[GRASS-SVN] r44588 -
grass/branches/develbranch_6/visualization/nviz/scripts
svn_grass at osgeo.org
Sun Dec 12 15:28:12 EST 2010
Author: marisn
Date: 2010-12-12 12:28:12 -0800 (Sun, 12 Dec 2010)
New Revision: 44588
grass/branches/develbranch_6/visualization/nviz/scripts/config.tcl
grass/branches/develbranch_6/visualization/nviz/scripts/nviz2.2_script
grass/branches/develbranch_6/visualization/nviz/scripts/panel_rquery.tcl
grass/branches/develbranch_6/visualization/nviz/scripts/panel_scale.tcl
grass/branches/develbranch_6/visualization/nviz/scripts/panel_sdiff.tcl
grass/branches/develbranch_6/visualization/nviz/scripts/panel_site.tcl
grass/branches/develbranch_6/visualization/nviz/scripts/panel_surf.tcl
grass/branches/develbranch_6/visualization/nviz/scripts/panel_vquery.tcl
grass/branches/develbranch_6/visualization/nviz/scripts/script_file_tools
grass/branches/develbranch_6/visualization/nviz/scripts/script_play
grass/branches/develbranch_6/visualization/nviz/scripts/site_attr.tcl
More NVIZ strings for translation; Use new ComboBox labels for translation
Modified: grass/branches/develbranch_6/visualization/nviz/scripts/config.tcl
--- grass/branches/develbranch_6/visualization/nviz/scripts/config.tcl 2010-12-12 16:49:36 UTC (rev 44587)
+++ grass/branches/develbranch_6/visualization/nviz/scripts/config.tcl 2010-12-12 20:28:12 UTC (rev 44588)
@@ -106,3 +106,6 @@
option add *menubutton.borderwidth 1
option add *button.borderWidth 1
+# All supported point types
+set Nv_(siteshapes) [list {x} {sphere} {diamond} {cube} {box} {gyro} {aster} {histogram} ]
+set Nv_(siteshape_names) [list [G_msg "x"] [G_msg "sphere"] [G_msg "diamond"] [G_msg "cube"] [G_msg "box"] [G_msg "gyro"] [G_msg "aster"] [G_msg "histogram"]]
Modified: grass/branches/develbranch_6/visualization/nviz/scripts/nviz2.2_script
--- grass/branches/develbranch_6/visualization/nviz/scripts/nviz2.2_script 2010-12-12 16:49:36 UTC (rev 44587)
+++ grass/branches/develbranch_6/visualization/nviz/scripts/nviz2.2_script 2010-12-12 20:28:12 UTC (rev 44588)
@@ -36,15 +36,6 @@
global DEBUG
set DEBUG 0
-#Initialize ProcessName variable
-set env(NV_processname) NVIZ
-source $src_boot/etc/nviz2.2/scripts/config.tcl
-#append bwidget for tooltip stuff
-lappend auto_path $env(GISBASE)/bwidget
-package require -exact BWidget 1.2.1
# Overloading internationalization procedures
# gui.tcl is not used to have separate translation file for NVIZ
if [catch {package require msgcat}] {
@@ -58,6 +49,15 @@
+#Initialize ProcessName variable
+set env(NV_processname) NVIZ
+source $src_boot/etc/nviz2.2/scripts/config.tcl
+#append bwidget for tooltip stuff
+lappend auto_path $env(GISBASE)/bwidget
+package require -exact BWidget 1.2.1
global Nv_ ScriptState ScriptFile ScriptPlaying NvizLoadState
set ScriptPlaying 0
@@ -881,7 +881,7 @@
global Nv_
if {[catch {set file_hook [open $new_file r]} error_code] != 0} then {
- display_error [G_msg "Error while opening file: %s" $error_code]
+ display_error [format [G_msg "Error while opening file: %s"] $error_code]
return
@@ -1035,7 +1035,7 @@
if {[catch {set file_hook [open $new_file w]} error_code] != 0} then {
- display_error [G_msg "Error while opening file: %s", $error_code]
return
Modified: grass/branches/develbranch_6/visualization/nviz/scripts/panel_rquery.tcl
--- grass/branches/develbranch_6/visualization/nviz/scripts/panel_rquery.tcl 2010-12-12 16:49:36 UTC (rev 44587)
+++ grass/branches/develbranch_6/visualization/nviz/scripts/panel_rquery.tcl 2010-12-12 20:28:12 UTC (rev 44588)
@@ -38,7 +38,7 @@
set Nv_(what_surfdist) 1
set Nv_(what_exagsurfdist) 1
set Nv_(what_pipe) 0
-set Nv_(what_pipe_text) "Send results to: (no file selected)"
+set Nv_(what_pipe_text) [G_msg "Send results to: (no file selected)"]
proc mkqueryPanel { BASE } {
@@ -49,23 +49,23 @@
# Initialize panel info
if [catch {set Nv_($BASE)}] {
- set panel [St_create {window name size priority} $BASE "Raster Query" 1 5]
+ set panel [St_create {window name size priority} $BASE [G_msg "Raster Query"] 1 5]
} else {
set panel $Nv_($BASE)
frame $BASE -relief flat -borderwidth 0
- Nv_mkPanelname $BASE "Raster Query Panel"
+ Nv_mkPanelname $BASE [G_msg "Raster Query Panel"]
