[GRASS-SVN] r44510 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Thu Dec 2 05:33:46 EST 2010
Author: martinl
Date: 2010-12-02 02:33:46 -0800 (Thu, 02 Dec 2010)
New Revision: 44510
grass/trunk/gui/wxpython/gui_modules/prompt.py
wxGUI: improvements in interactive prompt (patch by Anna Kratochvilova)
Modified: grass/trunk/gui/wxpython/gui_modules/prompt.py
--- grass/trunk/gui/wxpython/gui_modules/prompt.py 2010-12-02 09:59:51 UTC (rev 44509)
+++ grass/trunk/gui/wxpython/gui_modules/prompt.py 2010-12-02 10:33:46 UTC (rev 44510)
@@ -23,6 +23,7 @@
import sys
import shlex
import copy
+import difflib
import wx
import wx.stc
@@ -498,33 +499,7 @@
self.cmdbuffer = self._readHistory()
self.cmdindex = len(self.cmdbuffer)
- def CheckKey(self, text, keywords):
- """!Check if text is in keywords (unused)"""
- found = 0
- keys = text.split(',')
- if len(keys) > 1: # -> multiple keys
- for k in keys[:-1]:
- k = k.strip()
- for key in keywords:
- if k == key: # full match
- found += 1
- break
- k = keys[-1].strip()
- if k in key: # partial match
- found +=1
- break
- else:
- if text in key: # partial match
- found +=1
- break
- if found == len(keys):
- return True
- return False
def _readHistory(self):
"""!Get list of commands from history file"""
hist = list()
@@ -551,7 +526,7 @@
return self.moduleDesc[cmd]['desc']
return ''
def GetCommandItems(self):
"""!Get list of available commands"""
items = list()
@@ -560,7 +535,7 @@
mList = self.autoCompFilter
else:
mList = self.moduleList
if not mList:
return items
@@ -571,7 +546,7 @@
for command in mList[prefix]:
name = prefix + '.' + command
items.append(name)
items.sort()
return items
@@ -581,14 +556,23 @@
result = dict()
for module in globalvar.grassCmd['all']:
try:
- group, name = module.split('.', 1)
+ group, name = module.split('.',1)
except ValueError:
continue # TODO
if not result.has_key(group):
result[group] = list()
result[group].append(name)
+ # for better auto-completion:
+ # not only result['r']={...,'colors.out',...}, but also result['r.colors']={'out',...}
+ for i in range(len(name.split('.'))-1):
+ group = '.'.join([group,name.split('.',1)[0]])
+ name = name.split('.',1)[1]
+ if not result.has_key(group):
+ result[group] = list()
+ result[group].append(name)
# sort list of names
for group in result.keys():
result[group].sort()
@@ -639,7 +623,7 @@
def GetInput(self):
"""!Get main prompt widget"""
return self.input
class GPromptPopUp(GPrompt, TextCtrlAutoComplete):
"""!Interactive wxGUI prompt - popup version"""
def __init__(self, parent):
@@ -719,23 +703,69 @@
self.Bind(wx.EVT_WINDOW_DESTROY, self.OnDestroy)
self.Bind(wx.EVT_KEY_DOWN, self.OnKeyPressed)
self.Bind(wx.stc.EVT_STC_AUTOCOMP_SELECTION, self.OnItemSelected)
- def SetFilter(self, items):
- """!Sets filter
+ self.Bind(wx.EVT_LIST_ITEM_SELECTED, self.OnItemChanged)
- @param choices list of items to be filtered
- self.autoCompFilter = items
+ def OnItemChanged(self, event):
+ """!Change text in statusbar
+ if the item selection in the auto-completion list is changed"""
+ # list of commands
+ if self.toComplete['entity'] == 'command':
+ item = self.toComplete['cmd'].rpartition('.')[0] + '.' + self.autoCompList[event.GetIndex()]
+ try:
+ desc = self.moduleDesc[item]['desc']
+ except KeyError:
+ desc = ''
+ self.ShowStatusText(desc)
+ # list of flags
+ elif self.toComplete['entity'] == 'flags':
+ desc = self.cmdDesc.get_flag(self.autoCompList[event.GetIndex()])['description']
+ # list of parameters
+ elif self.toComplete['entity'] == 'params':
+ item = self.cmdDesc.get_param(self.autoCompList[event.GetIndex()])
+ desc = item['name'] + '=' + item['type']
+ if not item['required']:
+ desc = '[' + desc + ']'
+ desc += ': ' + item['description']
+ # list of flags and commands
+ elif self.toComplete['entity'] == 'params+flags':
+ if self.autoCompList[event.GetIndex()][0] == '-':
