[GRASS-SVN] r44630 - in grass/trunk: . include include/vect lib/gis lib/vector/Vlib vector/v.external.out
Sun Dec 19 15:23:06 EST 2010
Author: martinl
Date: 2010-12-19 12:23:06 -0800 (Sun, 19 Dec 2010)
New Revision: 44630
   grass/trunk/grasslib.dox
   grass/trunk/include/gisdefs.h
   grass/trunk/include/vect/dig_structs.h
   grass/trunk/include/vector.h
   grass/trunk/lib/gis/overwrite.c
   grass/trunk/lib/gis/parser.c
   grass/trunk/lib/vector/Vlib/build.c
   grass/trunk/lib/vector/Vlib/close.c
   grass/trunk/lib/vector/Vlib/close_ogr.c
   grass/trunk/lib/vector/Vlib/open.c
   grass/trunk/lib/vector/Vlib/open_ogr.c
   grass/trunk/lib/vector/Vlib/write_ogr.c
   grass/trunk/vector/v.external.out/args.c
   grass/trunk/vector/v.external.out/link.c
   grass/trunk/vector/v.external.out/local_proto.h
   grass/trunk/vector/v.external.out/main.c
   grass/trunk/vector/v.external.out/status.c
vectlib: very initial direct OGR write support (v.external.out)
Modified: grass/trunk/grasslib.dox
--- grass/trunk/grasslib.dox	2010-12-19 19:30:30 UTC (rev 44629)
+++ grass/trunk/grasslib.dox	2010-12-19 20:23:06 UTC (rev 44630)
@@ -58,7 +58,6 @@
 \image html "grass7_arch.png" "GRASS 7 Architecture"
-<p>
 <b>PLEASE UPDATE FOR GRASS 7</b>
 \section corelibs Principal library
Modified: grass/trunk/include/gisdefs.h
--- grass/trunk/include/gisdefs.h	2010-12-19 19:30:30 UTC (rev 44629)
+++ grass/trunk/include/gisdefs.h	2010-12-19 20:23:06 UTC (rev 44630)
@@ -468,6 +468,7 @@
 char *G_recreate_command(void);
 void G_add_keyword(const char *);
 void G_set_keywords(const char *);
+int G_get_overwrite();
 /* paths.c */
 int G_mkdir(const char *);
Modified: grass/trunk/include/vect/dig_structs.h
--- grass/trunk/include/vect/dig_structs.h	2010-12-19 19:30:30 UTC (rev 44629)
+++ grass/trunk/include/vect/dig_structs.h	2010-12-19 20:23:06 UTC (rev 44630)
@@ -163,16 +163,19 @@
 /*! \brief Non-native format info (OGR)
-  \todo Structure size should not change depending on compilation I think, do it better
+  \todo Structure size should not change depending on compilation I
+think, do it better */
 struct Format_info_ogr
+    char *driver_name;          /* OGR driver name */
     char *dsn;                  /* OGR datasource name */
     char *layer_name;           /* OGR layer name */
 #ifdef HAVE_OGR
+    OGRSFDriverH driver;        /* pointer to OGRDriver */
     OGRDataSourceH ds;          /* pointer to OGRDataSourceH */
     OGRLayerH layer;            /* pointer to OGRLayerH */
 #else
+    void *driver;
     void *ds;
     void *layer;
 #endif
@@ -193,11 +196,11 @@
     int feature_cache_id;	/* id of feature read in feature_cache */
     /* Array where OGR feature/part info is stored for each line in
-     * GRASS.  This is not used for GV_CENTROID.  Because one feature
+     * GRASS. This is not used for GV_CENTROID. Because one feature
      * may contain more elements (geometry collection also
      * recursively), offset for one line may be stored in more
-     * records.  First record is FID, next records are part indexes if
-     * necessary.  Example: 5. ring in 3. polygon in 7. feature
+     * records. First record is FID, next records are part indexes if
+     * necessary. Example: 5. ring in 3. polygon in 7. feature
      * (multipolygon) of geometry collection which has FID = 123 123
      * (feature 123: geometry colletion) 6 (7. feature in geometry
      * collection: multiPolygon) 2 (3. polygon) 4 (5. ring in the
Modified: grass/trunk/include/vector.h
--- grass/trunk/include/vector.h	2010-12-19 19:30:30 UTC (rev 44629)
+++ grass/trunk/include/vector.h	2010-12-19 20:23:06 UTC (rev 44630)
@@ -455,6 +455,7 @@
 int V1_open_old_ogr(struct Map_info *, int);
 int V2_open_old_ogr(struct Map_info *);
 int V1_open_new_nat(struct Map_info *, const char *, int);
+int V1_open_new_ogr(struct Map_info *, const char *, int);
 int V1_rewind_nat(struct Map_info *);
 int V1_rewind_ogr(struct Map_info *);
 int V2_rewind_nat(struct Map_info *);
Modified: grass/trunk/lib/gis/overwrite.c
--- grass/trunk/lib/gis/overwrite.c	2010-12-19 19:30:30 UTC (rev 44629)
+++ grass/trunk/lib/gis/overwrite.c	2010-12-19 20:23:06 UTC (rev 44630)
@@ -1,24 +1,21 @@
- * \file overwrite.c
+ * \file lib/gis/overwrite.c
  * \brief GIS Library - Check for overwrite.
