[GRASS-SVN] r43186 - grass/trunk/doc/python
Sat Aug 21 22:53:48 EDT 2010
Author: hamish
Date: 2010-08-22 02:53:48 +0000 (Sun, 22 Aug 2010)
New Revision: 43186
Added:
   grass/trunk/doc/python/README
   grass/trunk/doc/python/m.distance.py
   grass/trunk/doc/python/vectoraccess.py
add README, copy over SWIG examples from swig/python/examples/ (still need to be ported to ctypes)
Added: grass/trunk/doc/python/README
--- grass/trunk/doc/python/README	                        (rev 0)
+++ grass/trunk/doc/python/README	2010-08-22 02:53:48 UTC (rev 43186)
@@ -0,0 +1,17 @@
+There are two ways of using Python to run GRASS commands:
+ (or you could mix them together)
+- Module scripting using the grass python helper library and g.parser.
+    import grass.script as grass
+  For examples see scripts/ in the GRASS 7 source code.
+- Module creation using hooks into the C library functions using ctypes.
+  The scripts in the doc/python/examples/ directory will describe this.
+  (Ctypes is standard in Python 2.5 and newer; replaces the SWIG
+  implementation in GRASS)
+More details can be found in the GRASS Programmer's Manual.
Copied: grass/trunk/doc/python/m.distance.py (from rev 43184, grass/trunk/swig/python/examples/m.distance.py)
--- grass/trunk/doc/python/m.distance.py	                        (rev 0)
+++ grass/trunk/doc/python/m.distance.py	2010-08-22 02:53:48 UTC (rev 43186)
@@ -0,0 +1,201 @@
+#!/usr/bin/python
+# MODULE:       m.distance
+# AUTHOR(S):    Hamish Bowman, Dunedin, New Zealand
+# PURPOSE:      Find distance between two points
+#               If the projection is latitude-longitude, this distance
+#                 is measured along the geodesic.
+#               Demonstrates GRASS SWIG-Python interface
+# COPYRIGHT:    (c) 2008 Hamish Bowman, and The GRASS Development Team
+#               This program is free software under the GNU General Public
+#               License (>=v2). Read the file COPYING that comes with GRASS
+#               for details.
+# Requires GRASS SWIG-Python interface
+# Requires Numeric module (NumPy) from  http://numpy.scipy.org/
+# Requires NumPrt module from  http://geosci.uchicago.edu/csc/numptr/
+#%Module
+#%  label: Finds the distance between two or more points.
+#%  description: If the projection is latitude-longitude, this distance is measured along the geodesic.
+#%  keywords: miscellaneous, distance, measure
+#%End
+#%Option
+#%  key: coord
+#%  type: string
+#%  required: no
+#%  multiple: yes
+#%  key_desc: x,y
+#%  description: Comma separated list of coordinate pairs
+#%End
+#%Flag
+#%  key: i
+#%  description: Read coordinate pairs from stdin
+#%End
+import os, sys
+if not os.environ.has_key("GISBASE"):
+    print "You must be in GRASS GIS to run this program."
+    sys.exit(1)
+def main():
+    #### add your code here ####
+    # run this before starting python to append module search path:
+    #   export PYTHONPATH=$PYTHONPATH:/usr/local/grass-7.0.svn/etc/python
+    #   check with "import sys; sys.path"
+    # or:
+    sys.path.append("/usr/local/grass-7.0.svn/etc/python")
+    from grass.lib import grass as g7lib
+    # for passing pointers
+    import Numeric
+    import NumPtr
+    g7lib.G_gisinit('m.distance')
+    # returns 0 on success
+    ### calc distance ###
+    proj_type = g7lib.G_begin_distance_calculations()
+    # returns 0 if projection has no metrix (ie. imagery)
+    # returns 1 if projection is planimetric
+    # returns 2 if projection is latitude-longitude
+    # parser always creates at least an empty variable, and sys.argv is
+    #  toast, so no way to check if option was given. So it hangs if
+    #  --q was the only option given and there is no data from stdin.