+ desc = self.cmdDesc.get_flag(self.autoCompList[event.GetIndex()].strip('-'))['description']
+ else:
+ else:
+ self.ShowStatusText('')
def OnItemSelected(self, event):
"""!Item selected from the list"""
- text = self.GetTextLeft()[:self.AutoCompPosStart()] + event.GetText() + ' '
- self.SetText(text)
+ lastWord = self.GetWordLeft()
+ # to insert selection correctly if selected word partly matches written text
+ match = difflib.SequenceMatcher(None, event.GetText(), lastWord)
+ matchTuple = match.find_longest_match(0, len(event.GetText()), 0, len(lastWord))
+ compl = event.GetText()[matchTuple[2]:]
+ text = self.GetTextLeft() + compl
+ # add space or '=' at the end
+ end = '='
+ for char in ('.','-','='):
+ if text.split(' ')[-1].find(char) >= 0:
+ end = ' '
+ compl += end
+ text += end
+ self.AddText(compl)
pos = len(text)
- self.SetSelectionStart(pos)
self.SetCurrentPos(pos)
- cmd = text.split()[0]
+ cmd = text.strip().split(' ')[0]
if not self.cmdDesc or cmd != self.cmdDesc.get_name():
if cmd in ('r.mapcalc', 'r3.mapcalc'):
self.parent.parent.OnMapCalculator(event = None, cmd = [cmd])
@@ -761,35 +791,209 @@
del self.cmdbuffer[0]
+ def EntityToComplete(self):
+ """!Determines which part of command (flags, parameters) should
+ be completed at current cursor position"""
+ entry = self.GetTextLeft()
+ toComplete = dict()
+ try:
+ cmd = entry.split()[0].strip()
+ except IndexError:
+ return None
+ if len(entry.split(' ')) > 1:
+ if cmd in globalvar.grassCmd['all']:
+ toComplete['cmd'] = cmd
+ if entry[-1] == ' ':
+ words = entry.split(' ')
+ if any(word.startswith('-') for word in words):
+ toComplete['entity'] = 'params'
+ return toComplete
+ else:
+ toComplete['entity'] = 'params+flags'
+ return toComplete
+ else:
+ #get word left from current position
+ word = self.GetWordLeft(withDelimiter = True)
+ if word[0] == '=':
+ # get name of parameter
+ paramName = self.GetWordLeft(withDelimiter = False, ignoredDelimiter = '=').strip('=')
+ if paramName:
+ try:
+ param = self.cmdDesc.get_param(paramName)
+ except ValueError:
+ return
+ else:
+ return
+ if param['values']:
+ toComplete['entity'] = 'param values'
+ return toComplete
+ elif param['prompt'] == 'raster' and param['element'] == 'cell':
+ toComplete['entity'] = 'raster map'
+ return toComplete
+ elif param['prompt'] == 'vector' and param['element'] == 'vector':
+ toComplete['entity'] = 'vector map'
+ return toComplete
+ elif word[0] == '-':
+ toComplete['entity'] = 'flags'
+ return toComplete
+ elif word[0] == ' ':
+ return toComplete
+ else:
+ return None
+ else:
+ toComplete['entity'] = 'command'
+ return toComplete
+ def GetWordLeft(self, withDelimiter = False, ignoredDelimiter = None):
+ """!Get word left from current cursor position. The beginning
+ of the word is given by space or chars: .,-=
+ @param withDelimiter returns the word with the initial delimeter
+ @param ignoredDelimiter finds the word ignoring certain delimeter
+ textLeft = self.GetTextLeft()
+ parts = list()
+ ignoredDelimiter = ignoredDelimiter if ignoredDelimiter is not None else ''
+ for char in set(' .,-=') - set(ignoredDelimiter):
+ delimiter = '' if not withDelimiter else char
+ parts.append(delimiter + textLeft.rpartition(char)[2])
+ return min(parts, key=lambda x: len(x))
+ def ShowList(self):
+ """!Show sorted auto-completion list if it is not empty"""
+ if len(self.autoCompList) > 0:
+ self.autoCompList.sort()
+ self.AutoCompShow(lenEntered = 0, itemList = ' '.join(self.autoCompList))
def OnKeyPressed(self, event):
"""!Key press capture for autocompletion, calltips, and command history
@todo event.ControlDown() for manual autocomplete
- # keycodes used: "." = 46, "=" = 61, "," = 44
+ # keycodes used: "." = 46, "=" = 61, "-" = 45
+ pos = self.GetCurrentPos()
+ #complete command after pressing '.'
