[GRASS-SVN] r43326 - grass-web/trunk/grass64/binary/mswindows/cygwin
svn_grass at osgeo.org
Sat Aug 28 10:42:41 EDT 2010
Author: neteler
Date: 2010-08-28 14:42:41 +0000 (Sat, 28 Aug 2010)
New Revision: 43326
grass-web/trunk/grass64/binary/mswindows/cygwin/README.html
grass-web/trunk/grass64/binary/mswindows/cygwin/setup.ini
new RC7 frpm glynn
Modified: grass-web/trunk/grass64/binary/mswindows/cygwin/README.html
--- grass-web/trunk/grass64/binary/mswindows/cygwin/README.html 2010-08-28 10:15:51 UTC (rev 43325)
+++ grass-web/trunk/grass64/binary/mswindows/cygwin/README.html 2010-08-28 14:42:41 UTC (rev 43326)
@@ -184,7 +184,7 @@
From outside of GRASS you can run <tt>cygcheck</tt> to check for missing
DLL libraries by first changing to GRASS's library directory:
<pre>
- cd /usr/local/grass-6.4.0.RC6/lib
+ cd /usr/local/grass-6.4.0.RC7/lib
cygcheck ../bin/g.region
</pre>
@@ -206,11 +206,11 @@
<DD>
<pre>
$ cd /
-$ tar xjf /path/to/grass-6.4.0.RC6-1.cygwin.tar.bz2
+$ tar xjf /path/to/grass-6.4.0.RC7-1.cygwin.tar.bz2
</pre>
</DD>
-Everything will be /usr/local/grass-6.4.0.RC6, except for the grass64
+Everything will be /usr/local/grass-6.4.0.RC7, except for the grass64
script which is in /usr/local/bin.
<p>
Regarding external dependencies: the only dependencies which aren't
Modified: grass-web/trunk/grass64/binary/mswindows/cygwin/setup.ini
--- grass-web/trunk/grass64/binary/mswindows/cygwin/setup.ini 2010-08-28 10:15:51 UTC (rev 43325)
+++ grass-web/trunk/grass64/binary/mswindows/cygwin/setup.ini 2010-08-28 14:42:41 UTC (rev 43326)
@@ -2,5 +2,5 @@
sdesc: "GRASS - Geographic Resources Analysis Support System"
category: Database
requires: cygwin gdal libfftw3_3 lapack lapack libGL1 libGLU1 libX11_6 libXm2 libXmu6 libcairo2 libfreetype6 libiconv2 libintl8 libncurses9 libpng12 libpq5 libproj1 libreadline6 libsqlite3_0 libtiff5 proj tcltk zlib0 xinit
-version: 6.4.0.RC6-1
-install: grass-6.4.0.RC6-1.cygwin.tar.bz2 18962684 b98aec6b42a67bcabd68f8ef56f68a2c
+version: 6.4.0.RC7-1
+install: grass-6.4.0-RC7-1.cygwin.tar.bz2 18338102 31761c45a66f285469421bfc281b31a6