- * (C) 2001-2008 by the GRASS Development Team
+ * (C) 2001-2008, 2010 by the GRASS Development Team
  * This program is free software under the GNU General Public License
  * (>=v2). Read the file COPYING that comes with GRASS for details.
  * \author GRASS GIS Development Team, Martin Landa <landa.martin gmail.com>
- * \date 2007-2008
 #include <stdlib.h>
 #include <string.h>
 #include <grass/gis.h>
  * \brief Check for overwrite mode
  * Check variables OVERWRITE, GRASS_OVERWRITE and '--o' flag.
@@ -27,8 +24,8 @@
  * we can switch out the check and do it
  * in the module after the parser.
- * \param[in] argc number of arguments
- * \param[in] argv array of arguments
+ * \param argc number of arguments
+ * \param argv array of arguments
  * \return 1 if overwrite
  * \return 0 if not overwrite
Modified: grass/trunk/lib/gis/parser.c
--- grass/trunk/lib/gis/parser.c	2010-12-19 19:30:30 UTC (rev 44629)
+++ grass/trunk/lib/gis/parser.c	2010-12-19 20:23:06 UTC (rev 44630)
@@ -758,7 +758,17 @@
     fflush(fd);
+  \Get overwrite value
+  \return 1 overwrite enabled
+  \return 0 overwrite disabled
+    return st->overwrite;
 void define_keywords(void)
     st->n_keys = 0;
@@ -1304,6 +1314,11 @@
 			if(G_find_file(element, opt->answers[i], G_mapset()))
 			    found = TRUE;
+		    if (found && strcmp(element, "vector") == 0 &&
+			G_find_file("", "OGR", G_mapset()))
+			found = FALSE;
 		    if (found) {	/* found */
 			if (!st->overwrite && !over) {
 			    if (G_info_format() != G_INFO_FORMAT_GUI) {
Modified: grass/trunk/lib/vector/Vlib/build.c
--- grass/trunk/lib/vector/Vlib/build.c	2010-12-19 19:30:30 UTC (rev 44629)
+++ grass/trunk/lib/vector/Vlib/build.c	2010-12-19 20:23:06 UTC (rev 44630)
@@ -119,7 +119,8 @@
     /* If topology is already build (map on level2), set level to 1 so that lines will
      *  be read by V1_read_ (all lines) */
     Map->level = 1;		/* may be not needed, because  V1_read is used directly by Vect_build_ */
-    Map->support_updated = 1;
+    if (Map->format != GV_FORMAT_OGR_DIRECT)
+	Map->support_updated = 1;
     if (Map->plus.Spidx_built == 0)
 	Vect_open_sidx(Map, 2);
Modified: grass/trunk/lib/vector/Vlib/close.c
--- grass/trunk/lib/vector/Vlib/close.c	2010-12-19 19:30:30 UTC (rev 44629)
+++ grass/trunk/lib/vector/Vlib/close.c	2010-12-19 20:23:06 UTC (rev 44630)
@@ -57,7 +57,7 @@
    \brief Close vector map
-   \param Map pointer to Map_info
+   \param Map pointer to Map_info (vector map to close)
    \return 0 on success
    \return non-zero on error
@@ -146,6 +146,10 @@
     Map->name = NULL;
     G_free((void *)Map->mapset);
     Map->mapset = NULL;
+    G_free((void *)Map->location);
+    Map->location = NULL;
+    G_free((void *)Map->gisdbase);
+    Map->gisdbase = NULL;
     Map->open = VECT_CLOSED_CODE;
