[GRASS-SVN] r44516 - grass/trunk/scripts/v.krige
svn_grass at osgeo.org
Thu Dec 2 06:10:29 EST 2010
Author: aghisla
Date: 2010-12-02 03:10:28 -0800 (Thu, 02 Dec 2010)
New Revision: 44516
grass/trunk/scripts/v.krige/v.krige.py
Grass.fatal errors when dependenciees are not found.
Modified: grass/trunk/scripts/v.krige/v.krige.py
--- grass/trunk/scripts/v.krige/v.krige.py 2010-12-02 11:02:16 UTC (rev 44515)
+++ grass/trunk/scripts/v.krige/v.krige.py 2010-12-02 11:10:28 UTC (rev 44516)
@@ -397,16 +397,12 @@
# rpy2
global robjects
global rinterface
- grass.message(_('Loading packages, please wait...'))
+ grass.message(_('Loading dependencies, please wait...'))
try:
import rpy2.robjects as robjects
import rpy2.rinterface as rinterface #to speed up kriging? for plots.
- haveRpy2 = True
except ImportError:
- print >> sys.stderr, _("Python module 'Rpy2' not found. Please install it and re-run v.krige.") # ok for other OSes?
- haveRpy2 = False
- if not haveRpy2:
- sys.exit(1)
+ grass.fatal(_("Python module 'Rpy2' not found. Please install it and re-run v.krige.")) # ok for other OSes?
# R packages check. Will create one error message after check of all packages.
missingPackagesList = []
@@ -415,7 +411,7 @@
missingPackagesList.append(each)
if missingPackagesList:
errorString = "R package(s) " + " ".join(["%s" % e for e in missingPackagesList] + "missing. Install it/them and re-run v.krige.")
- sys.exit(_(errorString))
+ grass.fatal(_(errorString))
if __name__ == '__main__':
if len(sys.argv) > 1:
