[GRASS-SVN] r44519 -
grass/branches/releasebranch_6_4/vector/v.surf.rst
svn_grass at osgeo.org
Thu Dec 2 08:05:53 EST 2010
Author: neteler
Date: 2010-12-02 05:05:53 -0800 (Thu, 02 Dec 2010)
New Revision: 44519
grass/branches/releasebranch_6_4/vector/v.surf.rst/description.html
grass/branches/releasebranch_6_4/vector/v.surf.rst/main.c
z-coordinate and zcol support backported
Modified: grass/branches/releasebranch_6_4/vector/v.surf.rst/description.html
--- grass/branches/releasebranch_6_4/vector/v.surf.rst/description.html 2010-12-02 12:59:06 UTC (rev 44518)
+++ grass/branches/releasebranch_6_4/vector/v.surf.rst/description.html 2010-12-02 13:05:53 UTC (rev 44519)
@@ -1,9 +1,9 @@
<h2>DESCRIPTION</h2>
<em>v.surf.rst</em>
-<br>This program performs spatial approximation based on z-values (<em>layer=0</em>
-parameter) or attributes (<em>zcolumn</em> parameter) of point or isoline data
-given in a vector map named <em>input</em> to grid cells in the output
+<br>This program performs spatial approximation based on z-values (<em>-z</em> flag
+or <em>layer=0</em> parameter) or attributes (<em>zcolumn</em> parameter)
+of point or isoline data given in a vector map named <em>input</em> to grid cells in the output
raster map <em>elev</em> representing a surface. As an option, simultaneously
with approximation, topographic parameters slope, aspect, profile curvature
(measured in the direction of the steepest slope), tangential curvature (measured
@@ -13,8 +13,9 @@
outputs partial derivatives f<sub>x</sub>,f<sub>y</sub>,f<sub>xx</sub>,
f<sub>yy</sub>,f<sub>xy</sub>
instead of slope, aspect, profile, tangential and mean curvatures respectively.
+<!-- the feature below has been lost when switch was made from sites to vector points)
If the input data have time stamp, the program creates time stamp for all
-output files.
+output files. -->
<p>
User can define a raster map named <em>maskmap</em>, which will be used
Modified: grass/branches/releasebranch_6_4/vector/v.surf.rst/main.c
--- grass/branches/releasebranch_6_4/vector/v.surf.rst/main.c 2010-12-02 12:59:06 UTC (rev 44518)
+++ grass/branches/releasebranch_6_4/vector/v.surf.rst/main.c 2010-12-02 13:05:53 UTC (rev 44519)
@@ -24,7 +24,9 @@
* modified by Mitasova in August 1995
* modified by Mitasova in November 1999 (dmax, timestamp update)
* dnorm independent tension - -t flag
- * cross-validation -v flag by Jaro Hofierka 2004
+ * cross-validation -v flag (changed to -c) by Jaro Hofierka 2004
+ * use z-coordinates flag -z July 2009, Helena
#include <stdio.h>
@@ -54,6 +56,7 @@
double /* pargr */ ns_res, ew_res;
double dmin, dmax, ertre;
int KMAX2, KMIN, KMAX, totsegm, deriv, dtens, cv;
+int zcoord;
struct Map_info Map;
struct Map_info TreeMap, OverMap;
struct Categories cats;
@@ -151,7 +154,7 @@
} parm;
struct
- struct Flag *deriv, *cprght, *cv;
+ struct Flag *deriv, *cprght, *cv, *zcoord;
} flag;
@@ -183,6 +186,11 @@
sprintf(dmaxchar, "%f", dmin * 5);
sprintf(dminchar, "%f", dmin);
+ flag.zcoord = G_define_flag();
+ flag.zcoord->key = 'z';
+ flag.zcoord->description =
+ _("Use z-coordinates (3D vector only)");
+ flag.zcoord->guisection = _("Selection");
flag.cv = G_define_flag();
flag.cv->key = 'c';
@@ -374,11 +382,9 @@
parm.scalex->description = _("Anisotropy scaling factor");
parm.scalex->guisection = _("Parameters");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
per = 1;
input = parm.input->answer;
field = atoi(parm.field->answer);
@@ -429,15 +435,22 @@
&& (cvdev == NULL))
G_warning(_("You are not outputting any raster or vector maps"));
+ deriv = flag.deriv->answer;
+ dtens = flag.cprght->answer;
+ cv = flag.cv->answer;
+ zcoord = flag.zcoord->answer;
+ if (zcoord) {
+ field = 0;
+ G_message("Using z-coordinate for interpolation");
if (parm.wheresql->answer != NULL) {
if (field < 1)
G_fatal_error(_("'layer' must be > 0 for 'where'."));
cond2 = ((pcurv != NULL) || (tcurv != NULL) || (mcurv != NULL));
cond1 = ((slope != NULL) || (aspect != NULL) || cond2);
- deriv = flag.deriv->answer;
- dtens = flag.cprght->answer;
- cv = flag.cv->answer;
if ((cv && cvdev == NULL) || (!(cv) && cvdev != NULL))
G_fatal_error(_("Both cross-validation options (-c flag and cvdev vector output) must be specified"));
@@ -445,6 +458,13 @@
if ((elev != NULL || cond1 || cond2 || devi != NULL) && cv)
G_fatal_error(_("The cross-validation cannot be computed simultaneously with output raster or devi file"));
+ if (field == 0 && zcol)
+ G_fatal_error(_("Both z-coordinate and zcol attribute defined, only one is allowed"));
+ if (!zcoord && !zcol && scol)
+ G_fatal_error(_("Only smoothing column defined, zcol or -z flag is missing"));
+ if (!zcol && !zcoord && field > 0)
+ G_fatal_error("Value to be interpolated needs to be defined by zcol or -z flag");
ertre = 0.1;
sscanf(parm.dmax->answer, "%lf", &dmax);
sscanf(parm.dmin->answer, "%lf", &dmin);