Modified: grass/trunk/lib/vector/Vlib/close_ogr.c
--- grass/trunk/lib/vector/Vlib/close_ogr.c	2010-12-19 19:30:30 UTC (rev 44629)
+++ grass/trunk/lib/vector/Vlib/close_ogr.c	2010-12-19 20:23:06 UTC (rev 44630)
@@ -37,14 +37,17 @@
     if (!VECT_OPEN(Map))
 	return -1;
-    if (Map->mode == GV_MODE_WRITE || Map->mode == GV_MODE_RW)
+    if (Map->format != GV_FORMAT_OGR_DIRECT &&
+	(Map->mode == GV_MODE_WRITE || Map->mode == GV_MODE_RW))
 	Vect__write_head(Map);
     if (Map->fInfo.ogr.feature_cache)
 	OGR_F_Destroy(Map->fInfo.ogr.feature_cache);
+    if (Map->fInfo.ogr.driver)
+	OGR_DS_Destroy(Map->fInfo.ogr.driver);
     OGR_DS_Destroy(Map->fInfo.ogr.ds);
     for (i = 0; i < Map->fInfo.ogr.lines_alloc; i++) {
 	Vect_destroy_line_struct(Map->fInfo.ogr.lines[i]);
@@ -52,6 +55,7 @@
     G_free(Map->fInfo.ogr.lines);
     G_free(Map->fInfo.ogr.lines_types);
+    G_free(Map->fInfo.ogr.driver_name);
     G_free(Map->fInfo.ogr.dsn);
     G_free(Map->fInfo.ogr.layer_name);
Modified: grass/trunk/lib/vector/Vlib/open.c
--- grass/trunk/lib/vector/Vlib/open.c	2010-12-19 19:30:30 UTC (rev 44629)
+++ grass/trunk/lib/vector/Vlib/open.c	2010-12-19 20:23:06 UTC (rev 44630)
@@ -28,7 +28,7 @@
 #include <grass/glocale.h>
-  \brief Number of available levels
+  \brief Number of levels - without and with topology
 #define MAX_OPEN_LEVEL 2
@@ -37,6 +37,11 @@
     return 0;
+static int open_new_dummy()
+    return 0;
 #ifndef HAVE_OGR
 static int format()
@@ -63,6 +68,22 @@
 #endif
+static int (*Open_new_array[][2]) () = {
+    open_new_dummy, V1_open_new_nat}
+#ifdef HAVE_OGR
+    open_new_dummy, V1_open_new_ogr}
+#else
+    open_new_dummy, format}
+#endif
 static void fatal_error(int ferror, char *errmsg)
     switch (ferror) {
@@ -669,6 +690,8 @@
     char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
     G_debug(2, "Vect_open_new(): name = %s", name);
+    G_zero(Map, sizeof(struct Map_info));
     /* init header */
     Vect__init_head(Map);
@@ -690,49 +713,78 @@
     if (Vect_legal_filename(name) < 0) {
 	sprintf(errmsg, _("Vector map name is not SQL compliant"));
 	fatal_error(ferror, errmsg);
-	return (-1);
+	return -1;
-    /* Check if map already exists */
-    if (G_find_vector2(name, G_mapset()) != NULL) {
-	G_warning(_("Vector map <%s> already exists and will be overwritten"),
-		  name);
+    /* determine output format native or ogr */
+    if (G_find_file2("", "OGR", G_mapset())) {
+	/* OGR */
+	FILE *fp;
+	struct Key_Value *key_val;
+	const char *p;
-	ret = Vect_delete(name);
-	if (ret == -1) {
-	    sprintf(errmsg, _("Unable to delete vector map <%s>"), name);
+	Map->format = GV_FORMAT_OGR_DIRECT;
+	fp = G_fopen_old("", "OGR", G_mapset());
+	if (!fp) {
+	    sprintf(errmsg, _("Unable to open OGR file"));
-	    return (-1);
+	key_val = G_fread_key_value(fp);
