[GRASS-SVN] r43098 - grass/trunk/vector/v.distance
svn_grass at osgeo.org
Sat Aug 14 08:39:10 EDT 2010
Author: mmetz
Date: 2010-08-14 12:39:10 +0000 (Sat, 14 Aug 2010)
New Revision: 43098
grass/trunk/vector/v.distance/main.c
refined search box increase
Modified: grass/trunk/vector/v.distance/main.c
--- grass/trunk/vector/v.distance/main.c 2010-08-13 21:04:45 UTC (rev 43097)
+++ grass/trunk/vector/v.distance/main.c 2010-08-14 12:39:10 UTC (rev 43098)
@@ -85,6 +85,8 @@
struct Map_info From, To, Out, *Outp;
int from_type, to_type, from_field, to_field;
double max, min;
+ double *max_step;
+ int n_max_steps, curr_step;
struct line_pnts *FPoints, *TPoints;
struct line_cats *FCats, *TCats;
NEAR *Near, *near;
@@ -326,9 +328,11 @@
/* TODO: add maxdist = -1 to Vect_select_ !!! */
/* Calc maxdist */
- if (max < 0) {
+ n_max_steps = 1;
+ if (max != 0) {
struct bound_box fbox, tbox;
- double dx, dy, dz;
+ double dx, dy, dz, tmp_max;
+ int n_features = 0;
Vect_get_map_box(&From, &fbox);
Vect_get_map_box(&To, &tbox);
@@ -342,14 +346,62 @@
else
dz = 0.0;
- max = sqrt(dx * dx + dy * dy + dz * dz);
+ tmp_max = sqrt(dx * dx + dy * dy + dz * dz);
+ if (max < 0)
+ max = tmp_max;
+ /* how to determine a reasonable number of steps to increase the search box? */
+ /* with max > 0 but max <<< tmp_max, 2 steps are sufficient, first 0 then max
+ * a reasonable number of steps also depends on the number of features in To
+ * e.g. only one area in To, no need to step */
+ nto = Vect_get_num_lines(&To);
+ for (tline = 1; tline <= nto; tline++) {
+ /* TODO: Vect_get_line_type() */
+ n_features += ((to_type & To.plus.Line[tline]->type) != 0);
+ if (to_type & GV_AREA) {
+ if (Vect_get_num_areas(&To) > n_features)
+ n_features = Vect_get_num_areas(&To);
+ if (n_features == 0)
+ G_fatal_error(_("No features of selected type in To vector <%s>"),
+ to_opt->answer);
+ n_max_steps = sqrt(n_features) * max / tmp_max;
+ /* max 9 steps from testing */
+ if (n_max_steps > 9)
+ n_max_steps = 9;
+ if (n_max_steps < 2)
+ n_max_steps = 2;
+ if (n_max_steps > n_features)
+ n_max_steps = n_features;
G_debug(2, "max = %f", max);
+ G_debug(2, "maximum reasonable search distance = %f", tmp_max);
+ G_debug(2, "n_features = %d", n_features);
+ G_debug(2, "n_max_steps = %d", n_max_steps);
if (min > max)
G_fatal_error("dmin can not be larger than dmax");
+ if (n_max_steps > 1) {
+ /* set up steps to increase search box */
+ max_step = G_malloc(n_max_steps * sizeof(double));
+ /* first step always 0 */
+ max_step[0] = 0;
+ for (curr_step = 1; curr_step < n_max_steps - 1; curr_step++) {
+ /* for 9 steps, this would be max / [128, 64, 32, 16, 8, 4, 2] */
+ max_step[curr_step] = max / (2 << (n_max_steps - 1 - curr_step));
+ /* last step always max */
+ max_step[n_max_steps - 1] = max;
+ else {
+ max_step = G_malloc(sizeof(double));
+ max_step[0] = max;
/* Open database driver */
db_init_string(&stmt);
db_init_string(&dbstr);
@@ -382,7 +434,6 @@
i++;
else {
driver = db_start_driver_open_database(NULL, NULL);
@@ -509,9 +560,6 @@
/* Find nearest lines */
if (to_type & (GV_POINTS | GV_LINES)) {
struct line_pnts *LLPoints;
- double tmp_min = (min < 0 ? 0 : min);
