[GRASS-SVN] r44576 - grass/trunk/imagery/i.atcorr
svn_grass at osgeo.org
Thu Dec 9 12:08:26 EST 2010
Author: neteler
Date: 2010-12-09 09:08:26 -0800 (Thu, 09 Dec 2010)
New Revision: 44576
grass/trunk/imagery/i.atcorr/create_iwave.py
Daniel Victoria: bugfixes for filter function
Modified: grass/trunk/imagery/i.atcorr/create_iwave.py
--- grass/trunk/imagery/i.atcorr/create_iwave.py 2010-12-09 17:08:15 UTC (rev 44575)
+++ grass/trunk/imagery/i.atcorr/create_iwave.py 2010-12-09 17:08:26 UTC (rev 44576)
@@ -19,6 +19,10 @@
file name is used for sensor name
Updated by: Anne Ghisla, 2010
+Bug fix (9/12/2010) by Daniel:
+ 1) function interpolate_band was not generating the spectral response for the last value in the filter function. Fixed
+ 2) function pretty_print was not printing the 8th value of every line, cutting the filter function short.
import os
import sys
@@ -86,7 +90,7 @@
# interpolating
f = interpolate.interp1d(response[:,0],response[:,1])
- filter_f = f(np.arange(response[0,0], response[-1,0], 2.5))
+ filter_f = f(np.arange(response[0,0], response[-1,0] + 2.5, 2.5))
# convert limits from nanometers to micrometers
lowerlimit = response[0,0]/1000
@@ -117,8 +121,11 @@
8 values per line, with spaces, commas and all the rest
pstring = ''
- for i in range(len(filter_f)):
+ for i in range(len(filter_f)+1):
if i%8 is 0:
+ if i is not 0:
+ value_wo_leading_zero = ('%.4f' % (filter_f[i-1])).lstrip('0')
+ pstring += value_wo_leading_zero+', '
if i is not 1:
# trim the trailing whitespace at the end of line
pstring = pstring.rstrip()
