[GRASS-SVN] r43189 - grass/trunk/doc/python
svn_grass at osgeo.org
Sat Aug 21 23:04:43 EDT 2010
Author: hamish
Date: 2010-08-22 03:04:43 +0000 (Sun, 22 Aug 2010)
New Revision: 43189
grass/trunk/doc/python/raster_example_ctypes.py
expand, code comments, svn props (merge from devbr6)
Modified: grass/trunk/doc/python/raster_example_ctypes.py
--- grass/trunk/doc/python/raster_example_ctypes.py 2010-08-22 02:56:17 UTC (rev 43188)
+++ grass/trunk/doc/python/raster_example_ctypes.py 2010-08-22 03:04:43 UTC (rev 43189)
@@ -1,50 +1,95 @@
#!/usr/bin/env python
+This is an example of how to use "ctypes" to access GRASS's C API from
+within a Python script. See the GRASS Programmer's manual for details
+on the e.g. G_*() functions in the GRASS C libraries (libgis et al.).
+USAGE: example_ctypes.py [Raster map name]
+ If a raster map name is not given it will prompt you for one.
+ This raster map is then opened, read, and data values printed
+ to stdout. You may wish to use 'g.region' to set the rows x
+ columns to something small (say 10 x 5) to avoid overwhelming
+ yourself: `g.region rows=10 cols=5`
+# FIXME: as an example it should make extensive use of code comments and document
+# each and every step along the way. (e.g. explain c_char_p().value memory pointer
+# to string conversion for Python programmers not familar with C pointers)
+# FIXME: explain at a basic level what ctypes is & does.
import os, sys, subprocess
+# actiavate ctypes
from ctypes import *
-grass = CDLL("libgrass_gis.so")
-rast = CDLL("libgrass_raster.so")
+# check if GRASS is running or not
if not os.environ.has_key("GISBASE"):
print "You must be in GRASS GIS to run this program."
sys.exit(1)
+# load in the main GRASS C library
+grass = CDLL("libgrass_gis.so")
+rast = CDLL("libgrass_raster.so")
+# parse command line arguements, prompt user for a raster map name if one wasn't given
if len(sys.argv)==2:
input = sys.argv[1]
else:
input = raw_input("Raster Map Name? ")
-# initialize
+# initialize the C library
s = subprocess.Popen(['g.version','-r'], stdout=subprocess.PIPE).communicate()[0]
for line in s.splitlines():
if line.startswith('Revision:'):
version = '$' + line + '$'
grass.G__gisinit(version, '')
# find map in search path
mapset = grass.G_find_raster2(input, '')
mapset = c_char_p(mapset).value
-# determine the inputmap type (CELL/FCELL/DCELL) */
+if not mapset:
+ print "Raster map <%s> not found." % input
+ sys.exit(1)
+# determine the inputmap type (CELL/FCELL/DCELL)
data_type = rast.Rast_map_type(input, mapset)
if data_type == 0:
ptype = POINTER(c_int)
+ type_name = 'CELL'
elif data_type == 1:
ptype = POINTER(c_float)
+ type_name = 'FCELL'
elif data_type == 2:
ptype = POINTER(c_double)
-infd = rast.Rast_open_old(input, mapset)
-inrast = rast.Rast_allocate_buf(data_type)
-inrast = cast(c_void_p(inrast), ptype)
+ type_name = 'DCELL'
+print "Raster map <%s> contains data type %s." % (input, type_name)
+in_fd = rast.Rast_open_old(input, mapset)
+in_rast = rast.Rast_allocate_buf(data_type)
+in_rast = cast(c_void_p(in_rast), ptype)
rows = rast.Rast_window_rows()
cols = rast.Rast_window_cols()
+print "Current region is %d rows x %d columns.\n" % (rows, cols)
-for rown in xrange(rows):
- rast.Rast_get_row(infd, inrast, rown, data_type)
- print rown, inrast[0:cols]
-rast.Rast_close(infd)
-grass.G_free(inrast)
+# iterate through map rows
+print "Map data:"
+for row_n in xrange(rows):
+ # read a row of raster data into memory, then print it
+ rast.Rast_get_row(in_fd, in_rast, row_n, data_type)
+ print row_n, in_rast[0:cols]
+#TODO: NULL -> NaN
+# closed map and cleanup memory allocation
+rast.Rast_close(in_fd)
+grass.G_free(in_rast)
Property changes on: grass/trunk/doc/python/raster_example_ctypes.py
___________________________________________________________________
Added: svn:mime-type
+ text/x-python
Added: svn:eol-style
+ native