- double box_edge = 0;
- int enlarge = 0, enlarge_idx = 11;
if (G_projection() == PROJECTION_LL) {
LLPoints = Vect_new_line_struct();
@@ -523,42 +571,33 @@
for (fline = 1; fline <= nfrom; fline++) {
int tmp_tcat;
double tmp_tangle, tangle;
+ double tmp_min = (min < 0 ? 0 : min);
+ double box_edge = 0;
+ int done = 0;
- if (!enlarge) {
- enlarge_idx = 11;
+ curr_step = 0;
- G_debug(3, "fline = %d", fline);
- G_percent(fline, nfrom, 2);
- ftype = Vect_read_line(&From, FPoints, FCats, fline);
- if (!(ftype & from_type))
- continue;
+ G_debug(3, "fline = %d", fline);
+ G_percent(fline, nfrom, 2);
+ ftype = Vect_read_line(&From, FPoints, FCats, fline);
+ if (!(ftype & from_type))
+ continue;
- Vect_cat_get(FCats, from_field, &fcat);
- if (fcat < 0 && !all)
- continue;
+ Vect_cat_get(FCats, from_field, &fcat);
+ if (fcat < 0 && !all)
+ continue;
- if (!all) {
- box_edge = tmp_min;
+ while (!done) {
+ done = 1;
- if (!enlarge) {
- box.E = FPoints->x[0] + box_edge;
- box.W = FPoints->x[0] - box_edge;
- box.N = FPoints->y[0] + box_edge;
- box.S = FPoints->y[0] - box_edge;
- box.T = PORT_DOUBLE_MAX;
- box.B = -PORT_DOUBLE_MAX;
- Vect_select_lines_by_box(&To, &box, to_type, List);
- if (max > 0 && (enlarge || (!enlarge && List->n_values == 0))) {
+ if (!all) {
/* enlarge search box until we get a hit */
- /* enlarge_idx starts with 11, rather arbitrary but works */
- /* the objective is to enlarge the search box in the first iterations
- * just a little bit to keep the number of hits low */
- for (; enlarge_idx > 0; enlarge_idx -= 2) {
- box_edge = max / (enlarge_idx * enlarge_idx);
+ /* the objective is to enlarge the search box
+ * in the first iterations just a little bit
+ * to keep the number of hits low */
+ Vect_reset_list(List);
+ while (curr_step < n_max_steps) {
+ box_edge = max_step[curr_step];
if (box_edge < tmp_min)
continue;
@@ -572,146 +611,138 @@
- if (List->n_values > 0) {
- if (enlarge_idx > 1) {
- enlarge_idx -= 2;
+ curr_step++;
+ if (List->n_values > 0)
break;
+ else {
+ box.E = FPoints->x[0] + max;
+ box.W = FPoints->x[0] - max;
+ box.N = FPoints->y[0] + max;
+ box.S = FPoints->y[0] - max;
+ box.T = PORT_DOUBLE_MAX;
+ box.B = -PORT_DOUBLE_MAX;
- if (enlarge)
- enlarge = 0;
- else {
- box.E = FPoints->x[0] + max;
- box.W = FPoints->x[0] - max;
- box.N = FPoints->y[0] + max;
- box.S = FPoints->y[0] - max;
+ Vect_select_lines_by_box(&To, &box, to_type, List);
+ G_debug(3, " %d lines in box", List->n_values);
- G_debug(3, " %d lines in box", List->n_values);
+ tline = 0;
+ dist = PORT_DOUBLE_MAX;
+ for (i = 0; i < List->n_values; i++) {
+ tmp_tcat = -1;
+ Vect_read_line(&To, TPoints, TCats, List->value[i]);
- tline = 0;
- dist = PORT_DOUBLE_MAX;
- for (i = 0; i < List->n_values; i++) {
- tmp_tcat = -1;
- Vect_read_line(&To, TPoints, TCats, List->value[i]);
+ tseg =
+ Vect_line_distance(TPoints, FPoints->x[0], FPoints->y[0],
+ FPoints->z[0], (Vect_is_3d(&From) &&
+ Vect_is_3d(&To)) ?
+ WITH_Z : WITHOUT_Z, &tmp_tx, &tmp_ty,
+ &tmp_tz, &tmp_dist, NULL, &tmp_talong);
- tseg =
- Vect_line_distance(TPoints, FPoints->x[0], FPoints->y[0],
- FPoints->z[0], (Vect_is_3d(&From) &&
- Vect_is_3d(&To)) ?
