[GRASS-SVN] r43271 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Aug 25 17:37:15 EDT 2010
Author: martinl
Date: 2010-08-25 21:37:15 +0000 (Wed, 25 Aug 2010)
New Revision: 43271
grass/trunk/gui/wxpython/gui_modules/gmodeler.py
grass/trunk/gui/wxpython/gui_modules/goutput.py
wxGUI/modeler: fix OnCmdRun/Done
Modified: grass/trunk/gui/wxpython/gui_modules/gmodeler.py
--- grass/trunk/gui/wxpython/gui_modules/gmodeler.py 2010-08-25 21:05:27 UTC (rev 43270)
+++ grass/trunk/gui/wxpython/gui_modules/gmodeler.py 2010-08-25 21:37:15 UTC (rev 43271)
@@ -630,6 +630,24 @@
self.GetCanvas().Refresh()
self.SetStatusText("", 0)
+ def OnCmdRun(self, event):
+ """!Run command"""
+ try:
+ action = self.GetModel().GetItems()[event.pid]
+ if hasattr(action, "task"):
+ action.Update(running = True)
+ except IndexError:
+ pass
+ def OnCmdDone(self, event):
+ """!Command done (or aborted)"""
+ try:
+ pass
def OnCloseWindow(self, event):
"""!Close window"""
if self.modelChanged and \
@@ -936,7 +954,8 @@
for action in item.GetItems():
for vars()[condVar] in eval(condText):
- self._runAction(action, params)
+ if isinstance(action, ModelAction):
+ self._runAction(action, params)
if params:
dlg.Destroy()
@@ -948,7 +967,7 @@
paramsOrig = item.GetParams(dcopy = True)
item.MergeParams(params[name])
- self.SetStatusText(_('Running model...'), 0)
+ self.SetStatusText(_('Running model...'), 0)
self.goutput.RunCmd(command = item.GetLog(string = False),
onDone = self.OnDone)
Modified: grass/trunk/gui/wxpython/gui_modules/goutput.py
--- grass/trunk/gui/wxpython/gui_modules/goutput.py 2010-08-25 21:05:27 UTC (rev 43270)
+++ grass/trunk/gui/wxpython/gui_modules/goutput.py 2010-08-25 21:37:15 UTC (rev 43271)
@@ -665,10 +665,7 @@
"""!Run command"""
if self.parent.GetName() == 'Modeler':
- try:
- self.parent.GetModel().GetActions()[event.pid].Update(running = True)
- except IndexError:
- pass
+ self.parent.OnCmdRun(event)
self.WriteCmdLog('(%s)\n%s' % (str(time.ctime()), ' '.join(event.cmd)))
self.btn_abort.Enable()
@@ -676,10 +673,7 @@
- try:
- self.parent.GetModel().GetActions()[event.pid].Update(running = False)
- pass
+ self.parent.OnCmdDone(event)
if event.aborted:
# Thread aborted (using our convention of None return)
