[GRASS-SVN] r44634 - grass/branches/develbranch_6/scripts/v.colors
svn_grass at osgeo.org
Sun Dec 19 17:13:38 EST 2010
Author: hamish
Date: 2010-12-19 14:13:38 -0800 (Sun, 19 Dec 2010)
New Revision: 44634
grass/branches/develbranch_6/scripts/v.colors/v.colors
layer= isn't ignored by v.db.connect if -l is used, so re-add that
Modified: grass/branches/develbranch_6/scripts/v.colors/v.colors
--- grass/branches/develbranch_6/scripts/v.colors/v.colors 2010-12-19 21:55:44 UTC (rev 44633)
+++ grass/branches/develbranch_6/scripts/v.colors/v.colors 2010-12-19 22:13:38 UTC (rev 44634)
@@ -206,7 +206,7 @@
#g.message "column <$GIS_OPT_COLUMN> is type [$NCOLUMN_TYPE]"
# check if GRASSRGB column exists, make it if it doesn't
-TABLE=`v.db.connect -g map="$GIS_OPT_MAP" fs="|" | grep "^$GIS_OPT_LAYER|" | cut -f2 -d'|'`
+TABLE=`v.db.connect -gl map="$GIS_OPT_MAP" layer="$GIS_OPT_LAYER" fs="|" | cut -f2 -d'|'`
COLUMN_TYPE=`v.info -c map="$GIS_OPT_MAP" layer="$GIS_OPT_LAYER" --quiet | grep -i "|$GIS_OPT_RGB_COLUMN$" | cut -f1 -d'|'`
if [ -z "$COLUMN_TYPE" ] ; then
# RGB Column not found, create it
