[GRASS-SVN] r44502 - in grass/branches/develbranch_6: imagery/i.ortho.photo tools
Wed Dec 1 04:50:49 EST 2010
Author: neteler
Date: 2010-12-01 01:50:49 -0800 (Wed, 01 Dec 2010)
New Revision: 44502
   grass/branches/develbranch_6/imagery/i.ortho.photo/README
   grass/branches/develbranch_6/tools/build_html_index.sh
   grass/branches/develbranch_6/tools/module_synopsis.sh
   grass/branches/develbranch_6/tools/sql.sh
change module names from photo.* to i.photo.*
Modified: grass/branches/develbranch_6/imagery/i.ortho.photo/README
--- grass/branches/develbranch_6/imagery/i.ortho.photo/README	2010-12-01 09:34:37 UTC (rev 44501)
+++ grass/branches/develbranch_6/imagery/i.ortho.photo/README	2010-12-01 09:50:49 UTC (rev 44502)
@@ -25,13 +25,13 @@
 following programs:
 1 i.group
-2 photo.target
-3 photo.init
-4 photo.camera
-5 photo.elev
-6 photo.2image
-7 photo.2target
-8 photo.rectify
+2 i.photo.target
+3 i.photo.init
+4 i.photo.camera
+5 i.photo.elev
+6 i.photo.2image
+7 i.photo.2target
+8 i.photo.rectify
@@ -39,21 +39,21 @@
 	./menu:			main menu code       (-> menu/menu.c)
-	./photo.target:		select target location and mapset
+	./i.photo.target:		select target location and mapset
-	./photo.elev:		select elevation model
+	./i.photo.elev:		select elevation model
-	./photo.camera:		select a camera to use for parameters
+	./i.photo.camera:		select a camera to use for parameters
-	./photo.2image:		code for image to photo coordinate
+	./i.photo.2image:		code for image to photo coordinate
 				transformation
-	./photo.init:		choose initial camera exposure station
+	./i.photo.init:		choose initial camera exposure station
 				parameters
-	./photo.2target:	computes photo to target location
+	./i.photo.2target:	computes photo to target location
 				transformation paramters
-	./photo.rectify:	does the actual image rectification
+	./i.photo.rectify:	does the actual image rectification
 	./libes:		libraries for ortho programs
Modified: grass/branches/develbranch_6/tools/build_html_index.sh
--- grass/branches/develbranch_6/tools/build_html_index.sh	2010-12-01 09:34:37 UTC (rev 44501)
+++ grass/branches/develbranch_6/tools/build_html_index.sh	2010-12-01 09:50:49 UTC (rev 44502)
@@ -14,8 +14,8 @@
 i.ask \
 i.find \
 p.out.vrml \
-photo.elev \
-photo.target \
+i.photo.elev \
+i.photo.target \
 r.cats \
 r.watershed.ram \
 r.watershed.seg \
Modified: grass/branches/develbranch_6/tools/module_synopsis.sh
--- grass/branches/develbranch_6/tools/module_synopsis.sh	2010-12-01 09:34:37 UTC (rev 44501)
+++ grass/branches/develbranch_6/tools/module_synopsis.sh	2010-12-01 09:50:49 UTC (rev 44502)
@@ -173,13 +173,13 @@
 g.parser: Full parser support for GRASS scripts.
 r.mapcalc: Performs arithmetic on raster map layers.
 r3.mapcalc: Performs arithmetic on 3D grid volume data.
-photo.2image: Marks fiducial or reseau points on an image to be ortho-rectified and then computes the image-to-photo coordinate transformation parameters.
-photo.2target: Create control points on an image to be ortho-rectified.
-photo.camera: Creates or modifies entries in a camera reference file.
-photo.elev: Selects target elevation model for ortho-rectification.
-photo.init: Creates or modifies entries in a camera initial exposure station file for imagery group referenced by a sub-block.
-photo.rectify: Rectifies an image by using the image to photo coordinate transformation matrix created by photo.2image and the rectification parameters created by photo.2target.
