[GRASS-SVN] r43286 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Thu Aug 26 16:50:50 EDT 2010
Author: martinl
Date: 2010-08-26 20:50:50 +0000 (Thu, 26 Aug 2010)
New Revision: 43286
grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
wxGUI/modeler: if-else condition properties in progress
(merge r43285 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py 2010-08-26 20:47:49 UTC (rev 43285)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py 2010-08-26 20:50:50 UTC (rev 43286)
@@ -1,7 +1,7 @@
@package gmodeler.py
- at brief Graphical modeler to create, edit, and manage models
+ at brief wxGUI Graphical Modeler for creating, editing, and managing models
Classes:
- Model
@@ -22,12 +22,14 @@
- VariablePanel
- ValiableListCtrl
- ModelItem
+ - ModelItemDialog
- ModelLoop
- ModelLoopDialog
- ItemPanel
- ItemListCtrl
- ItemCheckListCtrl
- ModelCondition
+ - ModelConditionDialog
(C) 2010 by the GRASS Development Team
This program is free software under the GNU General Public License
@@ -210,7 +212,7 @@
for data in self.GetData():
if data.GetValue() == value and \
data.GetPrompt() == prompt:
- return dataItem
+ return data
return None
@@ -332,7 +334,7 @@
loopItem.SetItems(alist)
for action in loopItem.GetItems():
- action.SetLoop(loopItem)
+ action.SetBlock(loopItem)
def AddItem(self, newItem):
"""!Add item to the list"""
@@ -1651,7 +1653,7 @@
self.rels = list() # list of ModelRelations
self.isEnabled = True
- self.inLoop = None
+ self.inBlock = None
def GetId(self):
"""!Get id"""
@@ -1664,7 +1666,7 @@
def GetRelations(self, fdir = None):
"""!Get list of relations
@param fdir True for 'from'
if fdir is None:
@@ -1693,29 +1695,29 @@
def Update(self):
pass
- def SetLoop(self, loop = None):
+ def SetBlock(self, item = None):
"""!Register loop
- @param loop reference to loop (None to unset)
+ @param item reference to ModelObject which defines block of ModelObject (None to unset)
- self.inLoop = loop
+ self.inBlock = item
- def GetLoop(self):
- """!Get related loop
+ def GetBlock(self):
+ """!Get related ModelObject which defines block
- @return ModelLoop instance
- @return None if no loop defined
+ @return ModelLoop/ModelCondition instance
+ @return None if no block defined for this item
- return self.inLoop
+ return self.inBlock
- def GetLoopId(self):
- """!Get id of the loop
+ def GetBlockId(self):
+ """!Get id of ModelObject which defines block
- @return loop id
- @return None if action is not in the loop
+ @return item id
+ @return None if action is not in the block
- if self.inLoop:
- return self.inLoop.GetId()
+ if self.inBlock:
+ return self.inBlock.GetId()
return None
@@ -2206,7 +2208,6 @@
elif isinstance(shape, ModelLoop):
dlg = ModelLoopDialog(parent = self.frame, shape = shape)
- ### shape.SetPropDialog(dlg)
dlg.CentreOnParent()
if dlg.ShowModal() == wx.ID_OK:
shape.SetText(dlg.GetCondition())
@@ -2214,10 +2215,10 @@
ids = dlg.GetItems()
for aId in ids['unchecked']:
action = self.frame.GetModel().GetItem(aId)
- action.SetLoop()
+ action.SetBlock()
for aId in ids['checked']:
- action.SetLoop(shape)
+ action.SetBlock(shape)
if action:
alist.append(action)
shape.SetItems(alist)
@@ -2226,6 +2227,14 @@
dlg.Destroy()
+ elif isinstance(shape, ModelCondition):
+ dlg = ModelConditionDialog(parent = self.frame, shape = shape)
+ dlg.CentreOnParent()
+ if dlg.ShowModal() == wx.ID_OK:
+ shape.SetText(dlg.GetCondition())
+ dlg.Destroy()
def OnBeginDragLeft(self, x, y, keys = 0, attachment = 0):
"""!Drag shape (begining)"""
self.frame.ModelChanged()
@@ -2240,7 +2249,7 @@
shape = self.GetShape()
self.frame.DefineLoop(shape)
- loop = shape.GetLoop()
+ loop = shape.GetBlock()
if loop:
self.frame.DefineLoop(loop)
@@ -3858,6 +3867,45 @@
"""!Clear object, remove rels"""
self.rels = list()
+class ModelItemDialog(wx.Dialog):
+ """!Abstract item properties dialog"""
