[GRASS-SVN] r44610 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Dec 15 18:18:24 EST 2010
Author: martinl
Date: 2010-12-15 15:18:24 -0800 (Wed, 15 Dec 2010)
New Revision: 44610
grass/trunk/gui/wxpython/gui_modules/gselect.py
#1100 (Trim mapset name from maps list in wxGUI)
Modified: grass/trunk/gui/wxpython/gui_modules/gselect.py
--- grass/trunk/gui/wxpython/gui_modules/gselect.py 2010-12-15 21:51:16 UTC (rev 44609)
+++ grass/trunk/gui/wxpython/gui_modules/gselect.py 2010-12-15 23:18:24 UTC (rev 44610)
@@ -320,9 +320,9 @@
if self.filterElements:
if self.filterElements(fullqElem):
- self.AddItem(fullqElem, parent=dir_node)
+ self.AddItem(elem, parent=dir_node)
else:
except:
continue
@@ -377,7 +377,8 @@
return item
def OnMotion(self, evt):
- # have the selection follow the mouse, like in a real combobox
+ """!Have the selection follow the mouse, like in a real combobox
item, flags = self.seltree.HitTest(evt.GetPosition())
if item and flags & wx.TREE_HITTEST_ONITEMLABEL:
self.seltree.SelectItem(item)
@@ -385,22 +386,25 @@
evt.Skip()
def OnLeftDown(self, evt):
- # do the combobox selection
+ """!Do the combobox selection
self.curitem = item
if self.seltree.GetRootItem() == self.seltree.GetItemParent(item):
self.value = [] # cannot select mapset item
else:
+ mapsetItem = self.seltree.GetItemParent(item)
+ fullName = self.seltree.GetItemText(item) + '@' + self.seltree.GetItemText(mapsetItem).split(' ', 1)[1]
if self.multiple is True:
# text item should be unique
- self.value.append(self.seltree.GetItemText(item))
+ self.value.append(fullName)
else:
- self.value = [self.seltree.GetItemText(item), ]
+ self.value = [fullName, ]
self.Dismiss()
evt.Skip()
def SetData(self, **kargs):
