[GRASS-SVN] r44522 - grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify
Thu Dec 2 09:22:50 EST 2010
Author: mmetz
Date: 2010-12-02 06:22:50 -0800 (Thu, 02 Dec 2010)
New Revision: 44522
   grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/README
   grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/exec.c
   grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/local_proto.h
   grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/main.c
   grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/readcell.c
   grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/rectify.c
fix memory handling and update README
Modified: grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/README
--- grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/README	2010-12-02 14:20:26 UTC (rev 44521)
+++ grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/README	2010-12-02 14:22:50 UTC (rev 44522)
@@ -4,14 +4,10 @@
  - have changed elev reading from CELL to raster_type to support
    also FP elevations
-Bugs:
- - somewhere the map_type is undefined in an underlying function (can't
-   identify), so I added G_suppress_warnings(1) at top of rectify.c
-   -> the module works well
+12/2010: Markus Metz
- - when DEBUG3 is activated, the module silently stops in exec.c at
-   select_current_env() (line 87). Why???
-   However, not a real bug. Seems to be a problem of exit status or
-   whatever.
+ - sync'ed to i.rectify as far as possible
+ - the module is now non-interactive and stand-alone:
+   typing i.photo.rectify on the commandline pops up a gui if GRASS is started with a gui
+ - i.ortho.photo has a new interactive part to set the options for i.photo.rectify
Modified: grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/exec.c
--- grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/exec.c	2010-12-02 14:20:26 UTC (rev 44521)
+++ grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/exec.c	2010-12-02 14:22:50 UTC (rev 44522)
@@ -112,7 +112,7 @@
 	G_free(result);
     close(ebuffer->fd);
-    G_free(ebuffer);
+    release_cache(ebuffer);
     G_done_msg(" ");
Modified: grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/local_proto.h
--- grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/local_proto.h	2010-12-02 14:20:26 UTC (rev 44521)
+++ grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/local_proto.h	2010-12-02 14:22:50 UTC (rev 44522)
@@ -30,6 +30,7 @@
 /* readcell.c */
 struct cache *readcell(int, int, int);
 block *get_block(struct cache *, int);
+void release_cache(struct cache *);
 /* report.c */
 int report(long, int);
Modified: grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/main.c
--- grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/main.c	2010-12-02 14:20:26 UTC (rev 44521)
+++ grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/main.c	2010-12-02 14:22:50 UTC (rev 44522)
@@ -108,7 +108,7 @@
     mem->type = TYPE_DOUBLE;
     mem->key_desc = "memory in MB";
     mem->required = NO;
-    mem->answer = "300";
+    mem->answer = "100";
     mem->description = _("Amount of memory to use in MB");
     ipolname = make_ipol_list();
@@ -238,7 +238,7 @@
     get_target(group.name);
     /* Check the GRASS_OVERWRITE environment variable */
-    if ((overstr = getenv("GRASS_OVERWRITE")))
+    if ((overstr = getenv("GRASS_OVERWRITE")))  /* OK ? */
 	target_overwrite = atoi(overstr);
     if (!target_overwrite) {
@@ -302,7 +302,7 @@
     /* determine memory for elevation and imagery */
     seg_mb_img = seg_mb_elev = -1;
-    if (!seg_mb) {
+    if (seg_mb) {
 	int max_rows, max_cols;
 	int nx, ny;
 	double max_mb_img, max_mb_elev;
@@ -310,7 +310,7 @@
 	max_rows = max_cols = 0;
 	for (i = 0; i < group.group_ref.nfiles; i++) {
-	    if (!ref_list[i]) {
+	    if (ref_list[i]) {
 		G_get_cellhd(group.group_ref.file[i].name,
 			     group.group_ref.file[i].mapset, &cellhd);
 		if (max_rows < cellhd.rows)
@@ -331,8 +331,8 @@
 	max_mb_elev = ((double)nx * ny * sizeof(block)) / (1<<20);
 	if ((seg_mb_total = atoi(seg_mb)) > 0) {
-	    seg_mb_elev = seg_mb_total * max_mb_elev / (max_mb_img + max_mb_elev);
-	    seg_mb_img = seg_mb_total * max_mb_img / (max_mb_img + max_mb_elev);
+	    seg_mb_elev = max_mb_elev * (seg_mb_total / (max_mb_img + max_mb_elev)) + 0.5;
+	    seg_mb_img = max_mb_img * (seg_mb_total / (max_mb_img + max_mb_elev)) + 0.5;
Modified: grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/readcell.c
--- grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/readcell.c	2010-12-02 14:20:26 UTC (rev 44521)
+++ grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/readcell.c	2010-12-02 14:22:50 UTC (rev 44522)
@@ -24,9 +24,19 @@
     int nblocks;
     int i;
+    if (target_env)
+	select_target_env();
+    else
+	select_current_env();
     nrows = G_window_rows();
     ncols = G_window_cols();
+    /* Temporary file must be created in the same location/mapset
+     * where the module was called */
+    if (target_env)
     ny = (nrows + BDIM - 1) / BDIM;
     nx = (ncols + BDIM - 1) / BDIM;
@@ -46,11 +56,7 @@
     c->refs = (int *)G_malloc(nblocks * sizeof(int));
     if (nblocks < nx * ny) {
-	/* Temporary file must be created in input location/mapset */
-	select_current_env();
 	filename = G_tempfile();
-	if (target_env)
-	    select_target_env();
 	c->fd = open(filename, O_RDWR | O_CREAT | O_EXCL, 0600);
 	if (c->fd < 0)
 	    G_fatal_error(_("Unable to open temporary file"));
@@ -58,6 +64,8 @@
     else
 	c->fd = -1;
+    G_debug(1, "%d of %d blocks in memory", nblocks, nx * ny);
     G_important_message(_("Allocating memory and reading input map..."));
     G_percent(0, nrows, 5);
@@ -67,6 +75,8 @@
     tmpbuf = (DCELL *) G_malloc(nx * sizeof(block));
+    if (target_env)
     for (row = 0; row < nrows; row += BDIM) {
 	int x, y;
@@ -127,7 +137,17 @@
 	G_fatal_error(_("Error seeking on segment file"));
     if (read(c->fd, p, sizeof(block)) < 0)
-	G_fatal_error(_("Error writing segment file"));
+	G_fatal_error(_("Error reading segment file"));
     return p;
+void release_cache(struct cache *c)
+    G_free(c->refs);
+    G_free(c->blocks);
+    G_free(c->grid);
+    G_free(c);
+    c = NULL;
Modified: grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/rectify.c
--- grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/rectify.c	2010-12-02 14:20:26 UTC (rev 44521)
+++ grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/rectify.c	2010-12-02 14:22:50 UTC (rev 44522)
@@ -116,7 +116,7 @@
     G_free(trast);
     close(ibuffer->fd);
-    G_free(ibuffer);
+    release_cache(ibuffer);
     if (G_get_cellhd(result, G_mapset(), &cellhd) < 0)
 	return 0;