# Create frame, buttons, and attributes menu
frame $BASE.bf -relief flat -borderwidth 0
- checkbutton $BASE.bf.what -text "query on/off" \
+ checkbutton $BASE.bf.what -text [G_msg "query on/off"] \
-command whats_here -variable WhatsHere(on)
- Button $BASE.bf.separate -text Reset -command do_separate \
- -bd 1 -width 6 -helptext "Reset most recent query"
- Button $BASE.bf.clear -text Clear -command clear_text \
- -bd 1 -width 6 -helptext "Clear all queries"
- menubutton $BASE.bf.atts -text Attributes \
+ Button $BASE.bf.separate -text [G_msg "Reset"] -command do_separate \
+ -bd 1 -width 6 -helptext [G_msg "Reset most recent query"]
+ Button $BASE.bf.clear -text [G_msg "Clear"] -command clear_text \
+ -bd 1 -width 6 -helptext [G_msg "Clear all queries"]
+ menubutton $BASE.bf.atts -text [G_msg "Attributes"] \
-menu $BASE.bf.atts.m -relief raised \
-indicatoron 1 -bd 1
@@ -75,11 +75,7 @@
# Add menu entries for menu
set theMenu $BASE.bf.atts.m
- foreach i {{"Map name" "mapname" 0} {"Easting" "easting" 0} {"Northing" "northing" 0} \
- {"Elevation" "elevation" 1} {"Category of color map" "colorcat" 0} \
- {"XY dist from prev" "xydiff" 0} \
- {"XYZ dist from prev" "xyzdiff" 2} {"Dist along surface" "surfdist" 0} \
- {"Dist along exag surface" "exagsurfdist" 5}} {
+ foreach i [list [list [G_msg "Map name"] "mapname" 0] [list [G_msg "Easting"] "easting" 0] [list [G_msg "Northing"] "northing" 0] [list [G_msg "Elevation"] "elevation" 1] [list [G_msg "Category of color map"] "colorcat" 0] [list [G_msg "XY dist from prev"] "xydiff" 0] [list [G_msg "XYZ dist from prev"] "xyzdiff" 2] [list [G_msg "Dist along surface"] "surfdist" 0] [list [G_msg "Dist along exag surface"] "exagsurfdist" 5]] {
$theMenu add checkbutton -label [lindex $i 0] -underline [lindex $i 2] \
-offvalue 0 -onvalue 1 -variable Nv_(what_[lindex $i 1])
@@ -89,12 +85,12 @@
# frrame for close button and saving output to a file
frame $BASE.cf
- Button $BASE.cf.close -text Close -command "Nv_closePanel $BASE" \
+ Button $BASE.cf.close -text [G_msg "Close"] -command "Nv_closePanel $BASE" \
-bd 1 -width 6
Button $BASE.cf.output -textvariable Nv_(what_pipe_text) \
-command "whats_pipe_bind $BASE" -bd 1 \
- -helptext "Select file to receive all future query results"
+ -helptext [G_msg "Select file to receive all future query results"]
pack $BASE.cf.close $BASE.cf.output -side right -expand 0 -fill none
pack $BASE.cf.output -side left
@@ -127,7 +123,7 @@
if {$new_file == -1} then return
set Nv_(what_pipe) $new_file
- set Nv_(what_pipe_text) "Send results to: $new_file"
+ set Nv_(what_pipe_text) [format [G_msg "Send results to: %s"] $new_file]
proc whats_here {} {
@@ -153,8 +149,8 @@
set list [Nget_point_on_surf $x $y]
if {[llength $list] < 4} {
- $text insert end "Point not on surface\n"
- append tot_out "Point not on surface\n"
+ $text insert end [G_msg "Point not on surface\n"]
+ append tot_out [G_msg "Point not on surface\n"]
$text yview -pickplace end
return
@@ -165,21 +161,21 @@
set id [lindex $list 3]
if {$Nv_(what_easting)} then {
- set str [format "Easting: %15.4f\n" $x]
+ set str [format [G_msg "Easting: %15.4f\n"] $x]
$text insert end "$str"
append tot_out "$str"
if {$Nv_(what_northing)} then {
- set str [format "Northing: %15.4f\n" $y]
+ set str [format [G_msg "Northing: %15.4f\n"] $y]
if {$Nv_(what_elevation)} then {
- set str [format "Elevation: %15.4f\n" $z]
+ set str [format [G_msg "Elevation: %15.4f\n"] $z]
@@ -187,8 +183,8 @@
if {$Nv_(what_mapname)} then {
set str [Nget_map_name [string range $id 5 end] surf]
- $text insert end "Surf map: $str"
- append tot_out "Surf map: $str"
+ $text insert end [format [G_msg "Surf map: %s"] $str]
+ append tot_out [format [G_msg "Surf map: %s"] $str]
set str [Nget_cat_at_xy $id topo $x $y]
$text insert end "\t$str\n"
append tot_out "\t$str\n"
@@ -203,10 +199,10 @@
if {[lindex $map_name 0] == "map"} then {
set str [lindex $map_name 1]
} else {
- set str "constant"
+ set str [G_msg "constant"]
- $text insert end "Color map: $str"
- append tot_out "Color map: $str"
+ $text insert end [format [G_msg "Color map: %s"] $str]
+ append tot_out [format [G_msg "Color map: %s"] $str]
