[GRASS-SVN] r44560 -
grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify
svn_grass at osgeo.org
Tue Dec 7 12:49:57 EST 2010
Author: mmetz
Date: 2010-12-07 09:49:57 -0800 (Tue, 07 Dec 2010)
New Revision: 44560
grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/angle.c
grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/exec.c
grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/local_proto.h
always align camera angle map to elevation map to avoid artifacts
Modified: grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/angle.c
--- grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/angle.c 2010-12-07 14:19:08 UTC (rev 44559)
+++ grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/angle.c 2010-12-07 17:49:57 UTC (rev 44560)
@@ -13,7 +13,7 @@
#include <math.h>
#include "global.h"
-int camera_angle(struct cache *ebuffer, char *name)
+int camera_angle(char *name)
int row, col, nrows, ncols;
double XC = group.XC;
@@ -22,12 +22,12 @@
double c_angle, c_angle_min, c_alt, c_az, slope, aspect;
double radians_to_degrees = 180.0 / M_PI;
/* double degrees_to_radians = M_PI / 180.0; */
- DCELL *ep;
DCELL e1, e2, e3, e4, e5, e6, e7, e8, e9;
double factor, V, H, dx, dy, dz, key;
double north, south, east, west, ns_med;
- FCELL *fbuf;
- int outfd;
+ FCELL *fbuf0, *fbuf1, *fbuf2, *tmpbuf, *outbuf;
+ int elevfd, outfd;
+ struct Cell_head cellhd;
struct Colors colr;
FCELL clr_min, clr_max;
struct History hist;
@@ -37,11 +37,29 @@
select_target_env();
+ /* align target window to elevation map, otherwise we get artefacts
+ * like in r.slope.aspect -a */
+ if (G_get_cellhd(elev_name, elev_mapset, &cellhd) < 0)
+ return 0;
+ G_align_window(&target_window, &cellhd);
+ G_set_window(&target_window);
+ elevfd = G_open_cell_old(elev_name, elev_mapset);
+ if (elevfd < 0) {
+ G_fatal_error(_("Could not open elevation raster"));
+ return 1;
nrows = target_window.rows;
ncols = target_window.cols;
outfd = G_open_raster_new(name, FCELL_TYPE);
- fbuf = G_allocate_raster_buf(FCELL_TYPE);
+ fbuf0 = G_allocate_raster_buf(FCELL_TYPE);
+ fbuf1 = G_allocate_raster_buf(FCELL_TYPE);
+ fbuf2 = G_allocate_raster_buf(FCELL_TYPE);
+ outbuf = G_allocate_raster_buf(FCELL_TYPE);
/* give warning if location units are different from meters and zfactor=1 */
factor = G_database_units_to_meters_factor();
@@ -58,56 +76,58 @@
H = G_distance(east, ns_med, west, ns_med) * 4;
c_angle_min = 90;
+ G_get_raster_row(elevfd, fbuf1, 0, FCELL_TYPE);
+ G_get_raster_row(elevfd, fbuf2, 1, FCELL_TYPE);
for (row = 0; row < nrows; row++) {
G_percent(row, nrows, 2);
- G_set_null_value(fbuf, ncols, FCELL_TYPE);
+ G_set_null_value(outbuf, ncols, FCELL_TYPE);
+ /* first and last row */
if (row == 0 || row == nrows - 1) {
- G_put_raster_row(outfd, fbuf, FCELL_TYPE);
+ G_put_raster_row(outfd, outbuf, FCELL_TYPE);
continue;
+ tmpbuf = fbuf0;
+ fbuf0 = fbuf1;
+ fbuf1 = fbuf2;
+ fbuf2 = tmpbuf;
+ G_get_raster_row(elevfd, fbuf2, row + 1, FCELL_TYPE);
north = G_row_to_northing(row + 0.5, &target_window);
for (col = 1; col < ncols - 1; col++) {
- ep = CPTR(ebuffer, row - 1, col - 1);
- if (G_is_d_null_value(ep))
+ e1 = fbuf0[col - 1];
+ if (G_is_d_null_value(&e1))
continue;
- e1 = *ep;
- ep = CPTR(ebuffer, row - 1, col);
+ e2 = fbuf0[col];
+ if (G_is_d_null_value(&e2))
continue;
- e2 = *ep;
- ep = CPTR(ebuffer, row - 1, col + 1);
+ e3 = fbuf0[col + 1];
+ if (G_is_d_null_value(&e3))
continue;
- e3 = *ep;
- ep = CPTR(ebuffer, row, col - 1);
+ e4 = fbuf1[col - 1];
+ if (G_is_d_null_value(&e4))
continue;
- e4 = *ep;
- ep = CPTR(ebuffer, row, col);
+ e5 = fbuf1[col];
+ if (G_is_d_null_value(&e5))
continue;
- e5 = *ep;
- ep = CPTR(ebuffer, row, col + 1);
+ e6 = fbuf1[col + 1];
+ if (G_is_d_null_value(&e6))
continue;
- e6 = *ep;
- ep = CPTR(ebuffer, row + 1, col - 1);
+ e7 = fbuf2[col - 1];
+ if (G_is_d_null_value(&e7))
continue;
- e7 = *ep;
- ep = CPTR(ebuffer, row + 1, col);
+ e8 = fbuf2[col];
+ if (G_is_d_null_value(&e8))
continue;
- e8 = *ep;
- ep = CPTR(ebuffer, row + 1, col + 1);
+ e9 = fbuf2[col + 1];
+ if (G_is_d_null_value(&e9))
continue;
- e9 = *ep;
dx = ((e1 + e4 + e4 + e7) - (e3 + e6 + e6 + e9)) / H;
dy = ((e7 + e8 + e8 + e9) - (e1 + e2 + e2 + e3)) / V;
@@ -151,16 +171,20 @@
/* parallel to ground: 0 degrees */
c_angle = asin(cos(c_alt) * cos(slope) - sin(c_alt) * sin(slope) * cos(c_az - aspect));
- fbuf[col] = c_angle * radians_to_degrees;
- if (c_angle_min > fbuf[col])
- c_angle_min = fbuf[col];
+ outbuf[col] = c_angle * radians_to_degrees;
+ if (c_angle_min > outbuf[col])
+ c_angle_min = outbuf[col];
+ G_close_cell(elevfd);
G_close_cell(outfd);
- G_free(fbuf);
+ G_free(fbuf0);
+ G_free(fbuf1);
+ G_free(fbuf2);
+ G_free(outbuf);
type = "raster";
G_short_history(name, type, &hist);
@@ -188,7 +212,6 @@
G_write_colors(name, G_mapset(), &colr);
select_current_env();
return 1;
Modified: grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/exec.c
--- grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/exec.c 2010-12-07 14:19:08 UTC (rev 44559)
+++ grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/exec.c 2010-12-07 17:49:57 UTC (rev 44560)
@@ -112,13 +112,13 @@
G_free(result);
+ close(ebuffer->fd);
+ release_cache(ebuffer);
if (angle_map) {
- camera_angle(ebuffer, angle_map);
+ camera_angle(angle_map);
- close(ebuffer->fd);
- release_cache(ebuffer);
G_done_msg(" ");
return 0;
Modified: grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/local_proto.h
--- grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/local_proto.h 2010-12-07 14:19:08 UTC (rev 44559)
+++ grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/local_proto.h 2010-12-07 17:49:57 UTC (rev 44560)
@@ -1,5 +1,5 @@
/* angle.c */
-int camera_angle(struct cache *, char *);
+int camera_angle(char *);
/* aver_z.c */
int get_aver_elev(struct Ortho_Control_Points *, double *);
