[GRASS-SVN] r43094 - grass-addons/vector/v.vect.stats
svn_grass at osgeo.org
Fri Aug 13 08:14:29 EDT 2010
Author: mmetz
Date: 2010-08-13 12:14:29 +0000 (Fri, 13 Aug 2010)
New Revision: 43094
Added:
grass-addons/vector/v.vect.stats/grass7.patch
patch for grass7
Added: grass-addons/vector/v.vect.stats/grass7.patch
--- grass-addons/vector/v.vect.stats/grass7.patch (rev 0)
+++ grass-addons/vector/v.vect.stats/grass7.patch 2010-08-13 12:14:29 UTC (rev 43094)
@@ -0,0 +1,63 @@
+Index: main.c
+--- main.c (revision 43092)
++++ main.c (working copy)
+@@ -24,7 +24,7 @@
+ #include <grass/glocale.h>
+ #include <grass/stats.h>
+ #include <grass/dbmi.h>
+-#include <grass/Vect.h>
++#include <grass/vector.h>
+ struct menu
+@@ -108,7 +108,7 @@
+ char buf[2000];
+ int update_ok, update_err;
+ struct ilist *List;
+- BOUND_BOX box;
++ struct bound_box box;
+ dbCatValArray cvarr;
+ dbColumn *column;
+ struct pvalcat
+@@ -125,7 +125,9 @@
+ G_gisinit(argv[0]);
+ module = G_define_module();
+- module->keywords = _("vector, database, attribute table");
++ G_add_keyword(_("vector"));
++ G_add_keyword(_("database"));
++ G_add_keyword(_("attribute table"));
+ module->description = _("Count points in areas, calculate statistics.");
+ point_opt = G_define_standard_option(G_OPT_V_INPUT);
+@@ -169,7 +171,7 @@
+ method_opt->options = p;
+ method_opt->description = _("Method for aggregate statistics");
+- point_column_opt = G_define_standard_option(G_OPT_COLUMN);
++ point_column_opt = G_define_standard_option(G_OPT_DB_COLUMN);
+ point_column_opt->key = "pcolumn";
+ point_column_opt->required = NO;
+ point_column_opt->multiple = NO;
+@@ -478,10 +480,6 @@
+ pvalcats =
+ (struct pvalcat *)G_calloc(npvalcatsalloc, sizeof(struct pvalcat));
+- /* remove for GRASS 7 */
+- G_verbose_message(_("creating spatial index"));
+- Vect_build_spatial_index(&PIn);
+ G_message(_("Selecting points for each area..."));
+ count = 0;
+ for (area = 1; area <= nareas; area++) {
+@@ -657,7 +655,8 @@
+ if (Area_cat[i].count > 0 && method_opt->answer) {
+ /* get stats */
+- statsvalue(&result, Area_cat[i].values, Area_cat[i].nvalues);
++ statsvalue(&result, Area_cat[i].values, Area_cat[i].nvalues,
++ NULL);
+ if (half)
+ result += 0.5;
