[GRASS-SVN] r44578 - grass-addons/raster/r.stream.extract
svn_grass at osgeo.org
Fri Dec 10 03:18:01 EST 2010
Author: mmetz
Date: 2010-12-10 00:18:01 -0800 (Fri, 10 Dec 2010)
New Revision: 44578
Added:
grass-addons/raster/r.stream.extract/flag.c
Removed:
grass-addons/raster/r.stream.extract/flag_clr_all.c
grass-addons/raster/r.stream.extract/flag_create.c
grass-addons/raster/r.stream.extract/flag_destroy.c
grass-addons/raster/r.stream.extract/flag_get.c
grass-addons/raster/r.stream.extract/flag_set.c
grass-addons/raster/r.stream.extract/flag_unset.c
grass-addons/raster/r.stream.extract/description.html
grass-addons/raster/r.stream.extract/do_astar.c
grass-addons/raster/r.stream.extract/flag.h
grass-addons/raster/r.stream.extract/load.c
grass-addons/raster/r.stream.extract/local_proto.h
grass-addons/raster/r.stream.extract/main.c
grass-addons/raster/r.stream.extract/streams.c
add option for real depressions, clear up flag code
Modified: grass-addons/raster/r.stream.extract/description.html
--- grass-addons/raster/r.stream.extract/description.html 2010-12-10 03:59:25 UTC (rev 44577)
+++ grass-addons/raster/r.stream.extract/description.html 2010-12-10 08:18:01 UTC (rev 44578)
@@ -8,7 +8,6 @@
<dl>
<dt><em>elevation</em>
<dd>Input map, required: Elevation on which entire analysis is based.
NULL (nodata) cells are ignored, zero and negative values are valid
elevation data. Gaps in the elevation map that are located within the
@@ -29,6 +28,16 @@
as the number of cells, it can also be the optionally adjusted or
weighed total contributing area in square meters or any other unit.
<p>
+<dt><em>depression</em>
+<dd>Input map, optional: All non-NULL and non-zero cells will be regarded
+as real depressions. Streams will not be routed out of depressions. If an
+area is marked as depression but the elevation model has no depression
+at this location, streams will not stop there. If a flow accumulation map
+and a map with real depressions are provided, the flow accumulation map
+must match the depression map such that flow is not distributed out of
+the indicated depressions. It is recommended to use internally computed
+flow accumulation if a depression map is provided.
+<p>
<dt><em>threshold</em>
<dd>Required: <em>threshold</em> for stream initiation by overland flow:
the minumum (optionally modifed) flow accumulation value that will initiate
Modified: grass-addons/raster/r.stream.extract/do_astar.c
--- grass-addons/raster/r.stream.extract/do_astar.c 2010-12-10 03:59:25 UTC (rev 44577)
+++ grass-addons/raster/r.stream.extract/do_astar.c 2010-12-10 08:18:01 UTC (rev 44578)
@@ -128,13 +128,16 @@
ele_up = ele[nindex];
asp[nindex] = drain[r_nbr - r + 1][c_nbr - c + 1];
heap_add(r_nbr, c_nbr, ele_up, asp[nindex]);
- FLAG_SET(in_list, r_nbr, c_nbr);
else if (is_in_list && is_worked == 0) {
/* neighbour is edge in list, not yet worked */
if (asp[nindex] < 0) {
+ /* neighbour is inside real depression, not yet worked */
+ if (asp[nindex] == 0 && ele_val <= ele[nindex]) {
