[GRASS-SVN] r43128 - in grass-addons/raster/r.pi: r.pi.corrwin
r.pi.export r.pi.import r.pi.index r.pi.rectangle
svn_grass at osgeo.org
Sun Aug 15 19:20:59 EDT 2010
Author: neteler
Date: 2010-08-15 23:20:59 +0000 (Sun, 15 Aug 2010)
New Revision: 43128
grass-addons/raster/r.pi/r.pi.corrwin/description.html
grass-addons/raster/r.pi/r.pi.export/description.html
grass-addons/raster/r.pi/r.pi.import/description.html
grass-addons/raster/r.pi/r.pi.index/description.html
grass-addons/raster/r.pi/r.pi.rectangle/description.html
HTML fixes
Modified: grass-addons/raster/r.pi/r.pi.corrwin/description.html
--- grass-addons/raster/r.pi/r.pi.corrwin/description.html 2010-08-15 22:48:20 UTC (rev 43127)
+++ grass-addons/raster/r.pi/r.pi.corrwin/description.html 2010-08-15 23:20:59 UTC (rev 43128)
@@ -9,19 +9,12 @@
line. Alternately, the user can simply type <B>r.pi.corrwin</B> on the command line, without program
arguments. In this case, the user will be prompted for flag settings and parameter values.
-</DL>
<H2>NOTES</H2>
-<P>
<H2>BUGS</H2>
<H2>SEE ALSO</H2>
<EM><A HREF="r.pi.lm.html">r.pi.ENN</A></EM><br>
@@ -32,3 +25,6 @@
Programming: Elshad Shirinov<br>
Scientific concept: Dr. Martin Wegmann <br>
Department of Remote Sensing <br>Remote Sensing and Biodiversity Unit<br> University of Wuerzburg, Germany
+<p><i>Last changed: $Date: 2007-05-10 21:32:06 +0200 (Thu, 10 May 2007) $</i>
Modified: grass-addons/raster/r.pi/r.pi.export/description.html
--- grass-addons/raster/r.pi/r.pi.export/description.html 2010-08-15 22:48:20 UTC (rev 43127)
+++ grass-addons/raster/r.pi/r.pi.export/description.html 2010-08-15 23:20:59 UTC (rev 43128)
@@ -15,13 +15,14 @@
For export and import of patch values after e.g. R calculation <EM>r.pi.export</EM> and <EM>r.pi.import</EM> can be applied using the same raster (same extent, resolution is mandatory).
<H2>SEE ALSO</H2>
-<EM><A HREF="r.pi.import/description.html">r.pi.import</A></EM><br>
+<EM><A HREF="r.pi.import.html">r.pi.import</A></EM><br>
<H2>AUTHOR</H2>
Modified: grass-addons/raster/r.pi/r.pi.import/description.html
--- grass-addons/raster/r.pi/r.pi.import/description.html 2010-08-15 22:48:20 UTC (rev 43127)
+++ grass-addons/raster/r.pi/r.pi.import/description.html 2010-08-15 23:20:59 UTC (rev 43128)
@@ -18,10 +18,12 @@
<H2>SEE ALSO</H2>
-<EM><A HREF="r.pi.export/description.html">r.pi.export</A></EM><br>
+<EM><A HREF="r.pi.export.html">r.pi.export</A></EM><br>
<H2>AUTHOR</H2>
+<p><i>Last changed: $Date$</i>
Property changes on: grass-addons/raster/r.pi/r.pi.import/description.html
___________________________________________________________________
Deleted: svn:executable
Added: svn:mime-type
+ text/html
Added: svn:keywords
+ Author Date Id
Added: svn:eol-style
+ native
Modified: grass-addons/raster/r.pi/r.pi.index/description.html
--- grass-addons/raster/r.pi/r.pi.index/description.html 2010-08-15 22:48:20 UTC (rev 43127)
+++ grass-addons/raster/r.pi/r.pi.index/description.html 2010-08-15 23:20:59 UTC (rev 43128)
@@ -38,3 +38,5 @@
Modified: grass-addons/raster/r.pi/r.pi.rectangle/description.html
--- grass-addons/raster/r.pi/r.pi.rectangle/description.html 2010-08-15 22:48:20 UTC (rev 43127)
+++ grass-addons/raster/r.pi/r.pi.rectangle/description.html 2010-08-15 23:20:59 UTC (rev 43128)
@@ -12,22 +12,13 @@
command line, without program arguments. In this case, the user will be
-</DL>
<H2>NOTES</H2>
The areas can only be generated horizontally, not diagonal. This can be added
as wish and might be implemented in the future.
-<P>
<H2>BUGS</H2>
<H2>SEE ALSO</H2>
<EM><A HREF="r.pi.ENN.html">r.pi.ENN</A></EM><br>
@@ -39,3 +30,6 @@
