[GRASS-SVN] r44524 - in grass-addons/raster: . r.diversity
svn_grass at osgeo.org
Thu Dec 2 09:52:30 EST 2010
Author: lucadelu
Date: 2010-12-02 06:52:30 -0800 (Thu, 02 Dec 2010)
New Revision: 44524
Added:
grass-addons/raster/r.diversity/
grass-addons/raster/r.diversity/Makefile
grass-addons/raster/r.diversity/description.html
grass-addons/raster/r.diversity/r.diversity.py
new module to calculate diversity indices
Added: grass-addons/raster/r.diversity/Makefile
--- grass-addons/raster/r.diversity/Makefile (rev 0)
+++ grass-addons/raster/r.diversity/Makefile 2010-12-02 14:52:30 UTC (rev 44524)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = r.diversity
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/raster/r.diversity/Makefile
___________________________________________________________________
Added: svn:mime-type
+ text/x-makefile
Added: svn:eol-style
+ native
Added: grass-addons/raster/r.diversity/description.html
--- grass-addons/raster/r.diversity/description.html (rev 0)
+++ grass-addons/raster/r.diversity/description.html 2010-12-02 14:52:30 UTC (rev 44524)
@@ -0,0 +1,47 @@
+<h2>DESCRIPTION</h2>
+<em>r.diversity</em> calculates selected diversity indices by calling various
+<em>r.li</em> commands.
+<p>
+This script uses the Pielou, Renyi, Shannon and Simpson indices. The output is a
+map for each index.
+<h2>NOTES</h2>
+The user does not need to create a "conf" file with <em>r.li.setup</em> because this file
+will be created automatically by the script.<br>
+If the input raster contains NULL value cells, <em>r.diversity</em>
+returns -1 for these cells.<br>
+If the user wants to keep NULL values instead, run subsequently on the resulting map:
+<br>
+<div class="code"><pre>
+r.null setnull=-1 map=my_map
+</pre></div>
+<h2>EXAMPLES</h2>
+To calculate the set of indices from a NDVI map, with a moving window of 3 x 3 pixel, run:
+r.diversity input=ndvi_map out=test alpha=0.5
+</pre></div>
+To calculate the set of indices from a NDVI map, with a moving window of 7 x 7 pixel, run:
+r.diversity input=ndvi_map out=test alpha=0.5 size=7
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.li.html">r.li</a>,
+<a href="r.li.pielou.html">r.li.pielou</a>,
+<a href="r.li.renyi.html">r.li.renyi</a>,
+<a href="r.li.shannon.html">r.li.shannon</a>,
+<a href="r.li.simpson.html">r.li.simpson</a>
+</em>
+<h2>AUTHOR</h2>
+Luca Delucchi and Duccio Rocchini, Fondazione E. Mach (Italy)
+<p><i>Last changed: $Date$</i>
Property changes on: grass-addons/raster/r.diversity/description.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
Added: grass-addons/raster/r.diversity/r.diversity.py
--- grass-addons/raster/r.diversity/r.diversity.py (rev 0)
+++ grass-addons/raster/r.diversity/r.diversity.py 2010-12-02 14:52:30 UTC (rev 44524)
@@ -0,0 +1,152 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE: r.diversity
+# AUTHOR(S): Luca Delucchi
+# PURPOSE: It calculates the mostly used indices of diversity based on
+# information theory
+# COPYRIGHT: (C) 2010 by Luca Delucchi
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Calculate some vegetation index using r.li packages and moving windows
+#% keywords: raster
+#%end
+#%option
+#% key: input
+#% type: string
+#% gisprompt: input raster
+#% key_desc: name
+#% description: Name of input raster map
+#% required: yes
+#%end
+#%option
+#% key: output
+#% type: string
+#% gisprompt: output raster
+#% key_desc: name
+#% description: Name of output raster map
+#% required: yes
+#%end
+#%option
+#% key: alpha
+#% type: double
+#% gisprompt: alpha value
+#% key_desc: alpha value for Renyi entropy
+#% description: Alpha value is the order of the generalized entropy, it'll be > 0 and != 1
+#% required: yes
+#%end
+#%option
+#% key: size
+#% type: integer
+#% gisprompt: resolution
+#% key_desc: moving window
+#% description: Number of pixel used for the moving window, it must be odd number, if not set the module set your resolution to value 3
+#% required: no
+#%end
+# import library
+import os, sys, re
+import grass.script as grass
+# main function
+def main():
+ # set the home path
+ home=os.path.expanduser('~')
+ # set the name of conf file
+ confilename = homePath+'/.r.li/history/conf_diversity'
+ # check if GISBASE is set
+ if "GISBASE" not in os.environ:
+ # return an error advice
+ print "You must be in GRASS GIS to run this program."
+ sys.exit(1)
+ # input raster map
+ map_in = options['input']
+ # output raster map
+ map_out = options['output']
+ # resolution of moving windows
+ res = options['size']
+ # alpha value for r.renyi
+ alpha_value = options['alpha']
+ # resolution
+ if res=='':
+ res=3
+ else:
+ res = int(options['size'])
+ # check if is a odd number
+ if res%2==0:
+ # return the error advice
+ print "Your size option must be an odd number"
+ sys.exit(1)
+ # check if ~/.r.li path exists
+ if os.path.exists(home+'/.r.li/'):
+ # check if ~/.r.li/history path exists
+ if os.path.exists(home+'/.r.li/history'):
+ # create configuration file
+ createConfFile(res,map_in,home)
+ else:
+ # create ~/.r.li/history path
+ os.path.mkdir(home+'/.r.li/history')
+ else:
+ # create ~/.r.li
+ os.path.mkdir(home+'/.r.li/')
+ ### calculate r.li indices
+ # if overwrite it is set
+ if grass.overwrite():
+ env['GRASS_OVERWRITE'] = '1'
+ simpson = grass.run_command('r.li.simpson', map = map_in, out = map_out + '_simpson', conf = 'conf_diversity')
+ shannon = grass.run_command('r.li.shannon', map = map_in, out = map_out+ '_shannon', conf = 'conf_diversity')
+ pielou = grass.run_command('r.li.pielou', map = map_in, out = map_out+ '_pielou', conf = 'conf_diversity')
+ renyi = grass.run_command('r.li.renyi', map = map_in, out = map_out+ '_renyi', conf = 'conf_diversity', alpha = alpha_value)
+ os.remove(confilename)
+ print 'All works are terminated'
+#create configuration file instead using r.li.setup
+def createConfFile(res,inpumap,homePath):
+ # start the text for the conf file
+ outputLine = ['SAMPLINGFRAME 0|0|1|1\n']
+ # return r.info about input file
+ rinfo = grass.raster_info(inpumap)
+ # calculate number of lines
+ rows = (rinfo["north"]-rinfo["south"])/rinfo['nsres']
+ # calculate number of columns
+ columns = (rinfo['east']-rinfo['west'])/rinfo['ewres']
+ # value for row
+ rV = res/rows
+ # value for column
+ cV = res/columns
+ # append the text for the conf file
+ outputLine.append('SAMPLEAREA -1|-1|'+str(rV)+'|'+str(cV)+'\n')
+ outputLine.append('MOVINGWINDOW\n')
+ # open configuration file
+ fileConf=open(confilename,'w')
+ # write file
+ fileConf.writelines(outputLine)
+ # close file
+ fileConf.close()
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ sys.exit(main())
