[GRASS-SVN] r43157 -
grass/branches/develbranch_6/scripts/g.extension
svn_grass at osgeo.org
Wed Aug 18 10:16:43 EDT 2010
Author: hamish
Date: 2010-08-18 14:16:43 +0000 (Wed, 18 Aug 2010)
New Revision: 43157
grass/branches/develbranch_6/scripts/g.extension/g.extension
quoting (curly brackets do not protect from spaces in pathnames); remove == bashism; whitespace
Modified: grass/branches/develbranch_6/scripts/g.extension/g.extension
--- grass/branches/develbranch_6/scripts/g.extension/g.extension 2010-08-18 06:14:47 UTC (rev 43156)
+++ grass/branches/develbranch_6/scripts/g.extension/g.extension 2010-08-18 14:16:43 UTC (rev 43157)
@@ -4,7 +4,7 @@
# MODULE: g.extension
# AUTHOR(S): Markus Neteler
-# PURPOSE: Tool to download and install extensions from GRASS Addons SVN into
+# PURPOSE: Tool to download and install extensions from GRASS Addons SVN into
# local GRASS installation
# COPYRIGHT: (C) 2009-2010 by the Markus Neteler, GRASS Development Team
@@ -71,7 +71,7 @@
# definitions
-SVNURL_ADDONS=${GIS_OPT_SVNURL}
+SVNURL_ADDONS="$GIS_OPT_SVNURL"
MODULE="$GIS_OPT_EXTENSION"
PREFIX="$GIS_OPT_PREFIX"
@@ -113,29 +113,29 @@
expand_module_class_name()
# $1: module class
- if [ "$1" = "d" ] ; then
- echo "display"
- elif [ "$1" = "db" ] ; then
- echo "database"
- elif [ "$1" = "g" ] ; then
- echo "general"
- elif [ "$1" = "i" ] ; then
- echo "imagery"
- elif [ "$1" = "m" ] ; then
- echo "misc"
- elif [ "$1" = "ps" ] ; then
- echo "postscript"
-# elif [ "$1" = "p" ] ; then
-# echo "paint"
- elif [ "$1" = "r" ] ; then
- echo "raster"
- elif [ "$1" = "r3" ] ; then
- echo "raster3D"
-# elif [ "$1" = "s" ] ; then
-# echo "sites"
- elif [ "$1" = "v" ] ; then
+ if [ "$1" = "d" ] ; then
+ echo "display"
+ elif [ "$1" = "db" ] ; then
+ echo "database"
+ elif [ "$1" = "g" ] ; then
+ echo "general"
+ elif [ "$1" = "i" ] ; then
+ echo "imagery"
+ elif [ "$1" = "m" ] ; then
+ echo "misc"
+ elif [ "$1" = "ps" ] ; then
+ echo "postscript"
+# elif [ "$1" = "p" ] ; then
+# echo "paint"
+ elif [ "$1" = "r" ] ; then
+ echo "raster"
+ elif [ "$1" = "r3" ] ; then
+ echo "raster3D"
+# elif [ "$1" = "s" ] ; then
+# echo "sites"
+ elif [ "$1" = "v" ] ; then
echo "vector"
- else
+ else
echo "$1"
fi
@@ -175,8 +175,8 @@
cleanup(){
- if [ ! -z "${TMPDIR}" ] ; then
- rm -rf "${TMPDIR}"
+ if [ -n "$TMPDIR" ] ; then
+ rm -rf "$TMPDIR"
fi
@@ -191,8 +191,8 @@
exit 1
fi
-if [ "$PREFIX" == '$GISBASE' ] ; then
- PREFIX=$GISBASE
+if [ "$PREFIX" = '$GISBASE' ] ; then
+ PREFIX="$GISBASE"
fi
if [ -d "$PREFIX" ] ; then
@@ -202,9 +202,9 @@
exit 1
fi
-if [ "$GIS_OPT_OPERATION" == "remove" ] ; then
+if [ "$GIS_OPT_OPERATION" = "remove" ] ; then
g.message message="Removing <$MODULE>..."
if test -f "${MYINST_DIR}/bin/${MODULE}" ; then
rm -f "${MYINST_DIR}/bin/${MODULE}"
fi
@@ -222,7 +222,7 @@
cd "$TMPDIR"
g.message message="Fetching <$MODULE> from GRASS-Addons SVN (be patient)..."
-svn co ${SVNURL_ADDONS}/${MODULECLASS}/${MODULE}
+svn co "${SVNURL_ADDONS}/${MODULECLASS}/${MODULE}"
if [ $? -ne 0 ] ; then
g.message -e message="GRASS Addon ${MODULE} not found in repository or no network connection or another problem"
@@ -240,7 +240,7 @@
g.message message="Installing ${MODULE}..."
# is it a script?
- grep "default: script" $TMPDIR/${MODULE}/Makefile 2>&1 >/dev/null
+ grep "default: script" "$TMPDIR/$MODULE/Makefile" 2>&1 >/dev/null
if [ $? -eq 0 ] ; then
PROGTYPE=scripts
else
@@ -261,7 +261,7 @@
fi
touch "${MYINST_DIR}/`basename $0`.$$"
- g.message -e message="Cannot write to <${MYINST_DIR}>, installation failed"
+ g.message -e message="Cannot write to <$MYINST_DIR>, installation failed"
exit 1
else
rm -f "${MYINST_DIR}/`basename $0`.$$"
@@ -286,5 +286,5 @@
g.message message=""
g.message message="Installation of <$MODULE> in <$MYINST_DIR> successfully finished."
exit 0
