[GRASS-SVN] r44572 -
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules
svn_grass at osgeo.org
Thu Dec 9 05:39:12 EST 2010
Author: martinl
Date: 2010-12-09 02:39:12 -0800 (Thu, 09 Dec 2010)
New Revision: 44572
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gmodeler.py
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/goutput.py
fix #1232 (gui modeler don't works as aspected)
(merge r44570 from trunk)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gmodeler.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gmodeler.py 2010-12-09 10:36:38 UTC (rev 44571)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gmodeler.py 2010-12-09 10:39:12 UTC (rev 44572)
@@ -952,7 +952,7 @@
if not item.IsEnabled():
continue
if isinstance(item, ModelAction):
- if item.GetLoopId():
+ if item.GetBlockId():
continue
self._runAction(item, params)
elif isinstance(item, ModelLoop):
@@ -1033,12 +1033,11 @@
if xmax > xmaxImg:
xmaxImg = xmax
if ymin < yminImg:
- xminImg = xmin
- if ymax < ymaxImg:
- xminImg = xmin
- size = wx.Size(int(xmaxImg - xminImg),
- int(ymaxImg - ymaxImg))
+ yminImg = ymin
+ if ymax > ymaxImg:
+ ymaxImg = ymax
+ size = wx.Size(int(xmaxImg - xminImg) + 50,
+ int(ymaxImg - yminImg) + 50)
bitmap = wx.EmptyBitmap(width = size.width, height = size.height)
filetype, ltype = GetImageHandlers(wx.ImageFromBitmap(bitmap))
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/goutput.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/goutput.py 2010-12-09 10:36:38 UTC (rev 44571)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/goutput.py 2010-12-09 10:39:12 UTC (rev 44572)
@@ -720,7 +720,7 @@
self.console_progressbar.SetValue(0) # reset progress bar on '0%'
self.cmd_output_timer.Stop()
if self.parent.GetName() == "LayerManager":
self.btn_abort.Enable(False)
if event.cmd[0] not in globalvar.grassCmd['all'] or \
@@ -743,6 +743,8 @@
if mapName in mapLayers:
display.GetWindow().UpdateMap(render = True)
return
+ elif self.parent.GetName() == 'Modeler':
+ pass
else: # standalone dialogs
dialog = self.parent.parent
if hasattr(self.parent.parent, "btn_abort"):