+	fclose(fp);
+	p = G_find_key_value("format", key_val);
+	if (p)
+	    Map->fInfo.ogr.driver_name = G_store(p);
+       	p = G_find_key_value("dsn", key_val);
+	if (p)
+	    Map->fInfo.ogr.dsn = G_store(p);
+	Map->fInfo.ogr.layer_name = G_store(name);
+    else {
+	/* native */
+	Map->format = GV_FORMAT_NATIVE;
-    Map->name = G_store(name);
-    Map->mapset = G_store(G_mapset());
+	/* check if map already exists */
+	if (G_find_vector2(name, G_mapset()) != NULL) {
+	    G_warning(_("Vector map <%s> already exists and will be overwritten"),
+		      name);
+	    ret = Vect_delete(name);
+	    if (ret == -1) {
+		sprintf(errmsg, _("Unable to delete vector map <%s>"), name);
+		fatal_error(ferror, errmsg);
+		return -1;
+    Map->name     = G_store(name);
+    Map->mapset   = G_store(G_mapset());
     Map->location = G_store(G_location());
     Map->gisdbase = G_store(G_gisdbase());
-    Map->format = GV_FORMAT_NATIVE;
     /* set 2D/3D */
     Map->plus.spidx_with_z = Map->plus.with_z = Map->head.with_z = (with_z != 0);
-    if (V1_open_new_nat(Map, name, with_z) < 0) {
+    if ((*Open_new_array[Map->format][1]) (Map, name, with_z) < 0) {
 	sprintf(errmsg, _("Unable to create vector map <%s>"),
 		Vect_get_full_name(Map));
-	return (-1);
+	return -1;
-    /* Open history file */
-    sprintf(buf, "%s/%s", GV_DIRECTORY, Map->name);
-    Map->hist_fp = G_fopen_new(buf, GV_HIST_ELEMENT);
-    if (Map->hist_fp == NULL) {
-	sprintf(errmsg, _("Unable to open history file of vector map <%s>"),
-		Vect_get_full_name(Map));
-	fatal_error(ferror, errmsg);
-	return (-1);
+    if (Map->format == GV_FORMAT_NATIVE) {
+        /* Open history file */
+	sprintf(buf, "%s/%s", GV_DIRECTORY, Map->name);
+	Map->hist_fp = G_fopen_new(buf, GV_HIST_ELEMENT);
+	if (Map->hist_fp == NULL) {
+	    sprintf(errmsg, _("Unable to open history file of vector map <%s>"),
+		    Vect_get_full_name(Map));
+	    return -1;
     Open_level = 0;
     /* initialize topo */
Modified: grass/trunk/lib/vector/Vlib/open_ogr.c
--- grass/trunk/lib/vector/Vlib/open_ogr.c	2010-12-19 19:30:30 UTC (rev 44629)
+++ grass/trunk/lib/vector/Vlib/open_ogr.c	2010-12-19 20:23:06 UTC (rev 44630)
@@ -5,9 +5,7 @@
    Higher level functions for reading/writing/manipulating vectors.
-   \todo Implement V1_open_new_ogr()
-   (C) 2001-2009 by the GRASS Development Team
+   (C) 2001-2010 by the GRASS Development Team
@@ -29,6 +27,7 @@
 #ifdef HAVE_OGR
 #include <ogr_api.h>
+#include <cpl_string.h>
    \brief Open existing OGR layer (level 1 - without feature index file)
@@ -201,4 +200,81 @@
     return 0;
+   \brief Create new OGR layer in given OGR datasource (level 1)
+   \param[out] Map pointer to Map_info structure
+   \param name name of OGR layer to create
+   \param with_z 2D or 3D (unused?)
