[GRASS-SVN] r43151 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Mon Aug 16 14:38:17 EDT 2010
Author: martinl
Date: 2010-08-16 18:38:17 +0000 (Mon, 16 Aug 2010)
New Revision: 43151
grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
grass/trunk/gui/wxpython/gui_modules/toolbars.py
grass/trunk/gui/wxpython/gui_modules/wxnviz.py
wxGUI: don't crash when wxnviz is broken
(merge r43149 from trunk)
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_tools.py 2010-08-16 18:37:38 UTC (rev 43150)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_tools.py 2010-08-16 18:38:17 UTC (rev 43151)
@@ -36,11 +36,13 @@
import gselect
import gcmd
from preferences import globalSettings as UserSettings
-from nviz_mapdisp import wxUpdateView, wxUpdateLight, wxUpdateProperties
+try:
+ from nviz_mapdisp import wxUpdateView, wxUpdateLight, wxUpdateProperties
+ import wxnviz
+except ImportError:
+ pass
from debug import Debug
-import wxnviz
class NvizToolWindow(FN.FlatNotebook):
"""!Nviz (3D view) tools panel
Modified: grass/trunk/gui/wxpython/gui_modules/toolbars.py
--- grass/trunk/gui/wxpython/gui_modules/toolbars.py 2010-08-16 18:37:38 UTC (rev 43150)
+++ grass/trunk/gui/wxpython/gui_modules/toolbars.py 2010-08-16 18:38:17 UTC (rev 43151)
@@ -184,14 +184,9 @@
choices.append(_('3D view'))
self.toolId['3d'] = 1
else:
- from nviz import errorMsg as errorMsg1
- from wxnviz import errorMsg as errorMsg2
- if errorMsg2:
- errorMsg = str(errorMsg1) + ' (' + str(errorMsg2) + ')'
- else:
+ from nviz import errorMsg
log.WriteCmdLog(_('3D view mode not available'))
- log.WriteWarning(_('Reason: %s') % errorMsg)
+ log.WriteWarning(_('Reason: %s') % str(errorMsg))
log.WriteLog(_('Note that the 3D view mode is currently not working under MS Windows '
'(hopefully this will be fixed soon). '
'Please keep an eye out for updated versions of GRASS.'), wrap = 60)
Modified: grass/trunk/gui/wxpython/gui_modules/wxnviz.py
--- grass/trunk/gui/wxpython/gui_modules/wxnviz.py 2010-08-16 18:37:38 UTC (rev 43150)
+++ grass/trunk/gui/wxpython/gui_modules/wxnviz.py 2010-08-16 18:38:17 UTC (rev 43151)
@@ -22,15 +22,16 @@
from threading import Thread
from ctypes import *
-try:
- from grass.lib.grass import *
- from grass.lib.g3d import *
- from grass.lib.ogsf import *
- from grass.lib.nviz import *
- errorMsg = ''
-except ImportError, err:
- errorMsg = err
+from grass.lib.grass import *
+from grass.lib.g3d import *
+from grass.lib.ogsf import *
+from grass.lib.nviz import *
+errtype = CFUNCTYPE(UNCHECKED(c_int), String, c_int)
+errfunc = errtype(print_error)
+pertype = CFUNCTYPE(UNCHECKED(c_int), c_int)
+perfunc = pertype(print_progress)
log = None
@@ -56,12 +57,6 @@
return 0
-errtype = CFUNCTYPE(UNCHECKED(c_int), String, c_int)
-errfunc = errtype(print_error)
-pertype = CFUNCTYPE(UNCHECKED(c_int), c_int)
-perfunc = pertype(print_progress)
class Nviz(object):
def __init__(self, glog, gprogress):
"""!Initialize Nviz class instance