set str [Nget_cat_at_xy $id color $x $y]
@@ -225,7 +221,7 @@
if {$Nv_(what_xydiff)} then {
set val [expr sqrt(($px-$x)*($px-$x)+($py-$y)*($py-$y))]
- set str [format "XY distance from previous: \t%15.4f\n" $val]
+ set str [format [G_msg "XY distance from previous: \t%15.4f\n"] $val]
@@ -233,7 +229,7 @@
if {$Nv_(what_xyzdiff)} then {
set val [expr sqrt(($px-$x)*($px-$x)+($py-$y)*($py-$y)+($pz-$z)*($pz-$z))]
- set str [format "XYZ distance from previous: \t%15.4f\n" $val]
+ set str [format [G_msg "XYZ distance from previous: \t%15.4f\n"] $val]
@@ -242,7 +238,7 @@
if {$WhatsHere(pid) == $id} {
if {$Nv_(what_surfdist)} then {
set dist [Nget_dist_along_surf $id $x $y $px $py 0]
- set str [format "Distance along surface: \t%15.4f\n" $dist]
+ set str [format [G_msg "Distance along surface: \t%15.4f\n"] $dist]
@@ -253,7 +249,7 @@
if {$Nv_(what_exagsurfdist)} then {
set dist [Nget_dist_along_surf $id $x $y $px $py 1]
- set str [format "Distance along exag. surface:%15.4f\n" $dist]
+ set str [format [G_msg "Distance along exag. surface:%15.4f\n"] $dist]
Modified: grass/branches/develbranch_6/visualization/nviz/scripts/panel_scale.tcl
--- grass/branches/develbranch_6/visualization/nviz/scripts/panel_scale.tcl 2010-12-12 16:49:36 UTC (rev 44587)
+++ grass/branches/develbranch_6/visualization/nviz/scripts/panel_scale.tcl 2010-12-12 20:28:12 UTC (rev 44588)
@@ -42,22 +42,22 @@
set bar_text_clr "#DDDDDD"
set bar_text_size "non funct."
- set panel [St_create {window name size priority} $BASE "Scale bar" 2 5]
+ set panel [St_create {window name size priority} $BASE [G_msg "Scale bar"] 2 5]
- Nv_mkPanelname $BASE "Scale Bar Panel"
+ Nv_mkPanelname $BASE [G_msg "Scale Bar Panel"]
# This section contains widgets for placing the scale bar
set rbase1 [frame $BASE.scale]
- Label $rbase1.scalebar_lbl -text "Scale bar: " -fg black
+ Label $rbase1.scalebar_lbl -text [G_msg "Scale bar: "] -fg black
LabelEntry $rbase1.scalebar_size -relief sunken -entrybg white \
-textvariable scalebar_size -width 8 \
- -label "length (in map units) " -fg black -font $nviztxtfont
+ -label [G_msg "length (in map units) "] -fg black -font $nviztxtfont
pack $rbase1.scalebar_lbl $rbase1.scalebar_size -side left -expand no -fill none
$rbase1.scalebar_size bind <Key> {if {$Nauto_draw == 1} {Ndraw_all}}
- Button $rbase1.color -text "Color" \
+ Button $rbase1.color -text [G_msg "Color"] \
-bg $bar_clr -width 8 -bd 1 \
-command "change_scale_color $rbase1.color scale" \
-fg "#ffffff"
@@ -68,15 +68,15 @@
# This section contains widgets for scale text
set rbase2 [frame $BASE.txt]
- Label $rbase2.txt_lbl -text "Scale text: " -fg black
+ Label $rbase2.txt_lbl -text [G_msg "Scale text: "] -fg black
LabelEntry $rbase2.txt_size -relief sunken -entrybg grey \
-textvariable bar_text_size -width 8 -justify right\
- -label "size " -fg black -labelfont $nviztxtfont
+ -label [G_msg "size "] -fg black -labelfont $nviztxtfont
pack $rbase2.txt_lbl $rbase2.txt_size -side left -expand no -fill none
$rbase2.txt_size bind <Key> {if {$Nauto_draw == 1} {Ndraw_all}}
- Button $rbase2.color -text "Color" \
+ Button $rbase2.color -text [G_msg "Color"] \
-bg $bar_text_clr -width 8 -bd 1 \
-command "change_scale_color $rbase2.color text" \
-fg "#ffffff"
@@ -87,11 +87,11 @@
# close panel section
set rbase3 [frame $BASE.button]
- Button $rbase3.place -text "Place scale" -bd 1 \
+ Button $rbase3.place -text [G_msg "Place scale"] -bd 1 \
-command "sb_bind_mouse $Nv_(TOP).canvas; $Nv_(TOP) configure -cursor plus"
pack $rbase3.place -expand yes -side left -expand no -fill none
- button $rbase3.close -text "Close" -command "Nv_closePanel $BASE" \
+ button $rbase3.close -text [G_msg "Close"] -command "Nv_closePanel $BASE" \
-anchor se -bd 1
pack $rbase3.close -side right -fill none -expand no
pack $rbase3 -side top -fill both -expand yes -padx 3 -pady 4
Modified: grass/branches/develbranch_6/visualization/nviz/scripts/panel_sdiff.tcl
--- grass/branches/develbranch_6/visualization/nviz/scripts/panel_sdiff.tcl 2010-12-12 16:49:36 UTC (rev 44587)
+++ grass/branches/develbranch_6/visualization/nviz/scripts/panel_sdiff.tcl 2010-12-12 20:28:12 UTC (rev 44588)