+   \return 0 success
+   \return -1 error
+int V1_open_new_ogr(struct Map_info *Map, const char *name, int with_z)
+    OGRSFDriverH   Ogr_driver;
+    OGRDataSourceH Ogr_ds;
+    OGRLayerH      Ogr_layer;
+    int            i;
+    char         **Ogr_layer_options;
+    Ogr_layer_options = NULL;
+    OGRRegisterAll();
+    Ogr_driver = OGRGetDriverByName(Map->fInfo.ogr.driver_name);
+    if (!Ogr_driver) {
+	G_warning(_("Unable to get OGR driver <%s>"), Map->fInfo.ogr.driver_name);
+	return -1;
+    Map->fInfo.ogr.driver = Ogr_driver;
+    /* TODO: creation options */
+    Ogr_ds = OGR_Dr_CreateDataSource(Ogr_driver, Map->fInfo.ogr.dsn, NULL);
+    if (!Ogr_ds) {
+	G_warning(_("Unable to create OGR data source '%s'"),
+		  Map->fInfo.ogr.dsn);
+	return -1;
+    Map->fInfo.ogr.ds = Ogr_ds;
+    Ogr_layer = OGR_DS_GetLayerByName(Ogr_ds, Map->fInfo.ogr.layer_name);
+    if (Ogr_layer) {
+	for (i = 0; i < OGR_DS_GetLayerCount(Ogr_ds); i++) {
+	    if (OGR_DS_GetLayer(Ogr_ds, i) == Ogr_layer) {
+		if (G_get_overwrite()) {
+		    G_warning(_("OGR layer <%s> already exists and will be overwritten"),
+		      Map->fInfo.ogr.layer_name);
+		    if (OGR_DS_DeleteLayer(Ogr_ds, i) != OGRERR_NONE) {
+			G_warning(_("Unable to delete OGR layer <%s>"),
+			return -1;
+		else {
+		    G_fatal_error(_("OGR layer <%s> already exists in datasource '%s'"),
+				  Map->fInfo.ogr.layer_name, Map->fInfo.ogr.dsn);
+		break;
+    /* create new OGR layer */
+    /* TODO: spatial reference */
+    /* Ogr_layer_options = CSLSetNameValue(Ogr_layer_options, "OVERWRITE", "YES"); */
+    Ogr_layer = OGR_DS_CreateLayer(Ogr_ds, Map->fInfo.ogr.layer_name,
+				   NULL, wkbPoint, Ogr_layer_options);
+    CSLDestroy(Ogr_layer_options);
+    if (!Ogr_layer) {
+	G_warning(_("Unable to create OGR layer <%s> in '%s'"),
+	return -1;
+    Map->fInfo.ogr.layer = Ogr_layer;
+    return 0;
 #endif
Modified: grass/trunk/lib/vector/Vlib/write_ogr.c
--- grass/trunk/lib/vector/Vlib/write_ogr.c	2010-12-19 19:30:30 UTC (rev 44629)
+++ grass/trunk/lib/vector/Vlib/write_ogr.c	2010-12-19 20:23:06 UTC (rev 44630)
@@ -43,7 +43,7 @@
-  \brief Writes feature on level 1
+  \brief Writes feature on level 1 (OGR interface)
   \param Map pointer to Map_info structure
   \param type feature type
@@ -60,15 +60,19 @@
     struct field_info *Fi;
-    OGRGeometryH Ogr_geometry;
-    OGRFeatureH Ogr_feature;
-    OGRFeatureDefnH Ogr_featuredefn;
+    OGRGeometryH       Ogr_geometry;
+    OGRFeatureH        Ogr_feature;
+    OGRFeatureDefnH    Ogr_featuredefn;
+    OGRwkbGeometryType Ogr_geom_type;
     if (!Map->fInfo.ogr.layer) {
 	G_warning(_("OGR layer not defined"));
 	return -1;
+    Ogr_featuredefn = OGR_L_GetLayerDefn(Map->fInfo.ogr.layer);
+    Ogr_geom_type = OGR_FD_GetGeomType(Ogr_featuredefn);
     /* determine matching OGR feature geometry type */
     /* NOTE: centroids are not supported in OGR,
      *       pseudotopo holds virtual centroids */
@@ -76,16 +80,30 @@
      *       pseudotopo treats polygons as boundaries */
     if (type & (GV_POINT | GV_KERNEL)) {
+	if (Ogr_geom_type != wkbPoint &&
+	    Ogr_geom_type != wkbPoint25D) {
+	    G_warning(_("Feature is not a point. Skipping."));
+	    return -1;