-photo.target: Selects target location and mapset for ortho-rectification.
+i.photo.2image: Marks fiducial or reseau points on an image to be ortho-rectified and then computes the image-to-photo coordinate transformation parameters.
+i.photo.2target: Create control points on an image to be ortho-rectified.
+i.photo.camera: Creates or modifies entries in a camera reference file.
+i.photo.elev: Selects target elevation model for ortho-rectification.
+i.photo.init: Creates or modifies entries in a camera initial exposure station file for imagery group referenced by a sub-block.
+i.photo.rectify: Rectifies an image by using the image to photo coordinate transformation matrix created by i.photo.2image and the rectification parameters created by i.photo.2target.
+i.photo.target: Selects target location and mapset for ortho-rectification.
 EOF
 ## with --dictionary-order db.* ends up in the middle of the d.* cmds
@@ -302,12 +302,12 @@
 	cat << EOF >> "${TMP}.html"
 </ul>
-<h4>Imagery photo.* commands:</h4>
+<h4>Imagery i.photo.* commands:</h4>
 <ul>
 EOF
-	grep "^photo\." "${TMP}.txt" | \
+	grep "^i.photo\." "${TMP}.txt" | \
 	  sed -e 's/: /| /' -e 's/^.*|/<li> <a href="&.html">&<\/a>:/' \
 	      -e 's/|.html">/.html">/' -e 's+|</a>:+</a>:+' \
 	      -e 's/&/\&amp;/g' \
@@ -445,16 +445,16 @@
 	       /^\\/ {print}' >> "${TMP}.tex"
     if [ "$SECTION" = "i" ] ; then
-	# include imagery photo subsection
+	# include imagery i.photo subsection
 	cat << EOF >> "${TMP}.tex"
 \end{lyxlist}
-\subsubsection*{Imagery photo.{*} commands:}
+\subsubsection*{Imagery i.photo.{*} commands:}
 \begin{lyxlist}{00.00.0000}
 EOF
 	  sed -e 's/^/\\item [/' -e 's/: /]/' >> "${TMP}.tex"
     fi
Modified: grass/branches/develbranch_6/tools/sql.sh
--- grass/branches/develbranch_6/tools/sql.sh	2010-12-01 09:34:37 UTC (rev 44501)
+++ grass/branches/develbranch_6/tools/sql.sh	2010-12-01 09:50:49 UTC (rev 44502)
@@ -39,11 +39,11 @@
 # 	grass=> SELECT object FROM obj_imp WHERE symbol = 'I_get_target' ;
 # 	                               object
-# 	 imagery/i.ortho.photo/photo.2image/OBJ.i686-pc-linux-gnu/target.o
-# 	 imagery/i.ortho.photo/photo.2target/OBJ.i686-pc-linux-gnu/target.o
-# 	 imagery/i.ortho.photo/photo.elev/OBJ.i686-pc-linux-gnu/main.o
-# 	 imagery/i.ortho.photo/photo.rectify/OBJ.i686-pc-linux-gnu/target.o
-# 	 imagery/i.ortho.photo/photo.target/OBJ.i686-pc-linux-gnu/main.o
+# 	 imagery/i.ortho.photo/i.photo.2image/OBJ.i686-pc-linux-gnu/target.o
+# 	 imagery/i.ortho.photo/i.photo.2target/OBJ.i686-pc-linux-gnu/target.o
+# 	 imagery/i.ortho.photo/i.photo.elev/OBJ.i686-pc-linux-gnu/main.o
+# 	 imagery/i.ortho.photo/i.photo.rectify/OBJ.i686-pc-linux-gnu/target.o
+# 	 imagery/i.ortho.photo/i.photo.target/OBJ.i686-pc-linux-gnu/main.o
 # 	 imagery/i.points/OBJ.i686-pc-linux-gnu/target.o
 # 	 imagery/i.rectify/OBJ.i686-pc-linux-gnu/target.o
 # 	 imagery/i.vpoints/OBJ.i686-pc-linux-gnu/target.o
