[GRASS-SVN] r43330 - grass/branches/develbranch_6/raster/r.in.poly
Sun Aug 29 03:56:34 EDT 2010
Author: hamish
Date: 2010-08-29 07:56:33 +0000 (Sun, 29 Aug 2010)
New Revision: 43330
   grass/branches/develbranch_6/raster/r.in.poly/get_item.c
   grass/branches/develbranch_6/raster/r.in.poly/main.c
   grass/branches/develbranch_6/raster/r.in.poly/poly2rast.c
more precise surpression of warnings (needed at all?), add bad-coord warnings (side issue from #1142)
Modified: grass/branches/develbranch_6/raster/r.in.poly/get_item.c
--- grass/branches/develbranch_6/raster/r.in.poly/get_item.c	2010-08-29 07:37:59 UTC (rev 43329)
+++ grass/branches/develbranch_6/raster/r.in.poly/get_item.c	2010-08-29 07:56:33 UTC (rev 43330)
@@ -1,4 +1,6 @@
 #include <grass/gis.h>
+#include <grass/glocale.h>
 int get_item(FILE * fd, int *type, long *cat, double **x, double **y,
 	     int *count, struct Categories *labels)
@@ -69,13 +71,20 @@
 	    continue;
+	if (sscanf(buf, "%s %s", east, north) != 2) {
+	    G_warning(_("Illegal coordinate <%s, %s>, skipping."), east, north);
+	    continue;
-	if (sscanf(buf, "%s %s", east, north) != 2)
+	if (!G_scan_northing(north, &n, G_projection())) {
+	    G_warning(_("Illegal north coordinate <%s>, skipping."), north);
 	    continue;
-	if (!G_scan_northing(north, &n, G_projection()))
+	if (!G_scan_easting(east, &e, G_projection())) {
+	    G_warning(_("Illegal east coordinate <%s>, skipping."), east);
 	    continue;
-	if (!G_scan_easting(east, &e, G_projection()))
-	    continue;
 	if (*count >= nalloc) {
 	    nalloc += 32;
Modified: grass/branches/develbranch_6/raster/r.in.poly/main.c
--- grass/branches/develbranch_6/raster/r.in.poly/main.c	2010-08-29 07:37:59 UTC (rev 43329)
+++ grass/branches/develbranch_6/raster/r.in.poly/main.c	2010-08-29 07:56:33 UTC (rev 43330)
@@ -58,8 +58,5 @@
     if (n < 1)
 	G_fatal_error(_("Minimum number of rows to hold in memory is 1"));
-    /* otherwise get complaints about window changes */
-    G_suppress_warnings(1);
     exit(poly_to_rast(input->answer, output->answer, title->answer, n));
Modified: grass/branches/develbranch_6/raster/r.in.poly/poly2rast.c
--- grass/branches/develbranch_6/raster/r.in.poly/poly2rast.c	2010-08-29 07:37:59 UTC (rev 43329)
+++ grass/branches/develbranch_6/raster/r.in.poly/poly2rast.c	2010-08-29 07:56:33 UTC (rev 43330)
@@ -42,7 +42,12 @@
     G_init_cats((CELL) 0, title, &labels);
     format = getformat(ifd);
+    /* ?? otherwise get complaints about window changes */
+    G_suppress_warnings(TRUE);
     npasses = begin_rasterization(nrows, format);
+    G_suppress_warnings(FALSE);
     pass = 0;
     do {
