[GRASS-SVN] r44628 -
grass/branches/releasebranch_6_4/lib/cairodriver
svn_grass at osgeo.org
Sat Dec 18 19:46:20 EST 2010
Author: hamish
Date: 2010-12-18 16:46:20 -0800 (Sat, 18 Dec 2010)
New Revision: 44628
grass/branches/releasebranch_6_4/lib/cairodriver/Draw_bitmap.c
backport cairo driver fixes from devbr6 r43698 (#1152; untested)
Modified: grass/branches/releasebranch_6_4/lib/cairodriver/Draw_bitmap.c
--- grass/branches/releasebranch_6_4/lib/cairodriver/Draw_bitmap.c 2010-12-17 15:17:21 UTC (rev 44627)
+++ grass/branches/releasebranch_6_4/lib/cairodriver/Draw_bitmap.c 2010-12-19 00:46:20 UTC (rev 44628)
@@ -1,44 +1,53 @@
-#include "cairodriver.h"
+ \file cairodriver/Draw_bitmap.c
-static cairo_surface_t *fix_surface(cairo_surface_t * src)
- int width = cairo_image_surface_get_width(src);
- int height = cairo_image_surface_get_height(src);
- int stride = cairo_image_surface_get_stride(src);
- cairo_format_t format = cairo_image_surface_get_format(src);
- unsigned char *data = cairo_image_surface_get_data(src);
- cairo_surface_t *dst = cairo_image_surface_create(format, width, height);
- int stride2 = cairo_image_surface_get_stride(dst);
- unsigned char *data2 = cairo_image_surface_get_data(dst);
- int i;
+ \brief GRASS cairo display driver - draw bitmap
- for (i = 0; i < height; i++) {
- void *p = data + i * stride;
- void *q = data2 + i * stride2;
- int n = stride < stride2 ? stride : stride2;
+ (C) 2007-2010 by Lars Ahlzen and the GRASS Development Team
+ This program is free software under the GNU General Public License
+ (>=v2). Read the file COPYING that comes with GRASS for details.
+ \author Lars Ahlzen <lars ahlzen.com> (original contibutor)
+ \author Glynn Clements
- memcpy(q, p, n);
+#include <grass/glocale.h>
- cairo_surface_destroy(src);
- return dst;
+#include "cairodriver.h"
+ \brief Draw bitmap
+ \param ncols,nrows number of columns and rows
+ \param threshold threshold value
+ \param buf data buffer
void Cairo_draw_bitmap(int ncols, int nrows, int threshold,
const unsigned char *buf)
cairo_surface_t *surf;
+ int stride;
+ unsigned char *data;
+ int i;
G_debug(1, "Cairo_draw_bitmap: %d %d %d", ncols, nrows, threshold);
- surf = cairo_image_surface_create_for_data((unsigned char *)buf,
- CAIRO_FORMAT_A8, ncols, nrows,
- ncols);
+#if CAIRO_VERSION >= CAIRO_VERSION_ENCODE(1,5,8)
+ stride = cairo_format_stride_for_width(CAIRO_FORMAT_A8, ncols);
+#else
+#define MULTIPLE 4
+ stride = (ncols + (MULTIPLE - 1)) / MULTIPLE * MULTIPLE;
+#endif
+ data = malloc(stride * nrows);
+ surf = cairo_image_surface_create_for_data(data, CAIRO_FORMAT_A8, ncols,
+ nrows, stride);
if (cairo_surface_status(surf) != CAIRO_STATUS_SUCCESS)
- G_fatal_error("Cairo_draw_bitmap: Failed to create source");
+ G_fatal_error(_("Cairo_draw_bitmap: Failed to create source"));
- surf = fix_surface(surf);
+ for (i = 0; i < nrows; i++)
+ memcpy(&data[i * stride], &buf[i * ncols], ncols);
cairo_mask_surface(cairo, surf, cur_x, cur_y);