- WITH_Z : WITHOUT_Z, &tmp_tx, &tmp_ty,
- &tmp_tz, &tmp_dist, NULL, &tmp_talong);
+ Vect_point_on_line(TPoints, tmp_talong, NULL, NULL, NULL,
+ &tmp_tangle, NULL);
- Vect_point_on_line(TPoints, tmp_talong, NULL, NULL, NULL,
- &tmp_tangle, NULL);
+ if (tmp_dist > max || tmp_dist < min)
+ continue; /* not in threshold */
- if (tmp_dist > max || tmp_dist < min)
- continue; /* not in threshold */
+ /* TODO: more cats of the same field */
+ Vect_cat_get(TCats, to_field, &tmp_tcat);
+ if (G_projection() == PROJECTION_LL) {
+ /* calculate distances in meters not degrees (only 2D) */
+ Vect_reset_line(LLPoints);
+ Vect_append_point(LLPoints, FPoints->x[0], FPoints->y[0],
+ FPoints->z[0]);
+ Vect_append_point(LLPoints, tmp_tx, tmp_ty, tmp_tz);
+ tmp_dist = Vect_line_geodesic_length(LLPoints);
+ for (k = 0; k < tseg; k++)
+ Vect_append_point(LLPoints, TPoints->x[k],
+ TPoints->y[k], TPoints->z[k]);
+ tmp_talong = Vect_line_geodesic_length(LLPoints);
- /* TODO: more cats of the same field */
- Vect_cat_get(TCats, to_field, &tmp_tcat);
- if (G_projection() == PROJECTION_LL) {
- /* calculate distances in meters not degrees (only 2D) */
- Vect_reset_line(LLPoints);
- Vect_append_point(LLPoints, FPoints->x[0], FPoints->y[0],
- FPoints->z[0]);
- Vect_append_point(LLPoints, tmp_tx, tmp_ty, tmp_tz);
- tmp_dist = Vect_line_geodesic_length(LLPoints);
- for (k = 0; k < tseg; k++)
- Vect_append_point(LLPoints, TPoints->x[k],
- TPoints->y[k], TPoints->z[k]);
- tmp_talong = Vect_line_geodesic_length(LLPoints);
+ G_debug(4, " tmp_dist = %f tmp_tcat = %d", tmp_dist,
+ tmp_tcat);
- G_debug(4, " tmp_dist = %f tmp_tcat = %d", tmp_dist,
- tmp_tcat);
+ if (all) {
+ if (anear <= count) {
+ anear += 10 + nfrom / 10;
+ Near = (NEAR *) G_realloc(Near, anear * sizeof(NEAR));
+ near = &(Near[count]);
- if (all) {
- if (anear <= count) {
- anear += 10 + nfrom / 10;
- Near = (NEAR *) G_realloc(Near, anear * sizeof(NEAR));
+ /* store info about relation */
+ near->from_cat = fcat;
+ near->to_cat = tmp_tcat; /* -1 is OK */
+ near->dist = tmp_dist;
+ near->from_x = FPoints->x[0];
+ near->from_y = FPoints->y[0];
+ near->from_z = FPoints->z[0];
+ near->to_x = tmp_tx;
+ near->to_y = tmp_ty;
+ near->to_z = tmp_tz;
+ near->to_along = tmp_talong; /* 0 for points */
+ near->to_angle = tmp_tangle;
+ near->count++;
+ count++;
- near = &(Near[count]);
- /* store info about relation */
- near->from_cat = fcat;
- near->to_cat = tmp_tcat; /* -1 is OK */
- near->dist = tmp_dist;
- near->from_x = FPoints->x[0];
- near->from_y = FPoints->y[0];
- near->from_z = FPoints->z[0];
- near->to_x = tmp_tx;
- near->to_y = tmp_ty;
- near->to_z = tmp_tz;
- near->to_along = tmp_talong; /* 0 for points */
- near->to_angle = tmp_tangle;
- near->count++;
- count++;
- else {
- if (tline == 0 || (tmp_dist < dist)) {
- tline = List->value[i];
- tcat = tmp_tcat;
- dist = tmp_dist;
- tx = tmp_tx;
- ty = tmp_ty;
- tz = tmp_tz;
- talong = tmp_talong;
- tangle = tmp_tangle;
+ else {
+ if (tline == 0 || (tmp_dist < dist)) {
+ tline = List->value[i];
+ tcat = tmp_tcat;
+ dist = tmp_dist;
+ tx = tmp_tx;
+ ty = tmp_ty;
+ tz = tmp_tz;
+ talong = tmp_talong;
+ tangle = tmp_tangle;
- G_debug(4, " dist = %f", dist);
+ G_debug(4, " dist = %f", dist);
- if (!all && max > 0) {