 	Ogr_geometry = OGR_G_CreateGeometry(wkbPoint);
     else if (type & GV_LINE) {
+	if (Ogr_geom_type != wkbLineString &&
+	    Ogr_geom_type != wkbLineString25D) {
+	    G_warning(_("Feature is not a line Skipping."));
+	    return -1;
 	Ogr_geometry = OGR_G_CreateGeometry(wkbLineString);
     else if (type & GV_FACE) {
+	if (Ogr_geom_type != wkbPolygon25D) {
+	    G_warning(_("Feature is not a face. Skipping."));
+	    return -1;
 	Ogr_geometry = OGR_G_CreateGeometry(wkbPolygon25D);
     else {
-	G_warning("V1_write_line_ogr(): %s (%d)", _("Unsupported feature type"), type);
+	G_warning(_("Unsupported feature type (%d)"), type);
 	return -1;
@@ -98,31 +116,21 @@
     G_debug(4, "   n_points = %d", points->n_points);
-    Ogr_featuredefn = OGR_L_GetLayerDefn(Map->fInfo.ogr.layer);
     /* create feature & set geometry */
     Ogr_feature = OGR_F_Create(Ogr_featuredefn);
     OGR_F_SetGeometry(Ogr_feature, Ogr_geometry);
     /* write attributes */
-    if (cats->n_cats > 0) {
+    Fi = Vect_get_field(Map, cats->field[0]);
+    if (Fi && cats->n_cats > 0) {
 	cat = cats->cat[0];
 	if (cats->n_cats > 1) {
 	    G_warning(_("Feature has more categories, using "
 			"category %d (from layer %d)"),
 		      cat, cats->field[0]);
-	Fi = Vect_get_field(Map, cats->field[0]);
-	if (!Fi) {
-	    G_fatal_error(_("Database connection not defined for layer %d"),
-			  cats->field[0]);
 	write_attributes(cat, Fi, Map->fInfo.ogr.layer, Ogr_feature);
-    else { /* no attributes */
-	G_warning(_("Feature has no categories"));
     /* write feature into layer */
     ret = OGR_L_CreateFeature(Map->fInfo.ogr.layer, Ogr_feature);
@@ -277,17 +285,14 @@
 int V2_delete_line_ogr(struct Map_info *Map, off_t line)
-    int ret, i, side, type, first, next_line, area;
+    int ret, i, type, first;
     struct P_line *Line;
-    struct P_area *Area;
     struct Plus_head *plus;
-    struct bound_box box, abox;
-    int adjacent[4], n_adjacent;
     static struct line_cats *Cats = NULL;
     G_debug(3, "V2_delete_line_nat(), line = %d", (int) line);
-    type = first = n_adjacent = 0;
+    type = first = 0;
     Line = NULL;
     plus = &(Map->plus);
Modified: grass/trunk/vector/v.external.out/args.c
--- grass/trunk/vector/v.external.out/args.c	2010-12-19 19:30:30 UTC (rev 44629)
+++ grass/trunk/vector/v.external.out/args.c	2010-12-19 20:23:06 UTC (rev 44630)
@@ -8,19 +8,12 @@
 void parse_args(int argc, char **argv,
 		struct _options *options, struct _flags *flags)
-    options->dir = G_define_option();
-    options->dir->key = "directory";
-    options->dir->description = _("Name of output directory");
-    options->dir->required = YES;
-    options->dir->type = TYPE_STRING;
-    options->dir->key_desc = "path";
+    options->dsn = G_define_option();
+    options->dsn->key = "dsn";
+    options->dsn->description = _("Name for output OGR datasource");
+    options->dsn->required = YES;
+    options->dsn->type = TYPE_STRING;
-    options->ext = G_define_option();
-    options->ext->key = "extension";
-    options->ext->description = _("Extension for output files");
-    options->ext->required = NO;
-    options->ext->type = TYPE_STRING;
     options->format = G_define_option();
     options->format->key = "format";