if event.GetKeyCode() == 46 and not event.ShiftDown():
- # GRASS command autocomplete when '.' is pressed after 'r', 'v', 'i', 'g', 'db', or 'd'
self.autoCompList = list()
- pos = self.GetCurrentPos()
self.InsertText(pos, '.')
self.CharRight()
+ self.toComplete = self.EntityToComplete()
+ try:
+ self.autoCompList = self.moduleList[entry.strip()]
+ except KeyError:
+ return
+ self.ShowList()
+ # complete flags after pressing '-'
+ elif event.GetKeyCode() == 45 and not event.ShiftDown():
+ self.autoCompList = list()
- if entry not in ['r.', 'v.', 'i.', 'g.', 'db.', 'd.']:
- return
+ self.InsertText(pos, '-')
+ self.CharRight()
+ if self.toComplete['entity'] == 'flags':
+ if self.GetTextLeft()[-2:] == ' -': # complete e.g. --quite
+ for flag in self.cmdDesc.get_options()['flags']:
+ if len(flag['name']) == 1:
+ self.autoCompList.append(flag['name'])
+ else:
+ if len(flag['name']) > 1:
+ self.ShowList()
- if self.autoCompFilter:
- self.autoCompList = self.autoCompFilter[entry[:-1]]
- else:
- self.autoCompList = self.moduleList[entry[:-1]]
- if len(self.autoCompList) > 0:
- self.AutoCompShow(lenEntered = 0, itemList = ' '.join(self.autoCompList))
+ # complete map or values after parameter
+ elif event.GetKeyCode() == 61 and not event.ShiftDown():
+ self.InsertText(pos, '=')
+ self.CharRight()
+ if self.toComplete:
+ if self.toComplete['entity'] == 'raster map':
+ self.autoCompList = self.mapList['raster']
+ elif self.toComplete['entity'] == 'vector map':
+ self.autoCompList = self.mapList['vector']
+ elif self.toComplete['entity'] == 'param values':
+ param = self.GetWordLeft(withDelimiter = False, ignoredDelimiter='=').strip(' =')
+ self.autoCompList = self.cmdDesc.get_param(param)['values']
+ self.ShowList()
+ # complete after pressing CTRL + Space
+ elif event.GetKeyCode() == wx.WXK_SPACE and event.ControlDown():
+ if self.toComplete is None:
+ return
+ #complete command
+ for command in globalvar.grassCmd['all']:
+ if command.find(self.toComplete['cmd']) == 0:
+ dotNumber = list(self.toComplete['cmd']).count('.')
