if (mapset == NULL) {
+ G_message("cell file [%s] not found", raster_name);
+ return -1;
+@@ -62,19 +63,13 @@
+ G_message("[%s] is an illegal name", raster_name);
+ return -1;
+- if ((raster_fd = G_open_cell_old(raster_name, mapset)) < 0) {
++ if ((raster_fd = Rast_open_old(raster_name, mapset)) < 0) {
+ G_message("Cannot open cell file [%s]", raster_name);
+ return -1;
+- if (G_get_cellhd(raster_name, mapset, &cellhd) < 0) {
+- G_message("Cannot read file header of [%s]", raster_name);
+- return -1;
+- if (G_set_window(&cellhd) < 0) {
+- G_message("Unable to set region");
+- return -1;
+- if ((map_type = G_raster_map_type(raster_name, mapset)) != DCELL_TYPE) {
++ Rast_get_cellhd(raster_name, mapset, &cellhd);
++ G_set_window(&cellhd);
++ if ((map_type = Rast_map_type(raster_name, mapset)) != DCELL_TYPE) {
+ G_message("Map is not of DCELL_TYPE");
+ return -1;
+@@ -166,7 +161,7 @@
+ G_fatal_error(_("Error in filename [%s]!"), band[i].name);
+- band[i].rast = G_allocate_raster_buf(DCELL_TYPE);
++ band[i].rast = Rast_allocate_buf(DCELL_TYPE);
+ out_name = output->answer;
+@@ -192,16 +187,16 @@
+ for (i = BAND2; i <= BAND6; i++)
+ G_free(band[i].rast);
+- G_close_cell(band[i].fd);
++ Rast_close(band[i].fd);
+ // struct Categories cats;
+ // G_read_raster_cats(out.name, char *mapset, cats)
+ // G_write_raster_cats(out.name, &cats);
+- G_short_history(out.name, "raster", &history);
+- G_command_history(&history);
+- G_write_history(out.name, &history);
++ Rast_short_history(out.name, "raster", &history);
++ Rast_command_history(&history);
++ Rast_write_history(out.name, &history);
+ exit(EXIT_SUCCESS);
+Index: algorithm.c
+--- algorithm.c (revision 43088)
++++ algorithm.c (working copy)
+@@ -4,6 +4,7 @@
+ #include <math.h>
+@@ -217,8 +218,8 @@
+ double pixel[5], nsdi, rat56, rat45;
+ /* Creation of output file */
+- out->rast = G_allocate_raster_buf(CELL_TYPE);
+- if ((out->fd = G_open_raster_new(out->name, CELL_TYPE)) < 0)
++ out->rast = Rast_allocate_buf(CELL_TYPE);
++ if ((out->fd = Rast_open_new(out->name, CELL_TYPE)) < 0)
+ G_fatal_error(_("Could not open <%s>"), out->name);
+@@ -229,8 +230,8 @@
+ stats[KMAX] = 0.;
+ stats[KMIN] = 10000.;
+ for (row = 0; row < nrows; row++)
+@@ -240,8 +241,7 @@
+- if (G_get_d_raster_row(band[i].fd, band[i].rast, row) < 0)
+- G_fatal_error(_("Could not read row from <%s>"), band[i].name);
++ Rast_get_d_row(band[i].fd, band[i].rast, row);
+@@ -249,7 +249,7 @@
+ /* Null when null pixel in any band */
+ for ( i = BAND2; i <= BAND6; i++ )
+- if (G_is_d_null_value((void *)((DCELL *) band[i].rast + col)))
++ if (Rast_is_d_null_value((void *)((DCELL *) band[i].rast + col)))
+ code = NO_CLOUD;
+ break;
+@@ -326,22 +326,19 @@
+ if (code == NO_CLOUD)
+- G_set_c_null_value((CELL *) out->rast + col, 1);
++ Rast_set_c_null_value((CELL *) out->rast + col, 1);
+ else
+ ((CELL *) out->rast)[col] = code;
+- if (G_put_raster_row(out->fd, out->rast, CELL_TYPE) < 0)
+- G_fatal_error(_("Cannot write row to <%s>"), out->name);
++ Rast_put_row(out->fd, out->rast, CELL_TYPE);
+ G_free(out->rast);
+ return;
+@@ -358,17 +355,17 @@
+ Gfile tmp;
+ if (upper == 0.)
+@@ -376,8 +373,8 @@
+ else
+ fprintf(stdout, "Pass two processing ... \n");
+@@ -385,16 +382,14 @@
+ G_percent(row, nrows, 2);
+- if (G_get_d_raster_row(band.fd, band.rast, row) < 0)
+- G_fatal_error(_("Could not read from <%s>"), band.name);
+- if (G_get_c_raster_row(out->fd, out->rast, row) < 0)
++ Rast_get_d_row(band.fd, band.rast, row);
++ Rast_get_c_row(out->fd, out->rast, row);
+- if (G_is_c_null_value((void *)((CELL *) out->rast + col)))
++ if (Rast_is_c_null_value((void *)((CELL *) out->rast + col)))
+ else
+@@ -406,7 +401,7 @@
+ temp = (double)((DCELL *) band.rast)[col];
+ if (temp > upper)
+ else
+@@ -427,19 +422,16 @@
+ ((CELL *) tmp.rast)[col] = IS_SHADOW;
+ /* Finalización */
+ G_free(tmp.rast);
+Index: Makefile
+--- Makefile (revision 43088)
++++ Makefile (working copy)
+@@ -2,8 +2,8 @@
+ PGM = i.landsat.acca
+-LIBES = $(GISLIB)
+-DEPENDENCIES = $(GISDEP)
++LIBES = $(GISLIB) $(RASTERLIB)
++DEPENDENCIES = $(GISDEP) $(RASTERDEP)
+ include $(MODULE_TOPDIR)/include/Make/Module.make
