[GRASS-SVN] r43240 - grass/branches/develbranch_6/scripts/m.proj
Tue Aug 24 10:46:31 EDT 2010
Author: hamish
Date: 2010-08-24 14:46:31 +0000 (Tue, 24 Aug 2010)
New Revision: 43240
   grass/branches/develbranch_6/scripts/m.proj/m.proj
gui sections
Modified: grass/branches/develbranch_6/scripts/m.proj/m.proj
--- grass/branches/develbranch_6/scripts/m.proj/m.proj	2010-08-24 13:53:03 UTC (rev 43239)
+++ grass/branches/develbranch_6/scripts/m.proj/m.proj	2010-08-24 14:46:31 UTC (rev 43240)
@@ -33,6 +33,7 @@
 #% description: Input coordinate file (omit to read from stdin)
 #% required : no
 #% key_desc : filename
+#% guisection: Files & format
 #%end
 #%option
 #% key: output
@@ -41,6 +42,7 @@
 #% description: Output coordinate file (omit to send to stdout)
 #% required : no
 #%end
 #%option
 #% key: fs
@@ -49,38 +51,46 @@
 #% required : no
 #% key_desc : character
 #% answer : |
 #%end
 #%option
 #% key: proj_in
 #% type: string
 #% description: Input projection parameters (PROJ.4 style)
 #% required : no
+#% guisection: Projections
 #%end
 #%option
 #% key: proj_out
 #% type: string
 #% description: Output projection parameters (PROJ.4 style)
 #% required : no
 #%end
 #%flag
 #% key: i
 #% description: Use LL WGS84 as input and current location as output projection
 #%end
 #%flag
 #% key: o
 #% description: Use current location as input and LL WGS84 as output projection
 #%end
 #%flag
 #% key: d
-#% description: Output long/lat in decimal degrees or other projections with many decimal places
+#% description: Output long/lat in decimal degrees, or other projections with many decimal places
 #%end
 #%flag
 #% key: e
 #% description: Include input coordinates in output file
 #%end
 #%flag
 #% key: g
 #% description: Script style output in CSV format respecting the field separator settings
 #%end
 #%flag
 #% key: v
