[GRASS-SVN] r43092 - grass/trunk/scripts/g.extension
svn_grass at osgeo.org
Fri Aug 13 07:13:30 EDT 2010
Author: martinl
Date: 2010-08-13 11:13:30 +0000 (Fri, 13 Aug 2010)
New Revision: 43092
grass/trunk/scripts/g.extension/g.extension.py
g.extension: apply patch for GRASS7 if available
Modified: grass/trunk/scripts/g.extension/g.extension.py
--- grass/trunk/scripts/g.extension/g.extension.py 2010-08-13 11:11:43 UTC (rev 43091)
+++ grass/trunk/scripts/g.extension/g.extension.py 2010-08-13 11:13:30 UTC (rev 43092)
@@ -272,6 +272,19 @@
grass.fatal(_("GRASS Addons '%s' not found in repository") % module)
os.chdir(os.path.join(tmpdir, module))
+ if os.path.exists(os.path.join(tmpdir, module, 'grass7.patch')):
+ grass.message(_("Patch for GRASS 7 detected. Applying..."))
+ if not grass.find_program('patch'):
+ grass.fatal(_("Program 'patch' required. Exiting."))
+ stdin = open(os.path.join(tmpdir, module, 'grass7.patch'))
+ grass.call(['patch',
+ '-p0'],
+ stdin = stdin)
+ # rename manual page
+ os.rename('description.html', module + '.html')
+ grass.verbose(_("Manual renamed from 'description.html' to '%s.html'") % module)
grass.message(_("Compiling '%s'...") % module)
if grass.call(['make',
'MODULE_TOPDIR=%s' % gisbase]) != 0:
