[GRASS-SVN] r43315 -
grass/branches/releasebranch_6_4/vector/v.in.ogr
svn_grass at osgeo.org
Fri Aug 27 14:53:36 EDT 2010
Author: mmetz
Date: 2010-08-27 18:53:36 +0000 (Fri, 27 Aug 2010)
New Revision: 43315
grass/branches/releasebranch_6_4/vector/v.in.ogr/geom.c
fix bug for min_area
Modified: grass/branches/releasebranch_6_4/vector/v.in.ogr/geom.c
--- grass/branches/releasebranch_6_4/vector/v.in.ogr/geom.c 2010-08-27 18:30:11 UTC (rev 43314)
+++ grass/branches/releasebranch_6_4/vector/v.in.ogr/geom.c 2010-08-27 18:53:36 UTC (rev 43315)
@@ -97,10 +97,19 @@
if ((np = OGR_G_GetPointCount(hRing)) > 0) {
IPoints[valid_isles] = Vect_new_line_struct();
for (j = 0; j < np; j++) {
- Vect_append_point(IPoints[valid_isles], OGR_G_GetX(hRing, j),
- OGR_G_GetY(hRing, j), OGR_G_GetZ(hRing, j));
+ Vect_append_point(IPoints[valid_isles],
+ OGR_G_GetX(hRing, j),
+ OGR_G_GetY(hRing, j),
+ OGR_G_GetZ(hRing, j));
- valid_isles++;
+ size =
+ G_area_of_polygon(IPoints[valid_isles]->x,
+ IPoints[valid_isles]->y,
+ IPoints[valid_isles]->n_points);
+ if (size < min_area)
+ Vect_destroy_line_struct(IPoints[valid_isles]);
+ else
+ valid_isles++;
@@ -274,17 +283,23 @@
if (IPoints[valid_isles]->n_points < 4)
G_warning(_("Degenerate island ([%d] vertices)"),
IPoints[i - 1]->n_points);
- size = G_area_of_polygon(Points->x, Points->y, Points->n_points);
+ size =
if (size < min_area) {
- G_warning(_("Island size [%.1e], island not imported"), size);
+ G_warning(_("Island size [%.1e], island not imported"),
+ size);
else {
if (type & GV_LINE)
@@ -295,15 +310,15 @@
valid_isles++;
- } /* inner rings done */
+ } /* inner rings done */
/* Centroid */
/* Vect_get_point_in_poly_isl() would fail for degenerate polygon */
if (mk_centr) {
if (Points->n_points >= 4) {
ret =
- Vect_get_point_in_poly_isl(Points, IPoints, valid_isles, &x,
- &y);
+ Vect_get_point_in_poly_isl(Points, IPoints, valid_isles,
+ &x, &y);
if (ret == -1) {
G_warning(_("Cannot calculate centroid"));