+ asp[nindex] = drain[r_nbr - r + 1][c_nbr - c + 1];
} /* end neighbours */
Copied: grass-addons/raster/r.stream.extract/flag.c (from rev 40659, grass-addons/raster/r.stream.extract/flag_create.c)
--- grass-addons/raster/r.stream.extract/flag.c (rev 0)
+++ grass-addons/raster/r.stream.extract/flag.c 2010-12-10 08:18:01 UTC (rev 44578)
@@ -0,0 +1,49 @@
+#include <grass/gis.h>
+#include "flag.h"
+FLAG *flag_create(int nrows, int ncols)
+ unsigned char *temp;
+ FLAG *new_flag;
+ register int i;
+ new_flag = (FLAG *) G_malloc(sizeof(FLAG));
+ new_flag->nrows = nrows;
+ new_flag->ncols = ncols;
+ new_flag->leng = (ncols + 7) / 8;
+ new_flag->array =
+ (unsigned char **)G_malloc(nrows * sizeof(unsigned char *));
+ temp =
+ (unsigned char *)G_malloc(nrows * new_flag->leng *
+ sizeof(unsigned char));
+ for (i = 0; i < nrows; i++) {
+ new_flag->array[i] = temp;
+ temp += new_flag->leng;
+ return (new_flag);
+int flag_destroy(FLAG * flags)
+ G_free(flags->array[0]);
+ G_free(flags->array);
+ G_free(flags);
+ return 0;
+int flag_clear_all(FLAG * flags)
+ register int r, c;
+ for (r = 0; r < flags->nrows; r++) {
+ for (c = 0; c < flags->leng; c++) {
+ flags->array[r][c] = 0;
+ return 0;
Modified: grass-addons/raster/r.stream.extract/flag.h
--- grass-addons/raster/r.stream.extract/flag.h 2010-12-10 03:59:25 UTC (rev 44577)
+++ grass-addons/raster/r.stream.extract/flag.h 2010-12-10 08:18:01 UTC (rev 44578)
@@ -20,18 +20,18 @@
** FLAG *flags;
** sets all values in flags to zero.
- ** flag_unset(flags, row, col)
+ ** FLAG_UNSET(flags, row, col)
** FLAG *flags;
** int row, col;
** sets the value of (row, col) in flags to zero.
- ** flag_set(flags, row, col)
+ ** FLAG_SET(flags, row, col)
** FLAG *flags;
** int row, col;
** will set the value of (row, col) in flags to one.
** int
- ** flag_get(flags, row, col)
+ ** FLAG_GET(flags, row, col)
** FLAG *flags;
** int row, col;
** returns the value in flags that is at (row, col).
@@ -55,23 +55,9 @@
#define FLAG_GET(flags,row,col) \
(flags)->array[(row)][(col)>>3] & (1<<((col) & 7))
-/* flag_clr_all.c */
+/* flag.c */
int flag_clear_all(FLAG *);
-/* flag_create.c */
FLAG *flag_create(int, int);
-/* flag_destroy.c */
int flag_destroy(FLAG *);
-/* flag_get.c */
-int flag_get(FLAG *, int, int);
-/* flag_set.c */
-int flag_set(FLAG *, int, int);
-/* flag_unset.c */
-int flag_unset(FLAG *, int, int);
#endif /* __FLAG_H__ */
Deleted: grass-addons/raster/r.stream.extract/flag_clr_all.c
--- grass-addons/raster/r.stream.extract/flag_clr_all.c 2010-12-10 03:59:25 UTC (rev 44577)
+++ grass-addons/raster/r.stream.extract/flag_clr_all.c 2010-12-10 08:18:01 UTC (rev 44578)
@@ -1,14 +0,0 @@
-#include "flag.h"
-int flag_clear_all(FLAG * flags)
- register int r, c;
- for (r = 0; r < flags->nrows; r++) {
- for (c = 0; c < flags->leng; c++) {
- flags->array[r][c] = 0;
- return 0;
Deleted: grass-addons/raster/r.stream.extract/flag_create.c
--- grass-addons/raster/r.stream.extract/flag_create.c 2010-12-10 03:59:25 UTC (rev 44577)
+++ grass-addons/raster/r.stream.extract/flag_create.c 2010-12-10 08:18:01 UTC (rev 44578)
