[GRASS-SVN] r43176 - grass/branches/develbranch_6/doc/python
Sat Aug 21 08:05:54 EDT 2010
Author: hamish
Date: 2010-08-21 12:05:54 +0000 (Sat, 21 Aug 2010)
New Revision: 43176
   grass/branches/develbranch_6/doc/python/example_ctypes.py
expand, code comments, svn props
Modified: grass/branches/develbranch_6/doc/python/example_ctypes.py
--- grass/branches/develbranch_6/doc/python/example_ctypes.py	2010-08-21 08:05:30 UTC (rev 43175)
+++ grass/branches/develbranch_6/doc/python/example_ctypes.py	2010-08-21 12:05:54 UTC (rev 43176)
@@ -1,49 +1,93 @@
 #!/usr/bin/env python
+This is an example of how to use "ctypes" to access GRASS's C API from
+within a Python script. See the GRASS Programmer's manual for details
+on the e.g. G_*() functions in the GRASS C libraries (libgis et al.).
+USAGE:  example_ctypes.py [Raster map name]
+        If a raster map name is not given it will prompt you for one.
+	This raster map is then opened, read, and data values printed
+	to stdout. You may wish to use 'g.region' to set the rows x
+	columns to something small (say 10 x 5) to avoid overwhelming
+	yourself: `g.region rows=10 cols=5`
+# FIXME: as an example it should make extensive use of code comments and document
+#  each and every step along the way.  (e.g. explain c_char_p().value memory pointer
+#  to string conversion for Python programmers not familar with C pointers)
+#  FIXME: explain at a basic level what ctypes is & does.
 import os, sys, subprocess
+# actiavate ctypes
 from ctypes import *
-grass = CDLL("libgrass_gis.so")
+# check if GRASS is running or not
 if not os.environ.has_key("GISBASE"):
     print "You must be in GRASS GIS to run this program."
     sys.exit(1)
+# load in the main GRASS C library
+grass = CDLL("libgrass_gis.so")
+# parse command line arguements, prompt user for a raster map name if one wasn't given
 if len(sys.argv)==2:
   input = sys.argv[1]
 else:
   input = raw_input("Raster Map Name? ")
-# initialize
+# initialize the C library
 s = subprocess.Popen(['g.version','-r'], stdout=subprocess.PIPE).communicate()[0]
 for line in s.splitlines():
     if line.startswith('Revision:'):
         version = '$' + line + '$'
 grass.G__gisinit(version, '')
 # find map in search path
 mapset = grass.G_find_cell2(input, '')
 mapset = c_char_p(mapset).value
+if not mapset:
+    print "Raster map <%s> not found." % input
+    sys.exit(1)
 # determine the inputmap type (CELL/FCELL/DCELL) */
 data_type = grass.G_raster_map_type(input, mapset)
 if data_type == 0:
     ptype = POINTER(c_int)
+    type_name = 'CELL'
 elif data_type == 1:
     ptype = POINTER(c_float)
+    type_name = 'FCELL'
 elif data_type == 2:
     ptype = POINTER(c_double)
-infd = grass.G_open_cell_old(input, mapset)
-inrast = grass.G_allocate_raster_buf(data_type)
-inrast = cast(c_void_p(inrast), ptype)
+    type_name = 'DCELL'
+print "Raster map <%s> contains data type %s." % (input, type_name)
+in_fd = grass.G_open_cell_old(input, mapset)
+in_rast = grass.G_allocate_raster_buf(data_type)
+in_rast = cast(c_void_p(in_rast), ptype)
 rows = grass.G_window_rows()
 cols = grass.G_window_cols()
-for rown in xrange(rows):
-    grass.G_get_raster_row(infd, inrast, rown, data_type)
-    print rown, inrast[0:cols]
-grass.G_close_cell(infd)
-grass.G_free(inrast)
+print "Current region is %d rows x %d columns.\n" % (rows, cols)
+# iterate through map rows
+for row_n in xrange(rows):
+    # read a row of raster data into memory, then print it
+    grass.G_get_raster_row(in_fd, in_rast, row_n, data_type)
+    print row_n, in_rast[0:cols]
+#TODO: NULL -> NaN
+# closed map and cleanup memory allocation
+grass.G_close_cell(in_fd)
+grass.G_free(in_rast)
Property changes on: grass/branches/develbranch_6/doc/python/example_ctypes.py
___________________________________________________________________
Added: svn:executable
Added: svn:mime-type
   + text/x-python
Added: svn:eol-style
   + native