+ def __init__(self, parent, shape, title, id = wx.ID_ANY,
+ style = wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER, **kwargs):
+ self.parent = parent
+ self.shape = shape
+ wx.Dialog.__init__(self, parent, id, title = title, style = style, **kwargs)
+ self.panel = wx.Panel(parent = self, id = wx.ID_ANY)
+ self.condBox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
+ label=" %s " % _("Condition"))
+ self.condText = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY,
+ value = shape.GetText())
+ self.itemList = ItemCheckListCtrl(parent = self.panel,
+ window = self,
+ columns = [_("ID"), _("Name"),
+ _("Command")],
+ excludeId = [shape.GetId()])
+ self.itemList.Populate(self.parent.GetModel().GetItems())
+ self.btnCancel = wx.Button(parent = self.panel, id = wx.ID_CANCEL)
+ self.btnOk = wx.Button(parent = self.panel, id = wx.ID_OK)
+ self.btnOk.SetDefault()
+ def _layout(self):
+ """!Do layout (virtual method)"""
+ pass
+ def GetItems(self):
+ """!Get list of selected actions"""
+ return self.itemList.GetItems()
+ def GetCondition(self):
+ """!Get loop condition"""
+ return self.condText.GetValue()
class ModelLoop(ModelItem, ogl.RectangleShape):
def __init__(self, parent, x, y, id = -1, width = None, height = None, text = '', items = []):
"""!Defines a loop"""
@@ -3885,33 +3933,16 @@
"""!Get name"""
return _("loop")
-class ModelLoopDialog(wx.Dialog):
+class ModelLoopDialog(ModelItemDialog):
"""!Loop properties dialog"""
def __init__(self, parent, shape, id = wx.ID_ANY, title = _("Loop properties"),
- self.parent = parent
- self.shape = shape
+ ModelItemDialog.__init__(self, parent, shape, title,
+ style = style, **kwargs)
- wx.Dialog.__init__(self, parent, id, title = title, style = style, **kwargs)
- self.panel = wx.Panel(parent = self, id = wx.ID_ANY)
- self.condBox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
- label=" %s " % _("Condition"))
- self.condText = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY,
- value = shape.GetText())
self.listBox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
label=" %s " % _("List of items in loop"))
- self.itemList = ItemCheckListCtrl(parent = self.panel,
- columns = [_("ID"), _("Name"),
- _("Command")],
- excludeId = [shape.GetId()])
- self.itemList.Populate(self.parent.GetModel().GetItems())
- self.btnCancel = wx.Button(parent = self.panel, id = wx.ID_CANCEL)
- self.btnOk = wx.Button(parent = self.panel, id = wx.ID_OK)
- self.btnOk.SetDefault()
self._layout()
self.SetMinSize(self.GetSize())
self.SetSize((500, 400))
@@ -3945,23 +3976,6 @@
self.Layout()
- def GetItems(self):
- """!Get list of selected actions"""
- ids = { 'checked' : list(),
- 'unchecked' : list() }
- for i in range(self.itemList.GetItemCount()):
- iId = int(self.itemList.GetItem(i, 0).GetText())
- if self.itemList.IsChecked(i):
- ids['checked'].append(iId)
- else:
- ids['unchecked'].append(iId)
- return ids
- def GetCondition(self):
- """!Get loop condition"""
- return self.condText.GetValue()
class ItemPanel(wx.Panel):
def __init__(self, parent, id = wx.ID_ANY,
**kwargs):
@@ -3975,8 +3989,8 @@
label=" %s " % _("List of items - right-click to delete"))
self.list = ItemListCtrl(parent = self,
- columns = [_("ID"), _("Name"), _("In item"),
- _("Command / condition")])
+ columns = [_("ID"), _("Name"), _("In block"),
+ _("Command / Condition")])
self._layout()
@@ -4019,7 +4033,7 @@
"""!Populate the list"""
self.itemDataMap = dict()
i = 0
- if len(self.columns) == 3:
+ if len(self.columns) == 3: # ItemCheckList
checked = list()
for action in data:
if action.GetId() in self.excludeId:
@@ -4028,11 +4042,17 @@
self.itemDataMap[i] = [str(action.GetId()),
action.GetName(),
action.GetLog()]
- checked.append(action.GetLoopId())
+ aId = action.GetBlockId()
+ if aId not in self.excludeId:
+ aId = None
+ checked.append(aId)