     options->format->description = _("Format of output files");
@@ -44,7 +37,7 @@
     flags->r = G_define_flag();
     flags->r->key = 'r';
-    flags->r->description = _("Cease using OGR and revert to native output");
+    flags->r->description = _("Cease using OGR, revert to native output and exit");
     flags->r->suppress_required = YES;
     flags->p = G_define_flag();
Modified: grass/trunk/vector/v.external.out/link.c
--- grass/trunk/vector/v.external.out/link.c	2010-12-19 19:30:30 UTC (rev 44629)
+++ grass/trunk/vector/v.external.out/link.c	2010-12-19 20:23:06 UTC (rev 44630)
@@ -4,7 +4,7 @@
-void make_link(const char *dir, const char *ext,
+void make_link(const char *dsn,
 	       const char *format, char **options)
     struct Key_Value *key_val = G_create_key_value();
@@ -32,17 +32,8 @@
 	*p++ = '\0';
-    if (ext && ext[0] != '.') {
-	char *p;
-	G_asprintf(&p, ".%s", ext);
-	ext = p;
-    if (dir)
-	G_set_key_value("directory", dir, key_val);
-    if (ext)
-	G_set_key_value("extension", ext, key_val);
+    if (dsn)
+	G_set_key_value("dsn", dsn, key_val);
     if (format)
 	G_set_key_value("format", format, key_val);
     if (opt_str)
Modified: grass/trunk/vector/v.external.out/local_proto.h
--- grass/trunk/vector/v.external.out/local_proto.h	2010-12-19 19:30:30 UTC (rev 44629)
+++ grass/trunk/vector/v.external.out/local_proto.h	2010-12-19 20:23:06 UTC (rev 44630)
@@ -2,7 +2,7 @@
 #define V_EXTERNAL_OUT_LOCAL_PROTO_H
 struct _options {
-    struct Option *dir, *ext, *format, *opts;
+    struct Option *dsn, *format, *opts;
 struct _flags {
@@ -17,7 +17,7 @@
 void check_format(const char *);
 /* link.c */
-void make_link(const char *, const char *,
+void make_link(const char *,
 	       const char *, char **);
 /* list.c */
Modified: grass/trunk/vector/v.external.out/main.c
--- grass/trunk/vector/v.external.out/main.c	2010-12-19 19:30:30 UTC (rev 44629)
+++ grass/trunk/vector/v.external.out/main.c	2010-12-19 20:23:06 UTC (rev 44630)
@@ -43,11 +43,6 @@
     parse_args(argc, argv, &options, &flags);
-    if (flags.p->answer) {
-	print_status();
-	exit(EXIT_SUCCESS);
     if (flags.f->answer) {
 	list_formats();
 	exit(EXIT_SUCCESS);
@@ -61,8 +56,13 @@
     if (options.format->answer)
 	check_format(options.format->answer);
-    make_link(options.dir->answer, options.ext->answer,
-	      options.format->answer, options.opts->answers);
+    if (options.dsn->answer)
+	make_link(options.dsn->answer,
+		  options.format->answer, options.opts->answers);
+    if (flags.p->answer) {
+	print_status();
     exit(EXIT_SUCCESS);
Modified: grass/trunk/vector/v.external.out/status.c
--- grass/trunk/vector/v.external.out/status.c	2010-12-19 19:30:30 UTC (rev 44629)
+++ grass/trunk/vector/v.external.out/status.c	2010-12-19 20:23:06 UTC (rev 44630)
@@ -20,13 +20,10 @@
     fclose(fp);
-    p = G_find_key_value("directory", key_val);
-    fprintf(stdout, _("directory: %s\n"),
+    fprintf(stdout, _("dsn: %s\n"),
 	    p ? p : _("not set (default 'ogr')"));
-    p = G_find_key_value("extension", key_val);
-    fprintf(stdout, _("extension: %s\n"), p ? p : _("<none>"));
     fprintf(stdout, _("format: %s\n"),
 	    p ? p : _("not set (default ESRI_Shapefile)"));
