[GRASS-SVN] r43275 -
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules
svn_grass at osgeo.org
Thu Aug 26 04:36:53 EDT 2010
Author: martinl
Date: 2010-08-26 08:36:53 +0000 (Thu, 26 Aug 2010)
New Revision: 43275
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/menuform.py
attempt to fix #1137
(merge r43266 from trunk)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/menuform.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/menuform.py 2010-08-26 08:27:17 UTC (rev 43274)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/menuform.py 2010-08-26 08:36:53 UTC (rev 43275)
@@ -102,11 +102,9 @@
import goutput
import utils
from preferences import globalSettings as UserSettings
-try:
- import subprocess
-except:
- from compat import subprocess
+from grass.script import core as grass
wxUpdateDialog, EVT_DIALOG_UPDATE = NewEvent()
# From lib/gis/col_str.c, except purple which is mentioned
@@ -1803,13 +1801,12 @@
Note: 'cmd' is given as string
- cmdout = os.popen(cmd + r' --interface-description', "r").read()
- if not len(cmdout) > 0 :
- raise IOError, _("Unable to fetch interface description for command '%s'.") % cmd
- p = re.compile( '(grass-interface.dtd)')
- p.search( cmdout )
- cmdout = p.sub(globalvar.ETCDIR + r'/grass-interface.dtd', cmdout)
- return cmdout
+ try:
+ cmdout = grass.Popen([cmd, '--interface-description'], stdout = grass.PIPE).communicate()[0]
+ except OSError:
+ raise gcmd.GException, _("Unable to fetch interface description for command '%s'.") % cmd
+ return cmdout.replace('grass-interface.dtd', os.path.join(globalvar.ETCDIR, 'grass-interface.dtd'))
class GrassGUIApp(wx.App):