else:
+ bId = action.GetBlockId()
+ if not bId:
+ bId = ''
action.GetName(),
- str(action.GetLoopId()),
+ str(bId),
action.GetLog()]
i += 1
@@ -4166,7 +4186,10 @@
class ItemCheckListCtrl(ItemListCtrl, listmix.CheckListCtrlMixin):
- def __init__(self, parent, columns, excludeId = [], **kwargs):
+ def __init__(self, parent, columns, window = None, excludeId = [], **kwargs):
+ self.window = window
ItemListCtrl.__init__(self, parent, columns, excludeId, disablePopup = True, **kwargs)
listmix.CheckListCtrlMixin.__init__(self)
self.SetColumnWidth(0, 50)
@@ -4174,7 +4197,36 @@
def OnBeginEdit(self, event):
"""!Disable editing"""
event.Veto()
+ def OnCheckItem(self, index, flag):
+ """!Item checked/unchecked"""
+ name = self.GetName()
+ if name == 'IfBlockList' and self.window:
+ self.window.OnCheckItemIf(index, flag)
+ elif name == 'ElseBlockList' and self.window:
+ self.window.OnCheckItemElse(index, flag)
+ ids = { 'checked' : list(),
+ 'unchecked' : list() }
+ for i in range(self.GetItemCount()):
+ iId = int(self.GetItem(i, 0).GetText())
+ if self.IsChecked(i):
+ ids['checked'].append(iId)
+ else:
+ ids['unchecked'].append(iId)
+ return ids
+ def CheckItemById(self, aId, flag):
+ """!Check/uncheck given item by id"""
+ if iId == aId:
+ self.CheckItem(i, flag)
+ break
class ModelCondition(ModelItem, ogl.PolygonShape):
"""!Defines a condition"""
@@ -4220,6 +4272,84 @@
"""!Get object height"""
return self.height
+class ModelConditionDialog(ModelItemDialog):
+ """!Condition properties dialog"""
+ def __init__(self, parent, shape, id = wx.ID_ANY, title = _("If-else properties"),
+ self.listBoxIf = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
+ label=" %s " % _("List of items in 'if' block"))
+ self.itemListIf = self.itemList
+ self.itemListIf.SetName('IfBlockList')
+ self.listBoxElse = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
+ label=" %s " % _("List of items in 'else' block"))
+ self.itemListElse = ItemCheckListCtrl(parent = self.panel,
+ window = self,
+ _("Command")],
+ self.itemListElse.SetName('ElseBlockList')
+ self.itemListElse.Populate(self.parent.GetModel().GetItems())
+ self._layout()
+ self.SetMinSize(self.GetSize())
+ self.SetSize((500, 400))
+ """!Do layout"""
+ sizer = wx.BoxSizer(wx.VERTICAL)
+ condSizer = wx.StaticBoxSizer(self.condBox, wx.VERTICAL)
+ condSizer.Add(item = self.condText, proportion = 1,
+ flag = wx.EXPAND)
+ listIfSizer = wx.StaticBoxSizer(self.listBoxIf, wx.VERTICAL)
+ listIfSizer.Add(item = self.itemListIf, proportion = 1,
+ flag = wx.EXPAND)
+ listElseSizer = wx.StaticBoxSizer(self.listBoxElse, wx.VERTICAL)
+ listElseSizer.Add(item = self.itemListElse, proportion = 1,
+ flag = wx.EXPAND)
+ btnSizer = wx.StdDialogButtonSizer()
+ btnSizer.AddButton(self.btnCancel)
+ btnSizer.AddButton(self.btnOk)
+ btnSizer.Realize()
+ sizer.Add(item = condSizer, proportion = 0,
+ flag = wx.EXPAND | wx.ALL, border = 3)
+ sizer.Add(item = listIfSizer, proportion = 1,
+ flag = wx.EXPAND | wx.LEFT | wx.RIGHT, border = 3)
+ sizer.Add(item = listElseSizer, proportion = 1,
+ sizer.Add(item = btnSizer, proportion=0,
+ flag = wx.EXPAND | wx.ALL | wx.ALIGN_CENTER, border=5)
+ self.panel.SetSizer(sizer)
+ sizer.Fit(self.panel)
+ self.Layout()
+ def OnCheckItemIf(self, index, flag):
+ """!Item in if-block checked/unchecked"""
+ if flag is False:
+ return
+ aId = int(self.itemListIf.GetItem(index, 0).GetText())
+ if aId in self.itemListElse.GetItems()['checked']:
+ self.itemListElse.CheckItemById(aId, False)
+ def OnCheckItemElse(self, index, flag):
+ """!Item in else-block checked/unchecked"""
+ if flag is False:
+ return
+ aId = int(self.itemListElse.GetItem(index, 0).GetText())
+ if aId in self.itemListIf.GetItems()['checked']:
+ self.itemListIf.CheckItemById(aId, False)
def main():
app = wx.PySimpleApp()
wx.InitAllImageHandlers()