@@ -1,27 +0,0 @@
-#include <grass/gis.h>
-#include "flag.h"
-FLAG *flag_create(int nrows, int ncols)
- unsigned char *temp;
- FLAG *new_flag;
- register int i;
- new_flag = (FLAG *) G_malloc(sizeof(FLAG));
- new_flag->nrows = nrows;
- new_flag->ncols = ncols;
- new_flag->leng = (ncols + 7) / 8;
- new_flag->array =
- (unsigned char **)G_malloc(nrows * sizeof(unsigned char *));
- temp =
- (unsigned char *)G_malloc(nrows * new_flag->leng *
- sizeof(unsigned char));
- for (i = 0; i < nrows; i++) {
- new_flag->array[i] = temp;
- temp += new_flag->leng;
- return (new_flag);
Deleted: grass-addons/raster/r.stream.extract/flag_destroy.c
--- grass-addons/raster/r.stream.extract/flag_destroy.c 2010-12-10 03:59:25 UTC (rev 44577)
+++ grass-addons/raster/r.stream.extract/flag_destroy.c 2010-12-10 08:18:01 UTC (rev 44578)
@@ -1,11 +0,0 @@
-#include "flag.h"
-int flag_destroy(FLAG * flags)
- G_free(flags->array[0]);
- G_free(flags->array);
- G_free(flags);
- return 0;
Deleted: grass-addons/raster/r.stream.extract/flag_get.c
--- grass-addons/raster/r.stream.extract/flag_get.c 2010-12-10 03:59:25 UTC (rev 44577)
+++ grass-addons/raster/r.stream.extract/flag_get.c 2010-12-10 08:18:01 UTC (rev 44578)
@@ -1,6 +0,0 @@
-#include "flag.h"
-int flag_get(FLAG * flags, int row, int col)
- return (flags->array[row][col >> 3] & (1 << (col & 7)));
Deleted: grass-addons/raster/r.stream.extract/flag_set.c
--- grass-addons/raster/r.stream.extract/flag_set.c 2010-12-10 03:59:25 UTC (rev 44577)
+++ grass-addons/raster/r.stream.extract/flag_set.c 2010-12-10 08:18:01 UTC (rev 44578)
@@ -1,8 +0,0 @@
-#include "flag.h"
-int flag_set(FLAG * flags, int row, int col)
- flags->array[row][col >> 3] |= (1 << (col & 7));
- return 0;
Deleted: grass-addons/raster/r.stream.extract/flag_unset.c
--- grass-addons/raster/r.stream.extract/flag_unset.c 2010-12-10 03:59:25 UTC (rev 44577)
+++ grass-addons/raster/r.stream.extract/flag_unset.c 2010-12-10 08:18:01 UTC (rev 44578)
@@ -1,8 +0,0 @@
-#include "flag.h"
-int flag_unset(FLAG * flags, int row, int col)
- flags->array[row][col >> 3] &= ~(1 << (col & 7));
- return 0;
Modified: grass-addons/raster/r.stream.extract/load.c
--- grass-addons/raster/r.stream.extract/load.c 2010-12-10 03:59:25 UTC (rev 44577)
+++ grass-addons/raster/r.stream.extract/load.c 2010-12-10 08:18:01 UTC (rev 44578)
@@ -23,12 +23,13 @@
* gets start points for A* Search
* start points are edges
-int load_maps(int ele_fd, int acc_fd)
+int load_maps(int ele_fd, int acc_fd, int depr_fd)
int r, c, thisindex;
char asp_value, *aspp;
void *ele_buf, *ptr, *acc_buf = NULL, *acc_ptr = NULL;
CELL *loadp, ele_value;
+ CELL *depr_buf;
DCELL dvalue;
int nextdr[8] = { 1, -1, 0, 0, -1, 1, 1, -1 };
int nextdc[8] = { 0, 0, -1, 1, 1, -1, 1, -1 };
@@ -124,14 +125,19 @@
if (acc_fd < 0)
*accp = 1;
else {
- if (acc_map_type == CELL_TYPE) {
+ if (G_is_null_value(acc_ptr, acc_map_type))
+ G_fatal_error(_("Accumulation map does not match elevation map!"));
+ switch (acc_map_type) {