@@ -36,13 +36,13 @@
set panel [St_create {window name size priority} \
- $BASE "Scaled Difference" 1 5]
+ $BASE [G_msg "Scaled Difference"] 1 5]
} else {
- Nv_mkPanelname $BASE "Scaled Difference Panel"
+ Nv_mkPanelname $BASE [G_msg "Scaled Difference Panel"]
frame $BASE.top
frame $BASE.bottom
@@ -51,22 +51,22 @@
set maplist [Nget_map_list surf]
- Label $BASE.top.label -text "Reference surface:"
+ Label $BASE.top.label -text [G_msg "Reference surface:"]
Nv_mksdiffSurfacelist $BASE.top.list
pack $BASE.top.label $BASE.top.list -side left -fill y -pady 4
- Label $BASE.top1.lbl -text "Set difference between reference surface and others"
+ Label $BASE.top1.lbl -text [G_msg "Set difference between reference surface and others"]
pack $BASE.top1.lbl -side left -pady 4
Nv_mkScale $BASE.top2.sdscale h "z-exag" 0 2500 100 set_sdexag 2
pack $BASE.top2.sdscale -side bottom
- Button $BASE.bottom.none -text "Clear" \
+ Button $BASE.bottom.none -text [G_msg "Clear"] \
-command "unset_sdsurf" -bd 1 -width 5 \
- -helptext "unselect reference surface"
+ -helptext [G_msg "unselect reference surface"]
pack $BASE.bottom.none -side left
- button $BASE.bottom.close -text "Close" \
+ button $BASE.bottom.close -text [G_msg "Close"] \
-command "Nv_closePanel $BASE" -bd 1 -width 5
pack $BASE.bottom.close -side right
@@ -121,7 +121,7 @@
set name [Nget_current sdiff]
if {$name == 0} {
- set name "None selected "
+ set name [G_msg "None selected"]
} else {
set n [lsearch $list $name]
set list [lreplace $list $n $n]
Modified: grass/branches/develbranch_6/visualization/nviz/scripts/panel_site.tcl
--- grass/branches/develbranch_6/visualization/nviz/scripts/panel_site.tcl 2010-12-12 16:49:36 UTC (rev 44587)
+++ grass/branches/develbranch_6/visualization/nviz/scripts/panel_site.tcl 2010-12-12 20:28:12 UTC (rev 44588)
@@ -41,22 +41,22 @@
- set panel [St_create {window name size priority} $BASE "Vector Points" 1 5]
+ set panel [St_create {window name size priority} $BASE [G_msg "Vector Points"] 1 5]
} else {
########## create panel heading
- Nv_mkPanelname $BASE "Vector Points Panel"
+ Nv_mkPanelname $BASE [G_msg "Vector Points Panel"]
########## create top frame
set top [frame $BASE.top]
- Label $top.current -text "Current:" -anchor w
+ Label $top.current -text [G_msg "Current:"] -anchor w
mkMapList $top.list site
- button $top.new -text New -anchor center -command "add_map site" -bd 1
- button $top.delete -text Delete -anchor center -command "delete_map site" -bd 1
+ button $top.new -text [G_msg "New"] -anchor center -command "add_map site" -bd 1
+ button $top.delete -text [G_msg "Delete"] -anchor center -command "delete_map site" -bd 1
pack $top.current $top.list -side left
pack $top.delete $top.new -side right -expand 0
@@ -65,6 +65,7 @@
# initialize variables and map list
set curr [Nget_current site]
set Nv_(siteshape) sphere
+ set Nv_(siteshapelv) ""
change_marker
if {0 != $curr} {
@@ -110,11 +111,11 @@
########## create bottom frame
set bottom [frame $BASE.bottom]
- button $bottom.close -text Close \
+ button $bottom.close -text [G_msg "Close"] \
-command "Nv_closePanel $BASE" -anchor s -bd 1
pack $bottom.close -side right
- button $bottom.draw_current -text "DRAW CURRENT" -fg darkgreen -anchor s \
+ button $bottom.draw_current -text [G_msg "DRAW CURRENT"] -fg darkgreen -anchor s \
-command {Nsite_draw_one [Nget_current site]} -bd 1
pack $bottom.draw_current -side left
@@ -129,7 +130,7 @@
set row4 [frame $mid1.row4]
set row5 [frame $mid1.row5]
- set szlabel [label $row1.szlabel -text "icon size" \
+ set szlabel [label $row1.szlabel -text [G_msg "icon size"] \
-font $nviztxtfont -fg black]
@@ -145,23 +146,24 @@
$ptsize setvalue @$startindex
- set ptcolor [button $row1.color -text Color \
+ set ptcolor [button $row1.color -text [G_msg "Color"] \
-command "change_color site $row1.color"]
bind $ptcolor <Expose> "$row1.color configure -bg \[get_curr_sv_color site\]"
- set markerlbl [label $row1.markerlbl -text " icon type " -fg black -font $nviztxtfont]
+ set markerlbl [label $row1.markerlbl -text [G_msg "icon type"] -fg black -font $nviztxtfont]
set markertype [ComboBox $row1.marker -width 8 \