+    coord_ans  = os.getenv("GIS_OPT_COORD")
+    stdin_flag = bool(int(os.getenv("GIS_FLAG_I")))
+    if stdin_flag is True:
+        coords = []
+        # read line by line from stdin
+        while 1:
+            line = sys.stdin.readline().strip()
+            if not line:   # EOF
+                break
+            else:
+                coords += line.split(',')
+    else:
+        # read from coord= command line option
+        coords = coord_ans.split(',')
+    if len(coords) < 4:
+       print "A minimum of two input coordinate pairs are needed"
+       return
+    # init variables
+    overall_distance = 0.0
+    if proj_type == 2:
+        # lat/lon scan for DDD:MM:SS.SSSS
+        easting = Numeric.array(0., Numeric.Float64)
+        eastPtr = NumPtr.getpointer(easting)
+        northing = Numeric.array(0., Numeric.Float64)
+        northPtr = NumPtr.getpointer(northing)
+        # TODO: for clarity, figure out how to replace "3" with
+        #       the defined LOCATION_LL constant from gis.i
+        g7lib.G_scan_easting(coords[0], eastPtr, 3)
+        g7lib.G_scan_northing(coords[1], northPtr, 3)
+        x1 = float(easting)
+        y1 = float(northing)
+    else:
+        # plain old coordinates
+        x1 = float(coords[0])
+        y1 = float(coords[1])
+    x = [x1]
+    y = [y1]
+    for i in range(1, (len(coords) / 2)):
+            g7lib.G_scan_easting (coords[ i*2 + 0 ], eastPtr, 3)
+            g7lib.G_scan_northing(coords[ i*2 + 1 ], northPtr, 3)
+            x2 = float(easting)
+            y2 = float(northing)
+        else:
+            x2 = float(coords[ i*2 + 0 ])
+            y2 = float(coords[ i*2 + 1 ])
+        segment_distance = g7lib.G_distance(x1, y1, x2, y2)
+        overall_distance += segment_distance
+        print "segment %d distance is %.2f meters" % (i, segment_distance)
+        # add to the area array
+        # setup for the next loop
+        x1 = x2
+        y1 = y2
+        x += [x2]
+        y += [y2]
+    print
+    print " total distance is %.2f meters" % overall_distance
+    print
+    ### calc area ###
+    if len(coords) < 6:
+        return
+    g7lib.G_begin_polygon_area_calculations()
+    # returns 0 if the projection is not measurable (ie. imagery or xy)
+    # returns 1 if the projection is planimetric (ie. UTM or SP)
+    # returns 2 if the projection is non-planimetric (ie. latitude-longitude)
+    # do not need to close polygon (but it doesn't hurt if you do)
+    npoints = len(x)
+    # unset variables:
+    #del [Xs, Xptr, Ys, Yptr]
+    #   or
+    #Xs = Xptr = Ys = Yptr = None
+    Xs = Numeric.array(x, Numeric.Float64)
+    Xptr = NumPtr.getpointer(Xs)
+    Ys = Numeric.array(y, Numeric.Float64)
+    Yptr = NumPtr.getpointer(Ys)
+    area = g7lib.G_area_of_polygon(Xptr, Yptr, npoints)
+    print "AREA:  %10.2f square meters" % area
+    print
+    # we don't need this, but just to have a look
+    if False:
+        if proj_type == 1:
+            g7lib.G_database_units_to_meters_factor()
+            # 1.0
+        print "Location units are", g7lib.G_database_unit_name(True)
+    #### end of your code ####
+    return
+if __name__ == "__main__":
+    if ( len(sys.argv) <= 1 or sys.argv[1] != "@ARGS_PARSED@" ):
+        os.execvp("g.parser", [sys.argv[0]] + sys.argv)
+    else:
+        main();
Copied: grass/trunk/doc/python/vectoraccess.py (from rev 43184, grass/trunk/swig/python/examples/vectoraccess.py)
--- grass/trunk/doc/python/vectoraccess.py	                        (rev 0)
+++ grass/trunk/doc/python/vectoraccess.py	2010-08-22 02:53:48 UTC (rev 43186)
@@ -0,0 +1,96 @@
+#!/usr/bin/python
+# run within GRASS Spearfish session
+# run this before starting python to append module search path:
+#   export PYTHONPATH=$PYTHONPATH:/usr/local/grass-7.0.svn/etc/python
+#   check with "import sys; sys.path"
+# or:
+#   sys.path.append("/usr/local/grass-7.0.svn/etc/python")
+import os, sys
+from grass.lib import grass
+from grass.lib import vector as grassvect
+import grass.script as grassscript
+    sys.exit(1)
+if len(sys.argv)==2:
+  input = sys.argv[1]
+else:
+  input = raw_input("Vector Map Name? ")
+# initialize
+grass.G_gisinit('')
+# find map in search path
+mapset = grass.G_find_vector2(input,'')
+# define map structure
+map = grassvect.Map_info()
+# define open level (level 2: topology)
+grassvect.Vect_set_open_level (2)
+# open existing map
+grassvect.Vect_open_old(map, input, mapset)
+# query
+print 'Vect map: ', input
+print 'Vect is 3D: ', grassvect.Vect_is_3d (map)
+print 'Vect DB links: ', grassvect.Vect_get_num_dblinks(map)
+print 'Map Scale:  1:', grassvect.Vect_get_scale(map)
+# vector box tests
+box = grassvect.bound_box()
+c_easting1  =  599505.0
+c_northing = 4921010.0
+c_easting2  =  4599505.0
+grassvect.Vect_get_map_box(map, box)
+print 'Position 1 in box? ', grassvect.Vect_point_in_box(c_easting1, c_northing, 0, box)
+print 'Position 2 in box? ', grassvect.Vect_point_in_box(c_easting2, c_northing, 0, box)
+print 'Vector line 2 in box? ', grassvect.Vect_get_line_box(map, 2, box)
+# misleading:
+# print 'Number of lines:', grassvect.Vect_get_num_lines(map)
+# how to access GV_POINT?
+# print 'Number of points: ', grassvect.Vect_get_num_primitives(map,GV_POINT)
+# confusing:
+#print 'Number of lines: ', grassvect.Vect_get_num_primitives(map,GV_LINE)
+#print 'Number of areas:', grassvect.Vect_get_num_primitives(map,GV_AREA)
+print 'Number of areas:', grassvect.Vect_get_num_areas(map)
+layer = 1
+tmp = grassscript.tempfile()
+tmpf = file(tmp, 'w')
+try:
+    f = grassscript.vector_db(input)[int(layer)]
+except KeyError:
+    grassscript.fatal("There is no table connected to this map. Run v.db.connect or v.db.addtable first.")
+table = f['table']
+database = f['database']
+driver = f['driver']
+# call GRASS command
+grassscript.run_command('v.db.select', flags = 'c', map = input,
+                   stdout = tmpf)
+tmpf.close()
+# check if result is empty
+tmpf = file(tmp)
+if tmpf.read(1) == '':
+    grassscript.fatal("Table <%s> contains no data.", table)
+# print table to stdout
+for line in tmpf:
+    print line
+tmpf.close()
+os.remove(tmp)
+# close map
+grassvect.Vect_close(map)
+## end of the python script