+ case CELL_TYPE:
*accp = *((CELL *) acc_ptr);
- else if (acc_map_type == FCELL_TYPE) {
+ break;
+ case FCELL_TYPE:
*accp = *((FCELL *) acc_ptr);
- else if (acc_map_type == DCELL_TYPE) {
+ break;
+ case DCELL_TYPE:
*accp = *((DCELL *) acc_ptr);
+ break;
@@ -168,12 +174,24 @@
nxt_avail_pt = heap_size = 0;
- /* load edge cells to A* heap */
+ /* load edge cells and real depressions to A* heap */
+ if (depr_fd >= 0)
+ depr_buf = G_allocate_raster_buf(CELL_TYPE);
+ else
+ depr_buf = NULL;
G_message(_("set edge points"));
loadp = ele;
for (r = 0; r < nrows; r++) {
+ G_percent(r, nrows, 2);
- G_percent(r, nrows, 2);
+ if (depr_fd >= 0) {
+ if (G_get_raster_row(depr_fd, depr_buf, r, CELL_TYPE) < 0) {
+ G_warning(_("could not read raster map at row <%d>"), r);
+ return -1;
for (c = 0; c < ncols; c++) {
is_worked = FLAG_GET(worked, r, c);
@@ -203,13 +221,13 @@
thisindex = INDEX(r, c);
ele_value = ele[thisindex];
+ asp[thisindex] = asp_value;
heap_add(r, c, ele_value, asp_value);
- asp[thisindex] = asp_value;
- FLAG_SET(in_list, r, c);
continue;
/* any neighbour NULL ? */
+ asp_value = 0;
for (ct_dir = 0; ct_dir < sides; ct_dir++) {
/* get r, c (r_nbr, c_nbr) for neighbours */
r_nbr = r + nextdr[ct_dir];
@@ -221,17 +239,33 @@
asp_value = drain[r - r_nbr + 1][c - c_nbr + 1];
break;
+ if (asp_value) /* some neighbour was NULL, point added to list */
+ continue;
+ /* real depression ? */
+ if (!G_is_c_null_value(&depr_buf[c]) && depr_buf[c] != 0) {
+ thisindex = INDEX(r, c);
+ ele_value = ele[thisindex];
+ asp[thisindex] = 0;
+ heap_add(r, c, ele_value, 0);
G_percent(nrows, nrows, 2); /* finish it */
+ G_close_cell(depr_fd);
+ G_free(depr_buf);
G_debug(1, "%d edge cells", heap_size);
G_debug(1, "%d non-NULL cells", n_points);
Modified: grass-addons/raster/r.stream.extract/local_proto.h
--- grass-addons/raster/r.stream.extract/local_proto.h 2010-12-10 03:59:25 UTC (rev 44577)
+++ grass-addons/raster/r.stream.extract/local_proto.h 2010-12-10 08:18:01 UTC (rev 44578)
@@ -30,27 +30,29 @@
double *acc;
} *stream_node;
-int nrows, ncols;
-unsigned int *astar_pts;
-unsigned int n_search_points, n_points, nxt_avail_pt;
-unsigned int heap_size, *astar_added;
-unsigned int n_stream_nodes, n_alloc_nodes;
-struct point *outlets;
-unsigned int n_outlets, n_alloc_outlets;
-DCELL *acc;
-CELL *ele;
-char *asp;
-CELL *stream;
-FLAG *worked, *in_list;
+/* global variables */
+extern int nrows, ncols;
+extern unsigned int *astar_pts;
+extern unsigned int n_search_points, n_points, nxt_avail_pt;
+extern unsigned int heap_size, *astar_added;
+extern unsigned int n_stream_nodes, n_alloc_nodes;
+extern struct point *outlets;
+extern unsigned int n_outlets, n_alloc_outlets;
+extern DCELL *acc;
+extern CELL *ele;
+extern char *asp;
+extern CELL *stream;
+extern FLAG *worked, *in_list;
extern char drain[3][3];
-unsigned int first_cum;
-char sides;
-int c_fac;
-int ele_scale;
-struct RB_TREE *draintree;
+extern unsigned int first_cum;
+extern char sides;
+extern int c_fac;
+extern int ele_scale;
+extern int have_depressions;