- /* enlarging the search box is possible */
- if (tline > 0 && dist >= box_edge) {
- /* line found but distance > search edge:
- * line bbox overlaps with search box, line itself is outside search box */
- enlarge = 1;
- fline--;
+ if (curr_step < n_max_steps) {
+ /* enlarging the search box is possible */
+ if (tline > 0 && dist > box_edge) {
+ /* line found but distance > search edge:
+ * line bbox overlaps with search box, line itself is outside search box */
+ done = 0;
+ else if (tline == 0) {
+ /* no line within max dist, but search box can still be enlarged */
+ done = 0;
- else if (tline == 0 && enlarge_idx > 1) {
- /* no line within max dist, but search box can still be enlarged */
- enlarge = 1;
- fline--;
- if (!enlarge && !all && tline > 0) {
- /* find near by cat */
- near =
- (NEAR *) bsearch((void *)&fcat, Near, nfcats,
- sizeof(NEAR), cmp_near);
+ if (done && !all && tline > 0) {
+ /* find near by cat */
+ near =
+ (NEAR *) bsearch((void *)&fcat, Near, nfcats,
+ sizeof(NEAR), cmp_near);
- G_debug(4, " near.from_cat = %d near.count = %d",
- near->from_cat, near->count);
- if (near->count == 0 || near->dist > dist) {
- near->to_cat = tcat; /* -1 is OK */
- near->dist = dist;
- near->to_x = tx;
- near->to_y = ty;
- near->to_z = tz;
- near->to_along = talong; /* 0 for points */
- near->to_angle = tangle;
+ G_debug(4, " near.from_cat = %d near.count = %d",
+ near->from_cat, near->count);
+ if (near->count == 0 || near->dist > dist) {
+ near->to_cat = tcat; /* -1 is OK */
+ near->dist = dist;
+ near->to_x = tx;
+ near->to_y = ty;
+ near->to_z = tz;
+ near->to_along = talong; /* 0 for points */
+ near->to_angle = tangle;
+ near->count++;
- near->count++;
+ } /* done */
+ } /* next feature */
if (LLPoints) {
Vect_destroy_line_struct(LLPoints);
@@ -719,48 +750,36 @@
/* Find nearest areas */
G_message(_("Finding nearest areas..."));
+ int done = 0;
+ curr_step = 0;
- if (!enlarge) {
- enlarge_idx = 11;
+ continue;
- continue;
+ continue;
- continue;
+ while (!done) {
+ done = 1;
- if (!all) {
- if (!enlarge) {
- Vect_select_areas_by_box(&To, &box, List);
+ if (!all) {
continue;
@@ -774,155 +793,147 @@
- enlarge_idx -= 2;
+ curr_step++;
break;
+ else {
- if (enlarge)
- enlarge = 0;
- else {
+ Vect_select_areas_by_box(&To, &box, List);
+ G_debug(4, "%d areas selected by box", List->n_values);
- G_debug(4, "%d areas selected by box", List->n_values);
+ /* For each area in box check the distance */
+ tarea = 0;
+ int tmp_tcat;
- /* For each area in box check the distance */
- tarea = 0;
- int tmp_tcat;
+ area = List->value[i];
+ G_debug(4, "%d: area %d", i, area);
+ Vect_get_area_points(&To, area, TPoints);
- area = List->value[i];
- G_debug(4, "%d: area %d", i, area);
- Vect_get_area_points(&To, area, TPoints);
+ /* Find the distance to this area */
+ if (Vect_point_in_area(&To, area, FPoints->x[0], FPoints->y[0])) { /* in area */
+ tmp_dist = 0;
+ tmp_tx = FPoints->x[0];
+ tmp_ty = FPoints->y[0];
+ else if (Vect_point_in_poly(FPoints->x[0], FPoints->y[0], TPoints) > 0) { /* in isle */
+ nisles = Vect_get_area_num_isles(&To, area);
+ for (j = 0; j < nisles; j++) {
+ double tmp2_dist, tmp2_tx, tmp2_ty;
- /* Find the distance to this area */
- if (Vect_point_in_area(&To, area, FPoints->x[0], FPoints->y[0])) { /* in area */