-textvariable Nv_(siteshape) -modifycmd change_marker \
- -values {"x" "sphere" "diamond" "cube" "box" "gyro" "aster" "histogram"}]
+ -values $Nv_(siteshapes) -labels $Nv_(siteshape_names) -labelsvariable Nv_(siteshapelv)]
pack $szlabel $ptsize $markerlbl $markertype -side left
pack $ptcolor -side left -padx 10
- set rb1 [radiobutton $row2.disp3d -text "3D points" \
+ set rb1 [radiobutton $row2.disp3d -text [G_msg "3D points"] \
-anchor nw -variable Nv_(sitedisplay) -value 3d \
-command change_site_mode]
- set rb2 [radiobutton $row3.dispsurf -text "display on surface(s):" \
+ set rb2 [radiobutton $row3.dispsurf -text [G_msg "display on surface(s):"] \
-anchor nw -variable Nv_(sitedisplay) -value surfdisp \
@@ -177,7 +179,7 @@
set site_attr(FIELD_ATTR_PANEL) 0
- checkbutton $row4.themechk -text "thematic mapping for vector points" \
+ checkbutton $row4.themechk -text [G_msg "thematic mapping for vector points"] \
-variable site_attr(FIELD_ATTR_PANEL) -command "if {$curr!=0} {site_attr_gui $row5 $bottom $curr}" \
pack $row4.themechk -side left -anchor nw
@@ -363,10 +365,3 @@
Modified: grass/branches/develbranch_6/visualization/nviz/scripts/panel_surf.tcl
--- grass/branches/develbranch_6/visualization/nviz/scripts/panel_surf.tcl 2010-12-12 16:49:36 UTC (rev 44587)
+++ grass/branches/develbranch_6/visualization/nviz/scripts/panel_surf.tcl 2010-12-12 20:28:12 UTC (rev 44588)
@@ -48,14 +48,14 @@
- set panel [St_create {window name size priority} $BASE "Raster Surfaces" 2 5]
+ set panel [St_create {window name size priority} $BASE [G_msg "Raster Surfaces"] 2 5]
} else {
# surface panel frame
frame $BASE -relief flat -bd 0
- Nv_mkPanelname $BASE "Surface Panel"
+ Nv_mkPanelname $BASE [G_msg "Surface Panel"]
# resolution panel frame
frame $BASE.bottom -relief flat -bd 0
@@ -65,10 +65,10 @@
###### make widgets that control which is current surface (menu, new delete)###
set tmp [frame $BASE.top.top]
- Label $tmp.current -text "Current:" -anchor w
+ Label $tmp.current -text [G_msg "Current:"] -anchor w
mkMapList $tmp.list surf set_display_from_curr
- button $tmp.new -text New -anchor center -bd 1 -command new_surf
- button $tmp.delete -text Delete -anchor center -bd 1 -command delete_surf
+ button $tmp.new -text [G_msg "New"] -anchor center -bd 1 -command new_surf
+ button $tmp.delete -text [G_msg "Delete"] -anchor center -bd 1 -command delete_surf
pack $tmp.current $tmp.list -side left
pack $tmp.delete $tmp.new -side right -expand 0
@@ -76,7 +76,7 @@
####### make buttons that control attributes for current surface ########
set tmp [frame $BASE.top.bottom -bd 0 -relief flat]
set tmp2 [frame $BASE.top.bottom2 -bd 0 -relief flat]
- menubutton $tmp.menu1 -menu $tmp.menu1.m -text "Surface attributes..." -relief raised \
+ menubutton $tmp.menu1 -menu $tmp.menu1.m -text [G_msg "Surface attributes..."] -relief raised \
menu $tmp.menu1.m
@@ -85,18 +85,18 @@
-command "mkAttPopup .pop $i 1"
- button $tmp.wireclr -text "Wire Color" \
+ button $tmp.wireclr -text [G_msg "Wire Color"] \
-command "change_wirecolor $tmp.wireclr" \
-bg [get_curr_wire_color] -bd 1
- button $tmp.position -text "Position" -bd 1 -command "mkPositionPanel .pos_surf"
+ button $tmp.position -text [G_msg "Position"] -bd 1 -command "mkPositionPanel .pos_surf"
pack $tmp.menu1 $tmp.wireclr $tmp.position -side left -fill x -expand 1 -ipadx 3
- Label $tmp2.l1 -text "Mask zeros:" -relief flat
- checkbutton $tmp2.nozeros1 -text "by elevation" \
+ Label $tmp2.l1 -text [G_msg "Mask zeros:"] -relief flat
+ checkbutton $tmp2.nozeros1 -text [G_msg "by elevation"] \
-variable Nv_(TopNoZeros) -command no_zeros
- checkbutton $tmp2.nozeros2 -text "by color" \
+ checkbutton $tmp2.nozeros2 -text [G_msg "by color"] \
-variable Nv_(ColNoZeros) -command no_zeros
pack $tmp2.l1 $tmp2.nozeros1 $tmp2.nozeros2 \
@@ -106,41 +106,41 @@
set tmp [frame $BASE.bottom.t1]
menubutton $tmp.style -menu $tmp.style.m -relief raised \
- -text "Draw mode..." -underline 0 -indicatoron 1 \
+ -text [G_msg "Draw mode..."] -underline 0 -indicatoron 1 \
-justify center -bd 1
menu $tmp.style.m
- $tmp.style.m add radiobutton -label Coarse -value wire \
+ $tmp.style.m add radiobutton -label [G_msg "Coarse"] -value wire \