+extern struct RB_TREE *draintree;
/* load.c */
-int load_maps(int, int);
+int load_maps(int, int, int);
/* do_astar.c */
int do_astar(void);
Modified: grass-addons/raster/r.stream.extract/main.c
--- grass-addons/raster/r.stream.extract/main.c 2010-12-10 03:59:25 UTC (rev 44577)
+++ grass-addons/raster/r.stream.extract/main.c 2010-12-10 08:18:01 UTC (rev 44578)
@@ -20,14 +20,33 @@
#include <grass/glocale.h>
#include "local_proto.h"
+int nrows, ncols;
+unsigned int *astar_pts;
+unsigned int n_search_points, n_points, nxt_avail_pt;
+unsigned int heap_size, *astar_added;
+unsigned int n_stream_nodes, n_alloc_nodes;
+struct point *outlets;
+unsigned int n_outlets, n_alloc_outlets;
+DCELL *acc;
+CELL *ele;
+char *asp;
+CELL *stream;
+FLAG *worked, *in_list;
char drain[3][3] = { {7, 6, 5}, {8, 0, 4}, {1, 2, 3} };
+unsigned int first_cum;
+char sides;
+int c_fac;
+int ele_scale;
+int have_depressions;
+struct RB_TREE *draintree;
int main(int argc, char *argv[])
struct
- struct Option *ele, *acc;
+ struct Option *ele, *acc, *depression;
struct Option *threshold, *d8cut;
struct Option *mont_exp;
struct Option *min_stream_length;
@@ -39,7 +58,7 @@
struct Option *dir_rast;
} output;
struct GModule *module;
- int ele_fd, acc_fd;
+ int ele_fd, acc_fd, depr_fd;
double threshold, d8cut, mont_exp;
int min_stream_length = 0;
char *mapset;
@@ -63,6 +82,13 @@
input.acc->description =
_("Stream extraction will use provided accumulation instead of calculating it anew");
+ input.depression = G_define_standard_option(G_OPT_R_INPUT);
+ input.depression->key = "depression";
+ input.depression->label = _("Map with real depressions");
+ input.depression->required = NO;
+ input.depression->description =
+ _("Streams will not be routed out of real depressions");
input.threshold = G_define_option();
input.threshold->key = "threshold";
input.threshold->label = _("Minimum flow accumulation for streams");
@@ -137,6 +163,14 @@
G_fatal_error(_("Raster map <%s> not found"), input.acc->answer);
+ if (input.depression->answer) {
+ if (!G_find_cell(input.depression->answer, ""))
+ G_fatal_error(_("Raster map <%s> not found"), input.depression->answer);
+ have_depressions = 1;
+ else
+ have_depressions = 0;
/* threshold makes sense */
threshold = atof(input.threshold->answer);
if (threshold <= 0)
@@ -203,6 +237,16 @@
else
acc_fd = -1;
+ mapset = G_find_cell2(input.depression->answer, "");
+ depr_fd = G_open_cell_old(input.depression->answer, mapset);
+ if (depr_fd < 0)
+ G_fatal_error(_("could not open input map %s"),
+ input.depression->answer);
+ else
+ depr_fd = -1;
/* set global variables */
nrows = G_window_rows();
ncols = G_window_cols();
@@ -215,7 +259,7 @@
acc = (DCELL *) G_malloc(nrows * ncols * sizeof(DCELL));
/* load maps */
- if (load_maps(ele_fd, acc_fd) < 0)
+ if (load_maps(ele_fd, acc_fd, depr_fd) < 0)
G_fatal_error(_("could not load input map(s)"));
Modified: grass-addons/raster/r.stream.extract/streams.c
--- grass-addons/raster/r.stream.extract/streams.c 2010-12-10 03:59:25 UTC (rev 44577)