- tmp_dist = 0;
- tmp_tx = FPoints->x[0];
- tmp_ty = FPoints->y[0];
- else if (Vect_point_in_poly(FPoints->x[0], FPoints->y[0], TPoints) > 0) { /* in isle */
- nisles = Vect_get_area_num_isles(&To, area);
- for (j = 0; j < nisles; j++) {
- double tmp2_dist, tmp2_tx, tmp2_ty;
+ isle = Vect_get_area_isle(&To, area, j);
+ Vect_get_isle_points(&To, isle, TPoints);
+ FPoints->y[0], FPoints->z[0],
+ WITHOUT_Z, &tmp2_tx, &tmp2_ty,
+ NULL, &tmp2_dist, NULL, NULL);
- isle = Vect_get_area_isle(&To, area, j);
- Vect_get_isle_points(&To, isle, TPoints);
- FPoints->y[0], FPoints->z[0],
- WITHOUT_Z, &tmp2_tx, &tmp2_ty,
- NULL, &tmp2_dist, NULL, NULL);
- if (j == 0 || tmp2_dist < tmp_dist) {
- tmp_dist = tmp2_dist;
- tmp_tx = tmp2_tx;
- tmp_ty = tmp2_ty;
+ if (j == 0 || tmp2_dist < tmp_dist) {
+ tmp_dist = tmp2_dist;
+ tmp_tx = tmp2_tx;
+ tmp_ty = tmp2_ty;
- else { /* outside area */
- FPoints->z[0], WITHOUT_Z, &tmp_tx,
- &tmp_ty, NULL, &tmp_dist, NULL, NULL);
+ else { /* outside area */
+ FPoints->z[0], WITHOUT_Z, &tmp_tx,
+ &tmp_ty, NULL, &tmp_dist, NULL, NULL);
- Vect_get_area_cats(&To, area, TCats);
- tmp_tcat = -1;
- /* TODO: all cats of given field ? */
- for (j = 0; j < TCats->n_cats; j++) {
- if (TCats->field[j] == to_field) {
- if (tmp_tcat >= 0)
- G_warning(_("More cats found in to_layer (area=%d)"),
- area);
- tmp_tcat = TCats->cat[j];
+ Vect_get_area_cats(&To, area, TCats);
+ tmp_tcat = -1;
+ /* TODO: all cats of given field ? */
+ for (j = 0; j < TCats->n_cats; j++) {
+ if (TCats->field[j] == to_field) {
+ if (tmp_tcat >= 0)
+ G_warning(_("More cats found in to_layer (area=%d)"),
+ area);
+ tmp_tcat = TCats->cat[j];
- tmp_tcat);
+ tmp_tcat);
- if (all) {
+ if (all) {
+ near->to_along = 0; /* nonsense for areas */
+ near->to_angle = 0; /* not supported for areas */
+ near->count++;
+ count++;
- near->to_along = 0; /* nonsense for areas */
- near->to_angle = 0; /* not supported for areas */
- near->count++;
- count++;
+ else if (tarea == 0 || tmp_dist < dist) {
+ tarea = area;
+ tcat = tmp_tcat;
+ dist = tmp_dist;
+ tx = tmp_tx;
+ ty = tmp_ty;
- else if (tarea == 0 || tmp_dist < dist) {
- tarea = area;
- tcat = tmp_tcat;
- dist = tmp_dist;
- tx = tmp_tx;
- ty = tmp_ty;
- if (tarea > 0 && dist >= box_edge) {
- /* area found but distance > search edge:
- * area bbox overlaps with search box, area itself is outside search box */
- enlarge = 1;
- fline--;
+ if (tarea > 0 && dist > box_edge) {
+ /* area found but distance > search edge:
+ * area bbox overlaps with search box, area itself is outside search box */
+ done = 0;
+ else if (tarea == 0) {
+ /* no area within max dist, but search box can still be enlarged */
+ done = 0;
- else if (tarea == 0 && enlarge_idx > 1) {
- /* no area within max dist, but search box can still be enlarged */
- enlarge = 1;
- fline--;
- if (!enlarge && !all && tarea > 0) {
- near =
+ if (done && !all && tarea > 0) {
+ near =
- G_debug(4, "near.from_cat = %d near.count = %d dist = %f",
- near->from_cat, near->count, near->dist);
+ G_debug(4, "near.from_cat = %d near.count = %d dist = %f",
+ near->from_cat, near->count, near->dist);
- near->to_x = tx;
- near->to_y = ty;
+ near->to_x = tx;
+ near->to_y = ty;
+ near->count++;
- near->count++;
+ } /* done */
G_debug(3, "count = %d", count);