-variable Nv_(SurfStyle) -command set_drawmode
- $tmp.style.m add radiobutton -label Fine -value poly \
+ $tmp.style.m add radiobutton -label [G_msg "Fine"] -value poly \
- $tmp.style.m add radiobutton -label Both -value wire_poly \
+ $tmp.style.m add radiobutton -label [G_msg "Both"] -value wire_poly \
menubutton $tmp.gstyle -menu $tmp.gstyle.m -relief raised \
- -text "Coarse style..." -underline 0 -indicatoron 1 \
+ -text [G_msg "Coarse style..."] -underline 0 -indicatoron 1 \
menu $tmp.gstyle.m
- $tmp.gstyle.m add radiobutton -label Wire -value grid_wire \
+ $tmp.gstyle.m add radiobutton -label [G_msg "Wire"] -value grid_wire \
-variable Nv_(GridStyle) -command set_drawmode
- $tmp.gstyle.m add radiobutton -label "Surface" -value grid_surf \
+ $tmp.gstyle.m add radiobutton -label [G_msg "Surface"] -value grid_surf \
- menubutton $tmp.shading -text "Shading..." -menu $tmp.shading.m \
+ menubutton $tmp.shading -text [G_msg "Shading..."] -menu $tmp.shading.m \
-relief raised -underline 0 -indicatoron 1 \
menu $tmp.shading.m
- $tmp.shading.m add radiobutton -label Flat -value flat \
+ $tmp.shading.m add radiobutton -label [G_msg "Flat"] -value flat \
-variable Nv_(ShadeStyle) -command set_drawmode
- $tmp.shading.m add radiobutton -label Gouraud -value gouraud \
+ $tmp.shading.m add radiobutton -label [G_msg "Gouraud"] -value gouraud \
pack $tmp.style $tmp.gstyle $tmp.shading -side left -fill x -expand 1 -pady 3
########### make controls for setting resolution ##################
set tmp [frame $BASE.bottom.t2]
- set reslabel [Label $tmp.subsampling -text "Resolution:" -justify left -anchor w]
+ set reslabel [Label $tmp.subsampling -text [G_msg "Resolution:"] -justify left -anchor w]
- set sblabel1 [label $tmp.sblabel1 -text coarse -font $nviztxtfont \
+ set sblabel1 [label $tmp.sblabel1 -text [G_msg "coarse"] -font $nviztxtfont \
-fg black -anchor e -justify right]
set sbwire [SpinBox $tmp.gridarrows2 -range {1 100 1}\
-textvariable wireres \
@@ -150,7 +150,7 @@
-entrybg white]
set sblabel2 [label $tmp.sblabel2 -font $nviztxtfont \
- -fg black -anchor e -justify right -text "fine" ]
+ -fg black -anchor e -justify right -text [G_msg "fine"] ]
set sbpoly [SpinBox $tmp.gridarrows1 -range {1 100 1}\
-textvariable polyres \
-modifycmd {update_spinres "poly" $polyres} \
@@ -163,10 +163,10 @@
########### make radiobuttons that control scope of changes made ##################
set tmp [frame $BASE.bottom.t3]
- set rblabel1 [Label $tmp.rblabel1 -anchor w -text "Set resolution for:"]
- set rbcurrent [radiobutton $tmp.current -text "current surface"\
+ set rblabel1 [Label $tmp.rblabel1 -anchor w -text [G_msg "Set resolution for:"]]
+ set rbcurrent [radiobutton $tmp.current -text [G_msg "current surface"]\
-anchor w -value 1 -variable Nv_(CurrOnly)]
- set rball [radiobutton $tmp.all -text "all surfaces" -justify right \
+ set rball [radiobutton $tmp.all -text [G_msg "all surfaces"] -justify right \
-anchor e -value 0 -variable Nv_(CurrOnly) -command set_drawmode]
pack $rblabel1 $rbcurrent $rball -side left -fill x -ipadx 2
@@ -182,7 +182,7 @@
########## make button to close panel ########################################
button $BASE.close -text Close -bd 1 -command "Nv_closePanel $BASE"
- button $BASE.draw_current -text "DRAW CURRENT" -bd 1 -fg darkgreen \
+ button $BASE.draw_current -text [G_msg "DRAW CURRENT"] -bd 1 -fg darkgreen \
-command {Nsurf_draw_one [Nget_current surf]}
pack $BASE.close -side right -fill y
pack $BASE.draw_current -side left -fill y -padx 3
@@ -667,8 +667,8 @@
# Create toplevel widget to hold everything
toplevel $w -class Dialog
- wm title $w "Position Surface"
- wm iconname $w "Attribute"
+ wm title $w [G_msg "Position Surface"]
+ wm iconname $w [G_msg "Attribute"]
# Get current surface attributes
set curr_surf [Nget_current surf]
@@ -698,9 +698,9 @@
# Create X, Y, and Z entry widgets along with Reset and Close buttons
frame $w.coords
- label $w.coords.z_lbl -text "Z:"
- label $w.coords.x_lbl -text "X:"
- label $w.coords.y_lbl -text "Y:"
+ label $w.coords.z_lbl -text [G_msg "Z:"]
+ label $w.coords.x_lbl -text [G_msg "X:"]
+ label $w.coords.y_lbl -text [G_msg "Y:"]