+ self.autoCompList.append(command.split('.',dotNumber)[-1])
+ # complete flags in such situations (| is cursor):
+ # r.colors -| ...w, q, l
+ # r.colors -w| ...w, q, l
+ # complete parameters in such situations (| is cursor):
+ # r.colors -w | ...color, map, rast, rules
+ # r.colors col| ...color
+ for param in self.cmdDesc.get_options()['params']:
+ if param['name'].find(self.GetWordLeft(withDelimiter=False)) == 0:
+ self.autoCompList.append(param['name'])
+ # complete flags or parameters in such situations (| is cursor):
+ # r.colors | ...-w, -q, -l, color, map, rast, rules
+ # r.colors color=grey | ...-w, -q, -l, color, map, rast, rules
+ self.autoCompList.append('-' + flag['name'])
+ else:
+ self.autoCompList.append('--' + flag['name'])
+ self.ShowList()
+ # r.buffer input=| ...list of raster maps
+ # r.buffer units=| ... feet, kilometers, ...
+ elif self.toComplete['entity'] == 'raster map':
+ self.ShowList()
elif event.GetKeyCode() == wx.WXK_TAB:
# show GRASS command calltips (to hide press 'ESC')
try:
@@ -805,68 +1009,7 @@
self.CallTipSetForeground("BLACK")
self.CallTipShow(pos, usage + '\n\n' + description)
- elif (event.GetKeyCode() == wx.WXK_SPACE and event.ControlDown()) or \
- (not event.ShiftDown() and (event.GetKeyCode() == 61 or event.GetKeyCode() == 44)):
- # Autocompletion for map/data file name entry after '=', ',', or manually
- entry = self.GetTextLeft()
- if 'r.mapcalc' in entry:
- self.InsertText(pos, '=')
- self.CharRight()
- return
- if event.GetKeyCode() != 44:
- self.promptType = None
- if not self.cmdDesc:
- # No partial or complete GRASS command found
- return
- try:
- # find last typed option
- arg = entry.rstrip('=').rsplit(' ', 1)[1]
- except:
- arg = ''
- try:
- self.promptType = self.cmdDesc.get_param(arg)['prompt']
- except:
- pass
- if event.GetKeyCode() == 61:
- # autocompletion after '='
- # insert the '=' and move to after the '=', ready for a map name
- self.CharRight()
- elif event.GetKeyCode() == 44:
- # autocompletion after ','
- # if comma is pressed, use the same maptype as previous for multiple map entries
- # insert the comma and move to after the comma ready for a map name
- self.InsertText(pos,',')
- self.CharRight()
- #must apply to an entry where '=[string]' has already been entered
- if '=' not in arg:
- return
- elif event.GetKeyCode() == wx.WXK_SPACE and event.ControlDown():
- # manual autocompletion
- # map entries without arguments (as in r.info [mapname]) use ctrl-shift
- return
- try:
- param = self.cmdDesc.get_list_params()[0]
- self.promptType = self.cmdDesc.get_param(param)['prompt']
- except IndexError:
- return
- if self.promptType and self.promptType in ('raster', 'raster3d', 'vector'):
- self.autoCompList = self.mapList[self.promptType]
elif event.GetKeyCode() in [wx.WXK_UP, wx.WXK_DOWN] and \
not self.AutoCompActive():
# Command history using up and down
@@ -896,6 +1039,7 @@
self.InsertText(pos,txt)
self.LineEnd()
+ self.parent.parent.statusbar.SetStatusText('')
elif event.GetKeyCode() == wx.WXK_RETURN and \
self.AutoCompActive() == False:
@@ -925,6 +1069,7 @@
# add command to history & clean prompt
self.UpdateCmdHistory(cmd)
self.OnCmdErase(None)
elif event.GetKeyCode() == wx.WXK_SPACE:
items = self.GetTextLeft().split()
@@ -941,7 +1086,16 @@
else:
event.Skip()
+ def ShowStatusText(self, text):
+ """!Sets statusbar text, if it's too long, it is cut off"""
+ maxLen = self.parent.parent.statusbar.GetFieldRect(0).GetWidth()/ 7 # any better way?
+ if len(text) < maxLen:
+ self.parent.parent.statusbar.SetStatusText(text)
+ else:
+ self.parent.parent.statusbar.SetStatusText(text[:maxLen]+'...')
def GetTextLeft(self):
"""!Returns all text left of the caret"""