+++ grass-addons/raster/r.stream.extract/streams.c 2010-12-10 08:18:01 UTC (rev 44578)
@@ -217,7 +217,7 @@
DCELL value, valued;
int count;
struct Cell_head window;
- int mfd_cells, astar_not_set, is_null;
+ int mfd_cells, astar_not_set;
double *dist_to_nbr, *weight, sum_weight, max_weight;
double dx, dy;
int r_nbr, c_nbr, r_max, c_max, ct_dir, np_side;
@@ -257,6 +257,7 @@
/* reset worked flag */
flag_clear_all(worked);
+ /* distribute and accumulate */
for (killer = 1; killer <= n_points; killer++) {
G_percent(killer, n_points, 1);
@@ -272,6 +273,12 @@
else {
dr = r;
dc = c;
+ /* can only happen with real depressions */
+ if (!have_depressions)
+ G_fatal_error(_("Bug in stream extraction"));
+ FLAG_SET(worked, r, c);
+ G_debug(1, "bottom of real depression");
+ continue;
r_max = dr;
@@ -289,7 +296,6 @@
mfd_cells = 0;
astar_not_set = 1;
ele_val = ele[thisindex];
- is_null = 0;
edge = 0;
/* this loop is needed to get the sum of weights */
@@ -305,9 +311,8 @@
is_worked = FLAG_GET(worked, r_nbr, c_nbr);
if (is_worked == 0) {
ele_nbr = ele[nindex];
- is_null = G_is_c_null_value(&ele_nbr);
- edge = is_null;
- if (!is_null && ele_nbr <= ele_val) {
+ edge = G_is_c_null_value(&ele_nbr);
+ if (!edge && ele_nbr <= ele_val) {
if (ele_nbr < ele_val) {
weight[ct_dir] =
mfd_pow((ele_val -
@@ -341,6 +346,7 @@
/* do not distribute flow along edges, this causes artifacts */
if (edge) {
G_debug(3, "edge");
continue;
@@ -501,6 +507,7 @@
workedon = 0;
+ /* extract streams */
@@ -510,7 +517,7 @@
aspect = asp[thisindex];
/* do not distribute flow along edges */
- if (aspect < 0) {
+ if (aspect <= 0) {
G_debug(3, "edge");
is_swale = stream[thisindex];
if (is_swale) {
@@ -527,6 +534,13 @@
outlets[n_outlets].c = c;
n_outlets++;
+ if (aspect == 0) {
continue;
@@ -535,6 +549,8 @@
dc = c + asp_c[abs((int)aspect)];
else {
+ /* can only happen with real depressions,
+ * but should not get to here */
dr = r;
dc = c;
@@ -579,7 +595,7 @@
/* check for stream cells */
valued = fabs(acc[nindex]);
- /* if (valued >= threshold) */
+ /* check all upstream neighbours */
if (valued >= threshold && ct_dir != np_side &&
ele_nbr > ele_val)
stream_cells++;
@@ -659,6 +675,7 @@
/* update aspect */
+ /* r_max == r && c_max == c should not happen */
if ((r_max != dr || c_max != dc) && (r_max != r || c_max != c)) {
asp[thisindex] = drain[r - r_max + 1][c - c_max + 1];
@@ -674,7 +691,7 @@
if (mont_exp > 0) {
if (r_max == r && c_max == c)
G_warning
- ("Can't use Montgomery's method, no stream direction found");
+ (_("Can't use Montgomery's method, no stream direction found"));
else {
ele_nbr = ele[INDEX(r_max, c_max)];
@@ -720,9 +737,10 @@
if (is_swale > 0) {
- /* can't continue stream, add outlet point */
if (r_max == r && c_max == c) {
- G_debug(2, "can't continue stream at %d %d", r, c);
+ /* can't continue stream, add outlet point
+ * r_max == r && c_max == c should not happen */
+ G_debug(1, "can't continue stream at r %d c %d", r, c);
if (n_outlets >= n_alloc_outlets) {
n_alloc_outlets += stream_node_step;