entry $w.coords.z_ent -width 5 -relief sunken -bg white
entry $w.coords.x_ent -width 5 -relief sunken -bg white
entry $w.coords.y_ent -width 5 -relief sunken -bg white
@@ -722,8 +722,8 @@
pack $w.coords -side top -in $w.bottom -fill both
frame $w.commands
- button $w.commands.reset -text "Reset" -command "$w.zslide set 0; Nv_itemDrag $w.pos $Nv_(SURF_POS) 63 63; Nv_xyCallback $update_routine 126 126 63 63"
- button $w.commands.close -text "Close" -command "destroy $w"
+ button $w.commands.reset -text [G_msg "Reset"] -command "$w.zslide set 0; Nv_itemDrag $w.pos $Nv_(SURF_POS) 63 63; Nv_xyCallback $update_routine 126 126 63 63"
+ button $w.commands.close -text [G_msg "Close"] -command "destroy $w"
pack $w.commands.reset $w.commands.close \
-side left -fill both -padx 3 -pady 3 -expand yes
pack $w.commands -in $w.bottom -fill both
Modified: grass/branches/develbranch_6/visualization/nviz/scripts/panel_vquery.tcl
--- grass/branches/develbranch_6/visualization/nviz/scripts/panel_vquery.tcl 2010-12-12 16:49:36 UTC (rev 44587)
+++ grass/branches/develbranch_6/visualization/nviz/scripts/panel_vquery.tcl 2010-12-12 20:28:12 UTC (rev 44588)
@@ -407,7 +407,7 @@
toplevel $win
wm resizable $win true true
- wm title $win "Map: [$_map get_att map]"
+ wm title $win [format [G_msg "Map: %s"] [$_map get_att map]]
wm geometry $win "820x200+10+250"
wm minsize $win 150 100
@@ -609,8 +609,9 @@
proc highlight_set_marker_button {_w} {
global highlight
+ global Nv_
- set highlight(MARKERS_NAME) [list {x} [G_msg "sphere"] [G_msg "diamond"] [G_msg "cube"] [G_msg "box"] [G_msg "gyro"] [G_msg "aster"]]
+ set highlight(MARKERS_NAME) $Nv_(siteshape_names)
set highlight(MARKERS_INDEX) {"1" "3" "5" "4" "2" "9" "8"}
set m $_w
Modified: grass/branches/develbranch_6/visualization/nviz/scripts/script_file_tools
--- grass/branches/develbranch_6/visualization/nviz/scripts/script_file_tools 2010-12-12 16:49:36 UTC (rev 44587)
+++ grass/branches/develbranch_6/visualization/nviz/scripts/script_file_tools 2010-12-12 20:28:12 UTC (rev 44588)
@@ -123,7 +123,7 @@
# Read in each of the file fields one at a time, and create
# Field_Data as appropriate
return
@@ -132,14 +132,14 @@
# Read in state file
if {[catch {gets $file_hook state_file} error_code] != 0} then {
- display_error [G_msg "While reading state_file: %s", $error_code]
+ display_error [format [G_msg "While reading state_file: %s"] $error_code]
return
set_new_state_file $state_file
# Get number of fields
if {[catch {gets $file_hook num_fields} error_code] != 0} then {
- display_error [G_msg "While reading number of fields: %s", $error_code]
+ display_error [format [G_msg "While reading number of fields: %s"] $error_code]
return
@@ -148,13 +148,13 @@
for {set i 0} {$i < $num_fields} {incr i} {
# Input field type
if {[catch {gets $file_hook field_type} error_code] != 0} then {
- display_error [G_msg "While reading field type: %s", $error_code]
+ display_error [format [G_msg "While reading field type: %s"] $error_code]
return
# Input field attribute
if {[catch {gets $file_hook field_att} error_code] != 0} then {
- display_error [G_msg "While reading field attribute: %s", $error_code]
+ display_error [format [G_msg "While reading field attribute: %s"] $error_code]
return
Modified: grass/branches/develbranch_6/visualization/nviz/scripts/script_play
--- grass/branches/develbranch_6/visualization/nviz/scripts/script_play 2010-12-12 16:49:36 UTC (rev 44587)
+++ grass/branches/develbranch_6/visualization/nviz/scripts/script_play 2010-12-12 20:28:12 UTC (rev 44588)
@@ -28,7 +28,7 @@
set new_file "$NvizPlayScript"
} else {
tk_dialog .file_error [G_msg "File Error"] \
- [G_msg "Script file %s does not exist", $NvizPlayScript] \
+ [format [G_msg "Script file %s does not exist"] $NvizPlayScript] \
error 0 [G_msg "Dismiss"]
exit
Modified: grass/branches/develbranch_6/visualization/nviz/scripts/site_attr.tcl
--- grass/branches/develbranch_6/visualization/nviz/scripts/site_attr.tcl 2010-12-12 16:49:36 UTC (rev 44587)
+++ grass/branches/develbranch_6/visualization/nviz/scripts/site_attr.tcl 2010-12-12 20:28:12 UTC (rev 44588)
@@ -425,7 +425,7 @@
generate a color table."]
