[GRASS-SVN] r44536 - grass-addons/tools
    svn_grass at osgeo.org
    Fri Dec  3 13:40:34 EST 2010
Author: neteler
Date: 2010-12-03 10:40:34 -0800 (Fri, 03 Dec 2010)
New Revision: 44536
   grass-addons/tools/module_svn_propset.sh
added support for svn:ignore
Modified: grass-addons/tools/module_svn_propset.sh
--- grass-addons/tools/module_svn_propset.sh	2010-12-03 18:40:14 UTC (rev 44535)
+++ grass-addons/tools/module_svn_propset.sh	2010-12-03 18:40:34 UTC (rev 44536)
@@ -153,11 +153,20 @@
    unset_exe "$1"
+apply_OBJ_code()
+    OBJTMP=$$
+    echo "*.tmp.html" > ignore_$OBJTMP.txt
+    echo "*OBJ*" >> ignore_$OBJTMP.txt
+    svn propset -F ignore_$OBJTMP.txt svn:ignore .
+    rm -f ignore_$OBJTMP.txt
-for FILE in $* ; do
+for FILE in `ls` ; do
   #echo "Processing <$FILE> ..."
   if [ ! -e "$FILE" ] ; then
@@ -165,6 +174,13 @@
      continue
   fi
+  if test -d "$FILE" ; then
+     DIRPREF=`echo "$FILE" | cut -d'.' -f1`
+     if [ "$DIRPREF" = "OBJ" ] ; then
+	apply_OBJ_code "$FILE"
+     fi
+  fi
   FILE_SUFFIX=`echo "$FILE" | sed -e 's/^.*\.//'`
   case "$FILE_SUFFIX" in
     c)
@@ -213,7 +229,9 @@
 	elif [ `file "$FILE" | grep -c "shell script"` -eq 1 ] ; then
 	   apply_shell_script "$FILE"
 	else
-	    echo "WARNING: unknown file type <$FILE>"
+	    if test ! -d "$FILE" ; then
+		echo "WARNING: unknown file type <$FILE>"
+	    fi
 	fi
   esac