default {
- puts [G_msg "WARNING: No thematic mapping preferences set for %s!", $site_attr($_idx.ATTR)]
+ puts [format [G_msg "WARNING: No thematic mapping preferences set for %s!"] $site_attr($_idx.ATTR)]
@@ -444,11 +444,11 @@
set site_attr($_idx.WIN_CMD) $w
# Attribute
- label $w.attr -text [G_msg "Vary point %s", $site_attr($_idx.ATTR)]
+ label $w.attr -text [format [G_msg "Vary point %s"] $site_attr($_idx.ATTR)]
pack $w.attr -pady 1 -padx 0 -fill x -side top
# Field
- label $w.field -text [G_msg "GIS attribute: %s", $site_attr($_idx.NAME)]
+ label $w.field -text [format [G_msg "GIS attribute: %s"] $site_attr($_idx.NAME)]
pack $w.field -padx 0 -fill x -side top
# Type
@@ -457,7 +457,7 @@
} else {
set type "numeric"
- label $w.type -text [G_msg "Attribute type: %s", $type]
+ label $w.type -text [format [G_msg "Attribute type: %s"] $type]
pack $w.type -padx 0 -fill x -side top
# Instructions
@@ -1405,7 +1405,7 @@
set row_val "label \$w.l\$row -bg \$val -width 3 -borderwidth 1 -relief raised"
default {
- puts [G_msg "WARNING: No attribute behaviour for %s!", $site_attr($_lut_id.ATTR)]
+ puts [format [G_msg "WARNING: No attribute behaviour for %s!"] $site_attr($_lut_id.ATTR)]
return
@@ -1415,11 +1415,11 @@
catch {destroy $win}
toplevel $win
- wm title $win [G_msg "Thematic prefs file %s", $_lut_id]
+ wm title $win [format [G_msg "Thematic prefs file %s"] $_lut_id]
bind $win <Destroy> "site_attr_lut_destroy_win $_lut_id $win %W"
set w [frame $win.left]
- label $w.name -text [G_msg "Name: %s", $site_attr($_lut_id.NAME)] -pady 2
+ label $w.name -text [format [G_msg "Name: %s"] $site_attr($_lut_id.NAME)] -pady 2
pack $w.name -pady 1 -fill x -side top
if {$site_attr($_lut_id.TYPE) == "s"} {
@@ -1579,7 +1579,7 @@
if {$filename != ""} {
if {[file exists $filename]} {
file delete -force -- $filename
- puts [G_msg "Old LUT \"%s\" deleted", $filename]
+ puts [format [G_msg "Old LUT \"%s\" deleted"] $filename]
# file is new
site_attr_lut_write $_lut_id [site_attr_lut_file_from_name $filename]
@@ -1604,7 +1604,7 @@
close $fileId
set site_attr($_lut_id.NAME) [site_attr_lut_name_from_file $_filename]
- puts [G_msg "Thematic preferences file \"%s\" saved", $name]
+ puts [format [G_msg "Thematic preferences file \"%s\" saved"] $name]
@@ -1619,12 +1619,12 @@
if {$filename == ""} {return}
if {![file exists $filename]} {
- puts [G_msg "*** WARNING *** File \"%s\" is unavailable", $filename]
+ puts [format [G_msg "*** WARNING *** File \"%s\" is unavailable"] $filename]
return ""
if {[site_attr_lut_read $filename] < 5} {
- puts [G_msg "*** ERROR *** Some thematic pref component are missing in file \"%s\"", $filename]
+ puts [format [G_msg "*** ERROR *** Some thematic pref component are missing in file \"%s\""] $filename]
return ""
@@ -1697,7 +1697,7 @@
default {
- puts [G_msg "WARNING: Unknown Tag \"%s\" in file \"%s\"", $tag_name, $_filename]
+ puts [format [G_msg "WARNING: Unknown Tag \"%s\" in file \"%s\""] $tag_name, $_filename]
# foreach elt $tag_list {puts "*** $elt ***"}
@@ -1767,7 +1767,7 @@
"size" {set st_att [Nsite_attr_get_value "ST_ATT_SIZE"]}
"color" {set st_att [Nsite_attr_get_value "ST_ATT_COLOR"]}
"marker" {set st_att [Nsite_attr_get_value "ST_ATT_MARKER"]}
- default {puts [G_msg "WARNING: Unknown attribute %s!", $_attr]; return $ret_list}
+ default {puts [format [G_msg "WARNING: Unknown attribute %s!"] $_attr]; return $ret_list}
set max [Nsite_attr_get_value "GPT_MAX_ATTR"]
@@ -1788,14 +1788,14 @@
incr index
- if {$not_found} {puts [G_msg "WARNING: field %s NOT FOUND", $_field]; return}
+ if {$not_found} {puts [format [G_msg "WARNING: field %s NOT FOUND"] $_field]; return}
# verify if lut with this name is already loaded
set lut_id [site_attr_lut_id_from_name [site_attr_lut_name_from_file $_lut_name]]
if {$lut_id == "NO_LUT"} {
# if not, load it!
set lut_id [site_attr_lut_load [file join $site_attr(LUT_DIR) [site_attr_lut_file_from_name $_lut_name]]]
- if {$lut_id == ""} {puts [G_msg "WARNING: lut file %s NOT FOUND", [site_attr_lut_file_from_name $_lut_name]]; return}
+ if {$lut_id == ""} {puts [format [G_msg "WARNING: lut file %s NOT FOUND"] [site_attr_lut_file_from_name $_lut_name]]; return}
# FROM HERE ON EVERITHING SHOULD BE OK
